PDA
View Full Version : Water / Methanol Injection / Nitrous Oxide
Pages : 1 2 3 [4] 5 6
  1. Aquamist and the AEM Tru-Boost
  2. MBT and water/methanol injection
  3. how many 100% meth users have tried 50/50
  4. Question: DDS3 W/I gauge from Aquamist
  5. Dry vs wet?
  6. Nozzle mount Question
  7. Finally! FP Green + HSF-5 + Kevin D. Sorry no dyno graphs.
  8. Tons of meth - good or bad...
  9. meth/oct.
  10. Aquamist Success Story Videos
  11. Can you run nitrous with meth?
  12. HSF-5 ecu pinout issues with evo IX
  13. This is getting installed tomorrow!
  14. S-L-X Denatured Alchohol and HFS-5?
  15. question about meth
  16. Aquamist components and Methanol
  17. Converting from Snow to Aquamist
  18. How Meth Made My Car Fun Again
  19. Hooking up a test button to Aquamist HFS
  20. Snow Peformance: New Controller Reads Boost Or MAF!
  21. Aquamist what? stealth tank+pump install
  22. HFS-5 Issue - Urgent
  23. HFS-1 IDC or MPS trigger
  24. Head studs and Meth
  25. Aquamist Advantage
  26. New Coolingmist Evo Failsafe Water/methanol kit!
  27. Al - the "feel" of a alky injection kit
  28. DDS3 adjusting?
  29. 50/50 mix still flammable
  30. meth/alky???
  31. New to methonal kits
  32. Aquamist HFS 1 and HFS 5 "complete install kits" available
  33. Plugs for meth/35r
  34. Apex'i NEO and Aquamist HFS-5
  35. AquaTune system
  36. Basic info about Methanol Injection??
  37. SMC guys, Start Stop suggestions...
  38. Install price?
  39. Predicting Nozzle Size (HFS-5)
  40. HFS-5 Install - Stupid Question
  41. Milo on the dyno - Aquamist HFS-5 + 50 Trim
  42. Where to buy SMC kit?
  43. 521 WHP with Aquamist HFS- 5 on PUMP gas
  44. Video and logs of W/M system failing to spray
  45. Alky mixing question
  46. Need Gasket for Aquamist Level Sensor
  47. MAC Solenoid connectors
  48. Aquamist port injection?
  49. SMC M10 nozzle... need one
  50. EBC w. Safe Injection
  51. HSF-5 install question: How long of a piece of aluminum
  52. Miss fire at 25 PSI w/ meth?
  53. Help Please-HFS-5 kit Failsafe Questions...
  54. Take of two meth injection cars on the dyno 470 and 500 whp
  55. ATTN: Richard L please help asap!!!
  56. Progressive pump speed injection system - Do they work?
  57. Aem Meth kit fail safe Q?
  58. What kind of water should I use?
  59. Aquamist kill switch?
  60. Basic Kit, Looking for upgrades
  61. upgraded lines...
  62. Aquamist HFS-1 Review
  63. Explain Water/Alcohol Injection
  64. Has anyone used a Cooling Mist set up??
  65. Woot Woot SafeInjections are back FINALLY....
  66. Important update on aquamist tank hole size...
  67. Anybody heard of this "SMG" and "devils own" Kits?
  68. am i ready for my hfs-1 tune?
  69. question about snow performance meth kit
  70. Need HELP! Oversized hole for HSF-5 nozzle holder
  71. What are you guys paying for Methanol?
  72. Valve flow calculator
  73. Is someone tries to develop his own system?
  74. Anyone used the silicon hose water jet adaptor?
  75. LaBonte Motorsports failsafe controller
  76. Another Partial HSF-5 Install w/ Pics
  77. Discussion of WAI trigger point
  78. AEM meth kit questions.
  79. Pump and Tank install
  80. HFS-1 Install problem
  81. methanol + water = hot
  82. Milo's 18 quart Aquamist HFS-5 methanol/water injection system + pics of car
  83. Indepth study of WAI injection systems
  84. <<<Tuned with meth>>>
  85. Pumpless/wireless (almost) HFS-5 install
  86. 3.5 Year old shurflo pump 100% Meth break down - BIG pix
  87. Problem with HFS-1
  88. New AEM kit or Snow 2D kit?
  89. FS: Hole saw, hole saw drill bit, tap, tap drill bit
  90. Oil Change Evo 9 Mr
  91. AEM has just brought out a WAI system
  92. aquamist system Q
  93. Aquamist 22mm hole cutter ON LOAN thread...
  94. Aquamist HFS-1 system: Official Q&A...
  95. Adding a flow meter
  96. Axial nozzle mounts...
  97. question about aquamist hfs-1 install
  98. help!!! METH AND WATER MIX!! aquamist
  99. Aquamist Install Question
  100. Running higher boost with meth
  101. The beauty of the "Nick" Tank/Pump/Tank setup
  102. Super Size It! - Aquamist HFS-5 Milo style
  103. how to test your methonal
  104. meth corrosive to aluminum
  105. Does M3 methanol damage seals on SMC kits?
  106. smc to aquamist meth inj
  107. Aquamist HSF-5 Phase I Complete:
  108. How Much Meth Pressure Should I Have????
  109. Meth leaking after short trips normal?
  110. Where to place AEM AIT Sensor??
  111. Loud Snow Performance Pump
  112. alky vs meth
  113. hanging twin 6 quart flambeau tanks
  114. Snow Performance Stage 2 and 100% Meth
  115. Picture or measurement request for DDS3 gauge
  116. HFS-5 multiport questions
  117. special tools for aquamist HFS system install
  118. Snow install help
  119. Formic Acid -- Is this an issue for injecting water?
  120. 72 quart injection system...
