PDA
View Full Version : General Engine Management / Tuning Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28
  1. 1.7 w/ 1000cc injectors
  2. 1.7 firmware - Utec to Ecu timing and vice versa interpolation.
  3. Utec 1.7/w 680cc injector problem, Please help!
  4. Utec 2005?
  5. stage II questions
  6. UTEC took a dump on me
  7. Timing Low rpm, Low Load..
  8. Utec, Flased, Injectors, Open Loop
  9. Tuner question
  10. WHere are you guys running your tuner...
  11. Utec log with new 1.7 firmware
  12. Afc or Afc2
  13. Effects of E-85
  14. How tricky is it to tune?
  15. Autronics and emissions?
  16. Disconnect UTEC from ECU before upgrading to 1.7? (9v Battery?)
  17. Maxed out stock injectors @ 23psi?
  18. 01
  19. CEL after CEL is it my UTEC?
  20. Am I stupid?!?!? LOL
  21. Tuner knock sensor placement
  22. PO108 code after switching to 1.7
  23. Cams and fuel and UTECS oh my!
  24. Looks almost like UTEC
  25. Rev limit set to 7,000 reguardless?
  26. Turboxs Tuner questions...
  27. maf sensor ????
  28. Hear-Ye Hear-Ye! UTEC Firmware v1.7 is online...
  29. Wideband o2 sensor placement, as well as knock sensor?
  30. Need a Uteck
  31. theres a lil x next to my knock meter.
  32. Need a Afc n harness new/used
  33. Will the Utech's new Firmware allow a Speed Density Conversion?
  34. Evo Utec Ver. 1.6 Pre-Release Party
  35. S-AFC2 Install w/o guage package
  36. Interface Question
  37. Rev Limit?
  38. Release date on DTec?
  39. Newbie:Help w/ AFC II. Installation with harness!!
  40. UTEC and XEDE Comparo
  41. WTF not again.
  42. UTEC Owner Survey
  43. AVC-R Install and settings
  44. Tuner Advice for PFC
  45. External Map Sensor
  46. Couple ?s about afc can some1 help me
  47. Data Logging
  48. Logging with UTEC
  49. buschur stage 2 s-afcII settings?
  50. FS Turbo XS Tuner Pro(Brand New)
  51. Wideband o2 ?
  52. Utec yeilds a 11.98@115
  53. UTEC with new turbo kits
  54. Getting a UTEC, but need a few answers
  55. Finally Solved My Knock Problem
  56. Post your UTEC Logs Here
  57. UTEC noob
  58. cant rev past 4.5k?
  59. Flash + utec?
  60. Stock E.C.U. ?
  61. Could some post Datalog with MAP sensor data ?
  62. wiring question
  63. wiring question
  64. Karman readings
  65. Post your GM 3-bar sensor setup values
  66. Larger Injectors effect on IGN timing
  67. need help getting TXS map
  68. Temp Changes
  69. Opened loop or Closed loop boost control
  70. Knock reading? Reliable?
  71. High boost
  72. Request: UTEC FAQ
  73. My UTEC is wrong? or it's normal?
  74. Stage 1 Map help
  75. Faster Turbo Response
  76. UTEC Problem
  77. TunaPro Logging problem, need some ideas
  78. Questions for utec owners
  79. Questions on datalog #2
  80. MAF to MAP???
  81. s-afc harness for evo
  82. ? on map 0
  83. CN-4 Field Harness and SAFC-II
  84. feelings about emanage?
  85. usb to serial adapter?
  86. First OPEN LOOP Fuel map..
  87. UCC Release 2 Available
  88. TXS Tuner $399 with VW Wideband
  89. Base SAFC II settings?
  90. S-AFCII + BOV question
  91. Can I see some timing maps?
  92. engine light flashing
  93. Importing A/F ratio into UTEC
  94. Help with datalog need a few pointers
  95. Stage 2 Map
  96. UTEc and aftermarket intake?
  97. Map Seletor
  98. Something really weird happened...
  99. US Instructions for Power FC D-Jetro
  100. Questions on my 1st datalog
  101. safe to run car like this?
  102. To Blow Off or Not?
  103. Throttle reading on my SAFC2
  104. WORKS plus Utec
  105. *** UTEC Control Center - NEW UTEC GUI ***
  106. Power FC problem mapping
  107. UTEC and Boost Controller??
  108. Any tips on installing and tuning a PowerFC?
  109. Tuna Pro install question
  110. Getting ready to tune
  111. want a utec?
  112. Power FC on a Mitsubishi RVR?
  113. UTEC idea...may be far fetched. mmmmm
  114. I'm on the SAFC2 Fence...
  115. Tuning idle
  116. test pipe
  117. This is my dilemma...what would u do?
  118. Some UTEC install ??
  119. SAFC II Question
  120. Any thing different about installing SAFCII on an 04 Evo?
  121. UTEC seems to work!
  122. Who is the POO when it comes to tuning the power FC in TX?
  123. Boost 1.6.....2.0 bar
  124. Apex'i World Sport 2 Exhaust?
  125. Here's one for ya, Jack.
  126. Does Map 0 bypass UTEC?
  127. Anyone here running 272's?
  128. Timing Question
  129. Prototype closed-loop boost control solenoid for UTEC
  130. tired of waiting....
