PDA
View Full Version : Lancer Troubleshooting
Pages : 1 2 [3] 4 5
  1. Bluetooth audio/No song info problem
  2. Known radio issue, but how to approach it to the dealer?
  3. Hit&Run......
  4. Code p0241 and p0240 question
  5. Engine sounds
  6. Some of the wires popped out of the nav harness
  7. Aux input question
  8. AUX trouble
  9. Wind Noise (Leak) at Front D/S Door
  10. Going limp
  11. Loss of sound.
  12. Lancer Stalls when i connect MAF Sensor only
  13. Headlight issue
  14. Power loss
  15. Strange Noises from my 08 gts
  16. Wiring problem?
  17. No audio
  18. Clunking sounds while backing out of driveway
  19. High Revving
  20. map lights don't come on with door
  21. No fuel filler neck flapper?
  22. car feeling restricicted and holds at 2000 rpms???
  23. USB dongle problems
  24. Trunk release wire location inside trunk???
  25. P0107 + P0171 error codes
  26. CD wont come out.
  27. blower motor problems?
  28. sound system got quiet?
  29. Mitsubishi Lancer 08 ES Blue Tooth Stoped Connecting To Head Unit
  30. This Amp problem is driving me Crazy!
  31. Broken plastic piece under front of car
  32. Grey foam bits found in cabin air filter
  33. Abnormal Clicking
  34. 2008 Lancer DE Rev Problem?
  35. Taillight Electrical Help
  36. [2008 Lancer ES] Stabilizer End Link
  37. Astc Off Error After Led Tail lights
  38. key fob problem!!!
  39. How do I disable daytime running lights?
  40. sri giving me headache
  41. warranty???
  42. HID kit flicking issue
  43. rattling/scraping sound at 2k rpm?
  44. throttle asc issue
  45. 2008 stalling problem
  46. air pushing out of rear when shutting a door
  47. 2008 GTS oem Fog lights
  48. Lost Clutch 02 OZ Rally
  49. Hands free passcode reset trouble
  50. cant take off sway bar end links
  51. CVT "Shifter Knob" removal?
  52. Spoiler Rattling Due To Subs
  53. Car pulls to the left?
  54. Iphone 4 and Lancer
  55. GTS Amp not working
  56. Creaking noise/sound from steering
  57. Remoter Starter
  58. Keyless Entry Issue
  59. Body Trouble
  60. Navi Upgrade
  61. ticking noise while heater or AC is on
  62. 2010 Lancer GTS exhaust issue
  63. Lancer 09 ES
  64. Mits Lancer GTS / Vibration
  65. 2009 GTS engine noise around 3000rpm
  66. Blue Smoke
  67. Any tint issue with 2011 GTS?
  68. Center console tray/cubby part number
  69. '10 GTS Pulls to the Right
  70. 2008 GTS Concerns - Looking for Advice
  71. Factory nav question
  72. Don't know what to do anymore... (08 GTS concern)
  73. For the guys with aftermarket seats
  74. Service Required Light Confusion
  75. Popping noise when turning the steering wheel
  76. Hissing sound from under rear of the car
  77. Lancer 09 gts front left vibrations
  78. Aaaaaah windshield wipers!
  79. Crashed My Lancer Yesterday....Insurance isnt paying for it
  80. Passanger Side Mirror + Cover, HELP!
  81. P0171 and P0340
  82. air bag module location?
  83. Issue with Middle Display
  84. How much does a driver side mirror cost from the dealer?
  85. SOMEONE PLEASE HELP!! Lancer Rev Limiter!!!
  86. Air control unit lights
  87. Starting issue
  88. Handsfree bluetooth pairing lost every few months
  89. Anti-Theft System Problem
  90. Another HID problem...(already installed jrox bypass)
  91. 2010 GTS Sport VS Sedan Ride Quality
  92. Broken lug safety key
  93. DRL Solution
  94. Hid headache
  95. Brake bleeding procedure
  96. HID's and DRL's
  97. Trip gauge/meter help
  98. Severe Electrical Issue, Lots of things not working!
  99. bogs at low rpms after axelback/SRI install
  100. Trailer Turn Signals Issue 08 ES
  101. Ignition switch
  102. Broken Windshield...
  103. Weird acceleration/transmission issue
  104. Squeaky Suspension in low mileage
  105. Dirty power source
  106. transmission issue
  107. First Oil Change?
  108. Aux hook up for 08 ES
  109. Steering wheel volume and channel change control problems
  110. Why???
  111. Headlamp condensation
  112. lower front truss bar install?
  113. Need help whining noise???
  114. Parking light/ angel eye
  115. Bluetooth + Outside Temp
  116. I need a quick answer!
  117. 2008 Lancer - Keyless Entry?
  118. Possible Wheel Bearing issue?
  119. Angel Eye Help!!
  120. Radio cutting in and out?
  121. MMCS "delete backup memory," etc.
  122. After Installing Navigation System the AUX Jack does not Work
  123. center compartment/armrest outlet
  124. Sunroof Just Crash!!
  125. CEL New Air Filter question
  126. Dead Starter Solenoid
  127. High idle on cold start with strange coasting behavior
  128. No settings menu in the center MID
  129. a little help guys!
