View Full Version : AEM EMS
- aem issue after i washed motor
- Logging Options
- AIM dash reading AEM
- AEM EMS how does it affect the OEM gauge cluster.
- where to get aem ems the cheapest!
- A/C relay turning on/off...any ideas?
- FYI: ACD error code and EMS
- How to setup NLS
- db9 serial connector pin location
- Jumping car on AEM
- AEM of stock ecu..?
- View my first AEM log
- Passing smog question..
- AEM EMS Tutorial Resources
- AEM Series 2
- push-starting an AEM-equipped car??
- Aem in Ny
- Which way to set up
- Trouble on first start of the day
- Idle "Hang"
- Need Help with 35r evo
- EMS connection problem
- Look at this log
- AEM EMS First time install
- Few AEM issues
- Boost control..what is current?
- Lean Spool.........what A/F?
- Compatible USB to serial adapters
- Coil Dwell Settings Help
- Cold start and E85 calibration!
- FullBlown/Double pumper wiring question
- Aem Ems Start Up map
- Lean idle/cruise AFR's after hard pulls.
- CEL shift light?
- Backfire then No start!
- A series of questions re: AEM EMS
- Problem with Evo 9 EMS - Burned 3 times already - Pics & LONG
- Passing emissions in VA
- AEM EMS+NYS inspection...... solution???
- aem start up map
- Fuel Injector recommendations
- aem ems question plz help
- Anyone using the AEM Serial Guage to read Fuel or Oil Pressrure?
- Aem Pencil Coil
- Car Sputtering, Due to weather?
- Starting problems... HELP!!
- David Buschur in Vegas tuning AEM's in December.
- Peak & Hold Injector Driver recommendations....
- Idle problem - advice needed
- Aem ems tuner??
- AEM EMS drivability?
- Fuel Pump problem
- AEM computer problems
- to much knock WTF
- Precision 1600cc injectors Battery offset?
- Buschur in Alabama?
- User Defined PW output setup
- Leaning A/R ratio?
- AEM EMS &small battery kit problems
- Battery dead? Do you need to sync again?
- idle death!
- fuel cut load with 3.5map
- AEM Startup map for 35R
- Need opinion
- boost control vss & hi/lo sw
- boost control map
- Too rich for a poor man’s evo 9
- ems vs wideband a/f
- AEM Serial Gauge Users Please Chime in!!!
- No Start
- Aem ems and Uego install
- Wide band compatability question
- Idle control not working
- How to properly set up NLTS with EMS?
- AEM EMS to Stock?
- Timing, Timing, and more Timing...
- Boost gauge is off 3psi than what AEM EMS says???
- AEM EMS Street ability
- David Buschur tuning in Vegas Nov 4-5-6th
- Coil Dwell, I don't think its right causing weak spark.
- ecu afr vs. W.B. gauge reading different
- Hard start ups when warm
- 4 coils setup
- Installing external switch for different maps for different fuel.H E L P!
- Another 2 Step thread
- little help here please!!!!
- 2 Step rev limiter
- Stock Solenoid Duty Cycle
- HOuston wa tuners
- Need a base map..any vendor would sell me one?
- Tuning E85?
- Problem With Knock Sensor feedback
- EMS sensor question
- Benefit From AEM EMS?
- AEM 3.5bar map vs. stock maf???
- WB o2 Sensor
- EMS timing values- 20 psi ,7k rpm's
- Pruven Performance AEM Install
- Colorado or Utah Tuner?
- Start up map. 35R stock block hks 272
- Tach
- Seattle Wa TUNERS
- Part Throttle AFR in boost
- Miss fire @ idle and running rich?
- Sensors on Aem ems for evo 8 and 9 interchangable?
- o2 sensor removal
- AEM without AIT and UEGO controller?
- AEM EMS 5bar vs 3.5bar MAP sensor
- Connecting LC-1/DB gauge to 1313 ems
- Can you use a switch to change maps on EMS?
- Anti Lock light on!!!!!
- Windshield wiper issues :(
- Fuel table question - EMS
- Help:Egt 30_2050 and knock sensor for EVO_IX
- Switching turbos, 30r to 35r, Do I need to make a lot of changes?
- EMS 1313 on 03 Evo VIII
- Switching to AEM EMS. A few questions?
- Ecu?
- Another idle question
- bucking and cut out?crazy crank and cam sensor readings?
- AEM+Meth ? MAP/AIT ?
- evo 9 aem differences?
- Quick Question!
- aem tuner south fl
- Radiator Fan
- Dwell settings on M&W box
- Timing Sync and Adjustable cam gears
- MAP Sensor Calibration
- AEM misfire problem
- Emissions Stuff I can throw out
- Saving some gas.
