PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. In dash computer
  2. Accessport and restrictor pill
  3. knock after drop-in filter install
  4. EGT gauge issue...
  5. New Car Help
  6. Removing my turbo this weekend. Any tips?
  7. What is needed to convert your Evo from 93 to E85?
  8. I want a better tune
  9. My Evo's Dyno - input needed please!
  10. Do I need more fuel to make 400whp?
  11. can't get a signal out of the tuner
  12. LC1 installed by a shop, help me find it!
  13. questions about tune..
  14. Boost control !?
  15. What hardware?
  16. Utec for evo 9 Q
  17. F Con V Pro Users\tuners
  18. Evoscan v2.0 NEED HELP!
  19. Boost Problems
  20. Zeitronix EGT broken??
  21. dissconnecting battery
  22. Thank you Cobb!
  23. Apexi Avcr losing settings
  24. TTP Tuned Dyno Chart
  25. What's FPR on sensors??
  26. Correct values for innovate lc-1 to emulate o2 sensor with test pipe DP
  27. ECU boost control
  28. Getting/Making charts from Mitsulogger
  29. What do tunned Fuel maps look like?
  30. Evo ix Basemap
  31. What can't you do in BOOTCAMP?
  32. p0300 on evo x!
  33. AccessPortInstalled>>Blown Turbo.
  34. Vishnu Flash Question/Help
  35. Still love my UTEC!
  36. In Need of a Stock EVO IX MR Rom.
  37. Balance Shafts
  38. Good idea?
  39. Q on wideband.
  40. LC-1, XD-16 Error 2 (first use)
  41. Got new vacuum line from Cobb
  42. Ecu Flash
  43. Fuel Trims +60%, Help
  44. knock levels and peak hold ?
  45. Help, no spark after new engine install
  46. Differences between dyno tune and mail flash
  47. !! Very useful ECU Readiness Code Steps specifically for Passing Emissions with P0300
  48. Map sensors
  49. silly white connector
  50. Anybody knows what is FIC 850cc Latency values?
  51. Does anyone use ecuedit?(LC-1 ref)
  52. Evo 2 Step?????
  53. New Tune For My Car
  54. Defi boost gauge broken??
  55. Please Clarify my Wideband Research (Innovate/Zeitronix)
  56. Question about tuning
  57. dyno tuner in the OC
  58. Got Protuned today.
  59. Question about my '06 MR
  60. Another Utec/Tuner for Sale
  61. Tune?
  62. Problems with Access Port
  63. Activating Evoscan Alarms/Triggers
  64. Anyone using ECUEDIT?
  65. Limit of engine EVO VIII?
  66. Am I missing anything?
  67. idle keeps dropping??
  68. GOT IT!!! Just installed
  69. Tuning
  70. MAF-T nubee
  71. Accessport right for me?
  72. anyone have info on evo X ecu, tuning, stock or base maps, etc...???
  73. Dave Buschur or Tym Switzer?
  74. Aftermarket IC Tuning question
  75. should I do a tune? what do you all think? tuners???
  76. log with aem wideband?
  77. Can't change Timing/Fuel Tables
  78. please help?!?!?!
  79. ODB-II Port
  80. Tuning Questions
  81. Worth a tune?
  82. Making a tuning cable?
  83. Can I ground my LC-1 to the ECU?
  84. Where to place Lc-1 unit
  85. Who is tuned at 18psi?
  86. Accessport with stock turbo and mods
  87. ECU locked need help
  88. Boost Spikes to 24-25 psi
  89. iddle issues
  90. Question for professional tuners
  91. Newbie question on immobilizer code
  92. Evo IX idle and black soot/smoke from exhaust
  93. misfire code p0300
  94. Can someone break down ECU LOAD for me?
  95. Ticking noise
  96. Blow through maf with ap???
  97. question about hks eids
  98. Access Port and 2-step
  99. Apexi Neo O2 Sensor?
  100. Can't get mistulogger and inovative to work
  101. Do i Need Reflash for Apexi..!!
  102. Anyone know if Evoscan v2.0 works with LC-1?
  103. Standalone? or Tune Stock ECU?
  104. loggin 2byte load with Evoscan or Mitsuloger help me
  105. Carolina Residents Attention
  106. exhaust rap
  107. noob question
  108. twin fuel pumps question
  109. The Official "I Got Pro-Tuned" Thread
  110. service engine soon light
  111. only hits 160% load
  112. What should I do?
  113. What the HELL should I do for tunning?
  114. Traction Control on EVO?
  115. Fuel pump upgrade question...
  116. Question about extending wires for LC-1
  117. Question about extending wires for LC-1
  118. O2 sensors with Power FC
  119. First Steps...
  120. More AP Questions
  121. intakes and tunes?
  122. Bigger Injectors
  123. Tuning in winter vs. summer
  124. Losing your tune?
  125. ZT-2 Lcd screen slow!!!
  126. ignition, interesting points, needs cliffs.
