- flashing ralliart or mines maps?
- Tactrix help
- Speed Density?
- Utec TBE map?
- Can a Noob lower boost on a 3 port?
- AFR Error ( Acutal vs Map)
- 80700010 2byte load help please
- 2-step help
- ecu option
- Help diagnosing starting issue after MAP installed/tuned 1050cc's
- Maf IAT circuit operation
- 2.3 Stroker to 2.4 Long Rod
- Anyone with Pectel E2 here ?
- Power FC with Evoscan android app??
- not idleing correctly/stalling after hard pull
- Looking for tibuc valve info
- 4g64 w/ evo head and bf272 timing questions
- EBCS/Low Boost/WGDC Not Logging [Grimmspeed ebcs, stock turbo, stock wga, v7 SD]
- EVO 8 2003 US Spec
- EBC choice
- Formula for AEM UEGO in Evoscan
- ECU pinout question
- Tuning question about speed density.
- engine and maintance
- timing question
- Greddy Emanage Blue
- Evo 5 -7 owners Tactrix needs your help in redesigning our Mitsubishi reflash adapter
- Valve stem seals with gsc stage 3 valve springs?
- Need Custom Request ID for BISS
- Prosport wideband gauge
- Logging AFR via serial problems
- need 2.4l start up
- Mapped before?
- MAF sensor code
- OBD 2 port not communicating
- Vems?
- Evo 8 ECU in Evo 4 Problems
- Evoscan 2.9 wont flash rom with tactrix 2.0?
- Can someone explain the difference in Tactrix Products?
- Apexi PFC- Gear based boost control
- 2g ecu in my evo 8
- Anyother Logger ?
- EVO7 GTA ecu alternate map switch wiring help
- evo 9 switchable anti lag
- Hydra ems
- Apexi SAFc 2
- STM Tuned for 93. Ok to run 91? (Roadtrip)
- Accessport Maps for 2010 MR- EDM - Europe version ? help pleas..
- Tuner Needed???
- low CR pistons
- Accessport: Tuning Options
- Motec or OEM SD Mivec Maps, Evo IX
- AFR calibration and setup
- Logwork3 datalog with tactrix?
- Evo IX tuning results
- Choppy at WOT.
- Evoscan 2.9 will not open error
- Innovate LC-1 Wideband Install
- evo scan aftermarket map sensor evaluation value
- Will evoscan work on my car
- Weird?!!!!! Please help.
- Returning a ecu to stock maps?
- blow off
- EvoScan with other ObdII?
- Power FC Help EVO 5
- evoscan FTDI USB driver error???
- Fuel pump limiting max power ?
- VIPEC V88P on EBAY
- Stock ROM after reflash?
- Exaust and Intake
- bored out??
- transmiccion
- Evo 9 Stock block and head
- Anyone have an Accessport for sale?
- Evo IX ECU
- need evo 8 ecu!
- Tuning for Altitude
- ohms and recreating a circuit
- Disappointed after tuning
- Power FC
- need help with ecu!
- AEM boost Logging?
- What to Tune first: timing or afr?
- Valve lift Question
- Will i need to retune if i swap stock map sensors?
- apexi power fc evo3 map problem
- Understanding AFR Tuning
- Looking forward for my tune
- DIY COP Question
- Help! Wideband Selection on Evoscan
- Help!! very strange idle
- Building an ignition cut device: looking for input
- Max load on N/A
- Aem Uego / Evoscan
- question about tuning
- IX Tuning for a ETS LICP & Intake
- Coil over Plug Question
- Outside bounds of array (Evoscan)
- need mitsubishi Airtrek CU2W ECU pinout diagram
- Oxygen Sensor
- Evoscan tablet anyone still waiting
- DIY Tensioner Tool Questions
- evo 7 ecu tune help
- From OEM to 4" thick Intercooler, well affect tune?
- need help with evoscan
- Map sensor connector
- Issues with new injectors
- Looking to get 350-60whp on 91
- First Step in Retuning after Injector Scaling
- Who tunes themselves?
- Wanting to atleast make 400hp/tq
- AEM truboost 3 port solenoid
- Question Prior to Beginning to Self-tune
- How does ecutek work?
- other tuning software vs evoscan and aem ems
- cobb question
- FIC 1100 Hi-Z
- Mase Engineering
- Boost solenoid A?
- evoscan issues
- Stock ecu vs aem ems
- SMOG HELP: OBDII won't connect
- evo 8 sequential or batch injection?
- Best shop to get tuned by in VA/MD area
- Wide band query
- Boost cut
- Some issues after getting tuned by a reputable shop
- Help! Loosing power
- iPad Evoscan software?
- Info on Evo 8 add ons
- How is your Idle after tune?
