PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. cant log autometer wb with evoscan?
  2. PERRIN TUNES A IX WITH AccessPort
  3. Dialing in Blitz Dual SBC
  4. clutch..maybe
  5. NEED HELP!!! New mods injector probs
  6. Zeitronix boost sensor problem
  7. Innovate XD-16/LC-1 Calibration
  8. Evo AccessPORT Beta Firmware Update...
  9. LC1 out put voltage question.....
  10. 05 slight modded any opinions on what next
  11. remap and remap for a few $
  12. Autronic SMC 1.99 PNP EVO VIII IDLE HELP
  13. Going to get tuned by AMS, going on a trip..
  14. IX ECU O2 outputs for Apex turbo timer
  15. software
  16. wastegate question
  17. What is average EGT's
  18. Major Roadblock! Please help!
  19. Key program and ecu tune
  20. When to tune?
  21. Best way to have OBD II back for Emissions
  22. help!!! turboXS
  23. Will An Evo 8 Engine Fit In An Evo 4 ?
  24. evoscan will not open
  25. custom tunes?
  26. Safc for tuning
  27. MAF-T -VS- MAFTPRO.. i need help
  28. What Is A Speed Density Setup?
  29. help no boost at all????????????????
  30. MAP Sensor Part Number
  31. General questions of getting AP, right for me?
  32. ebc's and different wga
  33. o2 sensor
  34. Are all Stock Ecu's interchangable?
  35. Connecting LC-1 to analog gauge
  36. TUNE yes or no??
  37. Evo 8 ECU Question.
  38. if im tuned for 93oct and i go out of state can i put 91oct in
  39. Email flashes..
  40. Installation Successful
  41. Convert to peak & hold injector driver?
  42. Few Questions before tune
  43. The Cosworth Engine?
  44. No MAF = No knock?
  45. evoscan no HP reading
  46. *help* possible fuel cut out in MR
  47. Finalizing map
  48. autronic sm4 AFR issue
  49. Questions about log values after installing 65mm TB
  50. please help identify this ecu! CAPS?
  51. Read my plugs
  52. Read my plugs
  53. Tuning Results
  54. dynoflash lacking
  55. Wideband Question...
  56. aem twin fire module 4 channel for evo 9
  57. plug gap from factory at 20?
  58. Apexi Power FC L-Jetro for sale
  59. evoscan cable
  60. Help! No ObdII with autronics? How to pass emissions?
  61. When do I really need a tune?
  62. evc 6 ebc tuning help?
  63. Autronics Cable and software?
  64. Need older version of Evoscan
  65. reflash if adding o2 housing?
  66. tuning questions
  67. please post mods and dyno numbers here!
  68. aem help
  69. apexi question
  70. GM IAT sensor temp vs volts scaling?
  71. Greddy Emanage
  72. ignition boot miss
  73. is this stroker kit capable
  74. Need Immobilizer help!!!
  75. Interesting fix....
  76. Total noob to tuning...few questions
  77. Power between winter and summer? (temperature changes)
  78. Base lancer 16g help?
  79. Boomslang harness compatibility?
  80. Exhaust Gas Recirc (P0401)
  81. Life in my shoes
  82. General Help With EVO ECU.
  83. Dyno day at P & L
  84. knock caused by something mechanical
  85. Pos Lc-1?
  86. Sharing Maps
  87. Need input on barometric reading at wot...
  88. Exhaust and Intake b4 tune can hurt?
  89. SM4 locked!
  90. hks vpc
  91. F/S ECU+ plug and play
  92. No support for UTEC makes me sick!
  93. Tuning Cosworth Cams w/ GM Boost Solenoid
  94. 3" GM maf and MAFT setup w/ AP ??
  95. Evo IX RPM Signal
  96. Could I be maxing out my MAF?
  97. i need some expert advise??!!!
  98. i need
  99. What LC-1 firmware are you using?
  100. P0104
  101. LC-1 and DB gauge wiring problems?
  102. the numbers are in
  103. Pocket Pc Logging software?
  104. Evo IX SAFC II Diagram
  105. help to set up cam gear
  106. wtb tunner pro
  107. utec ecu + or other?????
  108. Power FC Alternator Control
  109. So torn between EcuFlash and Access Port
  110. new tune.
  111. Evolution specialists in the San Francisco area
  112. Any tuners in the Colorado area??
  113. Tarmaq Gravel Snow (All 3 lit up)
  114. Evoscan Issue
  115. P0300 code and Tunning?
  116. Baud rate and ECU+
  117. Noob questions
  118. Moving to Jersey selling stuff Buschur/AMS!!
  119. Air/fuel Problems Cant Go Over 4500 Rpms! Please Help!
  120. Hks Evc 5
  121. Knock sum on 93
  122. cel and miss at idle?
  123. egr flow fault code p0400 or p0040
  124. Cannot analyze CSV logs in EVOSCAN
  125. check engine light
  126. fuel cut issue???
