- I need HELP tuning my UTEC!!!
- greddy profec-e dilemma
- Can someone explain Engine Management stuff
- PDA Suggestions for Tuning UTEC?
- F-Con SZ and UniChip
- Great $6.95 Shift Light
- When is TurboXS going to post up some more maps??
- 91 UTEC MAP for stock turbo
- Possibly going from xede to utec....
- how to configure usb/serial adapter
- UTEC demo software?
- ultra speedmeter No.4000
- question setting turbosmart BOV???
- Ay Caramba!!
- Has anyone bought a Utec from this guy (Ebay)
- Can "EVO UTEC" works with MR
- UTEC's Knock Detection
- Power FC & LHD Evo 7
- UTEC Tuning issues
- looking for input
- CEL with UTEC, always after second start.
- car acting up
- wideband and s-afc 2
- Utec + H2O Injection
- Load problem
- PLEASE help
- Launch control idea
- Microtech LTX8S EMS
- Utec tuned by Harman Motive
- MAP Sensor Pin Diagram
- Which road should I embark?
- What is the value of your boost control gain?
- RAn update on profec e-01 now ecu flahing green orange red !
- Switch mounts
- Bringing Evo up to Colorado from Marland- Problems?
- Tuning Order?
- Do you have to use the greddy cable to hook it up(PC)
- Dyno Results: post yours!
- Considering a UTEC -- handful of questions
- Po 171 Ses
- Power Fc D-jetro
- Anyone wanna let me know the pic outs for the IG harness
- Advice needed..
- Utec Olf Background Map
- wierd utec problem - random mod maf numbers
- super afc2
- For sale, afcII
- Why my MAP sensor won't work
- Decel air settings
- Q about knocking
- A new emanage forums has started up!
- For Sale: SAFCII with harness
- ABC question
- safc how to?
- 04 getting p0300 with utec???
- Anyone running the UTEC with the Buschur alcohol injection?
- Map wiring
- safc2 extension harness
- Map sensor Calibration
- New UTEC book idea
- GM map sensor w/pigtail
- MAP sensor install
- need quick answer please N2O and utec extra solenoid controller
- UTEC detonation QUESTION
- Novice questions for boost control
- help with installing apexi T timer
- Dell Axim50x connections
- Closed loop Boost Map
- Knock Thresholds
- Advice on UTEC purchase
- 325whp / 315trq on DynoJet w/ AFC?
- Help with Fuel Maps?
- Misfire problem
- What obd scanner do you suggest?
- Opinions on Power FC
- Possible to add aux input to UTEC?
- Where to find...
- UTEC on '05 evo
- 720's to 780cc injectors?
- Questions
- You can make decent power on an SAFC2
- stock settings, stock car
- Finally Finished Motor...WOW!!!
- FS SafcI w/ buschur settings
- should I get AFC II?
- Not Afraid to ask stupid questions
- seeing state ref, hide safc?
- P0201 Code with UTEC
- Really quick question
- Need Some UTEC help
- Opinions on EGT's?
- FYI. Brand New Tuner FS for $300 in FS section
- Cheap New Safc-II
- Utec or Exede
- utec abc or hallman mbc
- FS: Mint condition Utec,Tuner Pro, etc..
- Utec + turbo kit ?
- UTEC is gonna get me fired and divorced!
- UTEC didnt like my injectors.....????
- not too sure about s-afc2
- Utec question
- keep getting fuel or boost cut?
- 25psi Help!
- FS SAFC II Cheap
- First logging run
- Any mapping out there?
- throttle response
- Just installed
- o.k. Utec tuners, a few Q's.......
- Tuner Pro
- utec question
- super afc2 help
- UCC Question
- Help a UTEC newbie out?
- Re-set emanage?
- Intakes, Inductions Boxes, Maf Pipes... OH MY!!
- MAP calibration
- MBC necessary w/ UTEC?
- Got my car dyno'd!
- PowerFC for sale
- 420 AWHP with Utec
- Utec timing stage 2 -100?
- Does the SAFC-II work?
- Tuner Pro ????
- Increasing Boost Slightly
- Apexi...first contact
- Have a quick question on SAFC II harness
- Q: for all you using UCC
- getting tuned anything else?
