- No reflash needed?
- high RPM misses??
- Air intake tune question
- s afc settings gone after car is off- anyone experience before?
- biggest injectors to use w/afc
- SAFC2 or UTEC
- Turbo Timer/Security system concerns
- Jestr Flash
- stock datalogs
- Profec E-o1 problems
- Custom tune question
- Where To Buy???
- kudos to TOPSPEED
- UTEC Loses Power at constant throttle
- L-jetro w/map sensor
- Cheapest Place To Get Fuel Cut Flash
- Knock from bad gas?
- Need help with wiring!
- Question on returning car to stock tune ....
- Next Buschur Tune Day?
- which intake should i choose
- Utec Maps??
- base timing MAP
- CEL flashing before start
- datalog results
- Misfire
- How do you delete maps???????
- TurboXS UTEC ?????
- xs tuner
- Autronic and knock controll
- Switch to XEDE SMART?
- EcuTek after dealer 0300 reflash
- Want to eliminate your MAF?
- Precision Dyno road trip
- Need help ASAP w/ SAFC II
- ECUtek vs. Tekcom (tekrom) sp?
- MBC Help
- Reflash in So Cal?
- ecu i can tune myself.......
- removable ecu upgrade
- Forge BOV from vividracing
- autronic site or know where i can get one for a E4?
- What do you think….
- utec timing with 272's and T67
- S AFC II for sale w/ Plug and Play harness
- Power FC tuners in Socal?
- Engine Management Survey
- Another set of logs, opinions wanted.
- To ECUTEK or not to ECU TEK
- good deal on harness
- jestr tuning
- Datalog ?s'
- Best Aftermarket ECU For my Evo 5
- hks bov ver2 no tool????
- only one problem please help
- Is my UTEC strange?
- NEW Question about Wide Band 02 bung placement
- ems vs ems vs ems etc.......
- GM Boost Control Solenoid Part Number?
- Ecu +
- HELP!! need advise
- Not running right after k&n intake
- initial setup for an used safc2
- Greddy type-rs blowoff valve
- Factory p0300 flash and UTEC
- Who has timing greater than 11 degrees at peak torque
- Will this Blow-Through MAF work?
- evo injectors
- P0202 code.... causes...??
- Maximum timing
- Trick electronic mounting?
- Just starting to tune my car & have some questions.
- Issue with PO234 Code
- My Alky problem NOW SOLVED!!!!!!!!!
- Service Engine Soon light...
- Running rich?
- utec map selector
- WTB- Apex AFC 2 w/harness
- Questions about MAP sensor
- maintanence help
- Reflash as a base map?
- palmnstein or pocket logger software?
- UTEC Questions **Advice Needed**
- new FP, now CEL
- First log / couple of questions.
- Just Installed Injen Intake and Forge RS BOV NEED HELP
- Brand New AFC !! FOR SALE!!!!
- TunerPro/EGT Question
- DIY (Homemade) LM-1 RPM Converter
- map sensor
- AVC-R problems !
- Engine Overboost...getting pissed!!!
- tuning question???
- make more hp?
- TurboXS RFL BOV
- help with TurboXS RFL BOV
- Looking to buy an Autronic PNP
- ABC installation (Look ok?)
- AFR ratios?
- MAF sensor problem.......I think.
- Car got hiccups
- dyno tuning ny/nj/long island
- here's my tuner pro
- Utec newbie questions.
- SAFC 2 w/Harness For Sale
- knob settings for Alkycontrol-street tune
- best ecu flash?
- just bought utec used???
- Hesitation when I go WOT
- Stock ECU RPM Signal, voltage or pulse?
- fuel pump 255 help
- PFC and intercooler sprayer control???
- Am i Running too lean
- Florida UTEC owners in need of tuning...
- stand alone tuning
- Which Safc Ii Harness?
- When should i tune?
- PnP ???
- Tuning for 100% Methanol Injection
- meth injection
- afc II password reset???
- Weird Boost Issues with EBCS Solenoid
- Wish me luck tomorrow with meth tuning
- Haltech Plug and Play system for EVO Lancers
- boosting around 24psi????
- ground wires
- help with safc install
- Mitsubishi Evo Hks Carbon Exhaust
- so whats everyone making???
