- The story so far......
- EVO8 Ecu suggestions
- Going back to stock Ecu... Questions.
- Few questions about Stage 1 91 map
- Wow, I have to bend my 1.3U to log or flash!
- 1.3u cable not connecting with evoscan help
- Locked ECU from previous tune
- speed density safc
- Fuel delivery problems
- AEM Series II or Haltec
- Hks evc
- Dyno in TN area
- 50k checkup
- Yellow # "75" Pin - rear o2 signal wire?
- Question about the 2.1 builds
- Evoscan gps data logger?
- HKS F-Con Tuner Near Little Rock?
- Evo 8 stalling during deceleration
- Need a place to tune Evo VIII
- What to start off with !!!!
- trying to make this thing faster, check out my logs please?
- Cobb Stage 1 with SF Knock sum 6
- External ACD Lights and Switch
- WGDC Correction Issue
- Simple dataloging qestions
- evoscan help!
- MUT protocol information for Torque app (Android)
- Just got a 1.3U, so......(?)
- Idle problem...
- Crank timing gear removal
- how to make more power
- new to tuning...
- RICH IDLE, tune doesnt fix
- Need a Tune
- Stroker motor
- Overheating
- Evo 9 ecu replacement
- Engine won't fire up :(
- Crank thoughts
- Bucking During Acceleration
- Formulating AFRs for Disabled Lean Spool
- unknown error codes.
- evoscan problem
- Gm 3 port ecu boost controller
- can you calibrate the speedometer?
- whats the most accurate way to change boost on the fly
- WTF? LC1 issue
- will subaru ap work on ix
- does anyone still use accesstuner race???
- installed cams now running rich
- evoscan help!
- Aem ECU miss firing.
- Need Guru help: Changing restrictor size with a MAF setup, will this need retune?
- Calling all evo owners!!! In dire need of help!!
- 2003 Lancer First Time help.
- Lean AFR during idle
- Adjusting Closed Loop and Idle AFRs
- Video Inside, AFR's went crazy after cam change
- Blitz SBC iD overboost issue
- Looking for advise
- Removing accelerator cable..?
- Tuning Companies near NE OH??
- AccessTuner & uego data log???
- NEED HELP ASAP, PTE 1600cc scaling, latency
- Tuning software
- cyclic or rotational idle for cool down purposes
- Cobb ap question
- NC Tuners
- Need help for my JDM evo IV!
- I need help finding the right piping kit.
- Trying to understand Lean Spool
- wow nobody uses this tech anymore?
- EVO IX fuel cut and poor/rough idle
- Stock VIII Ecu question! Help!
- O2 Housing/Turbo Outlet need a tune?
- How to spot stock cams.
- Is tuning a stock Evo ecu same as other brand ecu's?
- EVO9 BAD hesitation, P0304
- Check voltage on AEM?
- AEM WB02 questions....
- ECU Swap
- What Happening with my PFC Tune!!!
- Help..... what sensors can I delete
- Help with UICP...
- do i need a second 02 sensor with cobb AP?
- please help with boost gauge install
- FIC 1650 Cons??
- Need Help ASAP fic 850's wont scale
- 2003 Evo 8 P0300
- Peak Load vs Peak Torque and MBT
- 02 sensor question
- How to prevent a waterlocked engine????
- do YOU think i should buy this turbo back????
- Looking for tuning software compatible with an evo 9 and a 95 2g dsm
- Base map needed (4G63D-US v6.11)
- Lancer ES Parts
- ? about AL @ Dynoflash
- Lean idle until revved...?
- I need E85 tune?
- is pump gas tune with 10:1 pistons safe?
- HELP!! Car floods when cranking!?!? :-(
- evo9 ecu choices and possible dsmlink
- p0135 o2 heater code please HELP please read
- Have Ignition setup questions
- Evo 4 with 8 ECU - wiring O2 sensor ?
- Wideband formula help. Innovate MTX-L ---> EvoScan
- Oil
- Power drop when upshifting.
- Hks fcon vpro with navigator for sale
- Looking for a tune
- Stock Block and Tune Potential Questions
- How to check for error codes?
- Evo4 misfire!
- Car idles high now and then
- EVO9 Stalling
- Transmission Drain Plug
- tephra tune start issue.. 1.5 years strong..
- AEM True Boost help.
- Kelford 272 cam's
- Setting My Adjustable Cam Gear
- Got my wideband completely hooked up, need help.
- AEM EMS to stock ecu help
- lancer GTS throttle body
- copilot program
- Immobilizer location
- e-flash?
