PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28
  1. Need help on this please.
  2. UTEC and Tuner Pro For sale
  3. Stock FC Map
  4. Car WONT START
  5. gasket problem
  6. Need Stand Alone Or EMS???
  7. Fuel cut, Boost cut?
  8. Stock ECU can out learn a flash?
  9. EGR foolery
  10. Road Tune
  11. Boost controler issue
  12. datalogging and wideband....
  13. V4.5
  14. What should my boost gauge say?
  15. 4G63, 4G18 & 4G93 parts lists?
  16. Milking the stock ecu for MAX power
  17. Emanage (blue ) specific questions
  18. AFR meter...
  19. My first Sony,.....I mean Tune.
  20. UTEC for sale
  21. datalogging wideband signal with pocket logger
  22. Best tune for alky...non EMS
  23. Is Ecutek detectable from the dealers?
  24. Where can i find Evo IX ECU diagram ?
  25. Map switch interchangability
  26. T&TP and others: Please help with MAF Translator
  27. General UTEC questions
  28. FS: UTEC w/ MBC
  29. 1st datalogg + tune - confused
  30. Boost solenoid help
  31. Help setting up UTEC
  32. Utec Vs. SAFC II
  33. Wiring Alcohol kit
  34. Question about the MAF (MAS?)
  35. Question: Plug gap ???? BPRES7'S
  36. Video Of UTEC Launch Control
  37. Video Of UTEC Launch Control
  38. ix ecu plug and play
  39. Is it a good idea to get a wideband AF if you already have a flash?
  40. Question for 10.5 hotside buyers. Wich bolts??
  41. Flash with Revolvers???
  42. Motec M800 for EVO IX has been released!!!
  43. Possible ECU->UTEC "switchover" problem
  44. I Need Help! A/F off the chart lean!
  45. How did u learn
  46. Apex-i Power FC could never start
  47. Standalone EMS vs. ECU Re-flash
  48. Fried ECU+?
  49. general maftpro operation question
  50. setting plz?
  51. Boost control
  52. Let's talk Hydra EMS for the IX
  53. What are your knock settings at?
  54. Has anyone seen the new Motec plug-in ECU for Evo's?
  55. RPM readings dont match
  56. New from Greddy
  57. injectors question
  58. Just got dyno tuned today!
  59. Help tunning after intake
  60. Greddy EBC always on?????
  61. Autronic PnP + HKS DLI II + J&S safeguard
  62. ecu+, 50trim, 750cc inj
  63. maf translator with a flash vs. aem ems
  64. aem uego and ecu+
  65. Methanol Injection on EVO 8 Stock Turbocharger
  66. 06 IX MR Mod Suggestions Needed
  67. Intercoolers
  68. 2.3 stroker kit just put in but car won't start, please help!
  69. WTB: Used UTEC with map selector
  70. Evo IX ECU tuning --> what's best?
  71. Omit???
  72. Performance Tuning Shop?
  73. Help on PFC D-Jetro
  74. Immobilizer stand alone question.
  75. Wideband
  76. HKS EVC V Boost controller question
  77. Engine Seems To Stay Rev'd During Shifts???
  78. UCC compatible for mac?
  79. My 2006 Evo IX MR dyno tuning results....
  80. Speed Density
  81. Chiming In
  82. EGR Removal
  83. SAFC2 for a idle on a sti
  84. Boost Control
  85. maf delete ???
  86. Differences in ecu response to knock question
  87. Flash for which AKI (Anti Knock Index)?
  88. CEL P0102, Any one had it?
  89. AFR off on STOCK ECU?
  90. Map Conversion
  91. Error message while loading maps
  92. SmokedMustang's Misfire -- Caught on Tape!!
  93. Puzzled...
  94. Best MPG per HP/TQ
  95. My thoughts!
  96. Staged Tuning packages for evo ix
  97. ECU+ for RHD JDM Evos
  98. P2 Dyno
  99. Boost spike- a major problem?
  100. simple ECU
  101. Lean on high end?
  102. Tunerpro RT irritating me today
  103. Tuning Educational Video: Base Fuel Table
  104. Help! Advice for flash.
  105. Tuning a IX with SAFC-I/II
  106. ECU question.
  107. Best Next MODS
  108. Forced Fed Experience Anyone???
  109. Scott from TTP willing to do a Weekend Travel?!
  110. Evo ix Engine management system
  111. BOV flow too fast?
  112. Knock
  113. Setting for 680cc
  114. SC-Power SAFC holder
  115. New logging idea
  116. WTB: Used TurboXS Tuner or Tuner Pro
  117. Coil Explanation Needed! Can they be half-bad?
  118. HKS Twin-spark AND Coil-on plugs redundant?
  119. SAFCII, Profec E-01
  120. Power FC and 280 cams
  121. CEL after injector install..
  122. Injector size question
  123. First impressions with new evologger
  124. Power Pc and G.M. Boost Solenoid
  125. In Car PC Set Up For ECU+
  126. Connector question...
  127. utec questions
  128. My Works upgrade results
  129. Dan from MachV rocks!
  130. trouble codes....
