PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28]
  1. UTEC vs. DYNOFLASH!!!
  2. Apexi SAFC II display options?
  3. UTEC Dashboard for PocketPC
  4. UTEC-SD v1.0.0 Now released!
  5. How hard is it to change maps pump to race gas??
  6. Catless Question
  7. Knock
  8. Post your 3rd gear DATA1 Log Pull..
  9. Release date for rev 1.4 utec firmware
  10. Data Log Lab Version 1.4.1 Available
  11. emanage extras
  12. UTEC Map Yields 279whp on Buschur Stage 1
  13. Power FC Install Tips?
  14. UTEC vs. EXEDE
  15. Hey Jack, hows that new MAF sensor???
  16. Power FC Help...
  17. Map sensor, and load reference
  18. UTEC Digital Dash ALPHA RELEASE!
  19. What exactly is injector scaleing
  20. UTEC Makes Horsepower...
  21. Is utec appropriate for me?
  22. closed or open loop idle
  23. Check Engine Light
  24. PowerFC Laptop Interface
  25. went to Dyno-comp on saturday. Results.
  26. satisfied with your UTEC?
  27. Power FC Question?
  28. next stage of maps
  29. next level of mods
  30. 1st dyno after tuning with UTEC
  31. Who else got fried coil packs with the Emanage?
  32. TurboXS Downpipe Help
  33. HELP !! utec won't accept changes to basic MAPS
  34. Question concerning my UTEC log.....
  35. Data Log Labs users (and My evo's HP)
  36. MalibuJack
  37. Quick question
  38. Thread -O- Maps (post 'em here)
  39. Got my UTEC today!!! anyone have any air intake recomondations?
  40. Knock and Boost Creep
  41. Can Utec be used to log base fuel and ignition maps ?
  42. Open Loop Fuel Control?!? Soon?
  43. you wont believe what i did with my UTEC
  44. Utec & Pruven
  45. Questions...
  46. Tuna installed
  47. question for utec users
  48. Emanage Clone Cable Source!
  49. UTEC passing emmisions
  50. Opinions of the L-Jetro for daily driver duty...
  51. boy, this tuning thing is getting interesting....
  52. knock detection, stock ecu VS utec
  53. Very minor bug in TXS Tuner interface
  54. Normal AFR's
  55. TUNA w/ knock sensor and UTEC MAP Sensor INSTALLED
  56. MAF calibration question
  57. looking for a reflash
  58. Stand Alone?
  59. Apexi PowerFC D-Jetro Systems
  60. Wideband O2 sensor
  61. New UTEC user with rpm scale question
  62. Is my Innovative Wideband compatible with the UTEC??
  63. Should I use the E-manage on my Evo 5?
  64. UTEC for Evo 5?
  65. Data Log Lab Beta Testers Required
  66. Anyone Elses car do this with the UTEC? (Pics inside)
  67. Knock counts @ 4500-5300 rpm
  68. My first datalog, can someone explain the funkiness?
  69. Wrx Utec!
  70. what gives?
  71. MAP Sensor
  72. AutoLogger. Another utec logging software.
  73. I need Datalog files
  74. UTEC + Flash?
  75. Can some give me some info on tuning devices?????
  76. Sold on UTEC
  77. data log minus typhoon original settings
  78. took off my Typhoon and re-installed stock intake
  79. MalibuJack's UTEC DigitalDash
  80. Newbie friendly??
  81. ECU + cam
  82. Why no Load Site 100?
  83. water injection
  84. GUI based playback program
  85. Something's wrong.
  86. my wife hates the UTEC....
  87. TurboXS EVO race gas dyno plots
  88. UTEC Launch control
  89. TurboXS tuner questions
  90. Damn I'm Happy
  91. Emanage
  92. Just tuned at turbo trix
  93. Anyone using the ARC intake with the UTEC
  94. TXS UTEC and RFL-Ti On the Way
  95. Ray's UTEC studder transition log
  96. can we get an update on the MAP kit and Gameboy adapter..
  97. Tuning with the E-Manage
  98. UTEC Revisions (Flash info)
  99. Utec log
  100. [HELP!!!] ABC installation
  101. UTEC Request List
  102. changing the TPS value...
  103. Just upgraded my BOV to TXS BOV.
  104. WHP expected
  105. cheap place to get the Power FC..
  106. See if you can spot the new UTEC feature
  107. 520whp on UTEC
  108. Finally hooked my SafCII Up. OMG
  109. Boost Cut
  110. Tuna install
  111. Switching to a map that hasnt been set yet
  112. Why should I get a E-Manage?
  113. adapter to mount knock sensor on tuner
  114. pictures of my utec install.
  115. utec as a first mod?
  116. Evo utec ????
  117. What should I expect?!?
  118. Apexi Power FC and parts Evo VII
  119. EGT plug and play sensor
  120. should I get it?
  121. UTEC Parameter file change
  122. Utech \ Pruven Tunning. Wow!!!!!
  123. Flash VS Emanage.
  124. Inconsistencies with UTEC
  125. Evo installation notes
  126. Idle Quality with Cams..
  127. Tuner-WB O2 sensor mounting location
  128. Z1 Performance has the UTEC
  129. Tuner and UTEC Connected..
  130. RJ-11/16 port on the UTEC
  131. here is my first datalog with UTEC!!
  132. installed my UTEC today. Here is a preliminary review..
  133. Utec installed!
  134. I heard a rumor Nino installed a Utec today on an evo.......
  135. UTEC vs. XEDE...anyone know the difference yet?
  136. my UTEC is in the mail
  137. Closed Loop Boost Control
  138. Ease of Use
  139. Don't miss this! The Evo UTEC is Out!!!!
  140. Is there any Windows based software to be used with the utec?
  141. capability of e-manage
  142. e-manage loud point
  143. External signal harness
  144. anyone using UTEC yet? Post your results here
  145. E-Manage Screenshots/Software
  146. Suitable Laptops
  147. emanage not working right after install
  148. Screen Shots
  149. Getting a power fc for $1200
  150. Autronics
  151. Coil-frying info
  152. Apexi Power FC
  153. problems updating emanage...
  154. Updating for your mods
  155. pressure sensor and injector harness
  156. Which EVO tuner uses the eManage?
  157. anyone help?
  158. firmware question???
  159. Injector Harness wiring
  160. 780cc injetors with emanage
  161. ignition digrams
  162. coil burning?
  163. E-Manage How To?
  164. Greddy E-manage?
  165. Emanage ignition wiring
  166. ?Power-FC Update?
  167. Autronic support in the US
  168. Rotary/Jumper settings
  169. Grey Wire = TPS
  170. Anti Lag System
  171. E-Manage Anti engine stall
  172. TOMEI 2.2L Redline?
  173. Upgrade Ignition?
  174. Is there only one map on the E-manage?
  175. Autronic PnP on Stock Evos
  176. Input Output Sensor MPD?
  177. e-manage support tool
  178. Atronics Myths
  179. Profec E01, why so bad?
  180. interfacing a wideband O2 sensor
  181. E-manage v. Xede
  182. Emanage and Profec E01 on an EVO?
  183. greddy emanage vs safc 2 and profec b controller
  184. Lhd Evo 7
  185. Autronic questions
  186. How do you tune the timing????
  187. EManage pressure sensor & harness
  188. e- manage with harnesses
  189. Apexi Power FC
  190. Autronic???
  191. ApexI SAFC POLL - Please Respond
