PDA
View Full Version : Evo X How Tos / Installations
Pages : 1 2 3 [4] 5
  1. Changine out Trans switch to radio controls
  2. oil and fuel pressure gauge install?
  3. HOW TO: TPMS FIX with aftermarket / winter rims.
  4. Anyone replace the rear O2 sensor?
  5. How to: Evo X O2 Housing / Downpipe Replacement
  6. Engine oil draining from oil cooler
  7. intake and intercooler piping ?
  8. Ultimate Racing UICP 2 piece install
  9. Need help to remove AMS MBC to go back to stock
  10. help there is a light that comes on when driving
  11. Need Boost/Vacuum in the cabin
  12. Help Needed: How to relocate the ACD switch
  13. Boost gauge question
  14. wat size resistor is need for steering air bag
  15. How To: Install Bluetooth Kit for pre-wired 2009 Lancer.
  16. ETS Tubular Exhaust Manifold Install Guide
  17. Race harnesses
  18. What size plus for the non SSS small wing X
  19. OEM Evo X Front license plate
  20. HELP: Non SSS HID Install Mess!!!
  21. problem on installing the Hotchkis fron sway bar
  22. DIY: Transmission Fluid Change (EVO X 5 speed Manual)
  23. Fog Light Tint Help
  24. TWM Performance Short Throw Shifter on a 2010 Evo X
  25. new ams fuel kit, would it work for E85 conversion?
  26. How To: Build a custom hitch for the Evo X and RalliArt that is completely hidden
  27. Zeitronix ECU wiring diagram?
  28. Injector replacment
  29. Bov intallation problems
  30. new guy to evo world + first mod =)
  31. A Pillar removal?
  32. Front wheel studs?
  33. AMS Fan Shield trouble
  34. ETS Evolution X Intercooler Kit Picture Install
  35. Battery Question
  36. Rexpeed R-type ducts (fog light delete)
  37. How to pop open plastic racing harness holes?
  38. Modify stock exhaust to remove flapper
  39. SST Fluid Change
  40. Settings Menu On Gauge. Change to km and liters, etc
  41. PROBLEM: Installing Seibon OEM CF Front Lip
  42. HELP on installing Blox Vacuum Manifold Kit
  43. Installing your own clutch!
  44. help!!! how do I take off the o2 sensor
  45. Help with MBC install
  46. Installing DG Motors EVO 9 Converted Master Cylinder/pedal
  47. Headlight removal
  48. How to take out hood rod?
  49. My trick passport 8500 install sort of
  50. Why no Turbo Swap threads
  51. mmcs question
  52. Help! Takin the back seat off
  53. Passenger headlight won't move along with the dial.
  54. HOW TO: Brake Rotors and Pads Replacement
  55. Go from MBC back to stock electronic boost controllers
  56. Brake Oil Bleeding
  57. What is the best way to change out a front parking light?
  58. How hard to install a regular downpipe ( No O2 housing)
  59. How to test fuel pressure ???
  60. Remove and Polish Valve Cover
  61. HOW TO: Check Fuel Relay with Multimeter
  62. oem navi install questions
  63. HOW TO : fuel pump relay 1 test
  64. HOW TO: Make a distribution block for Gauge Installs/Radar Detectors/Anything else.
  65. Custom Gauge Pod Project
  66. Those who have removed the OEM high spoiler...
  67. zt-2 wire routing
  68. Request: how to wire up sound system on factory headunit
  69. Stock Boost controller question
  70. ets intake install
  71. Radar direct wire install help
  72. Fog Light Disassembly
  73. Airbag light issues/Bride seats
  74. Changing oil on rear diff
  75. Transfer case drain plug size
  76. Anyone knows how to do wheel alignments the X?
  77. Custom intake install w/ pics
  78. Removing antenna on roof
  79. mount camcorder in car
  80. HOW TO: Remove radiator grill
  81. Cabin air filter ("air purifier filter") change?
  82. Serpentine Belt Adjustment?
  83. how to for wideband 02?
