PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28
  1. Airflow source question
  2. switchable maps...
  3. JUN computer?.
  4. Anyone seen this?
  5. Engine tuning
  6. Will sampling you wideband from your dp vs a tail pipe sniffer make much difference?
  7. Car doesnt run after install... Help please
  8. Why cant i get to the setup parameters?
  9. flash question
  10. understandin Lo/Hi Throttle points...
  11. exaust for Evo IX
  12. Greddy Profec II problems
  13. How much TPS/MAP enrichment are you running
  14. Air Temp Sensor
  15. IveyFlash using Ecutek
  16. Wide band sensor location
  17. Aux Outputs
  18. Knock Setting
  19. DLI II - UCC datalog
  20. hi/mid/low and ve questions
  21. Another batch in stock!
  22. Logging: Dell Axim?
  23. Look at these 2 logs..
  24. ssl
  25. dc sports manifold
  26. I can't upgrade firmware with my palm pilot?
  27. Competition cables
  28. Hey TTP
  29. stroker kit
  30. knock values, are they legit??
  31. MR ecu on non MR 8?
  32. UTEC Launch Control Question
  33. Official Ecutek Dealer
  34. Do i need a heat sheild or a turbo wrap when I install my DP
  35. apexi safc 2 BLUE for sale
  36. RPM's on an AFC-II
  37. General questions about beginning to tune
  38. s-afc screen not working???? help!
  39. Just Got Ecutek Tuned at Precision Dyno
  40. TurboXS UTEC + Tuner for sale
  41. Air intake sensor error
  42. Evo3 SAFC2 Fitting Help Needed!
  43. MicroTech Information Wanted!
  44. Cold start
  45. what little time
  46. ECU+ and Wideband connections
  47. Timing to help Spool-up
  48. Emanage maps & Unit
  49. Help Please!!
  50. Anyone got one of these?
  51. New features on Utec question
  52. injector gas withdraw w/afc
  53. Question about aftermarket intake sound
  54. S-AFC 1 install help
  55. stock afr
  56. ABC boost spike/taper
  57. We would like to see your bins
  58. start hz mapping question
  59. Temp dropped now my knock reading is HIGH!
  60. Wierd knock back-off issue
  61. Tunerpro RT want list...
  62. Screenshots?
  63. Drop in filter to Helix intake change?
  64. Question for Tom :)
  65. Ecutek no lift shift
  66. MAFTP with reflash
  67. Deleted my ADS file
  68. Does anyone here use MAP ECU?
  69. wideband and afc II
  70. Hotside upgrade
  71. 05 MR at 21psi, 94octane
  72. where can I learn how to tune?
  73. EcuTek flash - checksums
  74. Boost "Control" Flashes
  75. P0456 code question
  76. Knock reading
  77. How Brain Tuning WORKS.....
  78. WORKS Brain Flash P2
  79. stock safc 2
  80. How is the initial tune?
  81. Launch control with 05s
  82. 280 cam question
  83. Finally a nice day outside.
  84. Which EMS should i use?
  85. Questions about GM 3inch MAF.
  86. Al, Mark your Dynoflash calander May 06! WWII
  87. CAM GEARS & 264'S
  88. Do you realize?
  89. Timing Adjustments
  90. EVO MAFT (std version) available soon
  91. MAFT Pro Info and clarification
  92. Apex-i GT Spec exhaust with clearance?
  93. Help with map
  94. How often do ECU sample vehicle speed
  95. problem with injector scaling to 720cc
  96. EVO Mods Question
  97. SAFC-II Red!!!
  98. Methanol Injection Help
  99. S-AFC II on top of Tune???
  100. Boost controller question?
  101. AEM UEGO Wideband vs others...
  102. Installation of S-AFC-II
  103. ETA on timing control
  104. request for EcuTek Flash in Minnesota...
  105. Use a 05 ecu in a 03
  106. SAFC-II and stock ECU for timing...
  107. What Is This Ecu +????
  108. Upgrades for my ECU Plus
  109. what version of emanager??
  110. Clear the confusion??
  111. Fuzzychi- clear some space in your message box
  112. UTEC Map sensor- Malibu have question
  113. TPS changeover point for alky tune?
  114. Wideband A/F Question
  115. SafcII...want to boost higher. do i need bigger injectors
  116. Emanage Ultimate
  117. Highest power output with the Utec?
  118. Found plug gap setting which works with Meth. inj.
  119. ECU+ and Zeiotronix?
  120. How do you know if dealer reflashed u?
  121. Boost Problem Question
  122. Front O2 Sensor w/ PFC
  123. Smokedmustang Video of Launch Control, sidepipe!
  124. Anyone Tune Apexi Power FC around Minnesota?
  125. TurboXS Utec for sale
  126. ecutec for mail in
  127. ECU+ inaccuracy LM-1 wideband reading...
  128. EcuTek boost control?
  129. No lift to shift w/o using launch control?
  130. How to hookup AFR input
  131. Check Engine Light?
  132. Tuning in Philly
  133. ECU+ For Sale
  134. EGT Temps
  135. MAfTPro Testing..
  136. Tuning shops in the Houston, Texas area
  137. OBD-II Simulator for Standalone users..
  138. help please!