- Mods/HP/TQ/Log/MAP
- Modified injector size
- tuned with safcII
- 650cc injector fuel settings
- Is nobody using the Emanage anymore?
- Found a nice addon gauge for the TurboXS Tuner
- My Yule Log.Comments Please
- Is this normal?
- Good base settings. (stage 1)
- a real newbie help!!!
- A christmas Gift.. UTEC Digital Dashboard
- TXS Dyno Day Results?
- i need a super afc2 book
- Wried Problem
- dsm translator/3in GM MAF
- Looking for BigBoogieman
- ABC Install?
- Quick but Importants Questions on UTEC Install
- Removal of MAF?
- BR Downpipe & O2 sensor?
- maybe bad pump or utec
- 1 Quick Q
- CEL help - P0234 code while tuning UTEC
- ECUFlash enough for bigger injectors?
- what map?
- Rev wire on ecu which one?
- UTEC a/f
- For anyone considering the AEM vs. Autronic...
- 11's
- Not boosting with Utec installed
- Tuner Remote Display
- flash swith up or down to set it to run?
- Map Sensor?
- TXS Rocks
- Do I need a S-AFC 2 if I get a ECU reflash?
- Yet another Utec question
- UTEC Boost controller?
- UTEC Tuned by Harmanmotive (Check out my numbers)
- Buying a used UTEC...
- Features the UTEC REALLY REALLY Needs to compete with a Standalone
- Tuner vs. Tunrer Pro
- 5k rpm studder with UTEC
- data logging with emanage
- Just Ordered UTEC. A few?'s
- UTEC and 05 models?
- Pass thru ?
- Thought I would take a chance
- Update on Engine
- New Maps?
- SAFCII from Talon
- question for Malibu Jack, knock and timing
- Setup of Power FC
- Helpful Addition
- SAFC I or SAFC II
- Colant temp 96c is it okay ? using Power FC
- Which to get first?
- New Greddy e-manage for sale.... LQQk
- evo 7 power fc on evo 8? please read
- map 0 with 1.7 firmware w/ OLF
- race gas and stalling
- UTEC for '04 Evo
- Pics of Head, may be ok
- Need Help Asap
- Buying a used Apexi-Power PC any advise ???
- IN-1 sensor check voltage???
- Anyone need an SAFC with harness?
- More success with the UTEC!
- Problem with Utec
- Just bought a afc and i dont know how it works
- Is the emanage universal?
- pics from motor
- safc2 wiring for europe version evo8??
- FS: Greddy Emanage with Extras
- New Dyno Resutls via UTEC Tune
- need help on gettin my afc2 wired up and workin
- weather question
- Experience Mapper Needed..
- my connector doesnt fit
- po234 fuel cut?
- Mounting Solutions S-AFC
- Is there any reason to have an AFC if I'm flashed?
- calling all s-afcII need help please
- Utec general question
- Might have seized
- beat my idle issues...I think
- Trouble With Safc2
- How to idle 272 cams with Utec
- Cold idle problem
- *** UTEC Control Center release 3 available ***
- Problems w/ UTEC and *flash?
- Installing my Greddy e-manegment Question`?
- Launch control rpm question
- Support tools for the E-managment !
- My shift light V1
- SAFC settings on 91 octane
- Considering UTEC
- AVCR installation help
- Trouble getting consistent A/F ratios
- Showin txs some luv
- Just got my UTEC tuned :)
- What Gauges are necessary?
- Cam/inj/1.7firmware questions
- Another restrictor pill help question
- Just upgraded to firmware 1.7 help
- FS: Greddy E Manage & Support tool
- DTEC First look
- Utec Maps For Australian 98 octane Fuel
- Autronic vs. AEM
- Road Tune
- Proper A/F and EGT and Timming?
- Boost problems!!
- Emanage + Profec E-01 No Boost
- 25 psi watta hoot
- shift light help
- Utec for sale!!!!!!!!!!!!!
- Emanage Password
- Problem holding 20psi to redline
- Safe injector duty cycle on stock injectors?
- Autotune program
- Super Afcii Wiring?
