PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Wideband vs narrow band
  2. Ems??
  3. Cam gear adjustment??
  4. What is this?
  5. where can i get the aem ems the cheapest!!!
  6. Need help tuning!!!!!!
  7. Pfc tuners
  8. battery being drained
  9. 03 ECU in late 04?
  10. How normal is this!!! LEAN..
  11. odb socket
  12. help choosing the right injectors!
  13. Quick question power FC
  14. Tuning in AZ
  15. New Injectors and Fuel pump advice
  16. Load % problems on a 2g with Evo 8 ecu swap...
  17. COBB AP Protuning VIA Guam
  18. AFR Map Logging Issues
  19. UEGO WB02 Sensor in place of the front narrow band 02 sensor
  20. Sputter Sputter (video incl.)
  21. UTEC Help!
  22. Need help with Datalogging
  23. your settings
  24. AEM Boost Gauge sender mismatch
  25. need help w/evoscan 2.5 com1 issue
  26. EBC Help
  27. Injector help need
  28. ap dyno app
  29. AEM WB02 vs ProSport WB02 - Logging question
  30. Climate Control Electrical Help! Please!
  31. need help?
  32. Rear O2 Sensor CEL Question
  33. Changing roms
  34. A Question about rebuilding Engine
  35. Get an HKS Suction Pipe to Idle at 38Hz ? ?
  36. Exh Cam Timing on Mivec Evo IX
  37. tactrix problem
  38. LM2 to Evo OBD Connection - Help
  39. queston about tuning
  40. Question on my tuning has this happend to u!
  41. Fuel Pump
  42. Brand new gsc s1 cams
  43. Cel p0202
  44. where did you mount your standalone?
  45. Why is it mbc>ebc
  46. how to check timming!
  47. Open source tuning?
  48. boost control ?
  49. I need to hold more boost up top
  50. Timing Question
  51. quick question
  52. Wideband
  53. Gizzmo launch control
  54. plx or LC-1?
  55. EVOScan question
  56. How do I adjust idle? P0507 code
  57. Question : EVC 6
  58. What are some must have gauges??
  59. LC-1 Troubles
  60. Cat install after tune
  61. Killing Timing Belts
  62. data logger
  63. car dies when headlights are turned on?
  64. HKS F-Con
  65. is accessport stage 2 ok with these mods or will my car run funny?
  66. Evo 4 Ecu
  67. Noob question: AFR gauge range?
  68. timing maps
  69. turbo timer install help needed
  70. o2 senor?
  71. innovate lc1 help
  72. not sure if im running into a problem or not...
  73. Look what UPS just brught..V-PRO 3.3
  74. emissions machine not reading my ECU???
  75. need hlp asap
  76. Is there a solution/workaround to the Apexi AVC-R Settings-Bug?
  77. Mut Monitor V1.9 Release 31/1/2009
  78. Who has pushed the power fc?
  79. .....Threw a Rod,.......
  80. Evoscan question
  81. manual on apexi FC(english) for russian
  82. Error: No response from vehicle ECU
  83. Open air filter shuddering on boost.
  84. evo 9 JDM map sensor vs evo X USDM map sensor
  85. DYNOFLASH and ICS Experience
  86. Tuning a Red with cams....injectors?
  87. Converting MAF to MAP Sensor
  88. Tuning a stock evo
  89. Help quick question b4 i order
  90. Coil pack getting hot and not firing!
  91. Pfc with New Map sensor(3.5 bar)..
  92. Stuff for tuning
  93. Anybody installed big injectors???
  94. help me
  95. For ALL you AEM A/F Ratio Guage(rs)
  96. setup questions for my evo8 pnp
  97. New Map Sensor for PFC ( apexi AVCR- 3.5bar)
  98. DLL Definition for Evoscan 2.5
  99. Clutch HELP!!!
  100. LC-1 w/ vista
  101. Damn ECU is "LOCKED"
  102. No difference b/w Ethanol and Methanol?
  103. Installing Apexi AVC-R in Evo X
  104. Wiring up a knock sensor into an aux jack.
  105. Helppp!!!
  106. Autronic Cold Weather Blues.......
  107. tuning with macbook
  108. apexi avcr 4 bar sensor.
  109. Mut Monitor V1.3 Release 10/1/2009
  110. racegas + meth??
  111. AIT Sensor Upgrade?
  112. Car is knocking
  113. Evoscan 2.5 Link??
  114. higher boost
  115. Engine Cranks but wont fire
  116. Mivec Head on Evo 8 block??
  117. Temporary wideband O2 sensor installation for tuning
  118. check engine light on
  119. Octane Testing
  120. dual stage boost controller and tune?
  121. something rubbing up front??? help
  122. something rubbing up front??? help
  123. Silver box ECU+ with extras!
  124. Do I need a Engine Management System?
  125. Evoscan problem
  126. Upgrading to IX turbo tomorrow!
  127. some advice on tuning
  128. Boost level's and high octane
  129. ICS Steps Evoscan
  130. from crappy socal 91 to North Carolina 93.
