- AIT and Ethanol Sensor in to MAF Plug (Haltech)
- Omni 4 Bar Issues
- Stock ECU to Elite 1500
- Anti-Lag System Valve Failure?
- Stock e8 JDM log -> lean ?
- EVO IX fuel cut at 4800RPM consistently regardless of boost level.
- Throwing a P0122 code. Losing throttle response. Hlp.
- Tuning with ECUFLASH
- High idle
- P0420 patch
- EvoScan not letting me add item
- hesitating over 6500 rpm
- Tomei poncam 270 r settings
- My Evo 5
- Failed SMOG in CA *PLEASE HELP*
- Evo 8 possible power levels
- Knocks after S2 Cams / Low power
- Need help one my ecu situation
- Aem ecu gen 1 for Evo 8
- evoscan logging issues
- Using Audi Red top coils, no ignition on cranking
- Evo7 ECU swap for 4G93T
- Idle increase during driving
- ACD ECU ABS Delete pin 49 not working
- Evo x dbw throttle body problem
- Evo 8 MR - Fuel concerns with new mods
- '03@400awhp - Driveability Re-Build/Tune
- about how much power am I making on a 6262 twin scroll 2.3
- What else does it need?
- PnP and Cheaper FlexFuel from TSComp
- Choosing between adaptronic m6000 and haltech elite 2500 for evo 8
- Help last bits engine swap
- evo8 wont start cold e85
- Engine Safety, Fuel Pressure and protection features
- 1500 rpm rich condition
- Spark Plugs not solving problem under boost?
- Evo Falling flat on its face WOT
- Best injector selection!
- Load drops with boost creep...
- Lifter tick? Rod knock? Timing? Help!
- Tuning Evo 9
- best injector and valve spring/retainer for spec!
- Evo 1-3 (2G) MAF Scaling
- getting afr under control
- More Boost Same Power?
- Evo 8 running rich
- Cant get rid of P0500 code after remote tune
- Question about haltech elite
- Does anyone have a EVO 8 4g63 HKS 2.3 Step2
- Issues with MAP sensor
- What do you think?
- Detecting MBT with Virtual Dyno
- Help with Bricked ECU (ECUflash or Evoscan solutions)
- Help please
- FIC 2150’s with higher base pressures
- Flex fuel evo 8 stock ecu
- Need help starting car :)
- steps to update Maf to SD EVO 6??
- Limp tune for driving before pro tune?
- SF Bay Area Tuning Options
- Rich cruise issues..
- Rpm didnt get up fast after launch & shifting
- Please help! Can't download rom image from ecuflash!!!
- Service engine light flashing Evo 8
- EVO iv to vii wiring
- Hybrid boost control question
- Need help setting high z 1100 on a 2.3
- 600+WHP Evo 9 Street setup
- EVO 8 can't fire up engine - Need Help
- Virtual Dyno issue
- evo 9 engine in evo 6.5
- EVO 3 GEMs ECU?
- Need a tuner to re-tune my car
- EVO ACD Communications
- AEM Series 1 vs Stock Ecu
- Big motor green SS?
- Speed Idle Sensor
- logging load
- How much HP is my motor capable of?
- Spark Tech Sequential Ignition on Evo VIII MR Issue
- need help with tune
- "Fuel Trim In Use LTFT" causing Rich AFRs part throttle?
- Maintenance and correct fluids ?
- FIC 1200: Should I be concerned with this data match?
- Broken wires plug .
- Okada Plasma Direct Coils vs STM COP
- Immobilizer (Newbie)
- .16 spark plug gap, still getting blowout. Bad coils?
- HELP!!! New build evo 8 2.4 cranks won’t start tried everything
- Logging my car for the first time!
- Moving to AZ, Need a Retune
- Rolling launch control with randomiser (Motec style)
- My AFRs are not smooth
- Evo IX bad idle PLEASE HELP
- Fixer Upper First Data Log
- Evo 6 harness to OBD2 Plug Wiring Help
- Looking for a e tune for evo 8
- Evo 8 Evo Scan settings.
- Evo 8 cams
- What to look for in a tuner?
- Evo 8 issues.
- Need stock evo 9 map
- ROM map (stock Evo 9 mr)
- Wierd stock ecu issues.
- 3rd gear pull
- Max power on 91 and how to get there
- power estimates?
- Apexi power fc
- Tactrix open port 2.0 (need stock 06 MR map)
- Issues after being tuned, Twice
- Wideband shows 10.0 but no symptoms of running rich.
- "Perfect" Tuning Hypothetical Thought Experiemnt
- Evo 8 ECU Communications port
- Sputter on acceleration
- Looking into to tuning my Evo 8
- Overboosting from the cold
- P0069. Yes, another thread
- Problems LC1 and Evoscan
- Start up/Break-in Tune
- Evo won't idle at all
- Knock, knock everywhere...
- How bad will idle (rev in neutral) be after 274/278 HKS cams without tune?
- Knock counts only in 1st-2nd on E85.
- Additional feature for GTA or Airtrek ROMS
- Any Apexi power fc guru's out there ? Please help !!!
