- Which engine management product?
- EVO IX SSL Weight?
- Lc1
- Rev matching knock
- Need Help Installing Wideband
- Stock map plz
- 06 IX MR log
- base ignition timing?
- Walbro 255 Fuel Pump
- fp evo green & 780cc inj NO TUNE
- utec
- Opinion on hp/tq and a/f graphs
- I need a tip please
- Question: Removed DynoFlash tune and set back to stock
- Power FC Map Sensor
- Evoscan will not connect.
- turbo mirage
- Will someone view these logs for me please. . .
- Intake Temp Sensor
- inductive/cdi discussion
- SpoCom Article
- Urgent Hks Blow Off Valve
- Official EVO AccessPORT Information from Cobb Tuning
- logging issues with windows 98..
- Comparing Innovate LC1 to AEM Uego
- Zeitronix signal wires ...
- evscan airflow/rev units
- WTB! stock IX ECU
- 2 step/anti lag
- Autronic Flat foot shifting
- HYDRA or AEM EMS
- afc ?
- Tunning places
- Car running extremely rich just in stalled WB o2 censor just ruined it running it ?
- I need help finding a RELIABLE AEM EMS
- Innovative wideband wont work.
- Help 21 AFR ???
- Help..Stalling with stock BOV
- Cobb Tunning
- Po172 Need Help
- Any DFW Autronics tuner's??
- ECU+ is the best logger EVER!
- Trouble code po172
- thanks atlantic motorsports great tune*****
- Access port install Evo8! WOW
- evoscan logging in a 99 eclipse gst
- Frying Widebands
- Searching for tuner in New England RI area anyone know of anyone ?
- IveyTuned my evo VIII
- Hks V-pro
- Ams Dyno Tune
- Can I Adjust My MBC While Having A Tune?
- What is the best air intake for EVO9?
- Tuners in Austin, Houston, Dallas???
- where to get autronics @ and how much
- nippon denso 560cc injector latency
- New ECU+ software firmware
- how many of you who have gotten tuned, log your car after the fact?
- VTA with a MAF Translator?
- Reflashing a stcok ECU
- Running Weird Question
- Tuning beyond WOT
- Unusual load reading observed during datalogging
- Another PFC IGN tuning.
- ecutek numbers?
- just put an injen intake
- bad afr's....
- EVO III low boost
- Can MAFT Pro control Meth
- Afr
- AFR in the low 12's
- Who needs an ams tune in hawaii
- What is this on the motor?
- xpost: Need help with ECUFlash, possible issue with Injectors scalling or fuel map
- evo dies
- Cheep UTEC!
- After Mivec Tune (Service Engine) Light turn on
- ECU patch harness evo VIII
- Zeitronix and Vista users....
- Reputable Shop Tune VS Local Tuner Tune
- COBB EVO AccessPORT released and DYNO results
- AP service bulletin
- Initial settings for 4.89
- PFC for EVO 3
- Evoscan question
- I need a tune in the Tulsa, OK for my new 50-trim Kit **HELP**
- Problem with bigger injectors and utec....please help!
- Problem...please help!
- FS: ECU + $395 shipped
- bigger intercooler now getting knock
- Utec map selector for sale
- Whats max power b4 stand-alone?
- Start Car up..Idles high 3000 RPM (Help)
- Evoscan / Mitsulogger / ECUFlash / MAFT GEN2 Help!
- engine flush
- Pop Quiz
- Datalogging options? Noob needs help
- Evo Tuners with boost hose pills
- New to PFC
- Anyone running VP Import Race Fuel
- Tuning 101
- Cobb Access Port!!!
- ok tried this in the general section..cat to testpipe
- Tuning
- Apex'i NEO & Aquamist HFS-5
- wideband vs afr meter
- Need help New to logging
- immobilizer help
- Vishnu Reflash
- Tuning Schools
- what should i go with
- very new to this
- EvoScan v1.0 graphing?
- MaftPro with Reflash????
- Getting a Tune
- Flash question
- Need a tuner in south florida
- FS: UTEC, Tuner, and MAP Selector
- EvoScan question
- utech for sale in Michigan
- Loss of power at low rpms
- 780's with a 35r?
- Idle
- Fuel Capacity - Racing Cell?
- aem uego
- ACT street clutch kit or CARBONETIC super clutch
- Help... Got an Older Turbo Timer..