  84. How to Blackout Headlight housing (even though I left a bit of chrome)
  85. Remove front/down pipe (not dump)
  86. Install LICP without removing body
  87. How do i clean evo exterior?
  88. Help on Turbo Removal
  89. how does this happen?
  90. AMS cai
  91. Ams test pipe install pictures
  92. Question about rexpeed Ralliart Style CF Ducts
  93. evo x stock wastegate aculator
  94. Scratches around emblem
  95. installing extended studs on rear hubs?
  96. Curbed my rim
  97. First Oil Change
  98. Has anyone made a custom heat shield for Cobb SF Intake?
  99. seatbelt warning sound
  100. Monday AMS test pipe install. Tips?
  101. Removing the Evolution aluminum shift knob.. AYUDA!!
  102. TurboXS Knock Light
  103. how do you change MR driver side DRL bulb?
  104. APR Vortex generator
  105. where can i get an oxygen sensor socket
  106. how hard is it to install a cp-e exhast
  107. Evo X Front Mount Intercooler (FMIC) Installation Howto (Illustrated)
  108. AEM Tru Boost Install Help
  109. How to make doors auto lock when you move?
  110. How to remove stock Evo X pedal covers?
  111. Interior Rattle
  112. Need Help With Tial Q BoV
  113. Step by step down pipe removal and installation instructions
  114. Whiteline Roll Center Kit
  115. Agency Power shorty antenna
  116. How To: Install long wheel studs in an EVO X
  117. TPS Sensor wiring diagram, or gas pedal?
  118. How to painting twin hood wents?
  119. Need some Help BC RACING BR coilover install
  120. Need Help with AMS Fuel Rail
  121. Flush/Change Coolant Instructions Needed
  122. Anyone Know How To Remove Switch Blank Next to Evo X Steering Wheel (Above Fuse Door)
  123. HKS Uprated Actuator
  124. Seibon Front Lip Install Instructions
  125. Display Speed in the Multi-Function Information Display (MID)?
  126. Quick Install: AMS Shifter Base Bushing
  127. Stock fuel rail removal ?s, Evo 8
  128. AMS Shifter (((Base))) Bushings
  129. How To: Lock/Unlock chime disable/enable
  130. HOW TO: disable non-HID X DRLs (this works :))
  131. Eibach Pro Kit install
  132. apr rad plate n ARC induction box
  133. airbag light
  134. Multi-tool/ tire press equalizer / deflator / boost leak test assist/ etc.
  135. Is this safe/ Will this work?
  136. Help with FMIC install (Pic included)
  137. how to install different front seats - with no fault codes
  138. How to install SSS spoiler on a Canadian GSR with GTS spoiler...help!!!
  139. Drifting your mitsubishi EVO X - Stability Control Secrets!
  140. HELP!!! how do you remove the X turbo?
  141. How do I connect the SWI-PS
  142. Replacing Evo X steering wheel with Evo 9/8 wheel
  143. How to remove spark plug cover?
  144. Oil temperature and pressure sensors for Greddy Informeter - oil sandwich?
  145. New Gauges Setup! Looks OEM + AC Control Relocation
  146. HOW TO: Make a Custom Heat Shield (SRI)
  147. How to remove SAFC ?
  148. how to install greddy tic on evo x
  149. Hide-Away License Plate Frame (Pictures & Video)
  150. HOW TO: 5v USB + 12v Outlet Power
  151. Apexi turbo timer install
  152. How to change miles in km on ODO and trip
  153. Air spoiler ( Tall Wing) Evo X
  154. New O2 sensor, now won't Start HELP!!!
  155. Fort Myers turboback installer
  156. How to: Install OEM Backup Camera (above license plate)
  157. Evo X Jack Points......
  158. Greddy Type S?
  159. Hks camp 2 & if unit
  160. HOW TO: Stainless Steel Clutch Line Replacement
  161. Unlocked MMCS
  162. wastegate forge problems
  163. hella supertones?
