PDA
View Full Version : AEM EMS
Pages : 1 [2] 3 4 5 6
  1. no start & ac fan staying on
  2. AEM EMS Fan and fuel pump controller
  3. Having problems setting up AEM Evo 9
  4. Please confirm: Evo 9 Aem Ems is 3 plug
  5. Red Neck Shift Light
  6. 2 map sensors???
  7. Mobile tuning?
  8. EMS and strange coolant temp/ait sensor readings
  9. Injector settings
  10. AEM 1313 bad start
  11. AEm 5 bar sensor issue?
  12. Aem software
  13. AEM EMS questions
  14. AEM EMS 30-1313 question
  15. !!!!Help!!!! Weird issue with TPS/MAP
  16. 87oct + AEM Meth kit
  17. Evo wont start with AEM EMS and has dead cyl number 2
  18. About tuning the Cam with Aem
  19. New AEM harness to help pass emissions?
  20. AEM EMS ix series 2 - ix harness/8block
  21. Omni 4bar??
  22. Does my AEM Wideband AFR support serial output?
  23. Inconsistant no start
  24. AEM EMS Response / TPS , Series 1, Series 2 boxes
  25. new to EMS
  26. Start up map evo 8 with 2150's on e85
  27. just installed aem and the car wont start
  28. AEMPro locking datalog files- cant send to tuner
  29. Evo 8 Won't start it please help
  30. Dual rail setup
  31. A/C settings
  32. EVO IX cold start issues (Help)
  33. Setting up NLTS -- How
  34. AEM start up issue evo8
  35. How do you change fuel percentage changes?
  36. Bad map sensor??
  37. Fuel pump vs Injectors?
  38. How to Adjust Engine Start Settings
  39. changing stock coils for ls2
  40. AEM EMS Help!!!
  41. aem ems
  42. Aem evo ix uego problems
  43. Fuol pump not working with AEM
  44. AEM EMS and Methanol Injection
  45. Anyone using a non oem knock sensor?
  46. How to check if sensors are connected?
  47. *How to setup idle for AEM ECU*
  48. AEM Tru Boost Help
  49. Idle -- How good is yours
  50. Need some help setting up FIC 1650cc injectors
  51. AEM EMS cold start without ISC
  52. Uego install, now runs super rich
  53. Will a netbook work with AEM EMS
  54. AEM ems question about front O2
  55. Can some one take a look at my logs please
  56. MacBook w/ Parrallels running XP....
  57. ID1000 Settings
  58. Will a aftermarket alarm work with AEM EMS?
  59. My EMS Just showed up.
  60. EMS Placement Fix
  61. Too Much Knock?
  62. Base Map Help 2150's
  63. Anyone have any decent Mivec maps for a 35r based car?
  64. Fuel pump not priming/no start
  65. Need to know if I have a bad sensor
  66. Evo 8 ems
  67. More cold start issues
  68. AEM 5 Bar Stainless Map Sensor Issue
  69. couple noob questions about my standalone
  70. AEM EMS - whoever helps me setup closed loop gets 60$
  71. Extremely weird need advice from experts!!
  72. Fic 2150 scaling latency help?
  73. "newbie" i think there is something direly wrong with my tune...
  74. Wideband output to AEM EMS
  75. basic settings
  76. Fuel type Gas/ Ethanol
  77. Sufferance between raw knock n knock volts?
  78. Car won't start. Need someone to read my AEM
  79. knock control problem
  80. map switching
  81. Help Starting
  82. Base Timing
  83. Needed revisions from AEM directly?
  84. unable to connect
  85. jdm 3bar??
  86. AEMPro how can i tell if im in Open Loop or Closed loop?
  87. Help with Start (series2) need help!
  88. Exporting Logs to Virtual Dyno (not dyno room)
  89. 2 step swith hooked into intercooler sprayer wiring?!
  90. Problem Logging
  91. Car wont start AEM,stat sync'd off!
  92. AEM boost solenoid=same ECU wires as stock?
  93. AEM Series 1 or Series 2?
  94. Ecu flash vs AEM
  95. EMS Users: You running the Fuel Pressure Solenoid Valve?
  96. ID 2000 settings
  97. can a 5 bar map be wired to two different sources?
  98. Boost control problems with MAC valve
  99. EMS 1313 + A/C + idle
  100. A/C issue with V2 ems
  101. F/S Evo 9 AEM EMS
  102. Map switch question
  103. Help with AEM updating
  104. aem uego problem with ems
  105. Can I start up car and idle with old map, changed a few things...
  106. Boost Comp Tuning Vs Table Tuning
  107. Exporting AEM Logs to Virtual Dyno Room
  108. Issue with using firmware V 1.11
  109. AEM serial guage
  110. Running extremely rich at startup...
  111. EGR Blockoff Plate
  112. starting with ems
  113. Wiring external fuel pressure sensor to AEM EMS
  114. regarding the universal ems
  115. Trouble starting car and car suddenly dies while driving. Bad Walbro?
  116. Aem > ecuflash :)
  117. People with AEM EMS and Emissions..
  118. All gauges off on factory cluster
  119. AEM Boost Gauge Help
  120. AEM & IC light
  121. How wire in external aem wide band to ems?
  122. Accel Fuel settings
  123. AEM and check engine light?
  124. strange ignition sequence problem
  125. Who has tried Series2?
  126. AEM Ignition problem. HELP!!!
  127. Biggest injectors not needing a separate driver?
  128. How do you set aem two step
  129. need help with non mivec evo 9 head with aem ems. pretty intresting!!