- Want to Get My EVO IX MR Tuned near CHICAGO
- New website is up! Mellontuning.com
- MoTec Ecu for Evo's - Standalone or PnP units
- reflash + cams or Intercooler? which would u choose first?
- 08 Lancer Running Lean?
- Race Gas on 93 tune
- Is someone runnig a cut-out exhaust?
- Looking for Tuner
- AFR Kit for electronic guys!
- hallman boost controller is it worth?
- Should I use a boost controller for this setup?
- ecuflash questions
- saving and switching maps
- Load vs TPS vs Efficiency
- Which flash/tune???
- Is Shell V Power all that ???
- Load vs. Load ???
- Evo Questions help plz?
- Dyno2003 Engine Simulation
- Enginuity
- How low does the AEM UEGO read? (richie rich)
- Any UTEc users using MAFT pro?
- Injector signal oscilloscoped?
- California Tune up
- General Tuning Question Regarding Flashes,Piggybacks
- necessary to tune for new setup?
- First trip to the dyno - EVO IX SE
- Some questions before i start modding...
- Reflash best bet for one time tuning?
- What about this setup?
- camshaft timing help
- NEW FP GREEN, setup doesn't produce expected power!!!
- Need to get tuned!! I live in NEW HAMPSHIRE!
- Cold Start Idel Problems With Hks Eids
- AMS tune "Very pleased'
- HKS EIDS Type K
- Another IVEYTUNE Happy Customer
- power fc (map sensor)
- Inital Start Up
- how much can i lean out on c 16
- Error code and CEL!!! Please help!
- Best Injectors for EvoGreen setup
- Help with Exhaust Manifold
- Need some help stage I and stage II maps nocking
- trying to use a narrow band A/F meter
- Wide band O2 sensor question?
- SpooldYou's Part Out
- tuned by CBRD today
- power fc -switchable maps?
- hks turbo
- After market ECU
- High Coolant Temp?
- Ses/cel Po136
- Need some help, Map knocks in 4th.?
- Any tuners in the NW who can tune this bad boy?
- Help with evoscan...invalid serial?
- Water Temp Increase
- speed shop
- Could the tune be the problem?
- A Trade My Utec For A Stock 2003 Evo 8 Ecu
- is tuning required
- utec shuts car off?
- please help car not starting!
- wtb utec cable for laptop
- Apex tubro timer wiring ???
- Boost Level Check
- Need help in southern cali
- Kind of stuck with ECU situation
- Please Help Me Out Asap
- P0300
- Rich Fuel
- utec tuner
- reading knock sum
- Greddy V Manage
- EvoScan Glossary
- How to change two step launch limiter rpm
- Low AFR's using Evoscan
- Fs:TurboXS Utec
- FS:apexi Safc/avcr
- is there a evoscan for dummies??
- Good Tuning Books?
- Has anyone here have been tuned by nate?
- Turbo sounds like Supercharger?
- problems with evoscan v0.99
- Utec 4 sale chicagoland area
- Boost Controller Kit Help
- help deciding
- EvoGreen and BC 272's
- Fuel Pressure / IPW Fluctuation
- Ecu
- Gauges to keep an eye on my engine
- EVOSCAN vs PROSCAN which is best??
- scaling 660cc injectors
- Need Help with E-Flash InformatioN!! Plz!
- ECU Reflashing?
- **350z Guy here Need Help Tuning Apexi AVC-R
- Coworth cams and EcuTek
- Eclipse V6, Karmen type sensor?
- Need Replacement Connector for Greddy Profec B Spec II
- HELP!!! Unknown issue caused -30whp "blurp" on dyno
- gripe about horsepower numbers
- Help!
- TTP Tuned?
- Evo VII ralliart ecu
- Funny looking dyno graph inside!
- Reading the stored values in the ECU
- Delay in WB02 readings?
- Tuning and Injectors Question
- Autronic standalone for evo 8 for sale
- Max MAF signal with alcohol?
- [Need help] Problem with throttle position
- HELP! Evo Tuning in Illinois??
- tune at LSE Performance
- Will my car make it
- Tuning conservatively on meth
- is a re tune required for upgrading downpipe?
- HELP!! Looking for TACH signal, where is it?
- SES LIGHT? Can EVOSCAN pull the code?
- Is It a General Consensus?
- Can someone process (power) my Zetronix Log?
- Need help
- tunning
