- aem uego readings
- Thoughts on future car modifications?
- stock EVO re-mapping
- FIC 850cc low z injectors good buy/worth it?
- what power level warrants a 340 pump over a 255?
- Evo 9 Knock and Pull Problem
- Cat delete
- help identifying injectors
- Removing Fuel Cut on an Evo 6
- Which load does do my ecu maps read off of??
- Evo 7 EUDM vs JDM ECU swap
- JDM cp9a ECU need obd2 help.
- hit a speed bump with tuning
- Why do I have knock ?!? 4g64 timing problems
- new too tuning
- 2006 MR SE knock issue. (phantom knock???)
- My tune and dyno results evo8
- port and polishing near Savannah Ga
- Will O2 housing exhaust leak cause lean readings?
- help evo 1 ecu swap
- Drop boost on heat... :(
- PCM update question
- tephra v7 on 2004 evo 8 immobilizer
- What? Idle/Cruise AFR's get leaner.
- Cant reduce fuel anymore in ecu, Significantly higher than map
- FIC 1650 vs Deatschwerks 1500
- high knock on logs
- 03 EvO 8 ignition troubles Pls Help!
- Should my hp be higher then it is?
- Help with injectors, lataency and scaling aren't normal
- Evoscan shows AC switch fluctuating between on and off
- [WTB] AEM EMS 30-1313 || Openport 1.3u
- Reverting to stock from AEM v1
- Converting from E85 to Regular gas
- Can't work out why car wont' start after Ceddymods ROM
- Urgent help: 25G Dyno Results disappointing
- Bad ecu?
- rescaling?
- Was working on my Evo IV, hand slipped accidentally broke a piece
- New Dyno results, sound right??
- VIII died on an overpass: Crank, will not fire
- watch out for a windows update
- 93 and E-85 tune on stock ecu
- Tunerpro and speed density
- new cams/car not starting
- JDM EVO8 not running when connecting Powerfc 414-M907
- Help with Evoscan Maptrace
- Evo IX without a stock ECU tuning question
- applied patches but still failing Washington State Emissions with 'not ready'
- high knock !
- ECU Load stuck at 160 Evo 8
- 6 pin DIP evo 8 ecu (sorry for the over post)
- Pump gas - high boost - help
- EcuFlash cable needed?
- Car runs died lean over 3k rpms.
- help for useing 560cc injectors on apexi power fc
- Thought it was the engine... Turns out it's ECU?
- Looking for a good Elm327 bluetooth
- need help afr at idle is everywhere
- P0011 code after IM and TB install
- constant knock count of 9, no matter what
- SARD Trigger boost controller
- odb readiness need someone to look at rom for me. please help
- Vipec i-series and link g4+ ecus
- Evo 3 Stand alone ecu
- will eclipse tactrix cable for my evo 8?
- evoscan obd1 connection direct to the ecu
- Spark Plug Issue, High Idle, Misfires, Inconsistent Power
- Do I need to retune?
- tuning speed density and injectors
- Do I need a tune?
- Spec ops, Forcefed, or Tscomp tune?
- Stall between gear shift and overboost problem
- FS: motec m800 plugin
- good deal?
- HELP! ECU Question.
- new evo8 owner with CEL flashing
- Cel on but no dtc after new map
- RPM oscillation at steady state (hwy speeds, steady pedal).. “Stutter/tugging” feel
- Evo 8 low idle
- Evo 8 - Cold Start, Idle issue & Wideband reading odd numbers - Please Help!
- E-Check Help-VIN#
- Would this run Evoscan like the old GPS?
- home made det can vs 3 piece motor mount kit
- logging air/fuel with aem uego problem.
- WOT Fuel cut issue
- Evo 4-6 e-tune friendly?
- Innovative LC-1 vs LC-2?
- Lean E85 AFR (20+) at idle or at red light
- Evo 9 Cold Start Stalling Prob.
- ProEFI Rolling Anti-lag
- Knock Sum stuck at 0 or 9
- Knock issues on 91 octane
- New evo owner needing big help please
- Ecu load %
- motec m800 advanced map needed
- Ecu Flash Help
- HKS EVC 6 Issues
- Wanted: apexi power fc to evo 6 rs2
- Loopy idle after cam install
- Haltech Ecu
- Where to get mapped in the UK?
- aem or haltech??help!
- InternalID 9417008 Back After Long Absence
- Virtual Dyno
- Link G4 + Spoolinup COP kit
- Boosting issue? Please help.
- Load and knock problem
- idling issues?
- Evoscan stock evo 9 map equation
- Air/fuel issue thoughts
- can i change the vin# on evo8 with ecuflash?
- ECU Install
- EvoScan won't read/write
- EcuFlash use in EcuTek
- Tephra mods e7 ecu
- Zeitronix ECA Flex fuel sensor install help
- Evo 8 ecu question.
