View Full Version : AEM EMS
- Anyone ever seen something like this in a log ?
- Tuning Mivec map
- AEMlog scaling
- Question about switchin back to stock for emission
- Few questions about idle...
- Need base to get car started
- AEM EMS Tuning in or around Nashville TN
- Base Map to get me to shop
- switched map and car wont start, help!!!
- computer porgram
- Extra Injector
- AEM tune?
- EMS isn't reading RPM's
- Should I
- high sporadic idle and "hanging" rpm..
- Is there a AEM Tunning Course
- Tuning for dummys
- How to turn on the AC fan?
- MIVEC map in AEMPro?
- aem/ windows vista??
- EMS tuners in WA
- Got AEM then blew motor while tuning
- How do I use a separate boost controller?
- Bad idle... please help
- Does the AEM EMS utilize the stock 02 sensors???
- Electric fan install?
- Can a "shift cut" be programed?
- Which boost solenoid are you using?
- Shift Light
- Twin fuel pump tune question
- engine "putting" randomly
- Just Bought EMS for my IX
- question about buying EMS
- Switching Maps?
- question about ems boost control
- AEM tuners wanted in portland
- I have a question about EMS
- AEM Serial Datastream Gauge
- cold weather starting with an AEM EMS
- Need help, swapped out AEM EMS to stock ECU, now throwing codes!!!!
- TPS sensor problem!
- Turn ac fan on
- Setting up a Two Step..
- Is this calibration safe to use?
- Any step by step install for Evo 9?
- CEL as a Knock light
- Setting up Knock control etc etc....
- Problem w/ AEM PEMS for Evo VIII
- Uninstalling the EMS
- EMS VS FCON V Pro?
- Lets Play AEM Trivia!!!!
- Do you Like Your AEM EMS???
- Aem Ems
- newb aem question?
- Aem Pros Tune In Please
- 50 trim base map?
- nitrous wiring question
- I Got Mase'd!
- Need cable from EMS to Laptop!
- Evo 9
- Need 2.3L w/GT35R Basemap
- 2step Doesnt work.... weird
- fuel pmup cuts off
- Injector fuel trim
- aem tru boost
- Base map
- AEM wide band
- Is this the right one????
- need map for ems
- ems problem maybe
- installing EMS
- AEM Certification Program
- Car stalling more frequently w/ EMS...
- aem ems to aem 30-4100
- 2 step each time you push the clutch in?
- Cars running lean
- new tune for lower and upper piping?
- Questions about e85 tuning
- Knock issue question
- Problems with the 05 evo AEM EMS??
- Aem Uego Wideband Problem
- Can my AEM EMS be expanded easily?
- During Shifts...
- Bosch o2 short lifespan...
- aem
- HELP Needed with UEGO and 1313U EMS
- 2STEP on EVO
- 2STEP on EVO
- need opinions on where to go
- How do I view logged boost and AFR?
- AEM tuners in texas?
- Anyone have a basemap? 2.3L Stroker
- AEM EMS Problems? What are there?
- 1st gear rolling @ 0% throttle with AEM EMS
- gm boost control solenoid
- aem ugo gauge help
- serial port card for laptop
- Want a fast startup time?
- Massive Problem
- If anyone needs a Cal file for Engine Start and Idle...
- Looking into building a racecar
- WR application question
- Need alittle help!!!!!!!
- Lightweight flywheel and stalling
- how to's?
- Which output controls the radiator fan? (Evo VIII)
- Dash Outputs
- A/C disabled, need help
- How are u tweaking ur aem to get better mpg?
- who has modified their thr. inj. cor. tbl.?
- I need a V1.19 map......
- AEM Tune for IX??
- can i up the boost and be safe?
- Need some help with A/C fan always running...
- AEM base cals for IX
- AEM Crank Problem??
- AEM Serial guages.
- Finally cracked my AEM EMS open!!
- Is there a evo specific aem?
- What does your A/F trace after shift look like?
- AEM EMS for the EVO-IX Released!
- AEM EMS good for a daily driven evo?
- Where is your map sensor measuring location?
- New to aem ems
- AIT sensor question...
- Backfire at WOT
- AEM EMS Boost Control Vs Greddy Type S Dyno inside!