  121. Can three seven quart meth tanks be used with a snow meth kit on one pump?
  122. Mac failsafe valve ports (1/2/3) and aquamist HFS-5
  123. aquamist shsv
  124. Pre Turbo Injection
  125. Nitromethane Thread
  126. Perrin PWI Best place to put nozzles???
  127. My Aquamist HFS-5 Install Guide
  128. 5' Wiring Harness Now In Every Kit
  129. HFS-5 Installed and Tuned!
  130. Need some snow performance pics...
  131. DIY failsafe idea w/ schematic
  132. HFS-5, one or two nozzles?
  133. running meth...tune needed?
  134. Tuning H2O Injection Basics
  135. Adding external spray light for SMC controller??
  136. NEED SMC m-15 jet and junction block with gauge to mount on UICP
  137. Snow Performance Compare: Check Valves vs Solenoids
  138. moving forward with ethanol injection
  139. HFS-1/5 : MAC solenoid valve & flambeau tanks
  140. Max MAF values running alchy?
  141. Adding Ice to Meth Tank.
  142. Aquamist...Special Thanks!!!
  143. Aquamist
  144. ethanol injection
  145. Reverse Flow Check Valve
  146. Can I use two seven quart snow meth tanks with a snow meth kit?
  147. aquamist race pump - increase flow
  148. Did the alky destroy my cat?
  149. What 3 gallon tank to buy and use with a snow meth kit.
  150. N-tercooler
  151. what alky kit are you using w/stock turbo
  152. How much fuel are you guys taking out?
  153. HFS-1 & Pressure switch ?
  154. alky?
  155. what's the best jet to spray meth????
  156. Sti meth tank
  157. Another install
  158. jet location
  159. Any HSF-5 kits installed completely in the engine bay?
  160. running meth...need headstuds?
  161. water and meth mix???
  162. Shelf life of methanol
  163. Methanol and Denatured
  164. Quick pics of HFS-5 Install
  165. Setup on Nitrous?
  166. Post Your Set -ups
  167. feeding time
  168. Bolt on IX 50shot dyno/track vid's
  169. OEM IC sprayer tank on IX?
  170. 100% Methanol 3 Weeks
  171. Nitrous Questioning
  172. methanol mixtures
  173. Replacing my SMC pump with another brand
  174. Snow Performance Kit Users - Need Help!
  175. Anyone using the Aquamist HSF-5?
  176. Cheap Fail Safe
  177. Mac Solenoid Group Buy
  178. Help decipher mystical world of injection
  179. safe injection keeps coming on....(stumped)
  180. yellow wire to ? on maf sensor plz help
  181. High load timing with alchy
  182. alky question
  183. Gb Hfs-1
  184. Perrin Meth Injection kit Primer Pump
  185. can't find fluid
  186. Where can you buy methanol???
  187. injectors
  188. water jet size thread
  189. Spraying water before tune
  190. Meth Pressure gauge ??
  191. Fuel Injector Wiring?? (for FIA2)
  192. Smc not spraying, supposed to get tuned tomorrow.
  193. Aquamist and denatured alcohol
  194. Snow Performance: "GOOP" Now Included In Every Kit!
  195. smc settings
  196. Race Gas and meth
  197. Venting a Meth Tank?
  198. do any one on evom make a meth kit
  199. Venting a meth tank?
  200. best alcohol injection kit.
  201. Priming/Testing Pump for Alky Injection Setup
  202. Snow Performance
  203. which pin on the AEM EMS?
  204. Snow performance meth install help
  205. Alky kit ?
  206. New DV / BOV Needed??
  207. Meth tank placement?
  208. Nozzle options???
  209. Zeitronix ZAVT problem
  210. Rookie Questions
  211. General meth questions.
  212. Aquamist tuning configuration
  213. Need to Buy Meth Tank(s)
  214. Windshield Washer Fluid
  215. Recommended Nozzle Size for SMC Kit on 9
  216. Anyone running Meth or Alk with a factory exhaust
  217. snow performance alky kit problem
  218. SMC Kit Malfunctioning?
  219. snow performance install
  220. HFS-Install, Beautiful !!!
  221. Looking for a Meth Tank
  222. NEW Snow Performance Mounting Adaptor and Bungs
  223. Front SMC kit, can it pump water?
  224. SMC Kit: Where to purchase?
  225. Storing methanol.
  226. I did a search, but I still need some help.
  227. Selecting Nozzle Size (Aquamist)
  228. Getting Meth
  229. Isopropanol vs Methanol???
  230. Shurflo pumps of major WAI kit manufacturer
  231. Where canI find a larger nozzle for my snow performance kit?
  232. Going to test new SMC kit with just water?
  233. Aquamist myths and views... HFS-5
  234. ultimate auqamist system
  235. 360° questions, i'm new to wi.....
  236. Faisafe's with the SMC kit?
  237. NEW Snow Performance Safeinjection Q&A...
  238. Evo 9 running meth at 30 psi with a gt35r and ignition amplifer, question.
  239. Introducing the new HFS-1 system by Aquamist
  240. Warning to all water injection users...
  241. What are damages to the engine?
  242. where to installed jet info please
  243. A few questions before I get started.
  244. Winter Storage
  245. Quick question on the SMC Alky injection kit controller.
  246. new to meth.
  247. I Have a Failsafe for My Meth Kit. What Else Can I Get to Monitor Everything?
  248. Snow Performance... users pls share your experience!
  249. Pls help me finalize my decision
  250. race gas + meth vs. race gas + H2O
