View Full Version : Lancer Troubleshooting
- Random Crank/No-Start Issue
- Abnormal Noise from the engine bay when pressing the clutch
- Help w/ Headlights
- FAST key issues
- 2012 Lancer Sportback - Clunking and creaking rear suspension
- No heat from blower motor
- A/C making noise
- p1241 code idle fluctuates
- Please help, car won't start
- Coolant pipe
- Urgent, 2015 Lancer No Start
- 2009 Mitsubishi Lancer GTS Battery Drain
- Battery Problem
- What is this cable that broke off? Service Engine Soon came on...
- No creeping when in drive?
- Burning oil
- Connecting rod Assy size issue 2009 lancer DE
- Where can i Find the right skid plate?
- Slow Acceleration Causes Quick Rpm Drop (09 2.4L Cvt)
- 2009 Lancer GTS battery drain help!
- RPM fluctuation with A/C on!!!
- NEED RADIO HELP!!! 2009 Lancer
- Potential buyer of '08 Lancer GTS - has issue
- Bolt size for Drain Plug in 2012 Lancer.
- Hail mods FTW
- 9 volt doesnt work
- boost leak/acceleration issue?
- Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on screen
- Wheel and Oil sign for couple of seconds in the second position of the car key
- weird clicking sound
- Replacing Front Bumper and Headlights
- Fuel door dampener spring
- Help! Base model clutch troubles
- 2010 lancer GTS, fog lights inop
- idling issues
- 08 Lancer aux cord causes engine problems?!
- Should I buy a 09 GTS, what should I look for?
- AC ISSUES 2011 Mitsubishi Lancer ES
- 2008 Lancer GTS no start please help
- 2003 Lancer Es Automatic- TPS Problem?
- Weird P0420 issues....
- Jacked in the wrong spot! Help :(
- 2008 Lancer Voltage Fluctuation
- Head lights flickering
- Clunk Noise in reverse and on start up?
- Brake Issue
- 2 codes P0725 and P0420-Please reply
- 09 GTS Accident need suggestions
- smells like a valve tap?
- Light Pattern on Spyder HID Projector Headlights
- Lancer GTS 08 AC Issue!
- Failed Emissions: OBD Not ready
- 2009 GTS fog light troubleshooting
- HID Kit problems with Daytime Running Lights
- Brake problem
- HVAC Help Needed
- 2009 GTS: Trunk release wont work. Fast Key and Trunk Lid
- Questions about my 2008 Lancer ES
- Stiff Brake Pedal, Vibration, Headlight Dimming, and Hissing... Oh My!
- MMCS CAN communication issue
- Interior electrical/lighting issue in shifter
- Center display stays on.
- 08 GTS dies overnight w/ new battery
- 2009 GTS - Hard Suspension Noise and Inside Tire Wear
- 09 lancer gts dies and I need help!
- 09 Steering wheel audio switch issue.
- Code P0725. Help please
- Shield on the exhaust
- Strange Puffing/Rough sounds coming from engine/exhaust
- Fuel pressure regulator
- Tail lights (trunk lid) not working on, when do the red lights come on?
- A few problems: Engine sounds Louder, sometimes car wont start, and lower fuel econ
- 2008 Lancer GTS left channel audio issue
- Car dies, new alternator and battery help?
- P0017 Code Thown...
- Help! Reverse/Back-Up Lights Not Turning On
- Buzzing sound and vibration coming from sensor
- Daily clunk noise
- LIGHTING issue, please offer some light!
- Strange Flutter ticking between shifts. (CVT)
- Blinker Multifunction Switch
- driver's seatbelt sensor problem
- 2008 rockford navi into a 2009 rockford non navi harness
- Looking for an MMCS Expert...
- 08 Lancer Bluetooth wiring diagram?
- 08 Lancer - Steering Push/Talk button
- Airbag light reset?
- 08 Lancer Navi - No temp, alt, baro
- 4" Custom Intake; MAF Sensor Mounting Bracket/Adapter
- Residual Current?
- Idle when stopped
- Lancer ES 08 Rear Brake Pads wont fit
- Please Help: 2012 Lancer Starting Problem
- Occasionally, my HVAC system GROWLS AT ME.
- Lancer ES p0171!
- P0171 system too lean 2008 lancer 4b11
- service required light strange one .pic uploaded
- abs light nesesary service
- Please help :(
- Is my 08 Lancer GS3 (UK) missing some of the undertray?
- 08 DE misfiring with no code
- Stereo loses bluetooth pairings
- wiring diagram
- Need Help!!
- Guys I really need help. Starting and sluggish issues
- P0421 CEL code help!
- Serp Belt Woes. Warped Pulleys?
- Suddenly won't turn over?
- Stock RF sub
- Interior Lighting
- Blower Motor Problems - NEED HELP
- Oil Loss?
- Bank 1 Sensor 3
- Trunk Wont Open With Key Button
- Service Light & Break Switch Issue
- Question About BT And Stereo
- Car Color Code Missing?
- P0138 & p0037
- 2009 mitusbishi lancer A/C unit - help ???
