PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28
  1. evoscan help
  2. Evo IX Utec
  3. AEM 3.5 bar map on power fc
  4. injector setting vrs ecu
  5. Fcon Vpro
  6. help!! need jdm tuner in fl
  7. thinking about offering my Stock ECU tuning services...feeler
  8. help me fix evoscan!!!
  9. how do i run 2 maps on a laptop?
  10. Overcame fuel cut & started logging
  11. Data Log Lab aka DLL errors
  12. Strange boost and A/F ratios need help!
  13. MAN ! What does it take to get someone to tune your car??
  14. 2 Step or Antilag
  15. Stock EVO IX MR... lumpy idle normal? Need some answers please!!
  16. stock ngk gap at .32
  17. UTEC Help Runing Rich At Idle
  18. The value of a tune.
  19. Motec Plug N Play Question
  20. Knock with 2.3 sroker Turbo XS Utec and Knock Lite
  21. i need some logging and tuning help!!!
  22. Which Falsh
  23. gauges on a radio?
  24. Not a harbor, but still a port
  25. AEM UEGO Acting funny
  26. MAFT Pro installed, problems
  27. Openecu as primary EMS with utec as secondary?
  28. HELP! EVO rough idle and stall & no full boost
  29. NOS what type EVO VIII?
  30. where to buy ecu jumper harness
  31. FS: Like new turboXS Utec
  32. Tune solve misfires?
  33. U-Tec for sale
  34. FS: Apexi Safc2 Special Edition Black W/ evo8 harness
  35. MSD DashHawk?
  36. FS: ECU+ "Wire-it-yourself" silver box
  37. SAFC2: Knock during deceleration/idling
  38. Using Two ECU'S
  39. Safe way to lean out w/ AFC?
  40. Speed density
  41. Which is better turboback, cat-back?
  42. Apexi AVCR settings help
  43. Finally eclipsed 300whp..
  44. UTEC Problems
  45. Apexi PFC tuning - From Kenya
  46. Need Boost Help!!!
  47. Boost Control Question/Problem?
  48. I want to get tuned...but?
  49. Results of fooling around with the stock BCS
  50. 04 and 05 transmission?
  51. datalogging ?????
  52. My Utec
  53. Please help
  54. Please help
  55. Zeitronix boost log - long decay time
  56. AMS tunes? (Atlantic Motorsports, not Automotorsports)
  57. Stock Ecu Swapping????
  58. SES with tactrix?
  59. IX Whp and Tq on Dyno Dynamics w/ TBE, MBC, and 20-22psi
  60. Just Got back from ISP
  61. pick-up errors
  62. So you STILL haven't purchased a Tactrix Cable?
  63. Hks 3037 kit
  64. spark issue?
  65. Ecu flashing error
  66. Serial to USB adapter that works.
  67. E-Flash (Dynoflash) Question or Two before writing to ECU
  68. 2003 Evolution 12 PSI?
  69. MAS cleaning
  70. questions
  71. some stupid question about timing
  72. Apexi Gizzmo's
  73. Mitsulogger
  74. Free Datalogger?
  75. How to go back to stock
  76. So Much For a BaseLine Dyno Run
  77. HKS mushroom causing knock?
  78. Cobb AP
  79. street tune/ part out question
  80. A/F measurement. Which O2 sensor?
  81. Anyone have this code before?
  82. How much would i make on the dyno?
  83. LC-1 / LMA-3 Users....Where did you connect for your power source?
  84. My exhaust fires flames, is it wrong?
  85. install ecu+/lc-1/ logworks
  86. Looking to purchase EcuTek...
  87. Utec log HELP!!!!!!!
  88. works p2e datalog
  89. For Sale Hks Ssqv Bov
  90. Lean AF at peak torque
  91. Dynoflash E-Mail Flash on the way!
  92. Can people post examples of various logs generated - in CSV format.
  93. speedelement tune?
  94. Anyone running MAP sensor on stock ecu or flashed ecu?
  95. need more help with the mas
  96. Access port release?? anyone know?
  97. Innovate exhaust clamp with LM-1 ?
  98. Overboosting problem?
  99. Restrictor pill removal necessary for ECU reflash
  100. P0171 Code Help!!
  101. help with maf
  102. s-afc??? help
  103. s-afc??? help
  104. Problem holding up the boost in my EvoIX
  105. Just Got Flashed
  106. LC-1 good start?
  107. EMS for Gt35r?
  108. selectable map tuning options?
  109. Engine knock problem
  110. HKS evc ez II boost controller few questions
  111. V-Manage
  112. profec setting problems
  113. Commander mount?
  114. Hks Ssqv Bov
  115. Tuner Question..queries question
  116. Is anyone on this Forum Running there car on a Wolf 3d ecu?
  117. Cosworth just contacted me about their new Evo standalone....
  118. Bung for LM-1 sensor
  119. Innovative wideband
  120. So . . . what's happening in this forum
  121. what computer mangment should i get
  122. Can immobilizer be removed?
  123. ECUtek... hp gains???
  124. ECUtek>s-afc.wat hp gains?
  125. Ecuflash vs Power FC
  126. tuning question
  127. New ECU+ feature: EVO ROM editing and map tracing
  128. My Dyno tale - Guidance from Alfred @ Tuning Tech and Jestr M1 flash...
  129. Need a tune
  130. werid noise when you crank the car
  131. GM map w/pigtail and map switch
  132. where are you guys mounting your bosch knock sensor?
