- Please Help With Tuning Stock 9 Turbo!!!
- burning oil
- 88840016 ROM evoscan Lambda voltage
- Which Flash to get?
- Fuel Map Help
- a "i feel retarded question!"
- utec
- Help, car feels like its hitting a brick wall under boost!!
- speed density tuning question
- Changing Tunes?
- Haltech or Pro EFI?
- drive ability on speed density with stock ecu tuning
- Speed Density Intake Selection
- bov advice
- Anyone running the HKS v pro ecu?
- Haltech Evo 9 plug In ECU VS Motec Evo 9 Plug In ECU
- Tuning noob. do i get 1.3 or 2.0?
- Evo 4/ GSR high temp sensor/EGT Sensor cheat
- Intake tune?
- Cobb access port
- how much boost on a stock motor....
- Haltech Platinum Pro
- question about parts and tuning
- virtual dyno
- Spark plugs for cold weather...
- just installed my Kelford 272's; how much more timing can i give?
- i need help with tuning!!!!
- Choosing camshafts
- High Idle after double pump install...help
- anybody know of a tuner in ND?
- Question about speed density and tune!!
- Low-speed tuning and jerkyness
- Quick question
- Decrease injector PW
- va tuners
- info
- info please
- Need help with tuning.
- power FC instruction manual?
- help with tuning.
- Best tuner along the East Coast
- How do I go blow through (MAP only)?
- Persistent Misfire Problem
- micro tech ltx8
- When getting tuned, how important is which software they run?
- Accessport still worth it?
- Issue while trying to tune. NEED HELP!
- Cam
- Xs engineering racemax cams
- AFR oscillating at idle
- Sun Auto Hyper Voltage System
- Any good tuning shop near by tri state ?
- Test Pipe?
- Evo 8 issue*HELP*
- Tuning my Evo 9 for better response, Mivec questions
- My Set up
- 780 injector
- HKS Twin Power DLI II Ignition amplifier
- Will COP from Older DSM Like Evo 3 Work on Evo 8 with work?
- HKS EVC boost controller help!
- Now that my Evo is fixed, is my tune bad?
- disabling P0300 code and emissions testing...
- p0340 and p0335 codes
- Buschur Racing Hobb switch
- Help I have a TPS/MAP issue on an AEM EMS
- Does anyone know if a evo 5 ecu can be flashed to a evo 8
- Evo 5 harness and ECU in EVO 8
- Will 4G64 Crank Fit in 4G63
- Wideband installed wrong?
- MBC needed to tune
- Anyone have evoscan?
- Need of tuner!!!!!!!!!!!!!!!!!!!
- make new fuel maps for new fuel pump?
- Dyno question
- Wide-band O2 Sensor Placement
- First time tuner
- Best place in Dallas to tune evo 9!!
- Evoscan problem w/ stock ecu
- Can removing MDP sensor cause knock? MDP Function in Evo 9?
- EvoScan 1.3R Cable Not Recognized by EvoScan 2.8
- Noob tuning question
- WB warm-up necessary?
- wastegate crack pressure
- Ecu flash works just fine Evoscan doesnt recognize obdII usb.
- Need some good tuning advice....
- best place for tune in South FLorida?
- need input on what i should so with my mods
- Engine wont run smoothly
- Which tactrix?
- Cobb AP custom map?
- 93 tune to a 91 tune?
- would cobb be right for me?
- 1050cc injector questions
- zeitronix 3.5 boost sensor
- EnglishRacing Now Cobb Dealers
- Aem fic
- I have a simple question.
- 2 tunes?
- posted this in a diff section and got no answer
- AEM UEGO Best Wideband?
- Modding without tuning?
- Bad MAF?
- Speed density vs maf
- Cold start idle/stalling issues
- Having something weird going on??
- Pressure sensor
- Do I need a re-tune going to an open dump tube?
- Searching for a good set of det cans
- LTFT fluctuation?
- Prosport Wideband - HELP!
- pro efi
- 3 Bar Map Install
- delay on accelerating and back firing after changing spark plugs
- Replace my Mines evo IV ecu?
- Knock alert idea?
- 08 Lancer ES engine build up upgrades more whp
- hello everyone id like to know more about evoscan
- Prep for Self Tuning
- Scan tool evo 7
- Need Retuned?
