PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28
  1. Best ECU Mail-IN Flash?
  2. ecu flash
  3. Cold Idle Problem
  4. ECU flash by 4-wheel-slide
  5. Advice Please on Vishnu Stage 2 kit?
  6. Sputtering Issue
  7. Anyone needing a 500R?
  8. WORKS flash / ECUUnlocker questions
  9. WORKS flash / ECUUnlocker questions
  10. power fc, power gains ?
  11. blow-through MAF
  12. 2.10 SW, firmware beta release
  13. New to tuning, what to look for?
  14. New to tuning, what to look for?
  15. What's the purpose of a wideband if anlready tuned?
  16. Jester Tuneing
  17. Ralliart ECU
  18. Prosport Gauges.
  19. DLL DYNO comparison my modded EVO8 GSR vs Stock EVO9 MR
  20. 01 lancer
  21. Ecuflash wont read ecu
  22. intake and tb ???
  23. Wideband Comparison
  24. Max wastegate duty
  25. can 100 octance change AFR?
  26. Ems...
  27. FC datalogit com port error
  28. wtt: my tuned safc for your stock ecu
  29. Avcr Help
  30. OBDII pinout
  31. MaftPro=GOD piggyback!!
  32. utec not reading correct boost
  33. Walbro255
  34. EvoScan and 2G DSMs
  35. New to site recently purchased EVO MR
  36. Idle fluctuations
  37. remote map switch
  38. change setting to use 3.5 bar map?
  39. Problem with Fuel Cut In Need of Help!!!
  40. stop cel with anti foulers.
  41. evo 9 cams
  42. 272's and tune
  43. Boost leak test
  44. build boost on the line?
  45. Custom air box?
  46. Wanted: Stock 03 ECU
  47. Evo VII GT-A ECU
  48. MOTEC Fuel testing on Evo9
  49. Captured a UTEC log - help me understand ...
  50. Wideband
  51. Email flash
  52. using AEM map for speed density setup
  53. Tuner Shops
  54. Another gauge
  55. Engine Management
  56. Set Fuel pressure with engine out of the car
  57. Flashes vs Engine managment
  58. F/s Ecu +
  59. Engine Ice.
  60. Choking Issue
  61. Blown Fuse in tuner
  62. Which do most prefer....
  63. To Advance, or Retard?
  64. vishnu vs gruppe-s
  65. ?'s for TTP
  66. St Louis Flash
  67. Possible Immobilizer issue - original stock ECU won't start car
  68. map switch question
  69. utec/nitrous
  70. ECU wiring schematic?
  71. WORKS Tune Dyno Numbers
  72. Stock Map
  73. Retune from summer to winter?
  74. Zeitronix boost sensor not showing vaccum?
  75. Very Crappy! My LM-1 Died!!!!
  76. Will tuning pass smog
  77. Billet Design!
  78. Bigger injectors?
  79. Cannot connect, probs with tactrix cable
  80. Autronic EVO 8 PNP board Brand new.
  81. Haltech EMS?
  82. LC-1 problems ... HELP !!
  83. Drivability and MPG re: Opinions on my flash
  84. Boost
  85. apexi S-AFC NEO for sale with harness
  86. Tuned by Sean Ivey Today
  87. I need help logging Evoscan with Innovate LC-1
  88. Need tach signal for data acquisition
  89. AGENCY POWER....vs....HKS Ti....vs.....GREDDY Ti-C
  90. Keep BLowing Engine fuse? Help
  91. Dyno run video (Did some upgrades today)
  92. Ivey Tune
  93. Installing Cams Without Tune
  94. Machines Gone Wild (MGW) Tune
  95. Need help. Bad Idle
  96. Reseting the ECU
  97. Check Engine Light On ( Engine Over Boost)
  98. Log reading help
  99. going to get my first flash...need some advice
  100. Need A Tune !!
  101. FS ECU+ plug & play
  102. Location of Tuners?
  103. Test Pipe or high flow cat
  104. tune shops in ny???
  105. Help! Any Jestr affiliates, need a new map asap!
  106. Buscher Modified Walbro Pump
  107. IX spare ADC pin?
  108. putting back on the utec
  109. Mitsulogger --> Excel
  110. my evo9 RS need 350hp+
  111. HKS EVC VI problems
  112. wideband?
  113. 02 cel and Ecu safe mode question
  114. Bashing? And good setup?
  115. which setup to i buy
  116. Commifornia
  117. Radiator Fan Issues on an IX?!
  118. 2 Step install
  119. Need Greddy Harnesses.
  120. tuning?
  121. HKS EVC III 3 electronic turbo boost valve controller
  122. How to find a Turb back exhaust system thats quiet as stock??
  123. Apexi avcr or Blitz dual sbc?
  124. EcuFlash & EvoScan works on new MacBooks??
  125. What has to be checked to log load?
  126. Why are you using the S-AFC?
  127. is it natural that u get richer AFR in higher gears?