  131. calibrate your fuel trims?
  132. Scanmaster 3 and ECU+
  133. safc II display problem?
  134. Ecutek flash.
  135. WTB: Map Switch
  136. Timing and UTEC, where to start.
  137. Evo ix 6-speed Exhaust system
  138. can the safc2 control the fuel rich or not?
  139. Blow off Valve
  140. How to adjust fuel trims
  141. Log Knock with Zeitronix ???
  142. Huge power loss
  143. Stage 4 buschur safc 2 settings.
  144. Misc questions
  145. just a quetion
  146. clutch noise and the Utec?
  147. Which do you prefer: MAF or MAP load referencing?
  148. Which do you prefer: OLF or MAF-offset?
  149. Crickets....
  150. 264/272/280 cams
  151. Data Loggers and Scan tools
  152. AFC2 w/ MAP Mod using AEM 3.5bar sensor
  153. MAFTPro in MD,DC or VA area?
  154. turbo upgrade
  155. evo in mississippi needs help
  156. Top end lean out?
  157. Petition for Boomslang to make SAFC-2 Plug and Play Harness for IX
  158. Petition to make SAFC-2 Plug and Play Harness for IX
  159. For those running high boost
  160. timing?
  161. Help with a map
  162. MAP sensor ?.
  163. Somebody Have a decent map?
  164. WOT hesitation/fried coil problems solved?! Must read!
  165. ams mail in flash??
  166. Choosing a good wideband
  167. DTEC-FC Anyone using one?
  168. Throttle response help needed
  169. Wideband O2 location
  170. Why I chose Meth. over Race Gas. Was it worth it?
  171. Evo IX Standalone/Piggyback
  172. Tuned by Jester
  173. Voice ur opinion: Open source the ECU+ code
  174. Launch Control?
  175. what do you use for a logger
  176. where to buy afc II evo harness
  177. SAFC help on '03 stalling problem
  178. Tuners in NY Area
  179. Hydra EMS
  180. Tuned by Precision dyno tuning
  181. FS: Brand New ECU+
  182. stock 03/04 FMIC water sprayer activation conditions?
  183. Evo 8 Flash
  184. Questions about 05 EVO
  185. How many psi
  186. Need help on tuning///
  187. Launch control/2 step rev limit
  188. Tuner Lite -> UTEC - Where do I plug in the PC?
  189. how are u running ur alky
  190. engine shut down
  191. Does this sound like a "bad" O2 sensor problem? pop when STOMP!
  192. question about rpm converter
  193. P0401 and strange AFR. 03 EVO
  194. UTEC Generating Bad MAF Values
  195. Anyone using unichip?
  196. Dan @ Mack V (ECU+)
  197. tuners using headphones
  198. Map Ecu Ordered!!!!
  199. DynoScan Configuration
  200. FC-Datalogit Users Required!
  201. Possible to have some of these options?
  202. Is there an engine management solution out that can do the following:
  203. ECU+ with aftermarket gauges
  204. big problem. need educated help please
  205. Any XEDE Converts??????? Some questions....
  206. Vishnu Tuning Stages
  207. leaning out
  208. Can dealers detect a reflash?
  209. Is Anyone Here Using Pocketlogger?
  210. Saving and Loading maps from the Palm
  211. knock logging w/ utec
  212. Problems with UTEC
  213. Will speed density be a future option for ECU+
  214. Replacements
  215. 03 ecu into 05 evo????
  216. CAT Replacing test pipe =CEL?
  217. fs: Turbo XS UTEC w/ Map Switch
  218. CEL Problem
  219. Need feedback on this product
  220. Will leaning out your air/fuel .5 gain much extra hp?
  221. Tuning for cams
  222. Can I use the MAFT to simply measure airflow?
  223. Video: Ever make adjustments that the UTEC didn't like?
  224. Palm pilot help.....
  225. FS: TurboXS UTEC w/ map switch
  226. Factory Warrenty?
  227. Question about mail in tunes
  228. Tuning/Flash, ecutek evo IX questions
  229. boost controler and AEM
  230. Introducing the all new PLX R-300 unit, now available
  231. Anti-lag Setup with MSD-DIS2
  232. knock reading, how high?
  233. Motec M800 for IX
  234. BC+ EMS= only need one??
  235. New UICP
  236. WTB: FC-Datalogit
  237. Want MAFTPro? Here is what you need!
  238. Has anyone ever put the Unichip Guarantee to the test?
  239. Just tuned
  240. Max HZ numbers???
  241. Engine Management Challenge
  242. Advice - Evo 6 BIG POWER
  243. UTEC problems
  244. how much did you tune change in the winter?
  245. TunerPro RT software questions
  246. UCC How-to create a very base map
  247. questions
  248. Question about wideband readings.(Tailpipe vs. Downpipe)
  249. Confused about tuning solution, need help
  250. PLX R-500 Wideband A/F Computer, anyone using this?
