PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28
  1. rattling tuner pro......
  2. Apexi Boost Controller Settings?
  3. Suggestions for Tuner Pro knock settings?
  4. question???need answer or opinion
  5. self learning throttle?
  6. aftermarket comp/obd/piggyback
  7. RS-R gt2 Exhaust & DP w/ UTEC
  8. How do you feel about the Apexi BOOST CONTROLLER
  9. Turbo Trix vs Dynoflash >,<
  10. 05 GSR safc settings
  11. Please look at log for EGT and WB o2s
  12. UTEC setting Check Engine lights ramdomly?!!
  13. Topspeed In Alpharetta!!!!! Great
  14. What Dyno numbers have you guys Gotten With the UTEC?
  15. Hks V-pro
  16. Power FC and alky kit
  17. NEW APS 3.5" turbo back exhaust Q's NEED HELP ASAP!!!
  18. *** UCC Release 4 now available *** (part 1 of 3)
  19. Can 04 Ecu be reflashed for 05 evo?
  20. AEM power packages
  21. 0% Load column tuning woes
  22. tuner pro RPM input
  23. Map sensor with utec
  24. orientation of 4 pin molex plug for external MAP sensor
  25. ECU+ forum - Yes or no
  26. Newbie in need of help and advice with turbo kits
  27. Any Autronic EVO's in Bayarea
  28. placement of the utec knock sensor
  29. No Lift To Shift - Ecu Hunt
  30. Base maps?
  31. Where to get my UTEC installed and tuned?
  32. Boost gauge
  33. Just got my UTEC today with remote switch...
  34. Looking for gas mileage....
  35. How much timing adjustment can I do?
  36. Buschur AFC II and non-Buschur TBE
  37. EGT Temps??
  38. Dynoflashed + UTEC = ?
  39. need immediate help! can't get LM-1 to datalog rpm...
  40. Do any vendors offer a 280 flash?
  41. Stock ECU Bracket? Help :(
  42. Best tuner in florida
  43. ECU tuning after Perrin Intake?
  44. Zeroing out the Emanage?
  45. got a utec
  46. Stock MR w/S-AFC Logs
  47. Bung location
  48. anybody know what this is??
  49. MicroTEC
  50. S-afc Ii
  51. Blitz SBC i-D (Sequential Boost Controller i-D)
  52. timing question
  53. About to order UTEC what else is need
  54. Whats the difference between these to?
  55. Blitz R-Fit
  56. Apex-i boost controller and PFC
  57. Ecu+?????
  58. Old safc install, not safcII
  59. What are these ECU upgrades???
  60. Safc II Wiring Problems with Apexi boost controller
  61. weather compensation?
  62. New to logging please help
  63. Which Inputs Would you guys prefer?
  64. I have some UTEC questions
  65. Apexi PFC maps. HELP ME PLEASE
  66. look at this log, ok?
  67. the best for my wants
  68. Which Motec for EVO VIII ?
  69. Intermittent problems connecting PC to UTEC
  70. UTEC Serial Cable help
  71. Will maps work on new car??
  72. ..solder connections, poor idle
  73. Tuning and engine management 101.
  74. Advantages of a blowthrough MAF with the UTEC..
  75. Launch control not working
  76. Another Faulty O2 Sensor?
  77. 264/264 cams, stock ecu, and tuning
  78. Should I install the e-manage
  79. Emanage+E-01=no problems?
  80. ??? on the peak feature of S-AFC II
  81. This is fuel cut! Log attached
  82. FIC Injectors Question...
  83. new greddy emanage??
  84. Finally solved the WOT "burp" hesitation prob!
  85. does this happen to you
  86. Atlanta area dyno day. UTEC tuner.
  87. UTEC Handshake Problems
  88. just tuned question?
  89. Where can i buy this Apexi Boost Gauge?
  90. how to read this ?
  91. Big Thanks to Jermaine @ Turbo XS
  92. help for a beginner...
  93. L-Jetro Conversion
  94. Biggest Injectors with SAFCII
  95. jumpy feeling
  96. AMS Water Injection
  97. cam gears
  98. Tuning in an intake...
  99. Settings
  100. small help please
  101. Flash vs SAFC
  102. SAFCII knock reading
  103. Stage 1(TBE) map stalling?
  104. 325 code (knock sensor)
  105. how much awhp do you get with safc on stock engine and basic mods
  106. How to maximize power with Apexi AVC-R
  107. HELP!! S-AFCII & Check Engine Light
  108. Running lean
  109. what a/f are you guys at?
  110. AMS Turbo article .
  111. Anyone running derekdevises meth inj on their evo?
  112. Jack
  113. UTEC NEWB here
  114. this is a dumb one
  115. quick question
  116. safc ii setup question
  117. Need Help !! ??
  118. cheap fields harness
  119. Stock ECU Location ?
  120. Evo 3 Ecu...
  121. MAP Sensor Install
  122. MAP Sensor Q's
  123. PDA Scan Tool/ Data logging Ques
  124. AFC or GM mafs
  125. Can Anybody Interpret This Log File?
  126. S-AFC Troubleshooting
  127. support tool
  128. Newb Question.
  129. what hp/tq should i expect w/mods
  130. how to avoid detonation during the tuning process??