- differance between GM and AEM
- Replacement O2 Wideband for AEM Guage type.
- car dies?
- knock volts when to worry?
- AC stays on???
- logging paremeter's
- AEM works, my power went from 390whp/312wtq to 443whp/393wtq
- starting fix for AEM EMS trouble
- Car wont start
- dload, who has it working well?
- boost solinoid
- base map
- Question about AFRs
- help with aem gauges
- Need some help/info
- help please
- setup for 03 2 step
- hmm.. Either UEGO reading double or AEM reading half?
- iat sensor
- Best alky kit using EMS?
- wideband install
- Running AEM on Cam Angle Sensor Only?!
- Cold weather = car won't pull @ WOT?
- best place to buy aem ems
- Does my log look aright?
- AEM EMS for the IX
- Ntls Setup On '05'
- cheapest place to get sensors + install help
- ems sensors
- new aem ems for sale cheap
- AEM Tru Boost Tips
- WTB: stock boost control solenoid from AEM user
- Can evo 8 and 9 use same EMS??
- anywhere in Atlanta, GA??
- Help!
- Intake temperature sensor info...
- Base map needed for JUN 272 cams
- aem uninstall
- Does anyone use aem ems on evo6 tme???
- Any Tuners or Experts near Cincinnati?
- throttle rises when lifting off accelerator?
- Injector timing?
- Aem ems radiator fan won't shut off ?
- Question
- Fellow Evo owner needs help
- Log, Log,...the Log
- Mabye someone can help
- Buschur's AEM package???
- AEM EMS...apple mac??
- AEM EMS and HKS DLI II
- AEM Twin Fire Ignition Module or HKS DLI II
- AEM EMS, 50 Trim, 1000cc inj =startup video=
- Getting the AEM EMS - Questions
- AEM with ebc question
- to AEM please help and frinds
- Fuel pump on/off
- AEM EMS for Evo IX??
- Please Help!!!
- any tuner help needed.
- OBDII & AEM EMS
- New AEM Electronic Boost Controller 30-4350 vs. AEM Add-On Solenoid 30-2400
- How to Configure my AEM EMS to use 1000cc injectors??
- AEM tune vid...
- EMS plus GReddy Informeter
- EMS Probelm
- SMC alcohol with AEM EMS WARNING!!!
- Help getting ECU up & running! Fustrated!
- gas tank level reads low w/aem ecu?
- EMS with AMS 1600cc injectors
- AIT sensor bung
- need an Intake for map conversion?
- inconsistant warm start up's?
- Boost control and wastegate pressure
- 02 sensor- need help!
- intercooler sprayer with ems.
- LC-1 Wideband to AEM
- aem and smc alky kit
- feedback on my logs...
- Can you use a 1.19 map on a older aem unit using the 1.11 or1.17
- How bad is 2 step?
- 2step didn't work, what did I do wrong?
- which pc card to serial card?
- secondary injectors
- HELP!!! Car won't start with new injectors, AEM EMS fried?
- electrically problem with ems
- hks dli / AEM ems
- GM boost controller hook-up and a question about saving the tune
- AEM EMS Cold Start
- EMS won't connect
- Boost Contol Help
- Boost control
- Can you just isntall a driver?
- 2 step help~
- with my ems...
- Future Set-up.
- De-celeration Table
- Pigtail for my MAP sensor
- A/C cycling...
- What sensor for the AEM EMS?
- anyone using aem 3.5 bar with MAF?
- **Learn To Tune!!!**
- Blue wire on wideband ...
- pricing on aem ems 30-1313
- quick aem ems help
- UEGO Controller mounting location
- Need EMS tuner near or around Philly PA
- wideband
- What Do I Need
- 5 Bar MAP wiring
- AEM Serial Gauge
- Estimated HP opinions~
- Need some logs
- Where to get tuned?
- Just Had AEM EMS installed but now...
- brand new aem ems with x-tras 4sale cheap!!!!
- Does the AEM have anti lag?
- wtb: 30-4100 uego & controller
- What did it cost you to install/tune ems ?
- Can anyone help me with a base map?
- Please look at my log
- Can someone look at my cal?
- aem uego 7 greedy e-01