  127. Can Mitsuloger log a/f ?
  128. COBB ProTuner
  129. Tactrix cable problem...!?!?!
  130. Mounting locations
  131. Need advice on WB02 and placement
  132. determining target A/F
  133. Brian Crower Cams - How do they compare to cams twice the price???
  134. Ses?
  135. Still wondering if this is worth the money...
  136. utec for sale cheap
  137. Log boost: JDM MAP vs. Aftermarket gauge?
  138. Using Another Solenoid?
  139. AP on E85
  140. Install a breeze!
  141. pro efi ecu
  142. Data logging ?
  143. Mid throttle knock at 2500-3000
  144. Premier Evo Tuner?
  145. p172 from Hell and Factory ECU- HELP
  146. slow spool
  147. Mods Before Dyno Tune Question/
  148. Question about GM 3 BAR Map Sensor
  149. so i went to inquire about a tune...
  150. WTB: TurboXS MAP Sensor
  151. Aem Ems Or Apexi Power Fc And Commander
  152. 2.3L 4G63 Apexi D-Jetro Map needed?
  153. Aem Ems
  154. anyone not know how to do own mods?
  155. Tuning / logger cable? What the hell do i have??
  156. Whats the difference in tunes?
  157. Need Data log lab car definitions standards
  158. PFC Djetro
  159. evo 9 back to stock
  160. Slipping Clutch?
  161. Variable Geomeetry Turbo on EVO?
  162. cobb A.P. & flashed ecu???
  163. ecu question
  164. COBB Intake Only?
  165. Logging and tuning in cold temps.
  166. A Few Basic Questions
  167. questions about simple log parameters
  168. need advice on WBo2 sensor
  169. dyno'd! rich air fuel, help
  170. What gear do you use to Dyno your 5 speed Evo
  171. Tacho no running..
  172. LogWorks 2 issues, maybe laptop related...any ideas?
  173. aem uego cant log with evoscan, need help
  174. do i need a retune please help
  175. Anybody knows wat Deceleration Fuel Recovery means?
  176. Easy ECU question...
  177. Bog at 5k in 3rd gear
  178. Which direction to take with engine management
  179. Maft gen 2 Question
  180. Has anybody use the cobbtuning?
  181. Cobb map AFRs
  182. maps???? do they exist??
  183. little help pls
  184. Is the access port worth it..?
  185. Affect of Lower Reading TPS on ECU
  186. Need to buy a base Lite tune with my mods!
  187. Re-tune after 10.5
  188. Is this log too lean??? Tuning Guru's please look
  189. What to gap plugs to
  190. Can i flash AP map over my current EcuFlash map?
  191. How does an A/F Wideband work?
  192. How to get Log in table form??????
  193. Help! Which wires which?
  194. quick vaccum line question?
  195. FC L-jetro HELP...
  196. Must I run-in/break-in my new cams before tune?
  197. Motec M4 - need help in tuning
  198. Boost fluctuates
  199. Why Lower Boost on Alchy Than Race Gas?
  200. tuner question
  201. Tweaking my 91 oct map
  202. Does the stock ECU record driving patterns?
  203. Fc dataloggit "Protect settings"
  204. FC data edit won't connect
  205. Gus' EvoIX MR Tuning Story
  206. AFR fluctuates up and down?
  207. Safc
  208. EvoScan 2.0 release
  209. Tune and the dealership
  210. Speed Density with E-manage
  211. 1000 cc injectors with a utec?
  212. car runs rich after fill up
  213. Is the FC worth it?
  214. Need to get My Evo Tuned
  215. Just got flashed from Ivey
  216. WTB stock ECU VIII!!!
  217. Apexi Power FC (D-Jetro) in LA, CA (HELP!!!)
  218. 04 ECU into an 03 evo
  219. is this right???
  220. Adding O2 housing to Stage 2?????
  221. Good stock ECU writeup?
  222. Starting
  223. hydra ems
  224. Power Fc And Hks Eids
  225. Works ?
  226. Economy mode question...
  227. need opinion
  228. Cold Start Problems (AP stg2)
  229. Do EVOs sux that much....
  230. Check out my log please
  231. hp gain and tuning
  232. Need tuner in Austin.
  233. Need help guys.
  234. How to Log A/F as volts?
  235. What benifit w/O2 housing and mods
  236. Houston! Can someone please log my tune?
  237. Getting flashed on a dyno next week-any advice?
  238. LM-1 evoscan Q
  239. FC tuning
  240. Why is the A/F ratio so fat?
  241. Okada coil packs
  242. question about my AF #'s
  243. question about a/f
  244. Need Help W/ Instalation And Tuning Near Mt!!!!
  245. Blitz Induction Cover +Drop in filter
  246. Optimal timing???
  247. IX Log
  248. FC Datalogit
  249. MBC or JDM Map Sensor
  250. FS or WTT Turbo XS Utec
