View Full Version : AEM EMS
- Will this be safe?
- Need an installer and tuner in central illinois
- Tuners in Florida?
- DO i really need DLI??
- unecessary items while using EMS.
- do you have the EMS set up to control boost?
- AEM vs. Autronics
- finding good place to get tuned in socal?
- David Buschur in Vegas.....
- Aem Ems Wiring Diagram
- Uego/cable
- AEM is awesome
- Fabbing up MAF delete?
- Best price for an AEM EMS?
- Speed Density or MAS
- Boost controler
- Need Help - IAT Sensor Stuck at 77 Degrees?
- Big problem w/ AEM & UEGO....Help Please
- Help me fix my stalling issues please
- aem uego
- Problems on Spool up
- Launch Control Question
- Dissapearing EMS
- AEM is this correct?
- IAT sensor help
- i cant change my map!!
- Ems Or Reflash For Stock Turbo?
- need help 2step amd rev limiter not working
- Knock volt count
- Check Engine Light
- HELP.....please?
- can the EMS hold more than one map?
- I need a base map for cams
- Very Cold Start problem
- Anyone need an AEM 5 Bar MAP sensor?
- Need a little more explanation on wiring wideband into ems.
- I Need A Aem Tuner To Fly To Hawaii!!
- problems with internal logger?
- have a problem
- car revs up when I let off gas pedal
- Weatherpack connectors ?
- Safe to travel on a base map?
- Question regarding EMS & Sensors
- EMS: Beginners guide on how to get running.
- First Startup / Config
- No Lift Shift/2 step in an 05
- Guys with AEM EMS....which intake with MAF del
- EVO will not start! please help
- timing map
- Evo will not start
- AEM Uego wideband
- Is my AEM jacked or what?
- Evo 9 aem
- Crazy knock voltage >>> FIXED
- AEM Serial Gauge Installed
- Need 35 map!
- Sean Ivey Tuned
- Coolant temperature sensor
- car wont start on a dime
- HELP, I need a decent cal file
- *evo Ix Ems*
- Base Map for 35r?
- Did I fry my AEM EMS out???
- EGT Probe
- trouble with my wideband
- Convert to maf for emissions question
- Sputtering when trying to boost
- map vs maf
- fuel pop
- dEAR SEAN IVEY PLS HELP ME
- Open vs Closed Loop
- aem ems update on tuning
- will disconnecting my battery cause the AEM EMS to lose its maps, tune???
- Spyware/viruses on my laptop: will it screw up my AEM EMS???
- AEM EMS?? Is it possible to do boost logs?
- I need a temperary map
- power steering pressure switch input on AEM
- Anyone have a pic of the Buschur MAP sensor adaptor?
- overheating since aem is in....advice..?
- suddenly running really rich, please help
- Knock Retard Bug & O2 Bug ??
- will anyone help?
- 4.0-4.2 volts of knock n hiccup
- mini battery with EMS?
- aem uego
- 02 sensors
- Backfiring, Fuel Cut
- Which wires to what on MAP sensor? (pic)
- Help My Friend!!!!!
- downgrade
- AEM EMS tuning now i'm desperate
- AEM EMS tuner needed
- USB Serial adaptor
- New AEM Serial Guage!
- Compatibility with Evo 7
- Bought used AEM EMS......
- AEM boost controler question
- how do i scale a bigger set of injectors with the AEM??
- haywire
- Fuel pressure regulator solenoid?
- check engine light
- Selling my AEM EMS NEW!!! not used
- VSS Tuning
- EMS on 2.3l stroker?
- My first aem ems(sean ivey tuned)
- aem ems 2 step lunch help
- Maf Ems
- AEM users?
- Anyone Successfully Tune Rally-Style Antilag?
- AEM from EVO 8 To 9
- Parts for Converting Maf to Map?
- Question about AEM EMS
- afc?
- Clarifying some MAF to MAP wiring.
- idleing problem, please help!!
- AEM in the mail
- plugs? ignition system???
- gt30r + aem ems
- EMS boost control.....very impressed.
- sean ivy
- 35-2109, 3.5 bar or 5 bar
- EMS and knock?