  127. Evo8 street tune in SoCal
  128. idle and tailpipe sniffing AFR
  129. Please don't bash me for asking this...
  130. what is this? what does it do?
  131. Is Tactrix cable compatible with both: XP and Vista?
  132. Tactrix cable problem
  133. Confused
  134. got my 50trim evo 8 tuned!
  135. Iat gauge?
  136. Multiple Maps with Power FC?
  137. HKS DLI2 and GEMS ECU not working
  138. Intake mani question
  139. UTEC FS Stage 4 Parts Tuned
  140. aem truboost question
  141. AMS TUNE APRIL 11th and 12th BOSTON, MA
  142. Finally happy
  143. problem with boost
  144. EVOScan help
  145. Custom tune on stock ecu, P 300
  146. HELP!!!Turbo XS Tuner Pro Question
  147. HELP!!!!!!! Check Engine Soon light came on!!
  148. Hks Eids
  149. Defi EGT probe slow[er]
  150. afr
  151. WOT ---7.35 always on the wideband ???
  152. SARD Injector Specs?
  153. ??? About datalogging and widebands
  154. AMS Not Tuning with AP Any More!!!!
  155. Apexi AVC-R Boost Controller Question
  156. help!!!!!tuning
  157. Few AP owners?
  158. knock sensor wiring
  159. Throttle Hang, RPM Rise, Etc.
  160. Hmmm!
  161. fpgreen dyno. low torque?
  162. MoTeC M800 OEM Evo IX start up map
  163. Hear Ye, Hear Ye, new MAFT Pro update is out there.
  164. O2 sensor install in LA area
  165. What gap on plugs for more boost and meth?
  166. Question about map sensor and iat installation
  167. My Ap Wont Read Ecu
  168. $100 wideband o2 setup
  169. HELP! LC-1 guage problem
  170. 05 ECU into 03 Evo VIII shell
  171. max number of reflashes?
  172. question about load?
  173. WTF!? 6hrs on the dyno. no top end!!
  174. got my ecu rom, how to tell if its stock?
  175. WOT Pause?
  176. Innovate ot-1 obd2/CAN interface? lm2 info?
  177. Evoscan 2.1 Problem please help
  178. Help
  179. evoscan help
  180. Who can tune the AP?
  181. accessport question
  182. to xede or not?
  183. code reader
  184. Help the electrically challenged (me)!
  185. Greddy B-Spec II Tuned for 20 PSI
  186. Is this complete
  187. Max safe BHP output on EVO7.
  188. wideband says car is running 17+ AFR all the time, Power FC
  189. Just reflashed!!!
  190. need some help on connecting LC-1 to laptop
  191. MAF vs. MAP using Factory ECU
  192. Detonation?
  193. EMS experiences
  194. 2 step
  195. Evo X MAP Sensor
  196. New FMIC and Piping Retune??????
  197. Ordered mine today
  198. utec cable
  199. Missing Evoscan Hex Files
  200. WORKS Vs. K&N
  201. Factory Warranty?
  202. Timing retrad from 2.0 to 2.3L
  203. cobb tuning acces port
  204. Motor Patches Shirt Jacket F1 Motorsports Badges
  205. Noob tuner, with a couple logs
  206. 400 whp - what to do?
  207. evo 1 gsr tuning??
  208. ECUFlash load versus UTEC
  209. Evo IX Turbo Timer
  210. Getting motor to idle with PFC and no IAC
  211. idle sensor problem help pls
  212. hp?
  213. obd2 connector
  214. boost cotrol question
  215. How to pick the cam i need? 272 280 270 etc???
  216. help with gear box..
  217. no start
  218. Hks F-con Is
  219. Help Gems ecu stopped working
  220. what palm
  221. Lc-1 gauges
  222. size injectors
  223. t70
  224. need help on what to do next..
  225. MAF sensor removal with TurboXs Utec?
  226. what is wrong!!!!!!!!
  227. 30r question...need help asap!
  228. ECU+: almost 3X faster logging than other MUTII loggers
  229. New unofficial Autronic forum!
  230. mitsulogger
  231. Switching from AEM to HKS F-Con V Pro
  232. Wideband Shootout!!
  233. Trying to get 2byte load to work with mitsulogger
  234. Ecuflash and Apexi Neo Question
  235. Tune and Scan Tool Question
  236. $1000.00 to burn, you know the drill.
  237. Timing Tuning Infor
  238. Just a little information
  239. Good place to tune AP around NYC??????
  240. Cdi Cop
  241. Need setting for a AVCR map 3.5bar map sensor on PFC
  242. How much does mivec on the evo help with spool up of a big turbo compared to a evo 8?
  243. Slow spool stock turbo
  244. Anyone run HKS F-Con Vpro?
  245. Engine cut out
  246. Autronic issue
  247. any1 tuned by ICS?
  248. please help me
  249. Base Tune Neo Help!!!
  250. Evoscan 2.0 Reading problem!!!
