View Full Version : Lancer Troubleshooting
- 2011 Lancer ES Stereo Dot Matrix Display Issues
- 09 gts m/t ecu 1860b018 pinout needeed
- ASC Light On
- Rain light sensor question
- Throttle Cut out to 2500RMP? Need Help!
- 02 lancer battery and break dash light on
- Wiring issue
- SAS code and Limp mode, Need Help
- Torque Monitor and Torque Max tables/limp mode
- Rear Fog lights
- Lancer keeps locking itself
- Battery drain without Bluetooth module (2009 ES)
- 2009 Lancer DE Door Lock Mech
- Lancer 2008 Would not start
- Cannot get into maintenance page on display
- P0420
- 2010 Lancer GTS - I need pics of fuse boxes!
- 2009 Lancer ES Suddenly Dying
- Headlight etacs issue
- 2010 Lancer GTS whining sound
- Car refuses to start (when cold) until radiator fans have run
- Emission Control Sticker
- Amplifier is Cooked?
- P0089 + U1417 + U0401 + C121C + Limp Mode + ESP OFF
- 08 es doors unlock but wont locking
- 08 Lancer ES low Compression no start
- AC Compressor bolts came loose
- Odometer Does not work.
- Mileage Dash Screen Issue
- Lancer 2009 DE Loud hum on startup
- Cannot enable periodic maintenance on dash.
- Cranks but no start (STARTER REPLACED)(OBD SCANNED)
- Central Locking Mystery
- Idle vibration
- 2008 Lancer Battery Drain
- No Rear break lights no traction control & no cruse control
- Car Wont start, Fast Key Doesn't turn
- 2008 Lancer Car Battery Drain
- Noise under light throttle (Video available)
- P0507 please help
- A/C pressure sensor
- Rattling in my 2017 Lancer ES
- Ac fans runs full blast non stop
- p2097 With Tsudo
- CEL codes and performance issues after VLAND install
- Lancer DE 2008 WONT REV PAST 4K rpm’s in neutral and park
- ETACS and ECU problems. Help is appreciated
- Oil Separator for Engine
- 2012 Lancer GT idling issues
- Head unit buttons
- P0011 & P0014 codes, rough idle, died
- TCS/engine power loss
- TPMS issues
- Brake light intermittent
- 2009 Lancer GTS Rough Idle/ Bad Cold Starts/ High RPM
- Base 09 lancer parasitic drain/rough idle
- 09 Lancer ES Overheating
- 2009 Lancer DE upgrade Steering wheel controls
- Low voltage on fuel injector
- Key programming issues
- 13 lancer es weird acceleration sounds and cracked hose
- Rough idle when ac is on
- 2008 Lancer GTS tick
- Lancer 2008 Parasitic power drain
- 2011 Lancer parasitic draw
- Odd Ball Dash problems
- P0304 Trouble
- Evo IV check engine light at idle.
- Need help with hazard light button
- Repair shop has "bricked" my Lancer
- Oil in ECM (1860A843)
- Issues with starting
- Gts/autostick shifter in 2010 Lancer De?
- a/c issues on 2011 lancer gts
- 2015 Lancer GT starts but won't crank
- Back right rear tire rubbing.
- Delayed throttle response
- What is a lancer GT
- 2010 Lancer GTS starting issue
- 2008 Lancer ES O2 sensor help
- 2011 Lancer GT - Cranks/turns but no start
- Battery Indicator on - new battery and new alternator
- 2017 Lancer ES loud intermittent exhaust?
- Replacing slave cylinder 2010 gts lancer w/2.4l engine tips on bleeding?
- Aftermarket Stereo issues
- 2011 Lancer: Weird noise that sounds like loose metal when on a constant speed
- 2010 Lancer No Start Help!!!
- Front Silver Trim Replacement?
- Windshield washer not working
- Pixel crack on LCD display
- Steering Wheel Button Lights
- 2008 mitsubishi lancer DE headlight
- Question about keys
- 2013 Lancer ES Sportback Mysterious Coolant Loss
- Lancer wont start
- Mitsubishi lancer tail lights issue
- Overheating/Whining Issue?
- 09 Lancer not starting
- Please help me figure out what is happening to my 2009 Lancer
- Ticking noise help
- Evo wont idle with Maf plugged in please help me
- 4B12 oil pump failure?
- Low beams simultaneously cutting off and on
- 09 Lancer No power from battery after sitting overnight
- Lancer 08-15 Tailights on 2016
- Steering wheel airbag connector cover?
- Brake Help (TLDR @ End)
- Stange metallic rattling noise while driving
- Tire sensor question
- 2011 ES MMCS not recognizing HFM
- Loud Pop and loss of power- 2013 lancer GT
- Help me get rid of these codes! P0171, P0145, P0421 and P0456
- Parasitic Draw
- 08 lancer gts doesn’t start after a day
- Denso Vs NTK oxygen sensor
- Trunk Lid replaced, button doesn't work
- Radio and A/C dash light won't turn on
- Electrical Short
- Can't update FUSE
- Electrical problems PLEASE HELP
- A?C compressor question
- Took out battery of key fob, wont turn engine over now
- 2013 lancer DE no start with key
- Bouncing Idle - Lancer 10’ GTS Sportback
- Picture of factory Rockford fosgate amp wiring?