  164. Tapping into cigar lighter?
  165. Chargespeed Evo X Bonnet Center Duct
  166. How many ftlbs for the Brembo caliper bolts?
  167. Motul 600 brake fluid question
  168. Electronic Boost Controller???
  169. Panel Air Filter
  170. Spring Install - Tein S.Tech
  171. manual boost controller
  172. Hoodlatch will not open.
  173. Good place to run Wideband/EGT/etc (pics)
  174. How to take out intake manifold?
  175. Problem With Hks Ssqv Bov!
  176. AMS EVO X O2 Eliminator 3.0" Downpipe Installation
  177. Rear Bumper Removal (How-To)
  178. Fog light bulb replacement
  179. installing AMS Exhaust and test pipe
  180. mechanical boost gauge
  181. DIY Carbon Fiber Interior Trim
  182. Wideband Install Question
  183. Help!! Hardwire passport 8500 x 50
  184. Instructions for Ralliart Lip
  185. Pics of Evo side mounted plate?
  186. Best way to disconnect tranny from engine on floor???
  187. Custom Triple Gauge A Pillar!
  188. Quick Install: Nisei 1PC UICP with Front Bumper on
  189. How to put a test pipe on?
  190. Ralliart Pedals
  191. How would you use a trolly jack?
  192. seat slider-rail dissassembly
  193. UIP Install Question
  194. DIY heatshield for Cobb SF Intake
  195. Ralliart Taillight Install w/pics
  196. GSR Cam install
  197. How to install uprated wastegate actuator?
  198. 350Z intake on an X.
  199. Razin voltage stabilizer done
  200. A-Pillar fabrication Pictures
  201. LED Trunk lights
  202. Aftermarket Steering Wheel Install - eliminate Airbag light
  203. Q: Valve cover removal??
  204. How do you remove front aero lip?
  205. Prosport boost gauge power wiring
  206. How to: Install rear RA UR mud flaps WITHOUT removing rear tires
  207. How to run fogs with no low beam and drl delete on NON SSS
  208. How to take out rear bumper reflector
  209. how to debadge trunk emblems?
  210. Rexpeed Bumper Cover
  211. Headlight assembly
  212. ETS intake install help needed
  213. Lowering Springs on a X???
  214. Help with wiring Greddy Infometer Touch please?
  215. How To: Install Brake Pads on Evo X
  216. How to Replace Fender Plastic Vents with Rexpeed Carbon Fiber Vents (with Pics)
  217. BLOX Racing Counter Weighted 5-speed Shift Knob
  218. Replacing the EVO X wing with lower profile
  219. Installed HKS Catback system, but have a question?
  220. Troubleshooting
  221. AMS intake install with pics??
  222. HKS Racing Suction Reloaded Kit ..
  223. Tow Hook Install?
  224. How to remove the top wastegate solenoid restrictor pill?
  225. Wingless: How to cover the holes?
  226. How to remove rear bumper evo x
  227. Wiring Diagrams?
  228. MBC= service engine soon
  229. How To Install HID Fog Lights
  230. difficult to remove oem fog lights?
  231. Help Forge Unos and Prosport Boost gauge
  232. How to install LED headlight parking lights?
  233. A-pillar gauge pods
  234. Fog lights
  235. Request: HID alignment
  236. Innovate Wideband O2 Sensor
  237. Relocating traction control switch?
  238. How To Buschur FMIC for Evo X
  239. more questions about changing front seats
  240. Frustrating Front Bumper!!
  241. Request: Part Number
  242. How you change your HID light bulbs without removing the bumper?
  243. gauge pods/location of gauge
  244. HKS EVC VI installation instruction
  245. changing my clutch and flywheel and what tools needed
  246. Prosport boost gauge install...help!!!
  247. Aftermarket Seat Install?
  248. How to remove rear seats?
  249. Putting Car on Jack Stands
  250. Rust on exhaust..
