- M16C Experts?
- AMS Custom Tune?
- Evoscan & Data log lab logging questions
- AEM EMS or Stock ecu
- repin maf plug
- Will I need a wideband for my planned setup?
- Another cobb issue. help!
- AEM Tru boost question
- Thanks to Andrew & Bruce @ Dyno4mance
- WORKS flashing on the East Coast
- Evoscan logging issue with frozen fuel trims..
- next mod
- Pic of the idle bleeder screw
- evoscan not initializing
- innacurate wideband readings in evoscan 2.4
- Need a bad ass affordable stand alone?
- Water temp on Evoscan
- Where do I connect the "BARO" wire on an Evo IX?
- Pectel E2 Engine control for Evo
- 4th gear pull WOT timing advance
- Using Tuner Pro with Evoscan
- tactrix cable question
- Ecuteck / Emissions Help ! ! !
- Autronic Roll Call!
- Openport 1.3 cable w/out datalogging??
- AP and wrecked car..
- Which ECU?
- (Trinababe) Looking for the software (CD) for the greddy blue emanage
- How to tell if my engine is running too lean or too rich??
- AEM Tru Boost controller
- Is the AP worth it?
- need to upgrade injectors for evo9-20g+cams?
- tuning in nj?
- Any issues not having knock control?
- 2003 evo 8 rom
- Stock Injectors
- looking for a tuner in colorado springs
- Help need a tuner in Tampa, FL
- tatrix cable
- Jestr coming to Miami??
- zeitronix data logging problem?
- Mitsulogger version
- Tractrix 2.0 cable does NOT work with EVOSCAN!!!
- Walbro 255 fp install/ wideband install..lean idle afr!
- largest injectors on stock ECU??
- Anyone running MoTeC?
- Need Tuner in or Near CA That Can Tune For MAFT
- Does Tuning Affect Reliability
- boost drop problem please help
- Evoscan problems, need help
- Can we get this section to read "Autronic?"
- NGK Wire set for VIII
- New Power FC Install
- injector scaling
- Newb to maft pro
- Tactrix Cable blown component
- LC-1 Calibration
- loosing power plzz plzz help
- basic bolt on sean ivey tune
- Cobb cable use for ECUFlash?
- Motec M800 maps!!
- Access port on E-85 fuel tune
- Any Tuners for EVOs in the San Bernardino County?
- cobb ap w/mbc knock problem
- Evo 6.5 TME
- How to quick tune ?
- Ecu Link G3 Tune
- BF P2R + Tephra Mods
- ECUtek question
- quick boost question
- C16 Race Map Help.
- Low End Power Modz??
- what i need?
- anyone used the innovate lm2 yet?
- Race tuner live tunning/datalogging
- tune for nitrious?
- tuning for air/fuel
- Driver install issue
- What else besides a GM MAF
- Was going to pull my motor but . . .
- Hallman MBC, NOOB needs help
- Access Race tuner question...
- p0243 help??
- Pfc Tuner
- Aem Wb
- TPS voltage
- SAFC bad for the EVO?
- Tuning the RED.. Where to stop cranking the boost?
- Stock Evo 9 MR rom file
- No misfire, 0 knock, low timing advance???
- Does tactrix still sell logging cables?
- MAF sensor problems!
- Wideband/Boost controller opinions?
- Just got Tuned and now error codes
- tuning school
- what injector size???
- Gt Pro Performance????
- sotck bottom end durability
- Stroker pistons on stock crank?
- Methanol
- AccessTUNER Race for Evolution VIII/IX
- LC1 Analog out as o2 sim
- Stock 8 Turbo Gears to -9/-9 ???
- Is it worth it ?
- How to identify an Evo 9 turbocharger?
- vishnu tuning....
- HKS 280 Cams?
- mail in flashes?
- Learning how to read logs
- Real ALS
- Tell me if this tool will help me?
- New AccessPORT Firmware
- Differences between stock airbox and open filter
- Wideband calibration during decel with Evo
- HKS EVC VI qusetion???
- autronic SMC for sale on ebay
- Topspeed Dyno Tune
- Topspeed
- AP Tunes??
- Please help diagnose my friends IX
- hks knock amp wiring
- NewTurboBack - flat dead at WOT
- putting a cat back on the car, reflash needed?
- Evoscan 2.4 and ACRelaySw field
- evo scan ?????