  133. Beware the Dynojet Wideband
  134. So who else is tuning AEM's?
  135. Can this be done?
  136. possible whp from dyno flash?
  137. Super ITC
  138. Innovate LC-1 Compatible USB to Serial Converters
  139. Techgauges? Wideband suggestions?
  140. Power FC & AVCR problem
  141. submit content for the powerfc faq
  142. Cam gains before and after flash?
  143. Tuning estimate w/ ECUtek>s-afc(selling)!!!
  144. AFR'S and EGT's
  145. leaded or unleaded?
  146. s-afc removal???
  147. ECU Addressing?
  148. Hesitation at WOT, new WB and GM MAF
  149. Disabling CEL - Does it Still Register Knock???
  150. should i get retuned
  151. Dumb tuning ?
  152. IX Tuning Technologies Dyno graph - 91OCT
  153. just a noob question about logging
  154. Just purchase use UTEC need help
  155. UTEC vs ecu Flash
  156. Switching back to stock injector question.
  157. UTEC Plug-in
  158. Tuning Selection for Newbie
  159. pocketlogger
  160. boost solenoid removal...
  161. What do you use to run your race gas and pump map?
  162. Greddy Profec Spec B II too bright
  163. The stock 05 evo build has begun
  164. Orange County
  165. Problem after changing to Ralliart ECU on EVO 6 TME
  166. Any one has s stock IX AFR chart?
  167. Knocklink sensor
  168. Greddy V-Manage
  169. ECU Flash in Seattle Area?
  170. n00b question
  171. warrenty is fianlly gone, which reflash now?
  172. Anyone else get SES light from the Perrin cat
  173. Can someone answer this?
  174. "Service Engine Soon" light question
  175. Datalogging, knock, and Octane Flag reading...
  176. Cannot Reflash My Car!
  177. k i got a hks intake and ground kit for xmas
  178. AFRs too lean in high-load -> need fuel pump?
  179. got my new evo, I have questions about tuning and logging equipment
  180. 2.3L management
  181. Miami Ft. Lauderdale
  182. ECU Harness IX
  183. tunning for low,mid,high power?
  184. ECU Flash
  185. Map Sensor Kit
  186. wat to do
  187. loggin with ecuteck
  188. tuning changes (more bolts ons)
  189. Jester Tuning in Socal!?!?!??!
  190. problem with AEM wideband accuracy
  191. Switchable maps
  192. Which ECU?
  193. Wideband After Cat Accuracy
  194. Lift throttle knock
  195. GM MAP sensor trouble
  196. EvoScan Log: Help!
  197. WARNING: COSWORTH EVO IX CAMS SHAFTS... BEWARE... exhaust cam shaft does not align!!!
  198. got flashed
  199. MAP sensor trouble
  200. Dynoflash Custome Tune 320whp, 347wtq
  201. Ix
  202. TurboXS Love.. Mitsulogger 1.5
  203. Technical question about boost...
  204. Swapping front ECU
  205. Utec or Reflash?
  206. Too much boost!!!
  207. Apex'i ITC
  208. Cobb Stages?
  209. more knock and more logs + something interesting
  210. Tactrix-compatible firmware update available
  211. boosting
  212. When to replace o2's?
  213. Ideas on Ecu+ Knock Sensing / control
  214. stand alone ?
  215. log , any thoughts?
  216. check my log out
  217. hit wall while tuning last night (log attached)
  218. HKS 280 Cam timing
  219. Kingpin Performance??
  220. I/C Spray
  221. boost issue
  222. MUT-II diagnostic and logging support done
  223. Cobb Software
  224. Correct Pin-out For Zeitronix ZT2
  225. front oxygen voltage?
  226. Most Bang For The Buck?
  227. accessport release date?
  228. Evo 9 ECU Pinout
  229. Treo Palm Pilot Phone w/data logger.
  230. zt2 software
  231. install safc car not starting???
  232. fuel cut question
  233. Dyno graphs Wanted: Meth/Pump/Racegas. SAME MOTOR.
  234. Why Methanol can blow you up without a failsafe?
  235. Where is the OBDII port on an IX?
  236. Evo III OR IV parts
  237. houston, tx area tuner and dyno
  238. Which Wideband?
  239. any interest in silverbox Evo 8 ecu+??
  240. Offline map editing now working
  241. New GM 3.5" MAF support
  242. What should I do for a tune?
  243. air/fuel?
  244. What's the cheapest method for datalog (afr, knock,...) ?
  245. New used evo going on dyno need info.
  246. Any 1 for Mines ECU
  247. LMA 3 timing install
  248. Look at these logs please...
  249. ECU+ for logging only?
  250. EGT probe adapter
