PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28
  1. 850cc Injector Tuning Questions
  2. Will the PFC L-Jetro (2003) work in a 2005?
  3. EcuTek & Vishnu need advice
  4. any budy running the ECU+
  5. Autronic sensors
  6. Dynojet Question
  7. Confusion HP Score on Dyno
  8. Nitrous and Utec?
  9. Please, help with tps, i'm in total confusion......
  10. Stock ECU question
  11. stock exhaust dia
  12. Just A Little Bigger Turbo?
  13. Flash Preparation Thread
  14. quick Open Loop Fuelling question on Map1
  15. Final Tune Results!
  16. MPS_UTEClogger 2.3
  17. My First time tuning my car
  18. Calibration for Kavlico sensor
  19. 4th gear map 1 log
  20. Utec's 2 step take out cat?
  21. Need info on UTEC tuning basics...
  22. when to switch maps with different octane
  23. Autronic PnP board for Evo IX?
  24. Where should I mount my wideband o2 sensor
  25. Gold e-manage mod????
  26. a little help with my timing
  27. DSMLINK need help!!
  28. MalibuJack, what software are you using to graph HP vs. RPM?
  29. Turning with the Wideband
  30. how to hook up the sensors on the power fc?
  31. HKS Vpro or AEM? So confused!
  32. Autronics autotune Vs. vishnu smart
  33. AEM EMS-Precision Dyno
  34. Need Advice On Tuning My New Cams And Gears.
  35. Turbo XS must be close....
  36. which turbo timer?
  37. wtb: autronic
  38. Safc I or II
  39. UTEC for Dummies
  40. Passing Emissions with S-AFC
  41. Crazy idea about MAP conversion
  42. dynoflash vs turbotrix reflash
  43. Need Help Deciding Where to Tune???
  44. I need a good map
  45. Anyone mess with the low throttle fuel settings?
  46. newbzie question-
  47. Pocketlogger results
  48. Datalog a 03 and 05 evo
  49. I'm getting my UTEC Drunk
  50. What should I expect WHP with...
  51. UTEC logs - observe and diagnose
  52. TXS stage I/II maps
  53. I need a tuner lite
  54. Tuner lite compatability question
  55. What ECU w/ turbo upgrade???
  56. 23 PSI at IDLE
  57. What all is needed when running this system
  58. Perrin Shortram and Boost tubes
  59. safc II WITHOUT upgraded fuel pump or injectors
  60. cam gear settings question??
  61. Alcohol injection & SAFCII
  62. procedure for MAP based tuning
  63. Running on 90 RON!! Need Help!!
  64. rev/boost/fuel limiter removal then S-afc tuning
  65. Help with injector lag value...
  66. timing=good in gears 1-3, knocks in 5th in same load cell -- now what?
  67. boost loss
  68. Profec B-spec II question
  69. Turboback install??
  70. What System???
  71. Map 0 / EBC@20psi log
  72. got some questions about utec with flash
  73. Sorry if this is a stupid ??
  74. where to mount the commander?
  75. Please explain the optional MAP sensor
  76. Has anyone tried this software with an Evo?
  77. Dyno
  78. Pinout / Wiring Diagram For EURO Spec EVO 8 ECU
  79. MDP sensor and Power FC on Aussie EVO 8
  80. Issues with tuning in 90+ degree temps?
  81. Best Cam Gear settings for 272s?
  82. MBC or ABC with Utec
  83. Initial SAFC2 Settings
  84. Unichip
  85. Looking for Quality Tuner in NJ
  86. verticle FMIC?
  87. To anyone using the tuner lite
  88. evo 7 output question
  89. FS: Brand new EManage and Support Tool
  90. Standalone Engine management and Emission/inspection
  91. SAFC with flash??
  92. Starting Map from a WORKs flash
  93. wideband and a/f ratio
  94. HKS KANSAI OR TOMEI ECU for GTA
  95. tunning place in CA
  96. PLEASE HELP me with my profec B spec II
  97. MAP load maps? And tuning timing question.
  98. My HUGE discovery in the Utec... mainly for drag racing
  99. SAFC Tuning with Logger
  100. what to do for engine management??
  101. In car tuner question
  102. Tuning places in AZ?????
  103. Fuel Cut?
  104. running over 400whp with the power FC?
  105. S-AFC II Question
  106. TPS and injectors recognizing.
  107. Owens Developments cast manifold
  108. Looking For The Best Cold Air Intake... Anything Good Out There...
  109. Knock sensor
  110. retarding timing: UTEC more aggressive than stock?
  111. rev limiter
  112. got questions
  113. Knock Count 1
  114. power fc max boost
  115. Dyno Plot smoothing for the mathmatically inclined.
  116. Timing with 272's
  117. tap for wideband O2?
  118. Element Tuning/ Hydra EMS
  119. Run UTEC with AC Power?
  120. Is low throttle supposed to fluctuate?
  121. Confused by flickering CEL light
  122. UTEC MAF problems
  123. expert opinion--reliability with Power FC
  124. tuning generalities for aftermarket turbos
  125. What should I spend my money on?
  126. can you read knk with s-afcII?