- tactrix 1.3s to tactrix 1.3u conversion?
- Ms3-pro
- Best method log AEM UEGO
- Normal AFR bad gas smell
- pro efi evo 8
- lean afr's while swapping injectors
- Stock ECU ignition coil output signal died. FIXED
- Quick Cams Question
- AFR and Cold Weather
- Noise and Vibration
- EvoScan reading wrong psi????
- P0132 O2 #1 Circuit High (Rich). I need a tune
- Will 1860a118 ecu work on my evo 8
- Iveytune transmission rebuild reviews
- Looking for some graphs to help with a $1,000 bill
- Any experience with Vi-pec Plugin ECU??
- Evo 8 ecu in a 2G, ecuflash unable to connect to vehicle interface
- Need help with SD bung?
- Need Help
- Need Pectel E2 softwares etc.
- which speed density intake size???
- Idle air control pinout
- looking to fix this knock!
- Aem ems 2
- Prosport evo wideband gauge evoscan formula help
- Blitz Touch B.R.A.I.N.
- silicon valley tunners?
- Upgrading Evo 5 ECU
- Evo VI ECU tuning
- Gauges; Mech vs Elec?
- Bov
- Stand alone maf reading converted to analog
- Worlds first flex fuel factory Ecu GTR!
- New to tuning
- ecuflash help
- finding the right pistons
- Can I use a greddy profec b solenoid for ecu boost?
- seek AFR difference map vs log
- DTC P0420 Help
- EVOScan and ABS
- Spark tech Cdi pro 12 and dynatec arc2
- Do I NOT need high z bypass for ID1000cc injectors?
- Idle problem up and down
- New superchip vs stock ecu which one?
- Ecu ??
- Need a lil help
- need help with sputtering n back firing
- Disabling Immobilizer
- Need Some Tuning Help in Memphis Area
- pros/cons of speed density?
- windows 8 and evoscan
- school me on e-cutouts, meth injection and ecu flashing/tuning
- Good USB hub for in-car install?
- Timing Mark
- Compression Question
- Intake Manfold Vacuume Lines
- help ! voltage issues to fuel pump
- BOV leak. Aftermarket suggestions.
- Considering switching from HKS F-con vPro to AEM EMS Series 2 - Thoughts?
- wideband with O2 dump?
- Vipec vs Aem Ems
- turbo xs?
- No Ignition
- Tactrix 2.0 and evoscan
- Evo Intake Manifold Sensors
- What is Autronic Stand Alone Worth?
- Motec Tuning in Midwest
- Cant read codes using Evoscan
- Problems: Stage 2 but as slow as stock?
- Can I just drop a Walboro 255....
- i killed my ecu...butt why??
- OFFICIAL VIPEC THREAD - V44 PnP & V88 Thread
- Is there a way to know what type of cams I have?
- 06 Lancer oxygen sensor wiring
- EVO 8. Timing retard. What sensor can affect?
- Issues w/ logging AFR via AEM Analog (5130) thru ECU rear 02 input
- HKS FCON Vpro
- Torque Spec
- Spooling AFR???
- cone vs panel filter inlet temps
- Exedy Triple
- just a quick opinion on which tuning device is best
- LM2 analogue out logging in evoscan
- Aem failsafe tuning/ wiring
- Plate for exedy hyper single
- Need help from a guru!!
- Putting back the stock cams require tuning?
- HELP! Semi-Unresponsive BCS... Yeah... It's weird!
- E85 and lean afrs during weather changes
- Oil PAn Cracked please HELP (CLOSE)
- Tune Questions - altitude Change
- Help W/ E85
- ECU options for engine only.
- Idle Problems with Motec Ecu
- Where is the fuel pump check valve?
- Timing Tool
- tuned ecu back to stock
- Boost Leak? BOV Leak? Not sure..
- 04 ralliart 2.4L Throttle body advice
- Is anyone still interested in cobb ap ? if....
- Best aftermarket header to buy for an Evo 8?
- Dead ECU
- Evoscan wont log LTFT low...
- Evoscan problems
- Innovate O2 Sensor Help!
- power loss with bolt ons
- Cruizing Air fuel?????
- Learning to tune on AEM EMS..Like to look at some other good tuned maps to compare
- How to track the cells being used with evoscan
- Need help setting up Tephra V7
- Help, need some input
- Another "Which Map?" thread
- Fuel pressure gauge
- Accessport: What map to use?
- NB Voltage: How to determine AFR
- Is Zeitronix LCD compatible with third party sensors?
- noob question about tuning. wideband
- Overboost with ecu controlled boost
- Worth it to upgrade from the AEM series 1 To the AEM series 2?
