- where to buy MAP sensor?
- p2r flash and aem tru-boost?
- Airbox Evo 6
- ECU + or AEM ??
- jestr flash?
- Beginners tuning guide?
- Help can't get Ecutek flash.
- '03 Evo & Power FC?
- Stock EVO 9 ecu $$$??
- any ideas for the engine dying??/
- datalog lab
- ECU reflash recommendations?
- Stupid Question
- New ECU+ firmware and software now available
- Tuning Options
- is this a deal?
- Who offers the best custom TUNE?
- For Sale: ECU+ + Evo 8 Plug and Play
- Turbotrix or XEDE
- Any solution for difficult cold starts?
- Power FC on Ebay
- Call Out to Turbo XS to Open Source Development
- ill effects removing SAFC?
- To the 50 trim guys, what EM do you use?
- "closed loop" and test pipe
- safc neo karman signal problem!
- map remote switcher
- What can the utec do for me?
- First Logs, Evoscan stored DTC's
- help with service engin soon light
- Ecu+
- o2 sensor
- Power FC Boost Controller install??
- MAFTPro for your ECU map switching needs.
- Ecu
- WELD JAPAN will be tuning POWER FC Dec 13-27th.
- does it still have the software
- Race Gas
- Is this Lean?
- Xede vs AEM vs Flash. A dilema for a "simpleton"
- reflash or stock
- any drawback on ECU+
- SAFC 11 neo
- Oil/Air Change Question
- how much power are you making with an afc
- Fine
- APEX'I Vs HKS Vs MOTEC M800 OEM
- tuning: reflash Vs everything else...
- SAFC II question before purchase...
- Tuning question!
- Can I use Zeitronix without O2 sensor?
- 1000cc injectors with PowerFC
- ECU harness pins
- Power FC & AC?
- will ecu+ ever support the aem 5 bar map sensor?
- Tuning Software
- Turbotrix visit
- Interesting ALS Resources.
- 11.9 @ 118 Mph @ 22.5Psi EVO 9
- S-AFC II diagram to a EVO IX
- Just installed some upgrades on my IX MR
- Help - MAF Honey Comb Finished... What now?
- Access Port or Laptop..
- Zeitronix and map sensor??
- Power Fc Tuners Near Nashville,tn
- C16 on a car not tuned for it?
- beginner tips pls
- e manage or ultimate for Evo9
- do i need a reflash?!
- noob question
- can crank shaft sensor make ur car run poorly????
- Resetting ECU
- Uego AFR logging to have rpm based graphs
- end of sale powerfc
- Evo 9 ECU ????? Where i Can get one
- knock voltage vs knock count
- Ecutek results (dyno charts included)
- Just got my utec....some questions
- Noob questions, go easy on me
- help with evo 6 problem
- best data logging tool
- Question about reflash and AFCII
- waste gate spring
- AEM Wideband output with Datalogit - Anyone tried?
- Autronic ems
- evoscan help....
- Anyone USE UTEC to Trigger NX Express Solenoid?
- 2.0 Build Up Resources
- Are the oem spark plugs okay for 23-24psi?
- What is the max safe EGT(centigrade) for EVO IX MR
- What is the max/norm EGT temp(Centigrade) at WOT/23 psi for EVO IX MR
- Injector Scaling
- Please discuss my Log
- Launch Control
- Autronic pass smog?
- Several doubts about evo VI TME
- Got a new EVO IX MR w/ plans for a bigger turbo in year. What beginner mods?
- safc2
- Evoscan questions.
- MAF Hz vs. HP
- Switchable maps for different octane?
- anything else needed?
- oil leak.. please help
- Resetting the HKS Super AFR
- Motec M800 Oem
- Gems ECU Not powering fuel pump
- Let me know if I got this right.
- Cobb Tuning Accessport 2.0 Offical Information!!
- How does the stock cat affect wideband AFR readings?
- Datalog Lab shows 294whp from a flash.
- Hmmmm Help!
- Need engine management for APS turboback/cat/intake/bov
- VIII and IX harness
- Anyone been pulled over with the Greddy Ti in Cali w/ no silencer?
- Does anybody know if an exhaust silencer reduces power?
- Tuning options for Evo IX?
- my power went from 390whp to 443whp w/ AEM ems
- TurboXS UTEC and afew things for sale on EBay
- ECU Tek on the west coast?
- VIshnu Stage 3 Just dynoed; 422 WHP
- Which ECU tune gets the most whp increase
- AEM TRU-BOOST Gauge-Type Controller??
