- Has anyone sourced OEM ECU Pins/connectors?
- Evo IX Engine Control System Diagram
- code P0234 turbocharger overboost
- Ecu+ silver box PNP available
- LF : EVO IX stock mapping
- AEM UEGO problem
- Tuning software most like dsmlink
- Misfire When Tuning...
- quesiton about sparktech sequential and stock ecu
- Tuning issues
- Random missfire standard, remapped E7
- VALDI Sport ECU
- Tuners I need help with my project Evo VI JDM Please!!!
- Evo IX map
- Thinking of switching intakes
- afr differences on same car
- GM 3 port or Grimmspeed
- Relative boost
- o2 dump to atmosphere o2 housing tuning advice needed.
- 400WHP Goal, Have 650cc Injectors.....Upgrade?
- hey hows this tune look?
- Which has better features???
- Tuner near eastern TN?
- help! rear 02 sensor location?
- Vacuum/RPM relationship to mileage...
- Busted Finger (Tactrix 1.3 cable clone) question
- Sd conversion?
- anyone have any experience with Englishracing tunes?
- What other things could be changed/upgrading while doing 60K Service
- Are the Virtual Dynos as good as the real thing?
- innovate LC1 and G3 Gauge question
- Does a non ACD tranny use any sort of tranny ecu?
- info on greddy infometer touch
- Where to start on tuning if i cant make a full throttle run?
- HELP.. ECU problem
- Apexi power FC d-jetrp ( small question )
- Will a netbook work?
- MAF Translator Questions
- Best Tuning/ datalogging software? your opinions please
- Evo x Wideband Install
- WA State Emissions King County
- Puerto Rico GTS 2008 TURBO 380hp DynoCenter
- SoCal: Anyone have a bricked stock ECU they wanna get rid of?
- Innovate LC-1 Issue
- boost for EVO 7 JDM
- Difference between Raw Knock and Knock Volts
- Evo 8 running very lean lots of hesitation Need help! Grimspeed 3 port bcs
- Logging Software Personal favorites
- Is a retune required after a new IAC install?
- ECUFlash Street Tuned - Virtual Dyno
- 2000 rpm stutter, afr < 10
- Boost Leak test ?'s
- Can a L-Jetro convert to MAF sensor?
- whining noise.
- AEM Digital Boost Guage...
- MY buddy needs help with his subaru! please help! Tunning related!
- How do I start logging???
- good shop near L.A ?
- maptracer load not in the correct column
- Clutch Slip or Wet road in logs creating inflated HP/TQ numbers with Virtual Dyno?
- Evoscan ?
- Does PFC has Anti-Lag Feature?
- Fouling out / knocking problems, 03 evo 8
- running lean in closed loop?
- Cold Air Intake?
- what is needed to go "Speed Density"
- Am I SOL??
- White smoke while accelerating after new turbo install
- 96' CN9A Evo IV Support
- ECU stop thief, GPS tracking.
- What mod should i do next?
- Stock CAM!!
- How To wire Up a GM 3 Bar map to log in EVOSCAN?
- Turbo xs utec NJ
- EvoScan 2.7 WTF??
- Hks f-con pro v - evo 5 - air temp sensor
- How to tell if my car has been tuned.
- what happened here?
- iddle problem
- Who's got an Autronic?
- Is there a Evo 8 ECU that will will be a direct swap for an Evo 7?
- Thank you Admins!!
- Aem fic
- 20+ counts of knock on 11.7 AFR!!
- tuning question - VDR chart
- need help, what numbers should i watch out for on Live Data. 2005 evo MR
- plugs?!
- notchy gears?
- Fuel Octane V.S Tune
- Long term fuel trims stuck at 0
- what to do?
- Timing help
- Project Evo
- OEM ECU case?
- Rear O2 vs stock ecu tune
- Injector question
- PowerFC PC interface hardware
- ap show realtime afr for evo 8/9?
- Question and Advice
- What cable?
- So, how to tune...
- Need someone local to restore my tune to stock
- EVO 8 ECU in Evo 4
- Tuning School?
- New evo tuning
- apex-i avc-r settings?
- Scantech download
- can someone help me with Tephra V7 setup please?
- Ecu tune question
- engine clicking noise! help
- ECU 5V supply current
- Speed Density vs SD
- Best place to get tuned in norcal?
- E85 ? if anybody can help me out..
- ATTN: Franz (FatBastard)
- ect tec
- Pro EFI for evo 8-9
- Broke the evo :(
- IX shuts off when A/C is on???
- Is there a place in Sacramento to get a tune?
- utec password question
- gm bcs question
- greddy profec b spec ii HELP
- PTE 780cc injectors need to be identified
- 3 Bar Map Sensor with GrimmSpeed 3-port BCS
- MAF Senor issue?