- Stalling Problem
- weird sound coming from the door panel
- '09 Lancer GTS - HID Headlight issues
- Mito-02 and rear speaker problems
- the outside temp is not showing (08 GLS)
- Hands free Bluetooth not working
- Rear Defogger Problem
- HIDs w/ wiring Harness DRL flicker
- CEL p0420
- Disable the lights
- rain sensing wiper issue
- Need help on whining noise (suspect front passenger wheel bearing)
- *TIP* Stuck in park
- Power steering problem (grinding noise)?
- 2012 Mitsubishi Lancer - Sluggish / Slow Acceleration
- Blower Motor Not Working
- AM radio N/W
- Need some tech help!
- Strange noise when accelerating.
- Bluetooth set up - need help
- AC/Heater blower always on and also radio issues (not sure if they are related)
- Squealing problem and possible crack in a part
- Audio issues
- Lancer Sportback jerking problem
- 09 Lancer ES Key case broke
- interior lighting issue with radio and ac
- help grinding/sticking
- 4g69 throttle body help
- Hella SuperTones issue
- 12 volt ignition wire, no power??
- 2008 Lancer GTS Info Display Settings
- timing chain replacement-warranty void
- Can someone please help troubleshoot brake issue
- Help Pleeease!
- 2011 lancer no sound
- Driver/Passenger side floor squeaky?
- How the heck to you replace the factory RF AMP?
- DDM Tuning HID
- Bluetooth
- Popping out of gear
- Info Screen/Display Problems
- 2012 Lancer GTS electrical concern.
- 2008 lancer very loud noise while driving
- Fog light/stereo issues
- 2008 Lancer "GTS"
- 60/40 split rear seat
- Gauges
- Cold weather startup and CEL
- 2013 GT Bluetooth connection problems
- Radio won't turn on
- Back lighting for window controls
- No start for 08 DE
- Abnormally low MPG after CAI install?
- Noise in auto shifter and steering column
- Massive increase in gas consumption!
- radio problems
- Lancer ES 2008 CVT trans (how to?)
- drastic rise in fuel consumpton
- depo headlight issue
- 08 ES bluetooth issues
- rear left suspension sound
- 2013 lancer gt 5spd clutch slippage
- 2008 Lancer ES bluetooth install problem
- Warning light on my dash, need your help (guatemala)
- What cable to use to log 2008 lancer
- 2011 Lancer Bluetooth System stopped working
- Manual Shift Knob
- 09 GTS wont switch to AUX
- Heated Oxygen Sensor Error P2252 (Bank 1, Sensor 1)
- 09 Gts rear bumper replacement help!
- Stock Head Unit Radio - error 03
- press 5 times on rear defroster
- Installed steering wheel column & having a Steering angle sensor error
- Car doesn't respond to key fob or key
- Grinding every time I shift into second gear at high rpms quickly
- 08 ES Sticky Transmission 5spd
- HELP! Wire sliced in firewall - car is limping???
- Belt or chain?
- 2008 Recommended Service and Known Issue
- Helicopter sound....
- Removed/Cleaned K&N Air Filter, car now louder
- Block Heater for 2.0L
- Switching stock CD player with....
- Lancer ES transmission issues
- Need part # help. Front under tray
- Any how to's on Removing the steering wheel of a 10 lancer gts?
- 2010 GTS owners do u have a 02 sensor on your catalytic converter .my CAT was stolen
- Bought Auction car need advice on fixing damage to the ignition, Shifter, keys (pics)
- Gas smell on dipstick
- Radio Reception Issues
- Octane Blue Paint Code
- EvoX HID Headlights on a Canadian GT?
- ignition switch gets hot
- Random Plastic part under car. Engine/tranny mount?
- Lancer 08 Warranty question!
- Electronic problems
- Loud knocking sound
- Airbag Service Required?
- 08 Lancer GTS Problems
- Stock headlight harnesses
- 08 GTS bulbs run way too hot!
- Flash HBs w/o LBs?
- Lancer Airbag reset
- Lights question
- plastic piece of rear shelf rattles a lot
- Very loud noise on Lancer ES 2008
- 2012 A/C Unit Installation
- HID Fog light problem
- Fuel gauge hiccup
- Found a Lancer in a auction BUT says Tranimssion Service Required Needed advice.
- anyone else have this problem
- check engine light
- Thinkin of buying a Auction lancer gts but has no keys. Need info on getting keys
- 2011 Lancer es Floorshift from GTS install problems!?
- Three fake buttons???
- blower motor not working
- Noise in sound system
- Display not working
- radiator fans and ac not working help
- parking brake
- My 2008 GTS problem list
- Horn U/S
- Headlights / tail lights coming back on after auto-off
- HID issues/questions
- Handsfree systam is not responding
- Must I have a scanner to read error codes?
- Lancer DE 2010
- Heeeeelp installing projector headlight with hid
- Front end clunk on 2010the GTS Sportback
- Noises, are these normal?
- Amp install - volume doesnt effect subs
