PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. all 4 cylinders has low compression
  2. Having problems with stage 1 & 2 maps
  3. Which setup for evo 9 air intake?
  4. Knock The No Knock
  5. I know ANOTHER 60k service!
  6. Help me with Cobb AP
  7. anyone know the diamater of the maf adapter of the COBB sf intake (evo 8)
  8. Check light flashing with powerfc
  9. Do I need to be retuned?
  10. MoTeC M4: I need help
  11. Tuning classes - EFI University... Looking for feedback
  12. question on tuning
  13. engine problem you experts probably know how to fix
  14. Problems with LC-1 Data Logging
  15. Speed Density?
  16. When turning down the boost?
  17. Evoscan not logging, not reading ECU also
  18. Inspecting a tuned car
  19. False Knock
  20. Power FC tuners in SoCal
  21. Retuned w/cams but stuggling to start
  22. Wiring LC1 to ECU as factory O2 (lambda) sensor
  23. when it start to hurt bad the engine how many knocks
  24. Crank grinding question
  25. 2.0(4g63) vs 2.4(4g64)
  26. buying evo with tune problems
  27. Maft-pro vs aem ems
  28. did you guys experience this...
  29. vishnu xede
  30. haltech or stock ecu?
  31. help!! my DD is hurt. transmission?
  32. 450hp Stock ECU ( no mods)
  33. Wideband (Innovate vs GlowShift)
  34. Tune for Cut-Out ?
  35. HKS ssq bov idle problems!!
  36. factory ecu fried
  37. possibly superdumb question
  38. Seemingly random, but persistent p0300 code! Can't figure it out!
  39. compressor surge?
  40. Flashed - but now running stock exhaust = lower boost?
  41. Exhaust flames in Autronic
  42. HELP having trouble using a timing light on my evo 8.
  43. What logger is commpatible with windows 7?
  44. Perrin Boost Controller EBCS - worth it for mostly stock car?
  45. Ecu +
  46. Taking out the Vishnu Xede?
  47. radiator fan question
  48. dynoflash
  49. Need serious help/advice*
  50. where to get tuned
  51. AEM EMS W/ built in UEGO ISSUES
  52. pfc linker3
  53. new to tuning.....
  54. Getting started off right...
  55. Suspension advice needed
  56. New Intercooler?
  57. Vishnu Reprogram Ecu..
  58. Max HP on JDM Evo8 MR using stock turbo/head?
  59. thoughts on utec
  60. Need Help with Tuner Pro
  61. Fuel Rail needed?
  62. Petey Turbo Tune Q: Does he tune MIVEC too?
  63. Intake Cuestion
  64. Need help !
  65. Over 90% IDC?
  66. help weird overheating issue
  67. EVOscan for EVO X
  68. Key Code - Immobilizer Code
  69. Can someone help me critique this log please??
  70. Evo IX MR without an ECU...suggestions?
  71. Apexi PowerFC datalogit anyone?
  72. hep with afr tuning
  73. Changing Flat Panel Filter to Cone Filter
  74. What quick updates to do?
  75. Evo oil mixed with antifreeze coolant
  76. PROBLEM with EvoScan logging LC-1 on serial port
  77. Stupid Question: Anyway to run a EVO IX ecu in a Evo VIII 05
  78. vpc
  79. Open Port 2.0 wont log on evoscan 2.6
  80. Mines ECU
  81. Where to buy 2 solid, adjustable lifters for cam timing?
  82. sparkplug wires
  83. help
  84. Tuning options
  85. wideband
  86. Can i install HKS Twin Power DLI II With Power FC on EVO VIII MR
  87. e85 injectors
  88. Getting strange DTCs from evoscan
  89. installed turbo. now got a few problems. **help/suggestions**
  90. MN132874 Ecu question
  91. Upgrading Injectors
  92. adding fp black and ams intercooler, need advice
  93. About Tuning "If u live in PA,NJ,DE" look!
  94. Help with Tuning have a few question
  95. Reloaded HKS Intake
  96. TurboXS or OpenSource?
  97. Power loss issues - log
  98. rear o2
  99. Proper OHMS for the TPS?
  100. Purchased car with Vishnu Xflash Reprogrammed ECU
  101. Boost reading at idle?
  102. Fuel Tuning Question
  103. motec m800 E85 maps
  104. problem : check engine
  105. AP datalogging
  106. Stage 0 ECU Flash
  107. help
  108. ECU Tuning Questions
  109. Installed Aftermarket Parts now boost is dropping!!Help!!
  110. Quick Question Regarding Injector Scaling
  111. Fan relay issue and Aem Ems - Evo 8
  112. How good is the Apex-i Power FC?
  113. Best place to get my datalogit?
  114. What to do next
  115. Welding the block?!
  116. MAP switch question
  117. Major problems with 93 Evo
  118. evo8 with with pestering idle
  119. what kind of oil?