- 1313 vs. 1313U
- o2 question
- Car runs better than stock ECU now
- Cam gears + AEM EMS
- I need a good tunner in florida please help!
- Car doesnt start for crap, need help
- Got a ? for aem user's
- AIT sensor wiring question
- Can someone look at my AEM datalog???
- Good Tuner Required
- Newbie Help
- AC Condensor Fan ?
- AEM uego question
- Can AEM be used as a fan controller?
- Utec Pro, but EMS newbie.. could i tune the EMS???
- Aem + Hks Dli 2???
- Where to begin?
- AEM EMS for sale
- Comport problems
- Wideband and AEM EMS
- AIT sensor and alky question?
- map filter
- aem ems gains
- Base Map and Beginnings
- 2 step rev limiter with 05
- which USB to serial adapter works???
- Off the beaten path
- Newbie to AEM
- Question about AEM, MAP Converson, Wideband, + Tpye of BOV
- AEM Forum NOW Back!!!
- Cant keep car running with AEM....
- Aem Is Up!!!!!! Finally
- Both Computer and Tuning Literate
- NEED base AEM map
- Re-Tune needed?
- Potential stupid question
- AEM compatible with Coil On Plug setups?
- AEM Tuner in Texas, Oklahoma, Kansas area?
- AEM instead of Emanage
- Problems getting started
- AIT Sensor Wires?
- aem ems tuners in socal
- TOP SPEED in GA
- Which MAP and IAT sensors work with the AEM EMS?
- Quick instructions in adjusting A/F map
- evo 9 tuning
- Need an AEM Intro. course...
- AEM programable gauges...
- Aem Ems V1.19
- Evo Base Map
- Internal Log Analysis
- looking for AEM EMS tuner in oregon
- when will AEM site be back up?
- Wtf
- Cold start help?
- looking to Buy: AEM Questions
- EMS and Mivec...
- Aem Tuning!!
- What are these things and why are they needed?
- AEM Forums down - need to download latest software
- Why can't we post maps?
- AIT Sensors
- Blown motor--opinions?
- antilag switch
- AEM ignition map
- AEM EMS Controlling boost Vs. Hallman MBC
- AEM EMS Questions
- AEM EMS or Custom Dynoflash?
- Precision Dyno???
- AME EMS and a batch of bad gas?
- EMS or custom flash?
- noobie question about AEM EMS install
- Finally....
- Iat Sensor??
- aem ems school
- knock levels questions.
- Got my AEM EMS!!
- what kind a BOV
- Guide to tune
- AEM tuning in Florida!!!
- EMS daily as driver
- air temp sensor
- recirculate & vta
- write up for wideband install?
- aem shift light
- Is My Aem Wideband 02 Sensor Not Calibrated?
- raw, pulse width , or duty cycle V.S. RPM
- EMS and PLX R500 Wideband
- Bad AEM box?!?!
- Using 1g DSM coil and igniter?
- AEM CDI2 Compatibility????
- aem ems on stock maf, pnp
- Can i use it for Evo VII (JDM)
- Help car wont start
- AEM right for mostly stock 05?
- UEGO question
- AEM EMS with current Mods
- Anyone using MSD Coils?
- EMS??? please read
- Knock Light Configuration
- srs and aem ems
- AEM on Evo 8 MR?
- Help - Misfiring
- newbie to the AEM...one question
- AEM Safegaurds for Alky/Meth Instructions
- newb to AEM, a few questions
- To AEM or not To AEM
- [Garage_Defeat] in Houston TX - July 21-28
- quick question regarding aem ems and 05's
- Rough Idle following 2 Step (boost building)
- Aem Ems Idling Issue
- AEM and meth
- Best Place in MD/Va/Pa area to get AEM TUNNING
- What voltage/psi do you get with AEM MAP sensor with the car off?
- What do the various Knock params in the AEM mean?
- What average HP gains?
- non-EVO tuner
- sputtering back...HELP!!!
- bad coils???
- Widebands compatable with AEM EMS?
- Trouble With Gauge style UEGO controller and EMS
- Aem Ems W/ Uego Fs...
- Tune for altitude
- New to AEM EMS - daily driver
- fuel maps
- AEM boost control
- AEM EGT sensor
- Who is the one of the best tuner?