- Problem with car starting
- fuse problem
- PFC map question
- Boost Controller....ALONE
- Confused about solenoids...
- Boost related to temp/humidity?
- OLF Question
- Intereting Logs on IX
- anthing I need before re flash?
- p23
- High Fuel pressure due to UTEC??
- Why isnt it a good idea to run a electronic boost controller
- NGK Wideband?
- GM translator at ECU+ and flash?
- Is this a good piggyback
- Need Feedback, Please!
- muffler: before and after dyno
- question on which boost lines to use
- help: EVO 8 ECU DIAGRAM
- Reasons for pulled timing after 5k RPM's?
- Tuning for AFR and timing
- Large Boost Spike
- dynoflash?
- Tuning near Boston
- Converting an Evo for Ethanol E85
- New exhaust = Higher knock count ???
- quick tuning ? about 255 pump
- Only 9 Psi
- Simplest way to eliminate off-throttle surge?
- First log question about gm 3 bar
- Re-flash, Piggyback, or Stand-alone?
- turboxs fuel, and ignition maps
- What do you think ?
- engine management for the evo IX
- Knock?
- ECU Flash and P0121 Code
- help on ecu tunning please~
- Possible transition issues?
- Florida Tuners U-Tec
- SAFC install question
- i just got tons of new info on the cobb accesport
- Profec B Spec II issues
- help on ecu please~
- Will my Safc mess up my flash?
- Tom Collins Rules
- Can someone help me with my EVO VI power FC map?? PLEASE!!
- ECU+ Remote display prototype..
- Close loop vs Open Loop condition
- Help, Can Anybody Help Me??
- im new to this, and i need some help to dyno my car
- AM I in Limp Mode?
- EVO IX 406fwhp 575Nm. torque
- boost issue
- Dynoflash FKED YOUR OEM ECU?
- wbO2 vs nbO2 difference in tuning
- pump/alky maps on flash?
- ECU+ and Reflashing? Of course!!
- newbie here!
- Any ignition gurus out there???
- apexi AVC-R
- ecutek tuning cost??
- power fc questions
- Apexi AVC-R on an Evo IX
- anybody had turboxs dyno tune at their shop?
- idle problem
- Typical a/f ratios and timing
- tuning with afc or flash
- remote tuning with VNC
- '05 Evo Viii Mr Ecu Pinout...
- COBB AccessPORT for the EVO
- Autronic and FIC 1600's
- ecu (which one)
- First Tune - Finally!
- ECU+ PnP for JDM EVO9
- How to disable the boost control valve
- Management - Logging in Win XP on a carpc?
- Devo Tuning or AMS? Pros and Cons?
- O2 sensor volatge questions?
- How to tell if an injector is bad
- Newbie Wideband Questions
- Boost surging on WORKS flash
- Pocket Logger OBD-II
- Innovative LM-1 W/ Auxbox question...
- Formatting Issues During Logging
- Fastest time with afc
- Used fuel injectors
- Running too rich
- Pardon my n00bness... Which flash is the best cost/gain?
- timing advanced why???
- At what point is "Lean", TOO LEAN? With meth. also.
- How many actually blew up WHILE RUNNING METH INJ?
- Can some one help me with evoscan??
- Still Learning.....
- good 1st mods...
- Car problem....
- DetCan / Knock sensor audio clips?
- Bozz Speed Ecu?!
- upper i/c pipeing question
- utec mac compatable??
- Cobb tunning working on evos!!
- SAFC2 tuning question
- Need Help Quik. Power Fc w/commander or EcuTek
- Getting EcuTek tomorrow!!
- EcuTek mechanical CEL fix
- 02 Sensor and A/F
- Cobb Access Port
- boost questions
- tommi makinen and 1.4 bar ?
- Fuel pump question
- Pros / Cons to Removing the Stock Air Box Lid?
- please help me tune my safc2
- help.. tuning issues
- Stock 05/VIII / fq340 difference??
- HKS EVTC Mivec Controller
- EVOSCAN Log files??
- evo 9 ecu
- AEM or FLASH
- Evoscan and Wideband?
- 02 Sensor Hookup for Tuner
- emanage initial settings
- CTS question need quicky anwser
- AEM Uego 30-4100 need help
- E-85 / Methanol
- Apexi Gizzmo Mivec Controller Anyone used one yet?
- suddenly not reading O2's
