- Clean injection fuel injectors
- Evo X knock count 17
- EVO 8 , evoscan will only connect with MUT3?
- ECU resetting while cranking ? Link V3
- vehicle speed sensor specs for aftermarket ecu setup
- TephraMod V7 Not compatible with AUDM Evo 8
- Evo 8 ADM Stock ROM 96530006
- Link G4X Trigger Errors
- Jdm Evo 8 ignition map
- AFR: How rich is too rich?
- Tactrix cable anyone?
- Logging ACD with Evoscan but with Standalone ecu
- Haltech dash fuel level sensor voltage?
- Haltech elite 2500 aux wiring
- Evo 7 Immobilizer turn off
- Bench Testing EVO8 MAF
- Evoscan Actuator Help
- Fueltech FT450 on evo?
- Unusual Issue: 100% Duty Cycle at Idle
- How to get to 400hp without e85?
- Evoscan?
- Dual ECU Evo IX GT-A
- Evo IV performance mods
- Link ecu lanch control
- HKS Cam Gear Adjustment for new turbo and cams
- Performance issue Evo X
- Best way to correct overall rich tune?
- Failed Emissions MOT Evo7
- Help with EVO 8 Pops and Bangs
- Evoscan load too high
- Unknown ROM issues with ECU Flash
- misfire, bucking, and breakups at partial throttle
- Denso Ignition Coil Pack
- Tuning out knock help
- Lamspeed speed density conversion kit
- Is it smoked?
- Fuel pump relay constantly switching
- Coolant Recommendation
- ecuflash
- AEM AFR X-Series Serial Port = Random Number Generator
- Low speed buck/cough, odd timing values?
- Erratic boost issues
- Link ecu
- evo 9 Speed density fuel tuning
- Evo 4 Serpentine Belt Diagram
- Evo will only start once after flashing
- 2003 EVO 8 - Picking up knock and misfire on Cylinder 4
- Coolant Temp Sensor Issue
- EVO 8 JDM - FIC 950CC Injectors Not Scaling - Car running lean
- EVO 8 JDM - Pulling timing
- Can Evoscan read raw serial data through an arduino?
- Evoscan Still Selling Cables?
- Evo Scan & ECU Flash Issues. Weird Display/Not Logging
- Innovate LC-1 Serial Comms Configuration
- Quick SAS question
- Newbie tuning question
- Need Help!! Lean spot 3.7k and bog during part throttle
- Looking for gt-a / airtrek turbo r ecu pcb pictures
- Tuning help?
- New Evo IX MR owner needing tuning advice
- Evo 5 pops and bangs
- IPW Micro Pulse Width Tables
- Help with JDM Evo 7 GTA injector scaling/latency
- Timing at idle bouncing between 2-8 degrees BTDC
- IAT Question
- Surge while cruising
- Need Help Vi-Pec V-Series PNP Evo IX
- Holding More Boost to Redline
- Possible injector voltage issue. Please help
- CA dealer reflash
- 96260709 ignition problem
- Fuel temp sensor bad/tuned on speed density
- Engine temp issue
- The Evo 8 tuning saga continues
- Request: Evo 8 Base Link Tune?
- Does anyone have the full details of the MUT protocol?
- Benefits of upgrading from an E5 ECU to an E8?
- Front o2 keeps failing P0134, Help!
- evoscan
- Need help!
- Help evo8 engine starts smoothly at low temperature (engine working temperature / 180
- evo8 The vehicle engine is easy to start when the temperature is low, but cannot be s
- Fixed the no crank no start. Now I have a crank no start issue.
- 4B11+T Tuning
- 96530706 Tephra V7 compatibility?
- Turbo/Bov issues
- EVO 7/8/9 MAF vs EVO 10 MAF signal
- Major Self-Service (Fluid Flush)
- Adjusting tune for exhaust manifold in ecu flash
- Using second 4 bar mal sensor as a barometric pressure sensor
- FIC 1220CC Low Z Injector scaling help
- Ceddy mods back ground noise (knock)
- Halltech elite 2500 Help
- multi boost switch
- Haltech Elite mounting options
- Upstream O2 required with evolink?
- Evo 8 with Evo 9 turbo log review
- What ADC inputs are available for an Evo 5?
- Evo 8 ECU on CAN system?
- Help with logging boost and AFR on Evo 5
- Thinking about getting a LinkG4X. Opinions.
- Evoscan logging map change
- What do I need to tune after cam change from 272cams to 280cams
- Emtron Evo8 plug & play ECU vs. Boomslang harness to KV8
- Buying my first Haltech questions
- Pops and Bangs Evo 6 ecu
- Ceddymods map switch
- SD vs MAF and altitude delta
- Galant 4g64 vs 3g Eclipse 4g64
- Radium Double Pumper wring questions
- Performance Modification Suggestions?
- AEM 3.5 Bar Map brass sensor OR OMNI 4 Bar?
- SD conversion
- P0401 After ECU Tune, No P0401 on stock tune
- Cant start evo 6 with cams and link g4+
- Air fuel lean issue
- Running Lean After Tune?