- Idle and crusing AFR very rich!!
- Switching maps
- Tephra v7 baseline maps for 2g
- Innovate MTX-l not connecting through serial port
- Evoscan to Logworks Converter
- o2 sensor pinout VII!
- Where should I start..
- help eith knock (5 counts)
- Power problem
- No communication with obd2
- Evo 8 Fuel cut?
- 4 Channel Wideband
- screwed up launch control after tune!
- ECU evo 8?
- Transmission oil replacement
- Weird AFR at idle
- Evoscan v2.9.0023 1 byte load error
- switching between maps on tephra7?
- Boost map help!
- I need a stock Evo IX tune
- 850+ HP STOCK ECU guys/Tuners.
- Evo 8 died and leak problem!
- Evo 8 serious book leak and died problems help!!
- Evo 8 problems help!!
- Evo 7 ECU speed density rom
- Evo 7 tuning
- Tune needed after o2 dump/tubular mani install?
- compression test # help
- Boost drop off at higher rpms?
- need help weird idle
- need some advice evo 4 engine evo 8
- Check Engine Light EVO IXGSR
- Evo ix / ecutek
- Haltech e8
- Tuned Air-Fuel Ratio 15.9 at Idle
- Accessport evo 8 question
- Thoughts and suggestions
- Data-log viewer (csv format)………what do you use?
- SD calibration
- Alternative to garrett turbo speed sensor ?
- Voltage problems...
- Evoscan not logging LoadCalc after rescaling on EcuFlash
- O2 sensor spacer for tuning
- IAC question.
- Help with Knock
- Where do I start......
- BOV change!!
- Question: Evo 8 timing belt, tensioner, and idler pulley
- logging aem uego analog gauge?
- arithmetic operation resulted in an overflow
- Ecu pin 10 receiving 6v. No spark
- looking to buy
- How do these number look?
- evo 9 boost lowered
- Car won't start help!!
- Tuning a Two Step
- new setup now i need tuned
- replace plug on 1.3u cable
- Evoscan V2.9?
- Tactrix Open Port 2.0?
- Throttle-less gasoline turbo charged engine control.
- Evscan 2.0 Openport J2534-code
- Throttle Hang on AEM and OEM/COBB
- Want to go SD and start tuning.
- Evoscan Setup (TSCOMP settings)
- Bad injectors ??
- HELP; My car (evo4) is buring very rich in close loop!
- Evo8 High load on idle
- Part throttle engine break up w/logs
- Evo IV MAP
- Is my map way off?
- Idle issues out of nowhere
- Evolution 6 Gates Blue Timing Belt
- Problem datalogging with evoscan
- does anyone have ECU reflash for download
- MoTec Evo IV/V ECU info
- Evo 8 stalls when its not warm
- Switched BOV, re-tune?
- 04-05 Ecu in 03
- alternative lag strategies
- Does the ecu read wideband afr's?
- Rvr with evo8 mr ecu
- Power fc datalogit : backup tune
- Several Questions Related to ECU Swap and the Immobilizer
- Trying to hit 330hp.
- Switching from AEM to Stock ECU
- email/remote tuning
- Standalone and wideband
- E6 to E9 loom question
- Apexi power fc : Datalogit software needed Pls
- COBB Tuning: thoughts?
- RPM Glitch in DataLogs
- Evo 9 EVC-S Troubleshoot
- Just Ran A Datalog for my car
- new evo 9 owner, have question
- How much timing can I take out to get cam lope?
- HELP - KNOCKSUM spiking at 36
- Wavy AFR on Corn. What Gives? Got Pic.
- Spark Tech Pro CDI 12 install = Hard Cold Start?
- Gsc s2 cams stalling issue
- Fuel heat vs Injector flow issues
- What the different between Hks Ecu with any Ecu
- Apexi power fc : CEL warning help
- Evo 8 idc
- Question
- EVOscan settings
- Evo 4 running lean
- help with log
- ID2000, E85, and open loop issues
- Tuning Help
- Help with jumpy rpm
- Tuning after cams
- injectors on after rev
- Measure Boost with Innovate OT-2
- F-Con Navigator Help
- I plan to Buy New Cams
- Bad coil caused short in ECU?
- Aem true boost for viewing only
- Dual map question for AEM ems setup
- Need help with my engine questions please. Urgent
- datazap free log graphing
- Boost and Power issues
- Little help with Evo scan
- Leaking DV during tune
- Evo V unidentified problem ????!!!!!! please help me
- Cold issues - gets better when warm but not perfect
- Suddenly lean idle/cruise in closed loop?
- Evo IX with tephra v7, all readiness monitors good except O2 sensor
- Factory ECU Theorizing
- gauge choise help
- Suggestions before dyno session
- A/F Rations on E85?