  139. Ecutek difference?
  140. Apex SAFC > Emanage?
  141. I would like to make something perfectly clear!!
  142. Hks Evc
  143. Regarding timing control
  144. AFR Tracking questions
  145. Welcome Ecutek users
  146. Tunerpro rt software
  147. E-Manage Ultimate
  148. Ecutek Forum Released!!!
  149. welcome to the maftpro forum
  150. CReader OBDII and HKS 280 Cams
  151. EcuTek Forum??
  152. Function of the boost control solenoid
  153. dynoflash retune?
  154. 05MR w/exhaust and MBC set at 20psi
  155. SACFII and halman a reliable tuning combo?
  156. Ivan
  157. injector question
  158. Best ems for my goal
  159. oil change...
  160. going stand alone
  161. Installed a wideband...14:1 AFR wtf?
  162. Why do WRXs have launch AND shift RPMs??
  163. Idea on how to mount the ECU+ Box
  164. Any one have a MAP Sensor for sale
  165. serial to usb connectors
  166. where did u put ur afc
  167. Help
  168. Removing Fuel Cut from Factory ECU.....?
  169. The ECU+ now does OBD-II!
  170. TurboXS UTEC MAP Sensor for sale
  171. Slight stumble/hesitation at idle and low rpms in neutral....?
  172. ask for help -----Defi-Link Control Unit II
  173. best form of tuning
  174. tuning evo 9 with mivec
  175. Evo IX ECU Question
  176. Installed UTEC, no boost.
  177. ecu flash or standalone ecu
  178. Help please:
  179. What color is it?
  180. ECU+ and Evo IX
  181. safc2 and 680's on a 50trim
  182. tuning emanage with evo9
  183. Second time using ECU+. No P0300
  184. HKS SSQV BOV problem
  185. utec tuning
  186. Run 11s with these mods?
  187. E Manage Tuning With Evo9
  188. My first tune.
  189. at what voltage do you consider it a knock event?
  190. With afc installed will your stock ecu still change any settings
  191. first 2nd gear pull, no tuning, threw another code.
  192. Threw a code =/
  193. Fuel Trim???
  194. tuning safc for race gas?
  195. Mail in Reflash Help?
  196. actual dyno graph vs. ecu+ graph
  197. injector correction with Power FC
  198. wiring for gm mafs
  199. Engine managment....hmmmm
  200. F.S. Emanage w/support tool, ignition and fuel harness
  201. it just came the mail!
  202. Tuners with ECU+ experience?
  203. High Exhaust Temperatures
  204. Tuner PRO for sale
  205. best ecu program for warranted car
  206. Tuning read...
  207. having some software issues
  208. Topspeed In Alpharetta!!!!! Great
  209. Precision Dyno Sheets Comparison
  210. Arizona tickets booked for Precision Dyno!
  211. Injector size
  212. ECU+ Availability
  213. Anyone ever mess with Nitromethane injection?
  214. Propane Injection?
  215. Where to mount PFC?
  216. What exactly does a safco do??
  217. Flash before ECU+?
  218. Safc II black for sale
  219. ECU+ power Limit?
  220. safe egt's on stock block
  221. Utec tuner lite wiring diagram??
  222. "Hiccup" in my dynoflash tune...trying to fix, help
  223. Sharing Logs
  224. Safc question pls help
  225. Tom need help yet?
  226. What exhaust should I go with
  227. Alky support roll call
  228. Alky/Meth Option for ECU+
  229. How to hook up Safc
  230. Walbro Fuel Pump, reflash?
  231. DTEC Question: can I connect the MAP
  232. Utec
  233. stealth 12 second car?
  234. Knock question for Tom
  235. Future plans for boost control?
  236. My dynosheet with ECU PLUS
  237. Is it worth getting tuned
  238. MAFTpro Subforum
  239. Replacing The EVO MAS
  240. Welcome to the ECU+ forum!
  241. Head count
  242. ECU PLUS 1st STEPS
  243. YES!!!! Thanks ADMINS!
  244. Power FC knock control question
  245. Cruising A/F ratio?
  246. Zeitronix or UEGO
  247. A new PowerFC?
  248. Flaming Exhaust?
  249. Which wideband o2 sensor should I get?
  250. safc-II vs. Flash
