- Defi Link Unit Wiring Help
- how to install AEM truboost controller/gauge
- How To: 5-Speed Transmission & Transfer Case Fluid Change
- Help with reverse camera on stock navi
- COBB AP placement thread
- Cobb AP Install pics
- Where to tap for gauge lighting
- Oil Temp/Oil Pressure Gauges questions.
- Lip spoiler installation?
- How To Cam installation?
- How do you manually adjust the Headlight?
- info on how to take out front bumper
- Removing center console in EVO X MR
- How to: Oil and filter change on the EVO X
- sparkplug cover
- fuel pump mod
- removing front seats?
- rear bumper
- Rotor Install/Caliper Removal
- Gauge Help! Boost & Intake Manifold
- Refinishing Titanium Exhaust Tips
- flywheel install
- Test pipe 02 Sensor Socket Size???
- EVO X GSR Clutch Flywheel Change
- Second try....
- first post
- Brake Pad Change
- How to install a downpipe or TBE??
- HKS type 1 tubro timer
- Hood Scoop Removal??
- Headlights uneven. Any way to level one?
- Quick question: GReddy Profec B install
- Request: How To Take Off Fender Vents
- How to install a Forge Unos MBC????
- How to replace HID on the MR
- Request: EGT Gauge Writeup
- Coil trigger tap
- Apexi AVCR install help Please
- Installing an aftermarket steering wheel
- Install tip on Synchronic BOV on EVO X
- For Those Installing new turbo
- Evo X Mishimoto Radiator Install
- How To Install a TWM Performance Evo X Short Shifter
- Mits thread shift knobs work on MR
- X fog light installation
- Breaking in an EVO X
- Request: FMIC Install
- REQ: Cartridge Block Heater Installation How-To
- Dash Removal?
- Ipod
- Racing belts???
- Evo X Boost Gauge Install ,No splicing, No firewall drilling,Pics+Vid= Clean As Hell
- Evo X "Standalone Gauge"(Defi Racer) Install w/ Pics&Vid
- REQUEST: High Torque Take Off
- Request: Hella Supertone horn Install
- AMS coldair intake with no vacum inputs???
- clutch??
- O2 Housing removal is easy. . . .
- how to : Smoke
- how to change diff and tranny fluid
- How to install Parrot CK3100 Bluetooth?
- Hks Ssqv Bov
- removing spoiler?
- Request: HIgh res pic of a decal
- neep installing turbo timer hks type 1
- How to install coilover suspension?
- Shorty Attena on SSS X
- How to take tail lights out???
- fogs with parking lights?
- Fuel Pump Modification
- disabling daytime running lights?
- Ipod / MP3 player cable installation question.
- JDM Push Start
- Install Racing Harnesses AND Stock Belts
- How To - Aem Tru Boost
- How do you hook up Defi Controller?
- AMS small battery kint install
- Request: How to remove center console?
- Who installed this O2 sensor?
- sidemarker help
- Transmission Fluid Change.
- Request:How to remove the black door pillars
- How to remove and where is the ECU located?
- iPod integration into Evo X Navi
- AEM intake
- Where Can I Find A Tach Signal / Shift Light Install
- Anyone sell just MAF plate adaptor?
- Wiring into the tach signal (tach recall shift light)
- how to on walbro install???
- Bluetooth
- DYI oil change
- How to Install an EVC
- aem tru boost for your X
- Battery relocation project....anyone has wiring diagram?
- My CAI With custom heat shroud
- GTS wing removal, Evo wing install
- how to install a mbc
- Request: EBC installation.
- Buddy Club secu timer install questions?
- burnt exhaust tip look
- Request: Removing Rear Seats
- ams mbc?
- Where to obtain switched/accy 12V supply from
- How to Install a Front License Plate without drilling the Bumper
- Cigarret lighter fuse help
- Request: How to install AMS Intake pipe?
- Auto Signal
- TPMS - Anyone know how to disable it
- Homelink on EVO?
- ipod capable in sss/nav gsr?
- How to Install TT in an Evo x?
- MR 2-step?
- how to increase boost pressue for actuation of factory wastegate
- Tools Needed for Headgasket Replacement
- Video camera mount
- a/v
- Request:How to MBC install...again
- HID conversion on GSR non-SSS
- How to: Paint engine cover.
- PB with Mud/Splash Guards
- Front Clip Removal with intercooler pipes installed.
- How to paint rims?
- emblem removal and reinstallation??
- Nav wiring diagram
- Idles like crap!!!!
- Vaccum level for EVO X???
- Cone filter install - fixing the spinning bolt problem
- How To Use Factory 2 Step
- Factory Aero Kit Installation Instructions?
- EVO X Headlight Electrical Mod Question
- Unlocking Mitsubishi MMCS
- What kind of Paint?
- timing marks
- Gauge Locations Evo X ???
- IPOD on evo X
- a/v jacks
- HOW TO PAINT FOGS--- for those who dont know
- How do you lose weight on the X?
- How to insall a bov on the evolution x
- Play dvds while driving
- Help help help!
- Front Bumper removal
- HID retrofit has anyone done ityet?
- RPM signal wire
- clutch install
- Works Short Shifter for Evo X'
- How to install wideband O2 sensor bung
- Three more access points to go into the passenger compartment
- Oil Pressure gauge
- How-To Guide
- HOW TO: ETS Exhaust Install
- How to Red out the Tail lights on Evo X
- Looking how to remove AC cover panel?
- Is The MMCS Back-Up Camera Capable?
- mounting the license plate
- need a how Turn off or reset "PERIODIC INSPECTION"
- Anybody have the ECU Pinout yet
- Seat Change
- Canadian Rear Bumper PROBLEM
- Installing BC Racing Coilovers on your Evo X
- Aem Tru Boost Setup
- Trunk spolier, non SSS
- HOW TO: Firewall Access
- HOW TO: Install Cone Filter
- Vortex generator for the X?
- Anyone know how to kill the seatbelt beep?
- AMS Shift Bushings
- Zeitronix Help....
- Hid headlights??
- How to disable the factory 2-step
- Racing Pedals Install
- HID How To????
- replace stock air intake w/ cone style
- Removal of Rear Subwoofer.
- Boost Gauge and MBC install
- EVO X Front Spoiler Installation Instructions
- HOW TO: Install Factory Bluetooth into Evo X GSR
- Good Place For A Boost Gauge???
- HOW TO: Install factory Navigation into a NON-NAV Evo 10
- Lancer Evolution X - Service Manual
- How to turn off Daytime Running Ligths
- How to: Make your own shift boot
- How to: make an EVO X look good in one easy step