  131. Gear Specific Maps ?
  132. SAFC II default settings for EVO VIII...
  133. Greddy Emanage for sale...
  134. What you thing about this dyno plot?
  135. Hesitation when running TXS stage 1 map
  136. Harness - which side is ecu side?
  137. Looking for an aftermarket BOV
  138. Injectors going nuts?
  139. S-AFC newbie help
  140. downpipe-tuner-o2
  141. TurboXs Customer Service
  142. UTEC to turn off my CEL?
  143. utec boost control or ebc?
  144. TurboXS DTEC
  145. Utec Launch Control
  146. Looking for a Map for my UTEC
  147. will there be a tuner sale?
  148. FC-Datalogit Question??
  149. Connecting my UTEC to Laptop
  150. SAFCII knock reading?
  151. logging egt with tuner pro
  152. Open loop fueling saved my Day!
  153. afc fix k&n typhoon prob?
  154. Factory Fuel and Ignition Map
  155. accessories very cheap
  156. Anyway in Tampa, FL area with UTEC like myself?
  157. GM Boost control solenoid
  158. New Feature Suggestion..
  159. display screen
  160. Fluttering boost???
  161. Utec sale Prices
  162. UTEC / TXS Tuner interaction
  163. stage 2 map
  164. any good shops in so. cali for utec install and tuning?
  165. Just got back from track with TXS stage 2
  166. Software question...problems with laptop connection. techies please :)
  167. Firmware
  168. Just got my Stage 2 in...well, almost.
  169. Sure wish the TXS boys would comment on when we can expect.....
  170. Launch Control.. how bad is it for your car, and ignition or Injector cut?
  171. running catless w/ UTEC?
  172. SAFC II vs. HKS AFR
  173. can utec control boost? or do u need a boost contorller?
  174. Ordered my UTEC
  175. New UTEC Firmware, PLEASE!!
  176. UTEC Knock issues.
  177. Profec E-01
  178. stage 2 Map....
  179. BR580, round 2
  180. Utec Maps
  181. 700cc injectors / 255lph pump
  182. Knock Detection (CEL LIGHT) Question
  183. Power FC problem
  184. BR580 problems
  185. wideband ?
  186. airflow#'s in hz
  187. Troubleshoot my tuna problem
  188. track update - best time on new map
  189. a quick for you UTEC tuners
  190. just got back from track - ran MJ's map
  191. SAFC2 Quick question about throttle
  192. utec and data log ?
  193. New power graph
  194. Utec Maps
  195. made some g tech runs
  196. Another good reason to get an AFC
  197. Knock Reading using FC Commander
  198. First run with Utec - Data Log ?'s
  199. Tuner A/F graphs
  200. Help Power Fc Evo 8 280 Hp Jpd
  201. Service engine soon light
  202. Good AFC info from malibujack
  203. The Right Pin out for AFC is here
  204. MAP Sensor Driveability
  205. Utec Installed - Boost Issues - Help
  206. Max Maf Value ?
  207. TurboXS Tuner suggestions....
  208. more newbie ?'s
  209. safc2
  210. .....map crossover bump....
  211. Utec for sale
  212. newbie UTEC questions
  213. HKS VPC works with E-Manage
  214. Support tool cable
  215. WANTED Emanage
  216. Good base line map for a evo 6
  217. Emanage setting for 4G15 dohc
  218. MAP Sensor install?
  219. (Nathan)UTEC w/ MAP Sensor?
  220. Selling D-Jetro w/command, BC, datalogit, etc
  221. FC-Datalogit for D-Jetro
  222. Help with Power-FC D-Jetro
  223. how much boost are you running ?
  224. Poll How Much Boost Are You Running ?
  225. New UTEC software beta test help needed
  226. UTEC Changing maps on its own ???
  227. SAFC II not showing correction
  228. How much are you guys paying for the evo8 PnP system?
  229. Re-setting the ECU...
  230. Autronic/ Air Condition
  231. Comparision of S-AFC II to XEDE
  232. Proof the UTEC works
  233. Odd 5th Gear boost behavior
  234. Unichip
  235. Software Question...
  236. Comments on E-manage from Owners
  237. Is SFC-II and Power FC the same thing?
  238. EVO Utec Software Update
  239. laptop mounting???
  240. emmisons
  241. Lost boost
  242. Need some help with preliminary UTEC results
  243. UTEC compatibility?
  244. losing map sensor calibration when i save changes to map
  245. What are the best afc2 settings on stage 1
  246. E-manage with ignition harness
  247. My short 1 night review (L-Jetro)
  248. Where are the TXS guys hiding???
  249. just got POWER FC today!....need help with intake temp sensor.
  250. Connection / placemnet of Wideband O2 bung