  127. Anyone want Apexi boost controller?
  128. Apexi SAFC II for sale!!! $150
  129. Tuner Lite Question RPM
  130. dynoflash
  131. Evo9 Head on evo 8
  132. High Boost with Bleed Valve?
  133. A little frustrated with OLF
  134. Please help, I need a map for now!
  135. getting a Power FC
  136. General tuning chat
  137. Map sensor installed
  138. question about cams Again
  139. whats your timeing look like
  140. low throttle setting
  141. Quick Question... please help!~
  142. EcuTek.. new information?
  143. My lame-a$$ street tune
  144. SAFC Reading RPMS Incorrectly
  145. Timing and overall performance help: log inside
  146. n00b safc question
  147. Stutter launch info
  148. UTEC is in: 3rd gear log w/Dynoflash basetune -- comments?
  149. external MAP calibration
  150. Anyone try this yet?
  151. air/fuel mixture 101...needed
  152. how come the AFC killed my idle
  153. Timing for a good idle help
  154. cant run utec without MAP
  155. Knock Question and between shift stutter
  156. Boost control question
  157. AFR Rich after tt custom tune
  158. efi 101 class
  159. Results with the Autronic?
  160. Question about using OLF with a flash already scaled for larger injectors
  161. tuning with lm1 and s-afc2?
  162. Can someone check this data log for me??!!
  163. Simple question about clutches
  164. Just got my new UTEC -- some starter questions
  165. It has been proven (better performance)
  166. Couple Qs about the tuner pro and the tuner
  167. greddy type s bov adjustment
  168. Timing
  169. Need Help Quick Please.
  170. When you left off gas, car idles poor but bliping the throttle will make it better?
  171. Splicing Fields Harness?
  172. point me in the right direction for a logger
  173. Just got my used tuner pro... need MAP sensor and o2 bung
  174. S-AFC II settings?
  175. quick question
  176. anyone know how to tune greddy profec b boost controller?
  177. Some thoughts on the newer ECUs and Vishnu active tuning
  178. Max Karman readings?
  179. what to do about Cold Start???
  180. Next UTEC firmware upgrade??
  181. what do you guys think about these features for a standalone?
  182. SAFC with flash ecu
  183. Pocket Logger ODBII - Which vendor has these?
  184. mail-in flash: dynoflash or turbotrix
  185. GT35R and Utec
  186. Close Loop Boost - Spikes in high gear
  187. Knock question
  188. autronic
  189. a few last minute questions before buying UTEC
  190. low throttle timing
  191. Would I need the Tuner if I get a UTEC?
  192. utecwshift lites,map mod map selector/tuner pro 800.00
  193. Tuner in GA
  194. Dealership approved mod sticker
  195. Ralliart ECU
  196. Info about Pfc on Evo VIII GSR
  197. utecwshift lites,map mod map selector/tuner pro 950.00 shipped
  198. Tune Utec w/ Mac?
  199. Questions about the Autronic
  200. Can my UTEC controll my nitrous???
  201. Load Sites with MAP sensor???
  202. cold idle/idle problems. please help
  203. need ECU
  204. Need ECU
  205. ABC Valve?
  206. Modding in New Evo 8
  207. p0300 dealer flash is messing things up
  208. Dyno tuned w/ bov hose loose
  209. MAP sensor question...
  210. typical A/Fs for lean versus rich conditions??
  211. Newbie Utec problems
  212. My "professional" tune!?
  213. What are you thoughts of Vishnu's new auto tuning?
  214. afc settings w/ flash & race gas
  215. Tuning sites
  216. Alcohol injection Tuning Tips??
  217. More tuning woes
  218. F/S Tuner Pro
  219. UK Tuners
  220. Changing plugs more often than my underwear!!!
  221. Putting in bigger injectors
  222. S-afc
  223. To stay at 11.0-11.5 a/f's
  224. bad misfire
  225. WORKS reflash question
  226. Switch to MAP sensor?
  227. reading AFR with LM-1
  228. Map Watch capture..... can anyone help?
  229. Newbie
  230. Should I purchase a UTEC?
  231. UTEC b/c with turbo upgrade
  232. Will go with 280's/Bushur21G/Alchohol inj!
  233. experiance of ecutek?
  234. I guess this would be the right area for my ??'s
  235. Anybody getting knok in 5th gear under load?
  236. 272's with Alky, or 280's with RS turbo? Help!
  237. next mod recs? where to find hotside?
  238. Splicing turbo timer onto Fields Harness
  239. HI/LOW% part throttle transition for auto-x
  240. Any tuners care to look at this log?
  241. Anyone running Ecutek yet?
  242. Stock 02 Sensor Help!?
  243. Need Help!!!!
  244. whats the best piggyback and turbo back combo?
  245. engine light/o2 sensor
  246. Karman Frequency
  247. CEL fix for test pipe...
  248. Horrible fuel pump problem
  249. E-Manage & Apexi AFC II
  250. Emanage options
