- Evoscan saving data in wrong columns causing MapTracer error (csv attached)
- 2006 evoIX factory recall ECU reflash?
- Where to put wideband sensor in exhaust?
- False Knock? Weird symptoms
- Evo 8 build
- Erratic TPS ( with data log)
- Ecumaster EMU?
- evoscan 2.9
- Ceddy mod
- Advice needed Walbro 255 has 40 psi on the return line
- Hot start/idle issues after mods/tune
- NLTS issues on my 03 evo
- Tephra nlts setting help, no rpm drop setting ?
- Automotive enthusiast, Automotive tech, Eager to learn the magic of tuning evos.
- EVOSCAN logging extremely innaccurate after installing newest ECUflash
- Question about data logging!
- 3rd gear, high knock; 1-4 WOT No Knock....
- AEM Gauges No wires!
- Innovate xd-16 help
- Random Load Drop During Pull
- Knock when doing a track day
- Basic Tuning Info
- My first dyno tune - some questions
- Evo 8 not getting boost
- evo 9 engine in evo 8
- Will a COP kit mess with timing?
- Check engine Light. Misfire on Cold start! HELP PLZ!
- Low fuel trim not updating
- Confused about evoscan
- EVO IX A/C Compressor???
- Need help reflash failed car wont start now
- UEGO Wideband Logging with Evoscan on a JDM Evo 6
- FP BLACK - dead zone in spool
- Precision 6262 WOT's with log inside, Opinions?
- KPH to MPH
- LTFTs are 0 after switching back to 93 from e85
- Hiccup/stutter at peak boost
- New turbo setup, back to 93 octane. Injector latency changes?
- How does EVO 8 ECU function without Boost input?
- Fuel Pressure Solenoid Circuit p0090
- ecu tune questions
- Running Lean under 5/8th tank of gas
- tuning changes for turbo upgrade
- Haltech Platinum Pro PnP Evo IX
- TurboXS DTEC Tuner
- Budget ECU for evo 9 GSR
- 2003 Evo VIII tuning cable question
- Evo 6 Idle and 2500rpm Lambda 0,8
- Can't dial back in injectors properly.
- AFR Tuning Question
- need help with boost
- FIC 1450cc Injectors - Tuning the idle/partial throttle/cold starts
- What are the suggested 272 cams to put in my Evo VIII
- Airtrek ecuflash defs
- Pump gas Comp. Ratio Q's?
- looking for help tuning
- lean cutout at 3500 rpms
- poor startup after driving.
- load
- 100 WGDC all the time, Is that normal
- Downloading a tune file?
- Sudden drop of load
- Anyone have a Pro Efi map???
- Looking for a street tuner oc ny
- Causes of this type of knock
- Ecu reset and cleared itself?
- S366 2.0 v7 Timing Map Help
- EVO9 - Revs won't return to idle
- global boost control + wgdc ?
- Snap on Pass Through Pro III with Evoscan or Ecuflash
- Boost controll
- Need help with 2.4l stroker
- JUN stroker kit 2.2
- Car leaning up at end of pull.. Not sure why. Need advice
- High knock count in logs
- bad 02?
- base timing on evo 8?
- Unsure if tuning issue or not.
- MUST I have a tune with a TBE?
- How Motorsport Fuel Injectors Are Made - Injector Dynamics Facility Tour
- evo 7 speed density rom
- etuning
- AEM UEGO for remote tune?
- Central CA tuner?
- ⛔★ 94170008 patch for rear 02 codes? (p0138)
- tuning 4g64 evo
- Evo 6 TME, which Ecu ?
- Which cheapest laptop can I used with the tactrix 2.0 and tuning advice
- EcuReflash on stock evo 8
- Looking for e6 ecu
- OEM Ecu analogue output Current ratings?
- Adjustments for new injectors
- in need of stock evo 8 DOCH Cams
- cant keep afr's out of the 9's
- 2.3L compression test results
- 1g dsm with 2g h8 ecu
- to lean?
- Microsquirt ?
- 2006 Evo 9 stuttering?
- Need a tune (fuel cut/poor idle)
- zeitronix display show different value AFR from LOG
- p0105 MAP circuit malfunction
- ECU id numbers ??
- evoscan connection issue?
- very odd problem.
- Knock load
- Evo ECU in DSM- Car runs but misfires
- Newest Evo 9 STOCK ROM
- Am looking for a Sparktech CDI
- Will e85 on stock turbo kill my car?
- setting up mut table to start logging
- no zip zero none nada immobilizer code wth
- Looking for someone to make me a base map...
- WTF! Car wont idle
- what do you think of this air to fuel map
- internal Id help. # not in Id list
- A gray area on smog
- Revs climbing
- Installed id1000 car wont start..
- Need a tune
- Looking for a tuner Al Ga area
- Fcon-V pro or power fc
- Please critique this tune
- Help my evo won't start
- Pops and bangs
- 93 octane map help
- RPM's skipping EvoScan 2.9
- 3 port boost solenoid Apexi ????