  120. TBE just installed; check engine light ON?
  121. Transmission Problem?
  122. Evoscan Navigator
  123. idling problem
  124. Getting a tune... questions..
  125. Innovative or AEM
  126. Walbro fuel pump question
  127. lc-1 install
  128. Haven't seen this question before, so
  129. Catt Converter
  130. Help: EvoScan on Windows CE
  131. mail in cobb tune
  132. OBDII output parameters
  133. Car Won't Start After Flash Please Help
  134. What will happen if i raise boost with no tune?
  135. Evo Scan2.6-JDM MAp, LC-1???
  136. Rescaling
  137. evo9 with idle and other problems
  138. Evoscan..
  139. What to do next? Help
  140. need to find tuner spot or speed shop!! sad/funny story for free if read
  141. Does disconnecting battery lose tune?
  142. HELP- Sputtering and Black Smoke
  143. max lean A/F while cruising/light load.
  144. Evo IX brakes question.....
  145. idle issues help please
  146. Cant read ECU, and have tried just about everything!!
  147. evoscan help
  148. xml files and how to use..
  149. evo 8 & 9 AP Discontinued?
  150. evo 4 evo 9 ecu probs any help plz
  151. tactrix cable openport 2.0
  152. GM IAT Sensor Placement w/out Meth
  153. Loggin Question:D
  154. Evo 9 MAF scaling
  155. Dealers for Motec in US?
  156. Motec M800
  157. Tammer tuning stock evo 4ws tunning
  158. Need help - agressive throttle work and idle @ Kelford's 272
  159. Looking for a good place to Start.
  160. i want my evo ix to backfire/shoot a flame out of the exhuast!!
  161. UTec MAPs
  162. utec downlad question
  163. what acts like a misfire, but isnt a misfire?
  164. aem ems or stock ecu?
  165. Tuning issues
  166. "variable" boost
  167. Can't Open EvoScan Anymore
  168. Link G4 or HKS F Con V Pro
  169. AEM wideband accuracy
  170. Hydra EMS
  171. looking for a good tuning shop in the southeast
  172. some Body can help me???
  173. Chrysler coil packs
  174. evoscan to logworks?
  175. save loads?
  176. Launch control/Anti-lag available?
  177. Duty Cycle
  178. EVO Injector Upgrade
  179. AccessTUNER Race email tuners?
  180. Loading dyno map from AP to the computer
  181. evo 8 high idle problems
  182. Cobb AP & Boost Problems
  183. PTE 780cc specifications
  184. EVOScan
  185. HELP for Tune
  186. autronic pnp f/s
  187. Vishnu Experiences!?
  188. gauges on your laptop from ecu
  189. Need help how to plug Hyper Force System
  190. HKS F-CON V Pro
  191. ticks over up & down
  192. zietronix wideband
  193. apexi neo
  194. problems with possible spark blow out.
  195. modding a car that has been previously tuned
  196. Motec maps
  197. usb to serial adaptor for tactrix cable?
  198. Zeitronix not working since EGT install
  199. evo dosnt feel right
  200. lean spool
  201. Using higher Octane then mapped
  202. AFC neo question.
  203. Ok to drive with tactrix cable when not datalogging?
  204. Can I flash with openport 1.3R?
  205. GSC S2's(1st/early version)....upgrade to ????
  206. data logging
  207. Evo not running well (PO300)
  208. evo viii 260 cyprus
  209. Altered Atmosphere?
  210. stock evo IX map
  211. Power FC models? Which one for EVO 8?
  212. Removing RRE dual map switch????
  213. Base injector scaling
  214. Evo1 STS
  215. Rich AFR's Idle and WOT
  216. Cant read Write ECU with evoscan???
  217. Knocking Please help me understand
  218. Alternator Upgrade
  219. whats pushing the limit for boost on 93
  220. looking for a good shop
  221. wide band readings (compare please)
  222. Partial throttle knock
  223. Evo 9, AEM ecu vs stock ecu + gm 3" MAF
  224. fq 360 reflash
  225. need help
  226. How many maps does 8 have ?
  227. throttle body spacer... ??
  228. What would cause a lean mixture?
  229. 12 Tooth Trigger Disc
  230. Car "Cutoff" Power in 3rd at 5k RPM
  231. can stock ecu be lock by tuner
  232. Evoscan convert PSI to Bar
  233. trying to figure out if my tune is good? please click.
  234. HELP!!! Innovate XD-16 Issue
  235. Clutch question, new clutch needed.
  236. RPM inconsistency in datalog with Evoscan
  237. Good Place To Tune
  238. All knocked up
  239. Tuning 1200cc on stock ECU???
  240. Need help wiring up Zeitronix ZAVT relay (pics)
  241. trying to figure what tune is best
  242. Obdii
  243. Injector duty cycle & eveoscan
  244. base map for a 35r 3582 or better 3586?
  245. Map ecu
  246. New guy.. looking to pick a few brains
  247. ECUflash for EDM evoIX
  248. Any one use FC tune on their EVO?
  249. Need help on boosting.
  250. fc tune