  131. Greddy Profec B Spec II Owners
  132. logs from 2 different tunes, feedback please
  133. Autronic calibration needed
  134. Tuning 4 Faster TURBO SPOOL
  135. Autronic with knock control!!
  136. Will this Fit?
  137. Evo Scan not working...
  138. EVO6 Bench ECU
  139. Evo 8 Detonating / Sputtering horribly Please Help!!!
  140. De-Jetro MAP Sensor Install
  141. EVO Guru's help....!!
  142. evoscan question
  143. Where's all the info gone.......
  144. water temp reading incorrect
  145. 500+whp on stock 2 liters??
  146. Installing an evo 8 usdm d jethro in an evo 7 JDM
  147. evo IX 16g is an FP red?
  148. AP Manager-AP not communicating
  149. kelford 272's and stock valve springs?
  150. Spark Plug Torque Down
  151. Need some help using ecuflash
  152. please help need older version evoscan
  153. Newb question
  154. EVOscan: playback problem
  155. problems with car and occaisional p0303 code.
  156. WTB: ECU+ Silver pnp box
  157. Apexi AFC NEO & HKS EV VI, Will these work together?
  158. Unstable idle, car almost stalling at low speeds, need help
  159. PowerFC controlling 8 Fuel Injectors
  160. Getting rid of MAF on stock ecu?
  161. Questions about APEXi AFC Neo
  162. Utec map
  163. TBE gains with and w/out catalytic converter
  164. o2 housing question
  165. Help with LC-1 and evoscan
  166. ECMlink vs ECUflash
  167. Ecu Pinout.. Can anyone help? JDM evo8 -7 -6
  168. EVO ECU pinout?? Power fc problem Evo6-7-8
  169. rpm raise neeed help!!!!!!
  170. Where t o download the EvoScan?
  171. Data logged a few times
  172. Greddy Informeter Touch and Boost
  173. question about cams
  174. Dwell time (dead Time) for COP..
  175. What is the most HP increase with the AP
  176. What's Cobb cooking up?
  177. The Next BEST upgrade? HELP
  178. P0303 Misfire!!!
  179. What is the gain set to on your EBC?
  180. Precision 780s
  181. AP the most user friendly EM?
  182. Tuner Options In Socal
  183. two mods = lean afr
  184. Do these trouble codes mean anything?
  185. backfire/hesitation under acceleration
  186. Knock in High Boost with Right AFR
  187. How to read ECU error codes with EVOSCAN ?
  188. THRO check light Power Fc evo VII
  189. Logging with alternate Wideband O2
  190. tuning question
  191. need some opinions
  192. EvoScan problem
  193. Free flow cat vs testpipe
  194. Innovate lc1 sensor replacement
  195. Adding AEM UEGO Wideband to AccessTuner Race Software
  196. EFI 101 Class
  197. Which Tuner to go with?
  198. freeze plug
  199. what computer do you use to tune?
  200. quick EvoSan and Tactrix Question
  201. engine issue
  202. WTB: ECU+ Silver pnp box
  203. Weird situation throwing p300 code.
  204. O2 Sensor Check engine light
  205. ECU Options
  206. Noob questiosn - coming right up ^^
  207. Dtc P0234 On Sacf2 And Avcr??
  208. Stock Head
  209. 2g Dsm Ecu + Dsm Link
  210. power fc and use of wideband?
  211. WORKS ECU flash development - behind the scenes
  212. Dyno numbers 313.2 whp on Dynodynamics, Dyno4mance tuned (Thanks Bruce and Andrew)
  213. 4wd traction control
  214. Exhaust gases smell a lot fuel!!! Could be a problem?
  215. Injectors
  216. Nashville Shi Pal Tennessee Evo Mechanic
  217. Nashville ****en Tennessee Evo Mechanic
  218. MAF or MAP with PowerFC Setup
  219. evo 8 ecu on evo 7
  220. new dyno update! 340whp! =)
  221. anyone using Vi-PEC
  222. New Projects?
  223. UTEC and Tuner Pro Set Up List in Private For Sale
  224. need a good evo mechanic in nashville tn please help!
  225. Anyone running Haltech on evo IX?
  226. Datalogit won't plug into PFC ?
  227. lc-1 reading 15.1 problem
  228. gauge choice
  229. dc sports exhaust and wideband
  230. Anyone ever use LS1 coil packs.
  231. Best Stand Alone for E85???
  232. do you think we could
  233. stupid question....
  234. Tuning gear?
  235. Really need help, greatly appreciated!
  236. two sets injectors
  237. I just purchased the BR filter kit and...
  238. Hks F-Con vPro
  239. Best laptop for factory ecu
  240. Evo patch harness
  241. How much timing and boost are you running?
  242. new to tuning
  243. I found this ECU upgrade
  244. Oem Ecu Trouble
  245. Total MR swap
  246. Tuning questions
  247. Turbo XS DTEC, where do I start?
  248. non-tune mods
  249. No Lift Shift?
  250. Mvec control