  128. Greddy Profec E-01... RPM signal?
  129. Not enough boost
  130. serial to usb help
  131. LogWorks3 Beta 1 released today.
  132. My first log
  133. NY Flash
  134. s-afc neo setup
  135. AEM or Flush
  136. newb tuning ?'s
  137. Economic Driving :D
  138. Boost Problem
  139. Dont waste $ on Racegas unless tuned on it?
  140. Props to 4 Wheel Slide
  141. tuning seminar
  142. Ams
  143. Software & EVO 9 Board
  144. Making a race gas tune ?'s
  145. fs: evo8 turboXS Utec
  146. 4 wheel slide tune!!! :)
  147. Is Engine management necessary?
  148. Motec M800 PnP Harness for the Evo IX?
  149. Blue tooth
  150. engine hose..setup?
  151. launch control
  152. What should my free air ratio be?
  153. i'm new her.searching parts for evo 9.
  154. Software?
  155. AFR = 0, Lambda = 1
  156. What Engine Managment??
  157. Need help from all of you guys
  158. New here
  159. tunning experts please read my concern
  160. A Strong Message to Turbo XS. Please help.
  161. Can the dealer tell?
  162. Compressor Surge?
  163. FS: TXS Utec $325 shipped
  164. Do I need my OEM ROM or will the Aktive Matrix do?
  165. Logs from Good Tunes
  166. Short ram intake question
  167. Schools of thought on tuning?
  168. help
  169. new flash method
  170. Which Reflash to get?
  171. Which Flash??
  172. Trying to tune - 2 questions
  173. what to do after fried coil pack?
  174. new here. need some help with my evo
  175. need help searching about tunes
  176. SES code P0000 and P0011 Please help?
  177. MoTeC or GEMS???
  178. Engine or Boost Issue after 1/4 mile runs
  179. Zeitronics help!!
  180. Check Engine/Tuning Question?
  181. What EGT are people seeing
  182. Safc-II to keep or not to?
  183. silver box ecu+ for evo 8 FS
  184. ECU Flash and Vista..?
  185. ECU+ Featured in Modified Magazine!
  186. ECU+ Now On Sale!
  187. dual stage MBC for 20psi and 12(WG) psi......possible?
  188. Who flashed my car? Is there a way to tell?
  189. here's a ? for the tuners
  190. SES "Engine Overboost Condition"?
  191. Need to tune evo and live in ND!
  192. Need Help, SAFC II or Flash??
  193. Can't decide on which tuning method
  194. Passing MARTA
  195. ACD and Anti'lock lights blinking
  196. dyno4mance tune!!!!!!!!!
  197. Anyone have ttp flash
  198. Ecu tune & Fuel Pump. Help a Nub out Please !
  199. Street Tuning advice?
  200. Ecu and Immobilization code Question at Mitsubishi Dealership
  201. Anyone Logging with Macs?
  202. What to log with?
  203. Need Help with Mitsulogger
  204. good place to good car tuned?
  205. coils just keeps blowingup
  206. High Knock
  207. Autronic ECU for Sale
  208. Vishnu Re-Flash for EVO 9 MR
  209. Tuning help
  210. Tune after cam install?
  211. logworks live tracking
  212. ECU TEK for EVO IX tuned by MZM in Austin TX?
  213. Logging/Wideband weird result
  214. USB to serial that work with the lc1
  215. Utec with evo 9?
  216. Need tune advice
  217. Machines Gone Wild
  218. Car Trouble: Slipping Clutch??? Not Sure Help!
  219. Injector resistor pack - removal or not
  220. Jestr M0 flash and M1 ?
  221. 30 PSI Stock Turbo Run Data Log
  222. need a tune!
  223. ecutek datalogging
  224. Sharing Some Dyno Tunes we did at Vivid Racing
  225. Missfire Issues
  226. 2 Step/Launch control bounces of limiter very slow???Help!
  227. How often do you log?
  228. sensor signal conversion, any electronics gurus?
  229. FS: Txs Utec IL
  230. safc2 questions
  231. Best tune in NC
  232. Knock sum vs. Knock voltage
  233. High Gear Issue
  234. Tuned @ YIMIS
  235. Hks Evc6 Questions/how To
  236. Perrin EBCS with Utec
  237. What is the limit of factory maf?
  238. EVOscan ?????????
  239. Good tuner in Virginia Beach Area???
  240. How do I put more power using stock turbo???
  241. 91 and 93 octane and tuning
  242. AFR variations due to temperature?
  243. Need help on finding a place for tune
  244. Stock Evo AFR
  245. New user with a few questions
  246. ecu+ info
  247. Looking For Others That Want A Tune From Ams In Tampa, Fl Area
  248. E85 AVAILABLE in TAMPA,FL !
  249. Boost gauge "T" Question? Never been asked before!
  250. Installation question before buying Power FC?