- Issue with EVO 5 injectors,no pulse from ecu on 2 Injectors
- Evo 8 ECU in Evo 6 Running Rich, close to 10
- Lean during Open/Close loop transition, how to fix?
- Innovate Wideband on untuned car?
- Power breaking up after 5K RPM 2.3 FP Black
- Who has buried the 399 MAF?
- AVC-R and Tephra v7, Any changes required / recommended?
- Evo XIII stroker kit Lots of Boost. Bending rods. Just bought. Need fast honest help
- Degreeing cams confusion
- External Boost Reference Device Question Logging
- I can't log with an eee pc running XP using Evoscan
- Tuning in st louis area
- Datalogging Cable, Evocan and tuning
- lifter tick?
- Pulled Rom- No start
- Evo 5 gsr base map
- Logged a fuel cut condition
- Idle ok. Major acceleration problem
- MAFT delete ?
- Atlanta mechanics for evo9?
- Normal Idle TPS
- ProEfi Pro48 launch control tesing (vid inside)
- Help! Evo 9 ECU to an Evo 8 2003
- TPS issue. reads 91% at idle.
- evo 8 & 9 share the same block?
- 90550701 v7 no launch control
- EvoScan ACD Trouble
- looking for help setting up ecuflash/evoscan
- 96260709
- Leaning out?
- Evo VIII Engine Build
- Issue with timing being pulled.
- Boost cut when NLTS activated
- jumpy idle with ac on? (evo 9)
- inconsistant boost issue
- Pulling a degree of timing with every count of knock
- Load is Jumping around.. 255, 5.6, 355, 4.2, 110..... ?? WTF
- Different Fuel Pump - Need A New Tune?
- Could someone take a look at my tune and help me fiqure this out.
- Wideband stuck on 14.8, p0133?
- New to Tuning EBC question
- EVO 6 hitting fuel cut with ceddy mod
- 2step Suggestion
- need help to undo 3 port!
- Looking for help tunning my 2.0L, T3 5857 full boost at 5K?
- Virtual Dyno Graphs
- Reflash cable
- laptop usb 3.0 question
- Evoscan and Windows 10
- evo4 with evo8 ecu, idle and revving issues
- Intake Temp Monitoring
- Help needed EvoScan logging MAT Evo9
- Revving itself
- Innovate SCG-1
- limitless / evoscan site down
- The old Ecutek unlock question, sorry
- Tuning Power FC ignition coil Dwell settings for aftermarket coils
- Issues with EvoScan 2.9
- Start up without tune?
- Cant Pull ROM from EVO 9 ECU Plug In.....
- Evo 4 to evo 7 ecu conversion
- 93 Tune on 91
- SD:How to wire map signal to EDM ecu
- Do I need to replace my stock ecu? Is it dead? (startup isssues)
- wtk- cam selection
- Exhaust leak causing rich AFR's??
- Logging AFR's with Innovate LC2
- Is it coming? SWR lockout from manufacturers
- Autronic SM4 PnP and Seq Ignition.Please help...
- 0-5 Volt input Evo 7 ECU
- MAF or Speed Density?
- evo X ignition coil in evo VI
- Warm start up issues on E85 + mini battery kit
- need help
- Anything left?
- Opinions on Innovate MTX-L versus LC-2
- Evo scan vs the competition.
- Question for Tuners or someone with some tuning experience.
- Cold timing map??
- Lean Cruising Miss / Stutter
- What is the Advantages of Standalone Ecu vs Evo Oem Ecu?
- Load question
- Putting in CAT for inspection?
- Automakers want to make it Illegal to work on your own car
- Gsc s2 cams evo 8
- What are Knock Flags For? Newbie needs help
- Altitude and gas changes with tune?
- Anyone familiar with EcuMaster
- Help needed please, Converting Airtrek to MPH
- help needed with 88570008
- Top end advice?
- GM IAT sensor wired to MAF harness
- advice! evo 1 with 7ecu time for speed density
- ECU advancing more than the map shows?! Help needed.
- Need injector scaling for precision 1600cc low impedance injectors
- ECU Pin swaps
- SD-GM ait sensor connect to noEDM evo 9 ecu
- Cold start issue w/ front o2 sensor
- A/C load request signal?
- Need help asap on motor
- Worried i switched over maps without knowing
- Cobb vs reflash
- Smog monitors on tuned evo 9
- Does anyone have UTEC firmware still?
- help, drop pulse injection
- Need help!!!!
- Question logging wideband
- where to get my Evo 9 tuned?
- map value on OBD bus
- No boost on launch control
- Tuning my Evo
- SD question
- Safe to run like this for a bit?
- Dyno tune vs remote tune
- Going from stock to mild mods
- Missing BISS screw
- issues with my car/tune
- Who to tune with (remote tune)
- Evo 8 Daily drive what turbo GTX3582R or PTE 6262?
- Help With Evoscan Second Bank Oxygen Sender
- aem uego readings