- epifanSoftware ecuEdit
- ? about evoscan V2.8
- question on vishnu
- Best way to start building up your evo
- ScanTech and Tactrix 2.0
- need new clutch
- Tactrix Open Port alternative
- Coolant leak and idle problem
- Stock ECU Won't Start but AEM does it!
- Vacuum leaks?
- Blitz sbc id over boost issue
- Having a Spark crisis...Dont know wat the hell happened!
- Boost solenoid vaccum problem
- What dyno numbers should i expect with my setup??
- car runs rich after installing uicp/licp?
- More Innovate WB 02 problems
- Injector firing issue?
- HELP my evo!!!
- Evo 9 ECU pins
- Defi Gauge Question
- STFT at idle really weird
- Tips for tuning (I'm new in this)
- Good or Bad AF MAP?
- FP Green tuning out torque?
- Stock ECU
- anyone ever heard this leak?.. VIDEO INSIDE!
- Can I run pump Gas on 10:1 with 272 cam
- Egr blanking
- GT35R 2.0 comp ratio?
- Help!!!! Overheating problem
- Curious about my tune
- Please Help.
- Hoping someone can help me out!!
- IS Tome the A/F a wideband O2?
- Any shops in ohio near the Akron area that are evo worthy?
- Running Rich WOT
- Evo Scan/Tactrix Cable
- Speed Dencity....don't know the first thing about
- evo 260 wiring diagram needed
- help to choose cable?????
- Idle problems need advice
- need expert advice
- Aem ecu knock sensor problem
- Knock!! What to do??
- When Evoscan goes berzerk (funny)
- LM-2 any good? Which wideband?
- Evo 8 will not idle on its own!
- HKS EVC 6 issue
- Please help! Third gear log provided.
- Tips on smoothing my timing map
- i need help
- ....another quick E85 afr question...
- 05 evo ecu
- Issue Installing Cobb AP
- got my tune but have a few ? before i flash my ecu...
- Recomendations for remote tuner
- Mustache March: Cast your votes now!
- Unknow Rom image
- Tuning revision pls :)
- Evo scan acd and anti lock flash
- Power FC cable/tuning options
- new to tuning...what do I need?
- Anyone familiar with Haltech plug in ecu setup?
- Dummy question
- Issue with tune
- ebay cable
- DIY on throttle surge control
- SD or STay w/ MAF
- is my map smooth enough? noobie
- EVOScan logging issues
- Tuning game
- Evo 8 wont run! need help
- Questions about MAFTpro
- 2003 evo 8 fuel pump whine/leans out
- help !
- Injector dead time questions
- Tune?? soon??
- base map?
- knock on evo ix.
- Making evo show worthy?
- Injector install and tuning help.
- Ditched the stock Evo7 fuel pump for a Walbro
- A/F Question
- cruising AFR
- Best spark plug wire set?
- mellon email tune
- Passing emissions testing with a JDM Evo 7??
- idle open loop
- code 13 on autronic
- Common reasons for "Very small evaporative emissions leak"
- Any of these features sound familiar?
- Tunners advice please
- New tuning Mutigauge
- Starting Tephra V7 mod
- standalones with knock control?
- clanzers mut monitor help
- Fuel pressue Reg
- PTE Injetors
- evo5 rvr
- Blow off valve?
- evo 8 ecu for sale
- Intake installation without tune
- timing and fuel maps
- Aem went bad what should i do
- misfire when cold
- Choosing tuning software
- aem ems tune questions
- Haltech PS1000 Evo8 Basemap
- ECU Wiring Help
- Link g4 xtreme vs haltech ps2000?
- 2 1/2 " O2 outlet for 3" turbo exhaust??
- Evo Engine timelines
- Ecu wire remove
- S-AFCII -- Say what?
- MDP (boost) reading at idle in Evoscan
- Evo 6 fuel pressure and flow
- Maintenance Reminder
- car wants to stall?????
- difference between knock sensors
- best timing advance for startup cranking?
- Cobb AP reprogramming....
- Uneven compression in cylinders
- Aem wideband help
- Evo v stall
- 2010/11 stock map on 2008 MR
- Need a good tuner for motec.
- aem wb cable help
- Relationship of: IDC / Meth / Loads v RPM and Gears - maybe noob question
- Anyone have experience with a usb to obd2 reader?