  130. 1) CEL from k&n Intake, 2) OBD2 scanner doesnt work!!
  131. installing hid kit
  132. 2010 GTS Manual 1st to 2nd gear jerk
  133. MMCS Calibration/Environment Issues
  134. oscillating noise at 65mph and 75mph
  135. Shift lock, no brake lights, no cruise control
  136. RRM Springs, after install question
  137. Engine light and maintanence wrench after attempted ecu read
  138. check engine light after k&n intake.. please help!
  139. sudden engine rpm increase!!
  140. CVT Transmission "Slow down" Warning?
  141. '09 Rockford Fosgate subwoofer rattle/banging
  142. Rear Bumper Crushed
  143. Excess Vibration with RRM Motor Mounts?
  144. Stinky A/C
  145. Too Hard on the Little Lancer.
  146. 2nd to 3rd gear grind, Out of sinc
  147. Electrical Problems Need Help!!!
  148. key fob stopped working
  149. Another CVT issue
  150. brake/stop light flashing
  151. 7,500 Miles, 1st Service
  152. High-pitch Side window noises&&rattling on snow
  153. So just curious about the fog lights
  154. 09 GTS, CVT wouldent change ratio
  155. Looking for owners of stock '09 Lancer GTS
  156. sunroof gap
  157. RRM Header Mesh Leaking
  158. Steering wheel controls for aftermarket Nav...
  159. Info Display
  160. Heater Fan Stuck On...
  161. Lancer GTS Navi Update
  162. Parking Light wont turn on!
  163. Locked Steering Column
  164. Electric Noise in rain/wet road
  165. Squeaking noise comming from the front after a bump?
  166. HID Bulb Plug Help
  167. '09 Lancer GTS CVT Throttle/Acceleration Problem
  168. FASTkey locked out... 08 GTS
  169. Performace Chips Question
  170. Burning Smell
  171. Gas Tank Lid
  172. low beam headlight wiring
  173. Turn signal Issues
  174. Airbag Sensor TSB
  175. GTS 08 CVT Shift lock noise
  176. Clutch Bypass, Cold Weather
  177. rockford sub fading badly
  178. Radio issue
  179. car charger
  180. my poor baby was hurt.
  181. Reset SRS light?
  182. Help Car died
  183. Passenger Door Tweeter Staticy
  184. question about CAI
  185. Trouble starting....
  186. HID Help and YES I've Searched
  187. 08 GTS Manual clicking???
  188. Cruise Control Issue
  189. Cheapest way to update maps on Factory Navi?
  190. 2010 GTS Engine problem...maybe?
  191. Periodic Inspection Notification on HUD
  192. Anyone know how to get to my AC's blower motor??
  193. Quick Question
  194. how do u reset the gps service timer?
  195. ddm tuning hid kit
  196. Grinding noise from HVAC Fan
  197. Blown Bulb Question...
  198. HID Harness help will be great!
  199. coolant change
  200. Parking Lights not turning on
  201. Need help random stalling
  202. Help! Anyone Order from this site?
  203. Lancer GTS 09 Steering Wheel Misaligned??
  204. AC cabin filter
  205. How do you remove rear passanger Dome light?
  206. AC stopped blowing air
  207. Bluetooth and Nokia
  208. Tsudo N1 install on 09 GTS... My experience...
  209. periodic inspection
  210. Driver Side Air Vent Rattle
  211. Driver side window acting weird
  212. gas gauge problem
  213. Rear Mud Flaps Install Question...
  214. 2009 gts auto tranny
  215. Start up with first gear, I hear a noise
  216. NEED HELP ASAP (those with F90BT)
  217. Door panel rattle
  218. K&N Drop in Filter Question...
  219. 2009 GTS - Wierd sound when turning slowly...
  220. Need help fast!
  221. A protest and request for comments and suggestions!
  222. Ratteling Question
  223. PO421:Warm Up Catalyst-below threshold (bank #1) CEL
  224. 08 driver door window rattle
  225. Injen Cai Install + Maf O-ring (pics Included)
  226. warrenty voided cause of oil filter...
  227. 2009 lancer de tsb for breaks
  228. GTS leather seating
  229. clutch pedal grinding
  230. Rattling noise?
  231. Paint question
  232. Service Manual Lancer '08
  233. Sqeaky noise in the engine & bucking???
  234. Rear and front breaks making a weird clicking sound?
  235. Rust prevention after drilling holes
  236. BlueTooth
  237. Help! Check engine Light
  238. Radiator, help, stuck in Wyoming.
  239. HELP HELP!!! turbo installation!!!!!!!!!!!
  240. window tint ?
  241. Fan Turning on and off very often
  242. Slight vibrations at higher speeds?
  243. 2009 GTS Front Emblem
  244. Deleting playlists from hard drive.
  245. Annoying rattle
  246. Hid drl fix
  247. Recall 2008-2009 lancers faulty brakes
  248. Seat frame rusty
  249. AFS problem
  250. hid issue with harness