  130. Grimmspeed BCS w/ EMS
  131. Light Throttle Input or Light load = bucking?
  132. Knock Sensor Settings
  133. How to tune.
  134. Idle issues
  135. Bad EMS unit?
  136. Wiring in the 5 bar map sensor..
  137. AEM freezing after initial map loading from ecu.
  138. Mivec disable!!!
  139. 2 step launch control settings Questions
  140. AEM 1320U problem
  141. place to download base maps?
  142. AEM EMS interchangable with both an 8 and a 9?
  143. New aem ems
  144. Car dies when put in neutral while driving. HELP!
  145. AEM EVO 8 Tune needed for new setup!
  146. Got one here what to do with it?
  147. aem problem
  148. New to Aem Ems Please help!
  149. Need some help, starting issue (pics)
  150. usb to serial cable guide and instructions
  151. Pulled log, have question
  152. Help me lower my boost....
  153. Fuel Map Question?
  154. need map help and help with injectors!! evo ix with 30-1320 ems
  155. Trigger disc?
  156. Car in nuetral. Clutch in. Stalls. HELP
  157. Mivec tuning
  158. Engine start, help please!
  159. As anyone doing this -- Using Low Side Output for Lean Protection
  160. Issues with starting/coils
  161. Idle Problems
  162. Going lean at 3500 rpm
  163. Lost evo 8 base map-help
  164. Launching with Retard Rev Only?
  165. just curiouse how everyone mounted there aem ems
  166. AEM EMS 1313. how to setup timing and TPS?
  167. Need help with boost value on aem ems
  168. Wot tuning
  169. Need opinions on my rev limits
  170. how to change maps on my ems with a switch
  171. AEM help reviewing log file.
  172. AEM UEGO sensor get hot w/o engine running
  173. base map
  174. ECU Possibly going bad?
  175. Need help car wont start
  176. WOT issue? Can't tell if it's the tune or mechanical
  177. Need some help, starting issue (not the normal)
  178. Need base map to tune evo VIII 2.5L GT37R 1200cc injectors
  179. wideband to AEM EMS
  180. AEM lost rpm signal?
  181. UEGO Wideband Problems
  182. help: need factory map sensor plug/pigtail
  183. How to properly setup non-cdi COP????
  184. Anyone Know a Good Tuner
  185. 50 trim 2 step question
  186. What is your Throttle Position on WOT ? ? ?
  187. Anybody not running a MAF anymore please read
  188. Question about tunes and different fuels...
  189. tuning in pa
  190. AEM Boost solenoid vs Standalone EBC?
  191. Please Help AEM EMS installing new wideband question
  192. tuning issue messed up piston?
  193. Sensors I can take off when using aem ems
  194. driving car just turns off
  195. questions??
  196. getting rid of AEM
  197. AEM 1313 x 1313-u
  198. aem and wideband problem?
  199. AEM EMS hiccup at after 5k
  200. Here's how I pass inspection with my AEM EMS ~500 AWHP EVO 8
  201. Any way to troubleshoot AEM without sending it out?
  202. A/C idle issues
  203. Drag cars using AEM EMS chime in please!?
  204. mivec error
  205. dragster
  206. Knock??
  207. Aem help!!!
  208. External switch for internal logging
  209. aem ems
  210. EMS with stock turbo
  211. aem 1313u and external wideband?
  212. AEM EMS and fuel level reading..
  213. Coolant or oil temperature-dependent rev limiter..
  214. What's your 2-step at, and how much boost do you build??
  215. Inspection
  216. AIT ~140 Degrees....What's yours? Im thinking about putting Water Injection
  217. questions
  218. Aem ems antilag
  219. Lean at cold, rich at hot..!!!??
  220. 1600 cc injectors? Stock Block
  221. AEM EMS crash during firmware upgrade
  222. 35R cars and timing maps?
  223. AEM EMS hard start
  224. AEM timing #s Vs ECU Flash timing #s?
  225. Which meth kit wires into AEM EMS easily?
  226. Blue Screen/Physical Memory Dump
  227. No lift to Shift
  228. AEM EMS second opinion
  229. AEM EMS and turbo timer
  230. Boost Control By Gear?
  231. Konck sensor tuning?
  232. Immobilizer
  233. Boost problem. Cuts out around 15-17psi.
  234. Mivec and triggerdisc
  235. need information (map) for tuning MIVEC on Evo IX
  236. help with UEGO
  237. TPS Unplugged? Why?
  238. Anti-theft
  239. Looking for assistance- Epic Lulz for stupidity.
  240. WTB: Sotck ecu and stock maf
  241. A/C Clutch (compressor) not turning on
  242. Inconsistent Logs
  243. FIC Bluemax Injectors + EMS
  244. In theory
  245. o2 disconneted, but still running fine?
  246. Any one use a buzzer or a horn for shift indicator?
  247. I need help asap!
  248. Symptoms of a dying AEM wideband 02 sensor?
  249. Email tunes?
  250. Cal file?