  131. Dont change the Fuel you were Dynoed on!
  132. Ingnition question
  133. ?Turbo upgrade and engine management?
  134. safc harness
  135. HKS Twin Power
  136. jumpy pully pushy feeling???
  137. Evo fuel question
  138. check ou these logs too rich still? stock injectors stock pump ? all on 1.4-1.3 bar
  139. DYNO 05' GSR w/ apexi catback, boost controller, and AFC. is it worth it?
  140. Rich spot between 4-5k
  141. safc default password?
  142. knocking on safc over 100 at wot?
  143. Evo Warrenty
  144. Zeitronix Questions
  145. Need help with Greddy E-01......
  146. quick. best size spark plug wires for 4g63?
  147. Random problem, maybe associated with launch control?
  148. S-AFC II install wiring trouble..... HELP PLEASE.
  149. Datalogit?
  150. what boost control do you use
  151. Abc...
  152. what is your throttle setting at?
  153. Turbo Guide
  154. Race Gas Versus Alky GT30
  155. Exhaust Heat Shield
  156. F/S: A'PEXi S-AFC I --- $150 shipped
  157. Tuning Help !!!!
  158. What system should I go with ??
  159. wiring - solder or male/female clip?
  160. Hey Jack............
  161. Security activated
  162. Dynoflash clarification needed
  163. XEDE? Flash? Reflash? Confused Help.
  164. Anyone running a crank pulley with their UTEC?
  165. Knockbox equivalent for EVOs?
  166. SAFC install with Harness help?
  167. UTEC Tuning Problems - PLEASE HELP!
  168. What software are the ECU flashers using?
  169. What are the EVO VIII stock AFRs?
  170. most power on safcII
  171. stock '05 on Mustang dyno...anyone?
  172. Help With Afc Ii
  173. Strange cut-out
  174. New UTEC and now...?
  175. S-AFC 2 help
  176. Can I use SAFC2 with my PFC to tune seperate maps?...
  177. just curious of those with emanage on Evo
  178. S-AFC II - how to splice wire
  179. Tuning smooth idle with UTEC and Cams
  180. Evo boost Taper
  181. D-Jetro Power FC sensor kit.
  182. Boost restrictor pill question??
  183. Greddy Emanage Tuning Locations
  184. Tuning with UTEC
  185. who's got the how to install SAFC?
  186. transfer error
  187. HKS Carbon-Ti Exhaust and downpipe wanted
  188. utec tuner question
  189. How much boost are you all peaking at w/ race fuel?
  190. How does your car run with an SAFC?
  191. Ppl In Ky,tn,va,nc Willing To Travel To Get Their Ecu Flashed
  192. Advice on UTEC
  193. help
  194. safc settings
  195. A little Dyno knowledge goes a long way
  196. For those using the HKS TT type 1
  197. Zeitronix Wideband 02
  198. DTEC and the PSP
  199. THe BEST ECUs out there.
  200. False stock Boost Cut??
  201. Load Of Cra* :)
  202. anyone has a profec e-01 on there evo?????????????????
  203. Will not go online
  204. perfection motorsports is hosting a turboxs tuning dyno day
  205. Injector scaling question??
  206. When should you buy ARP Head studs?
  207. POWER FC settings
  208. Well, the gt-35 is in, UTEC tuning time..
  209. How capable is the E-manage?
  210. UTEC ruined my day big time.
  211. Using TXS's Stg 2 map safe for daily driving?
  212. MAP 1 Knock
  213. Power Fc Whp???
  214. UTEC/ABC & boost spike?
  215. Can't say enough, H2O injection!!
  216. chart for VTA correction on a/f management
  217. ECU + Is anyone using this ??
  218. need help with BOV Whistling. and boost flux
  219. Software update switch position?
  220. Greddy Profec or Apexi AVC-R
  221. Purchased UTEC + TXS TBE!!
  222. What the hell?
  223. Lets see your fuel maps w/cams
  224. S-AFC II someone have a .pdf of the user manual?
  225. What are some of the top evo tuning companies?
  226. f/s SafcII
  227. asking a long shot question
  228. Can the ABC effect idle?
  229. boost issues with UTEC/ABC
  230. EManage, just want it to work!! HELP
  231. Which is the best Xede,Utec etc ?
  232. which VP racing fuel? O2 sensor probs?
  233. HKS computer ?
  234. UTEC advance timing/Xede retard Timing
  235. Injector question
  236. Question on tuning...after being flashed.
  237. whats going on with open loop???
  238. boost leak need help
  239. Anybody notice this??
  240. Zeitronix LCD install location?
  241. hks 272 vs. 280 camshafts, which one is better?
  242. F\S: SAFC II $200 shipped
  243. i need help
  244. Fuel Cut fix question?
  245. All Evo's aren't created equal
  246. SAFC2 info
  247. best setting for PROFEC B-SPEC2
  248. What happens when you reset UTEC?
  249. PLX or LM1
  250. UTEC ABC install?