- Some advise on basic ECUFlash tables needed !
- Installed hallman MBC, Making less boost and is slow
- Car wont start now that it's cold out.
- Wideband AFR and Fuel Maps are way off.
- Are My Fuel Trims Okay?
- car is rich at idle/cruise...need logs looked at...help...
- Questions about margin or error on AEM Widebands
- A good start?
- can Apexi PFC CT9A7 putting EVO6?
- ECU Not Reading
- Evo 8 MR bolt ons- 331whp
- Lc2 killing sensors
- injector low duty nonlinearity compensation delphi/lucas 1200 cc
- Harness swap, now no injector pulse
- Evo 8 stock tune
- Evo 8 not starting after Lifter Tick
- EvoScan Edit XML files error
- zeitronix/evoscan/log
- Feels like it has very little torque
- Head Replacement
- Speed Density Iat or
- Injector duty near 100% up top
- Rich idle, cruise, stumble
- Best injectors for e85?
- I dont see much Evo guys using Accesports. What do you use instead?
- ECM part no. (EVO X Final Edition)
- Running rich at wot after having it tuned
- Fuel injectors & Fuel Pump + Hp?
- Lehigh Valley, PA area help with Evoscan/ECUflash
- Car ejected a plug
- Good warning limits
- Cold start & AC idle issues
- NYS Inspection Problems
- Breather setup confusion idle/ stall out
- Which tephra rom for UK ix? 88570008?
- EvoScan Logging Error: value cannot be null
- 300WHP EVO 8/9 Whats needed? 2017
- Stock tune knocking? Or is it Phantom knock?
- what tephra rom for JDM ECU?
- New Evo owner - need some guidance
- Noob wondering about pops n bangs
- Grimspeed EBC on 2g DSM
- Turbo Flow rates and calibrated MAF's?
- AEM Infinity and Guages
- OLD Evoscan GPS PPC Some Information for Newbie
- Misfire/backfire
- Evo 8 boost leak
- Need help evo 7 speed density
- need help PS2000 idle up
- Need emergency help with E85 Tune!
- Fp Zero turbo output?
- Tial 38mm Chatter under high boost
- EvoScan 2.9 Trouble connecting and logging
- Most likely a stupid question, but please should be a simple answer!
- Need some advice
- Can I use PIASINI cable instead of TACTRIX 2.0 ???
- 120,000 Mile Maintenance
- Logging Fuel Trims in EvoScan Need HELP!
- Need a good tuner
- Evoscan Newb, pulled a log. Just want to get opinion on it.
- Need some help and guidance
- Tscompusa
- Need Input to Tune after full engine rebuild
- AFR's randomly running pig rich under wot (log included)
- FIC 1120cc Injectors AEM v1
- Engine failure
- Monitors help please!
- Issues with stalling when going into neutral after partial throttle application.
- Omni 4 Bar on Evo 9
- tuning help
- Power fc faults
- Evo IX Rolling anti lag with LinkECU
- Fuel Cut!!! Please Help!!!
- Evoscan Logs empty
- runing rich on idle
- GrimmSpeed EBC
- Kelford 272 cams
- P0136 back after 2 years with ecu patch
- 4g63t light acceleration interrupt
- Air and fuel ratios....
- Max knock and timing advance at 30 all throughout logs. HELP!!
- evoscan rpm issue won't log past 7968.75
- Running to lean at idle
- Tuning for higher boost
- 02 Sensor replace- still throwing code
- Engine load calculation with SD hardware
- Look at my spark plugs.
- old school fp green tune
- Grimmspeed ebcs questions
- fine tuning to get my car running "reliably"..
- P0300 Revisited
- New turbo, pull timing before Dyno tune?
- Retuning someones map
- Untuning from Meth Injection
- EVOSCAN problems?
- 2017: Self-tune vs pro-tune Evo IX thoughts
- Evoscan Anyone have any new gauge setups layouts
- EvoScan2.9 dont work???
- Putting Ceddymods on my existing Evo 5 ECU ROM?
- Need Tephra SD Maps for Evo7. Donation made.
- Evoscan Wont log
- AFR is Inconsistent
- Stock ECU vs. Haltec vs. MS3 PRO
- Ob2 sensore not communicating
- evoscan for evo 8 and impreza ?
- Evo 4 idles ruff when hot and then stalling out
- Haltech platinum pro + 1000cc injectors
- Southern california Dyno Tuners.
- Mystery hose under intake mani?
- MIVEC control by emap:imap
- Need a re tune?
- Lancer/Evo 8 ECU upgrade for 5G Mirages and Evo 4-6's
- iscv tuning
- Looking to borrow a EvoScan 1.3U Universal USB Datalogging and Reflashing Cable
- 02 hood dump daily question
- Help! Rough Idle and no boost!
- Haltech Tuners
- AEM CD7 digital dash display
- Tuning is Legal Again (in the U.S.)
- IDC going to zero
- Tuning WOT
- dyno vs street
- most important gauges
- wideband o2
- stand alone