- Black Face S-AFC II For Sale!
- MalibuJack's NEW UTEC Wishlist...
- xd-3 questions
- Looking for a good tuner
- BUMP for Turbo XS Response
- Launch control with an on/off switch?
- Will There ever be Speed Density?
- Why Greddy Emanage?
- dynoflash + boost controller
- Is it safe?
- Can we set up a map database?
- "Base" map on an 05
- Zeitronix accuracy
- farmers dyno sheet.. blah..
- flash and lg injectors..
- Well I did it
- First UTec log
- Does anyone sell Blowthru Meters anymore???
- Back from the drag strip with tuning question
- Tuning HKS 280's
- PO300 code problem
- p0412 code keeps poping up. what is it?
- SAFC2 fpr sale CHEAP
- TT or Dynoflash?
- txs tuner reading lambda
- UTEC map tables RPM range?
- Question bout s-afc II with wideband
- trying to figure out @ what rpm should you be @ around 11.5?
- can't get my pocketlogger to work.
- Mustang Dyno Graph Thread
- Is UTEC really all that limiting?
- engine surging?
- ecu
- My 1st Datalogs
- Coil On Plug DIS-2 question
- Will MAP sensor install change MAF...
- My Dyno graph.
- evos downtuned from factory
- UTECH vs. EXede
- tuning with SAFC
- 4 wheel Dyno in Wisconsin?
- Just got my XS UTEC!!
- dynoflash- mail in versus custom
- New Way Of Boost Ctrl
- TurboXS would like your help! MD/VA/DC Free Road Tune!
- tried 104 octane...disappointed
- Autronic PnP shopping
- AFR question
- Help, my evo does not start with PFC...
- Reflash and S afc
- For those with a fuel pressure guage
- UTEC map sensor
- Dyno day with Marco Passante of Magnus Motorsports.
- Water/Alky/Meth tuning
- home-made "racing chip"
- should i go with Utec?
- Question regarding S-AFC
- Reflashing in my area???
- Trade S-AFC1 FOR S-AFC2 BLACK
- Who stocks the UTEC MAP sensor?
- Question for you EVO guys,...
- Which Engine Management 2 go with?
- What is an acceptable knock count?
- GM Maf with Utec
- EManage Help
- Peak/Hold Voltage for FIC injectors
- guys save your car and read this if your new to the afc
- Stock ECU Modding
- People with FIC injectors, please help......
- Need a UTEC tuner in South Florida
- Building a DYI knock listener
- just installed new UTEC, sweet!
- Palm Treo 600 HyperTerminal software?
- Meth & SAFC
- Apexi Power Fc for 05 evo
- Rev Limiter
- TurboXS KnockLite
- UTEC and 880cc injectors?
- Wierd anomaly
- Remote map selector install -- I'm lost
- Knock Value
- went tuning for 3 hours...heres what i did...
- SAFC-II 2500-3500RPM Problem
- Timing/boost with race gas
- Ecu Flash or TurboXs Utec
- myth?
- Downpipe? ... next step in mod? help...
- utec tune on dyno
- ECU Pinout information
- Utec for GT35R??
- whos using the Evo 7 Power FC for the USDM Evo 8?
- Odd Utec question
- Motec M800
- Adjustment after adding Fuel Pump
- BOV Questions
- Cams = more rich than before?
- UTEC pulled timing?
- anyone running xede stage 1 w/o cam gears
- Can someone here help me to post 2 Hertz vs. RPM graphs?
- UTEC Vs. AEM EMS
- BOV need a Retune?
- What is the best way to read knock?
- Want car to go faster! HELP
- Super lean problem
- Review. Perrin EBCS + UTEC
- rpm does not match
- Questions about Utec
- ECU Reset
- HOw to enter TXS stage 1 or 2 fuel/timing/boost map
- Abc?
- safc2 solution for EIDS
- Harness for Emanage Ultimate
- Recirculating or VTA Bov for Utec?
- UTEC tuned at Harman Motive.
- Vpro who tunes near cinci?
- AVC-R thread QA
- Datalogger for MacOSX?
- Tuning R&D for those interested . . . .
- UTEC not displaying any numbers in Knock column
- S-AFC 2 monitor readings
- datalogger