- GOOD! AEM Tuner in NC
- AEM Wont Log
- Tuner in VA?
- CHanging Injectors
- stupid AEM 1313u question concerning Uego
- help uploading a log file
- Scaling PTE 1200cc Injectors
- CAL file help
- reason for settings not selected?
- what laptop do you use?
- ecu off line?
- misfiring..... Yay or Nay?
- Oil temp and pressure sensor question
- 1000cc injectors with stock turbo?
- Evo sounding like a Suby?
- good aem tuner in wa
- Few logs...
- P0300 code and AEM
- where is the ecu ground wire terminated?
- EMS with Basic AEM UEGO Wideband
- Evap. Control
- Throttle Inj Corr Table
- long crank and stalling
- Idle questions
- HELP Car wont stay on**New Install**
- Help Connecting To Ems!!!
- oem Oil temp signal into aem ecu?
- Aem 3.5 bar map sensor problem with 3315 aem ecu
- BR FP3065, PTE780cc
- What level of cut for 2step?
- ign phasing / knock tooth correlation ?
- am i getting ripped off for install + tuning prices for my aem ems for evo IX
- need a break in AEM map for Evo 9??
- Horrible AEM tuning from the "pros"
- Aem On Evo Vi??????
- Aem Map And Air Intae Temp
- Evo 9 AEM EMS
- URGENT: need AEM software v1.19 and a way to get my map from a cd to my AEM
- Ems Drivability Question!!!
- wb 02 sensor placement
- acd lights with AEM
- aem newbie problems
- attn: anyone who drives a car with AEM in cold weather
- Caroline Residents *Attention*
- Using JDM Map Sensor
- Shutting off ac compressor
- how to connect aem evo8 ems to wideband??
- AEM User Manual
- aem ems with aem wide band sensor
- Yet Another Hard Start Thread
- Weird high idle problems TUNERS HELP!
- Boost Controller Creating a Boost Leak?
- "Open Source" AEM cals...
- Evo IX AEM locks up
- How much knock (V) is actually knock?
- NEEDED EVO8 BASE MAP (2.3L Stroker, GT35R, 1000cc Injectors, HKS 272's)
- Please look at this log Tuning guru's
- Boost Control...
- AEm tunner
- Cold start Warm start!
- AEM Tru Boost controller gauge help
- aem 3.5 bar map sensor wiring to aem evo8
- aem ems tuning
- fan speed ?'s
- aem guage cable question
- Help With Cold Start!!!
- Good reputable/experienced tuner w/AEM EMS in Nevada/California area?
- Timing With Meth
- Looking for people who've used "Big Al" to tune AEM EMS...
- ems starting problem**please read**
- aem tune southeast wisconsin
- Drivability
- No Lift Shift Question
- Pump Not Priming
- "AEM" Boost Solenoid
- stock motor 35r base map
- AEM EMS on stock block with 35r
- question on boost solenoid
- AEM 1320 (IX) and AEM wideband gauge problems
- EMS offline - not a new install
- anyone in the indiana or indianapolis area with much experience with the AEM's???
- Tomei Cams 260 Evo9
- JDM 3bar MAP sensor & AEM?
- problem detected..............aem evo 8
- Base Map 4 05' evo 8...please :)
- no throttle response after shift?
- ecuflash to aem
- Base Map for EVO 9 with bolt ons?
- couple questions about EMS!!!
- AEM & Factory MAP and IAT sensors?
- AIT sensor harness
- Base map for hks 3037 turbo kit??
- Aem Tunner in the Bay Area
- low-Z Injectors
- EcuFlash Mivec map conversion over to an AEM map
- map sensor???!?!?!
- Opinions - No Lift Throttle Shifts !!!!
- Problem with AEM EMS *HELP*
- Aem wideband location
- starting fix for Evo 9???
- idle problem
- Ignition timing - how to play it safe?
- AIT sensor location
- 1313 or 1313U?
- Misfire at high rpm, possible sensor issue?
- AEM and Emissions
- Stop mileage counting?
- Aem Uego
- Who tunes ems in Florida thats reasonable
- Air fuel ratio?
- aem ems affect gas gauge??
- connecting aem uego 30-4100 to 30-1320 EMS???
- Tuners by state?
- Serial gauge and laptop connection
- Base Cal request for VIII, 3065, HKS 272, 1000cc, 5bar map
- Who do you guys think is the best AEM tuner in the country.
- Lean and knocking getting on throttle into a gear
- lookin for a good tuner in CT
- AEM>HKS V CON Pro?