- Emergency Tune!!
- egr disable question
- Openport 1.3 vs 2.0
- Help me clear some things up :)
- 2 cam gears or one
- is my fuel pump maxed?
- logging boost with omni 4 bar in evo scan
- Innovate Motorsports OT-2
- Does this look right? First idle log
- quick log for those that like looking at logs
- what do you guys think of this tune?
- Tune went away?
- Zeitronix wideband AF
- Aftermarket ecu vs stock ecu
- Intake side on-throttle surge control
- Tuned ECU swap, same mods
- any help would be great
- Question about MBC
- Evoscan 2.6 missing data when logging???
- Street Tune Vs Dyno tune, need advice.
- Evo 5 SAFC2 proper tuning
- Performance Racing Chip???
- How's my previous fuel map??
- tuning and the 08+ecu
- Evo 8 4G63T Question..
- Wideband logging via rear 02 on 3 plug ecu
- help on tune
- what intake manifold to get??
- LC1 in exhaust tail pipe
- Zeitroniz 2010 model wiring: what connects to ECU pin #49?
- Fujita F5 UICP Installed= Richer AFR's???
- 61 degrees of timing advance for start up
- Newb LC-1 issue, help please.
- is evoscan ok for my setup?
- hearing a tick sound at about 3500+
- Can I Log Boost from AEM Boost Gauge in Evoscan?
- Apexi Avcr map sensor
- What ECU is best for my application
- How do i fix car shuting off with ac on when rolling to a stop and pressing in clutch
- Ran out of fuel on 880s should I get bigger injectors or an adjustable fpr?
- instal MBC now car runs bad!!!help plz!!
- Ecu ecu ecu
- How do I open my dyno run files on a Mac???
- Wideband o2 & Tunig Info...PLZ help
- MAF Reading
- Raising Rev Limiter
- fcon vs stock ecu-speed density?
- Safc 2 settings help please
- P0507
- Hesitation on accelation, revisited
- rear o2 sensor?
- Stock Tune?
- which injectors 4 my set up..
- What do I need to log on Evoscan?
- Prosport WB vs. Innovate WB
- where to tune
- Speed Density conversion..whats needed?
- What is MBT?
- Simple evoscan question
- Fuel cut??
- Unlock
- spark blowout above 35psi on 6262
- HP ? does fuel injector 1000 make a big difference on stock setting
- Need ECU help!
- Is this considered knock?
- how can i log boost (non evo)
- Vi-Pec V44 Who knows about it/wants one?
- tuning question??
- Logging Mass Air Flow With EvoScan on Evo X
- wierd a/f r reading
- wideband quick question
- Swapping Intakes Where does MAP sensor go?
- Not boosting correct after removel of MBC
- Weird knock sum problem
- stock ecu burnt !!! please help
- Complex Problem: Rich AFR at WOT, then taper leaner. Inconsistent
- turbo timed w/o tt?
- Erasing codes with tactrix
- Knock Count
- retune after buschur 3.5 fmic????
- Tephra guide
- Going Crazy Need ideas!
- Searched but no help
- Tuning 2.3 stroker
- Nlts
- cat cel fix question?
- whats fuilds do i need for the tranny and t case
- Removing factory BCS
- How to tell what reflash I have
- Evo Scan 2.6/logging 2 byte
- Simple question: does the Evo's rev limiter use an ignition or fuel cut?
- emange blue not working
- afr after tune?
- MAFT Problems HELP!!
- Anyone has UTEC map for 05EVO with similar setup???
- AccessTUNER Race Server down May 21st-May 24th
- Air-Fuel Ratio Rich 1 Month After Tune
- alternator secret fuse?
- O2 sensor VS anti-seaze...
- Tephra??
- Hello anyone here
- Need a tuner ????
- TC-SST - EvoScan - Gear in Use Logging
- evoscan problem HELP WANTED
- Getting a tune in the rain?
- NEW ENGINE!!! NEW NOISES!!! argh
- blow off valve question
- Need some help...the evo is stalling and ideling high
- Air Fuel Gauge dancing?
- Need help with misfire!
- need help with wideband
- How u read boost in Evoscan2.5/Mitsulogger2.0
- ADM Evo 8 Logging Boost
- tactrix 2.0 + AEM Uego question
- Adding new requestID: Mitsulogger 2
- FTDI to usb cable question
- Adding new Logging Para.. Mitsu 2.0
- Evo 6 boost figures
- Limits of stock ECU ?
- aem uego and evoscan problem
- rom patches
- Help: What GM MAF meter?
- FOR SALE Total UTEC system with Tuner Pro
- Evoscan 2.7 Link