- EVO8 low boost (11psi)
- speed density vs blow through?
- How to learn this stuff basics to all of it?
- 2003 evo
- o2 housing?
- Stock Evo with MBC - what psi to set?
- Greddy T78 33D
- What cause car to stalled out in neutral??
- cooling fan fix
- the antilag will damage my turbo???????
- What kind of power should I get with these mods?
- EVO IX ecu location
- Boost map question
- P0403 And P0107???????????
- autronic smc FS: switching to sm4
- AEM Tru Boost Tuning - Need some advice please!
- evoscan 2.4 not working with aem wideband but version 1.0 does
- Most Important Guages For Tuning
- Difference between EVO Turbos
- My mod choices
- StandAlone Computer
- Does AP have Boost Reading?
- Want to have my buddy tune the car what software for stock ecu?
- which aem P&P or Universal?
- stock ecu issue
- V-manage
- cam sensor issue or ?
- does anyone sell evo maps yet? Cobb AP
- GSC S1 cams, Walbro?? Should I buy that??
- HELP!!! Car stalling!!!
- change filter, AFR?
- Ecu+ for sale
- Anyone get rid of their Service Engine Soon light?
- Boost Conroller? Manual or Electric?
- which wideband to use for logging and tuning
- Evoscan v2.0 DLL definition?
- Oxygen (lambda) sensor help
- Acoustic Dynamics
- Just got a live demo of Zeitronix DashDaq touch screen datalogger
- Big Problem not very happy
- AccessPort code issue
- Stock Evo IX MR ecu flash?
- how do i log wideband 02 with mitsulogger?
- ecutek
- hi guys
- Vinshu 400 package
- Hello From Guatemala, Pls I Need Help Experts With My Pfc
- Fuel Injector Plug Pigtail replacement
- Any vendor still have a brand new silver ECU+ in stock?
- Car nearly stalled..Need help..
- FC commander question
- MAP Sensor Wiring Adaptor
- need a little help...
- help something is wrong
- warning about perrinc ebcs
- Zeitronix/boomslang problem. pics inside.
- hp loss from high air temps?
- Zeitronix users, quick?
- Optional boost control help thru ECU
- Problem ecu ralliart
- extreme power cut falls on face!!!
- Lc1
- I Need help to tune or re-program my ECU (Evo III JDM)
- Local Tuner search
- Power FC D-jetro wiring Diagram
- Turbo timer - car shuts off as soon as I turn the key
- AMS short block question
- 2003-04 EVO 8 HP & Torque after tune
- HKS EVC VI question!!
- Engine Management
- Prosport Gauge Issue
- Zietronix ZAVT-1 Parameters?
- ecu harness evo ix
- Best Brand for my Evo VIII
- Cobb TBE getting louder and louder
- Flating out my boost
- Autronics
- DynoTuning
- knocking
- twin plate exedy clutch
- Tuning, do I need it?
- Hallman Pro vs. Hallman Pro RX
- Do I need a Reflash?
- engine problem help
- Weekend Tune
- Anyone know a datalogger that can support intercooler inlet/outlet temps?
- n00b question
- where do i plug in my tactrix cable?
- New EVO IX maps
- 03 evo problems
- apexi avcr connections
- DDL evo 9 definitions
- boost problem
- Hi New To This Forum Help
- maft or maft gen 2
- can the ecu lose its reflash somehow and go back to stock form?
- Mitsulogger!!
- What knock count should make me worry?
- Exhaust Minifold
- Evo 8 Tune with Selection ??
- running problems
- Logging Funtions With Autronis - wow
- e- manage for the oz
- EVOlink G3 Plugin Engine Management
- Maf ?
- Getting my car tuned by MINE's? contact info?
- ROM read & write error.
- Need some help
- question??
- Can I use JDM Boost Sensor on Zeitronix Display?
- random missfire CEL problem on EVO 8...
- i need numbers help!!!!!
- Whats the best Engine Management System for a 9?
- injector question
- evo 8 map
- Which EBC? AEM TruBoost or Greddy Profec B Spec II?
- EVO MR help!!!!
- EvoScan setup help
- EcuFlash v1.35 and v1.29a
- Hey Malibu Jack, Help! Losing My Afr's, Mitsulogger
- How to fit PnP IX + sensor
- Problems using the MAF Translator on MAFTPRO
- TPS Calibration
- Walbro installed today... AFR observations
- Tuning in General?!