- exhaust manifold question
- NEED HELP PLEASE! Immobilizer Question
- fuel and timming maps vr4
- want to tune
- idle issues
- Evoscan keeps crashing
- evo needs tuned, live near dayton, ohio
- ECU location/harness removal
- OBD port reading error??
- Tuning a 9, coming from a X
- Grimspeed Tuning Software?
- DSMlink
- Tomioka Exhaust Manifold (no wraps in pack!)
- Is There An "Official" Idle Speed?
- How to Interprete Pfc Fuel Map?
- Looking for good tune shop in or near South East Wisconsin
- Too Hot(on stroker motor)
- Hey guys random tune question...
- Lower Ball Joint
- Car missing after HKS SSQV 3 installed
- AUDM Evo IX XMLs - Who has the latest?
- proefi!
- Where do connect positive wire for boost gauge?
- Is this a good start?
- Someone please help asap!
- HELP! ive lost all hope
- AEM UEGO afr Data Logging - Help!
- Help! I am able to create knock counts on Evoscan near off-boost! Real or fake??
- Getting some "knock" IX MR
- Stock Evo VIII, Missing/Hesitate ?
- MAP sensor plug cut. Help?
- help: 2004 evo clicking noise? and belt whining with video
- How Does the Yaw Control React after Tune?
- Evo 8 Whining sound
- Need Help Sourcing Parts and Software For Autronic ECU
- stall issues
- good brand for a boost leak tester?
- Fuel Pump/Injector Demand Web App
- Stock Pistons
- Gsc s2 cams
- Help
- Air Fuel Upgrade Questions
- AFR deeps into 10~11 when full throttle.
- LA Tuners ECU patch
- Aem Wideband Question (screenshot)
- To stroke or not to stroke is the question
- EVO 8 LEAN at WOT
- Evo 8 wandering afr when warm
- altitude question?
- Head Gasket
- Help
- Cat Delete question
- Accessport alternative?
- COP Wiring
- biss screw adjustment settings question
- user freindly tuning stand alone or factory ECU?
- Tuners use??????
- Weird issue with uego formula for evoscan
- explosion of coils???
- Can't seem to hold 2500rpm? Tune?
- Help...What is Evo 8 Block Vin #
- weird tuning problem
- LC! Wideband reading of vacuum of 33.4??
- Accessport needed!!!!!!
- Ecu controlled boost
- evo 8 crank help
- Wanted OEM ECU EVOIX (9) Illinois
- Complete PFC tuning tools.
- Blown block due to bad tune???
- self tuners, user interface, etc
- Stalling on no load decel..
- ACD pump
- Evo 8/9 injector question
- Noob Tuning Questions
- Pro-Efi...experience, vendors, etc??
- to tune or not to tune?
- dump valve noise
- whirring noise near fuel tank.
- 0-5v input on the rear o2 sensor input
- Widebands???
- Innovate Wideband issues, help...
- Evoscan logging problems
- Quick question about Boost controlers
- PFC D-Jetro evo7 to evo8gsrUS
- anyone interested in proefi?
- Big CAMS GSC S2 and Iddle STALLING ISUES ON eVO 8
- Aem ems or stock ecu?
- Race ecu´s for sale for Evolution X
- Vi-pec Standalone computer system for Evo 9 MR
- Will injen uicp work with arc box
- Engine knock
- Data Logger only
- Software?
- Tuning thure seriell port ore USB ?
- Haltech Plug in for Evo9 MR?
- Custom map for stock EVO VIII
- NOOB question
- Running a little rich.
- ISO/WTB Evo8 Coil pack
- PFC and OBD2 Emissions Tests
- Over BOOST!
- EVO9 MR having major issues
- Utah Pro Tuners? or Email tuners?
- Standard PFC Functions.
- Help with Management systems?
- AEM's new Infinity-10 Standalone
- Question about FPR and COP setup
- Unlock my P-fc in the bay area?
- Evo 9 ECU issues
- help! what clutch to buy?
- Utec accessories?
- setting fuel trims help!
- logging boost thru LM-2 to evoscan
- log boost thru LM-2 to evoscan
- Uninstalling cobb AP with a pro tune
- HELP EVO MISFIRING..hks twin power dli 2
- Alternative replacement ECUs (evo 8)
- aem ems to stock ecu on 8
- Need Doggle For AP for Evo8/9
- Need to Buy OBD II connector for my Evo 9
- Evoscan Evo5 datalog irregular dataloss/poor communication