- Best tephra rom version for 93660005
- dealer reflash for p0300?
- Evoscan
- High boost low power
- LinkEcu and OBD problem
- Would someone smarter than me take a look at my log please? No LTFT, AFR unstable
- Has anyone ever done their own switchable dual low boost tune?
- How to control false engine knock
- Haltech Elite 1500 Help
- Unknown rom xml
- Rich AFR with new front O2
- importing and tuning an evo 4
- Startup issues
- Outlander 2.0T decat
- speed density set up
- AFRs on E85?
- Autronic help
- dual map flex fuel and speed density
- Boost Oscillating/fluctuating Issue w/Pics
- 6g75 help
- AFR bouncing, sputtering, and now misfire
- Evo SD 96531706 tuning questions.
- EvoScan Logging on the EU Colt CZT
- Stupid question about Alt Maps
- EVO 9 on a XR 8264s dyno chart??
- Revisiting EvoScan
- Evo 6 cutting at low rpm while driving
- AEM infinity vs Haltech
- Stock ECU Help
- Can you use a USDM EVO 9 ECU on JDM Model?
- 4g64 into suzuki sierra
- Evo 7-9 ROM Identification Tool
- Cold weather playing havoc?
- Evo 9 Detonation
- Ecumaster BLACK Emu anyone use it?
- Ecu numbers? Interchangeable?
- A/C Condenser fan cames on with ignition
- Hit boost without tune.
- Evo 8 Retune?
- Is it possible to train yourself to do tune changes on a non standard ECU?
- Haltech Platinum Pro plugin vs Link G4+ plugin
- Low idling, fan start with the engine
- Breaking 500whp
- Idle issue
- Kiggly 12-Tooth Trigger & AEM Infinity
- Evo Cam Idle Issue/Leak?
- Ecu
- Evo 4 tuning
- Vipec Idle trouble.
- Evo 8 remote tuner recommendations
- Fuel pressure too high
- Link ecu remote tuner
- Need a second opinion on my tune.
- CAR FLAGGED FOR CA State REF "PLEASE HELP"
- Looking for tuner for EVO 5
- Wiring in a Haltech Elite and Tuning
- ecu keeps fuel pump high voltage always on
- Phantom knock chasing ??? Evaluate my timing
- Setting up Rolling Anti Lag
- Evo 9 and some haltech questions?
- Can I tune away this problem?
- Need help with no start
- Will MN168749 (Evo 9 ECU) work with USDM Evo 9
- EVO 9 FQ320 XML file
- Need help logging AFR on EvoScan with Autometer Digital
- Evo7 ECU conversion into Evo4
- Help with deciding what AFR gauge and boost controller to use.
- Can someone please read my log and help me solve my airflow problem? Evo 4 with 6 Ecu
- Need Help! ECU Question!
- Question about my tune
- How many steps in IACV
- EcuTek Evo 9 ECU on a Evo 8
- Someone have FP54GREEN?
- Evo 9 Turbo installed and hot boi tune questions
- Afr reading’s for stock tune/bolt ons
- Best Haltech tuner for evo 8?
- Dump tube without tune, help!
- Best Tuners!
- Read MAF frequency
- Recommendations on tuning in Central PA?
- OEM EVO8 - Limits
- Wanted:965 evo rom map sensor voltage to load table for Tephramodv7 SD
- Evo 8 Basemap tune from Tscomp help!
- G4js anti-evo
- Anyone have experience with new FP green UHF ?
- motec
- Looking 4 Tuner/Help
- Haltech Map sensor
- Dataloggin on Mobile?
- Can i re-flash an evo 4
- Evo 8 RPM drop at Low RPMs
- evoscan
- New engine old tune
- Open loop fueling WAY off
- Evo IX MIVEC adjustable cam gear
- Fuel temperature sensor
- High impedance vs low impedance
- Need Help!
- Evo IX stuck at 5 deg timing
- Switching bov question
- P0134/P0171 code help.
- Hunting idle issue
- Please help
- How to choose an engine tuner
- Can someone look at my rom file please?
- Tuning for Kelford 272 Cams?
- Help
- evo8 ecu turning help
- Evoscan and AEM 4.9 LSU x series wideband
- Remote tuning
- AEM X series Wideband Installation question
- lean under boost
- Low boost knock issue
- Constant Knock at partial throttle
- Cams help
- Idle hang
- Faulty injectors
- I really need some tunes for my Evo 7 GTA.
- How stable is speed density (Tephra Mod) on Stock ECU? [JDM EVO 8]
- Looking for e 85 help
- ECU Mounting Options
- 2006 Stock Tune Evo IX ECU
- Evo V cranking issue
- How Retarded do I Have to Be?
- Is there a patch cable for twin ecus
- Locked ECU
- Can’t figure out how to disable rear o2 with ecu flash and the latest version of teph
- Rev limit set to 7500 but hits a wall at 7k?
- Logging Results from PO's Tune
- ACD + AYC data log please
- Engine Build Blue smoke from cutout
- Tune on octane92 but pump octane91
- Dealing with Knock and Hi Boost. Advice needed. Logs attached