- intermittent hard starting
- Bluetooth not working
- Metal rattling noise in engine bay
- strange noises when switching cabin airflow
- Gas door won't open
- Weird Knocking Sound
- 10MitsubLancer Why compressor makes on & off rattling noises when air is on
- HID problem on my Lancer!!
- Soft clutch and shifter goes into gear without pressing the clutch
- Mitsubishi Lancer 2014 ES Sportsback Tranction Control Issue
- Engine goes to WOT when turned on
- Speed Sensor Code P500
- Strange Squeal sound?
- Gear shift cable question for 2009 lancer DE
- Keyless entry
- Cooling Fan Help Asap!
- Temperature sensor not working
- Car blower sometimes not working
- Broken clips on front underbody for 2009 lancer
- Blackstone oil analysis shows gas in oil
- Third Brake wiring tips?
- RF Amplifier Bypass
- Car shutting off
- buzzing / maybe whining noise
- Turbocharged Lancer 08 DE possible fuel issues
- Lancer 15 es cvt maintence?
- 09 GTS P0463 No fuel reading
- 08 Lancer MMCS won't turn on
- Will not rev when in gear
- Lancer 2012 ES Headlamp/Tail lights
- 09 Lancer ES Ignition switch locking up.
- 2008 Lancer GTS rough idle only with AC on
- What are these elec connectors/plugs??
- Electronic issues
- Help P0401 Lancer 2.0 2011 :cool:
- Grinding noise during start up
- Hood latch blues.
- Lancer 2008 DE
- Steering Locking up
- Keep getting code P0133
- Need Pictures
- ECU Plug Pinout
- Driver Low Beam and Driver Taillight Go Out Intermittently
- '08 stereo faceplate has no lights except "EJECT" and "LOAD"
- rust prevention after reaming
- 2009 LANCER DE backseat question
- Wiring issues
- 2008 GTS Oil burning problem
- Acd light
- Electronic issues
- CVT invec 3 operation temps
- Timing Belt/Chain?
- Head lights not lining up on 2008 lancer
- Lancer no crank issue
- New Member CA question about EGR
- Engine codes discovered today - looking for some guidance
- Aftermarket seats and SRS system
- First gear problem
- Lancer hesitates to start
- Input and output speed sensor location
- Cvt transmission questions
- I need help!!!
- how can i remove mirror switch?
- Weird noise from engine (Video Inside)
- 2009 Lancer GTS won't start.
- Whats this noise? (Video Inside)
- 2010 lancer gts not starting!
- Limp mode/ ASC-Off, service required!
- Using oil extractor to change cooling fluid
- 08 lancer ticking noise
- Clicking noise from steering wheel of Mitsubishi Lancer ES 2.0L 2013
- Part Numbers for Driver and Passenger Side HVAC Vents?
- Headlight Help
- Stereo button and air control lights not working
- Bluetooth Issue
- 2008 Lancer ES, starter not getting power
- ECM question
- Can I reuse a "used" transponder module in a new blank key for a new car?
- Stereo volume control issues on my '08 ES
- 2009 lancer es no fuel?
- 2012 ES Lancer fan blowing when switched to off
- engine harness question
- What does this indicator mean?
- 2009 Mitsubishi Lancer DE ECM replacement
- Weird cooling issue
- 08 gts knocking type noise
- 2009 A/C Blower Motor
- 08 Lancer makes awful noise when switching heating zones.
- 08 Lancer GTS - needs new rear catalytic converter
- Code p0420 issue
- Issue with warning light (overheating)
- Revving up and down on parked
- What goes here beteren the throttle body (near intake) and starter
- Headlight adjustment not working
- 2009 Lancer DE won't start after engine rebuild
- 2008 LES whirring sound
- Timing chain help/diagnosis please
- Plz help! 2010 GTS sportback Rear wiper issues
- 2008 Lancer ES Radio Malfunction
- 08 Lancer GTS- Trans stuck in 1st gear
- 2010 Lancer DE Radio Wiring Diagram
- Handbrake shoe's rubbing on rotors???
- 2008 Lancer es AC not cold
- 2010 GTS Cooling System
- Fog light
- 02 es goes up and down in rpm and then dies
- Lancer de problems
- Parasitic draw issue, need help!
- Rear Driver Window Regulator Broken Plastic Piece
- Audio amplifier fuse blown, keeps blowing new fuse right away
- 2008 GTS Idle Problem
- upstream o2 senor plug loctaion
- Key & alarm question
- evo x trunk for a 2010 lancer es model
- 2008 Lancer GTS - Poor acceleration & Loud Engine
- Tail light issue (with pic)
- Cold air intake issues, rough idle, stalling
- Fob Key - 09 Lancer GTS
- Cig Lighter & 12 Power outlet not working - Fuses OK
- 2009 mitsubishi lancer DE aux harnass question
- Clicking noise when steering 2014 Lancer ES
- Speaker issue, radio versus cd please help
- Digital Display / MPG / HUD screen bug
