- Anti lag
- UTEC w/acc for sale..$550 shipped
- when logging 02 do you use bank 1 or 2
- Does anyone have or tried the turbo xs dtec?
- Syms TrecsII missfiring system
- Utec setup for sale
- Quick ECU+ question...
- What can and cant you use maft pro for?
- Big turbo + untuned engine, ok for track event?
- 300m COP coil part number?
- S-AFC II is it enough
- ECUflash
- My Ecutek results, so far!
- Interesting Quirk
- bov help..
- Keep the Xede or sell it?
- Exhasut Rattle
- Datalogging
- discrepencies air fuel ratios with high and low comp
- EcuTek Tuning Time
- my apexi avc-r.can someone PLEASE help me
- OpenPort Tuning Forum..
- openport 1.3M
- Blowing fuse...
- Tuning for AFR's...
- pics of my 3" gm mass air setup
- Evo tuning revolution
- Injectors for GT35r
- More power to the rear wheels
- UTEC problems....
- Tuners: Where and when do you tend to your sheep?
- Lambda?
- Mod for mod: STI and Evo Comparison
- downpipe and full pump
- Having some probelm with knock...
- High load overboost after ECUTEK tune
- Evo-8 UTEC + Tuner Pro + extras for sale!
- Power FC Water Temp Setting????
- Is it safe if I cut the speed wiring???
- Lm1---vs--- Xd16
- does boost affect timing advance?
- AFR- Diffinitive answer under various loads
- ? for Most Knowledgeable Tuners!
- Operating temp idle help...
- Updating software/firmware
- Weird problem with AEM Uego & Greddy Turbo Timer...
- David Buschur in Phoenix for tuning 5-6-06
- Quick Question about a test pipe
- more issues with my gm maf setup
- FS: EVO VIII UTEC w/ map switch
- Shift Light Install
- UTEC and Alcohol/Water Injection
- WTB Utec
- Which bc should i run?
- What do I need to pick up boost?
- Now pre-ordering: ECU+ for Evo IX!
- new parts=slower..........why?
- Closed Loop Fuel Trims at idle & low rpms
- Ecu/camshaft Question
- Open ECU
- Innovative Tuning-Log Works Can it be our best friend?
- CEL again after o2 fix? is it something else?
- utec questions
- changing octane
- evo tuning
- AFRs: Shell V-Power vs. Exxon w/105 Ethanol
- AEM vs. Autronics
- AEM vs. Autronics
- gt35r same as gt3571???
- Does the Wideband need to be recalibrated after power loss ??
- Need HELP!!!!
- Would Works Flash work for 95 Octane Gas w/ 20% Ethanol mix?
- spark plug question!!!!
- Load %'s?
- After an ECUTEK Flash what is next?
- Hello from UK & first ECU+ logs
- UTEC vs. ECUTEK
- emanage not holding a map
- my boost spikes at 1.4 and drops to about 1. or so
- Dyno Sessions (experiences, tips, Pics)
- P0300 caught on a log.
- 350 wheel hp
- Which engine management should i use for 400whp
- Got an ECUTEK flash tune today
- autronic PnP for sale
- Is this blow off valve still on the market??
- Hydra EMS
- Can I mix 91 octane with 100?
- another gt35R log
- dynoflash
- how much more boost?
- Tuner Pro/Map Sensor/Shift lights for sale
- Can i use 91 octane in a car flashed for 93?
- utec on evo9?
- 280 Cams, TurboXS UTEC, HKS DLI-2 & Blowthrough Meter.............
- MAP sensor problem
- ams dyno days
- 2003 Evo - Voltage Clamp
- Fs: Ecu+ Pnp
- help with MAP sensor
- GM BCS...ATTN: Malibu
- dsm link
- autronic evo8 pnp - for sale
- Pigtails for GM solenoid and 3 bar MAP Sensor
- Blonde, whats wrong with you?
- Ecutek transfer/sale? How can it be done?
- Messing with timing...
- need to check my wiring for gm maf
- SAFC@ with aem uego
- Hks Fcon-is
- cant get a computer to connect to my ecu+ hu
- Pulling fuel on stock turbo with 680's
- help?
- safc neo
- ecu+ wire groups?
- Help Need Cable
- Base map for MAP?
- Should I reflash
- Jr. At ICS !!!
- Camber kit
- Current Map and Pull
- GM 3inch MAF setup with pics
- Whats a good plug & wire set up?
- monster sport
- SD and MN tuners
- cheapest GM 3 BAR map
- any cp9a power fc to trade with ct9a?
- Flash or not to Flash that is my Question!
- where can i get a mail in flash
- AFR while building boost
- Is ECU Timing Useful?
- Suggestions?
- jun cams
- Evo 8 clutch
- Timing & O2 voltage question
- ECUTEK and alky?
- Question tuning for C16 race fuel
- around town cruising afr's too high
- Im back!!!
- Is the utec evo specific?
- Quick Question
- OBD Scanning??
- 12v source for gm maf
- Tuning engine for minor bolt ons
- Go motec or not?
- what do you think about blitz spak plugs?
- Review of ECU+ from an XEDE perspective
- Ecutek and Revolver Cams?
- autronics or flash
- i need hellppp!!!!
- Help to tune SAFC and SAFC 2 for my EVO 7
- EGT, AFR, and tuning...
- MAP sensor slow response time
- PDT Gets Over 570whp on ECUTEK!
- Ecutek tune dyno sheet
- finally a real tuner in the bay area
- quick log of gt35R..
- buying autronics
- getting in touch with autronic
- M300 or Zeitronix
- Backfire after OLF upgrade?
- ECU Harness for Evo9!!!!?????
- ECUTeK "Launch Control"
- Please help!
- HELP: Need help on some codes since utec install...
- idle jump
- Nitrous Control
- New V4.5 thread
- SAFC 2 and SC Power mount
- Knock control and the PFC
- Never AGAIN
- ECU+ log with larger turbo upgrade?
- Best EMS for my setup, need help plz!
- Who here has the produced the most whp w/an "SAFC II"?
- MoTeC vs Autronic?
- Turbo xs charge pipe
- Boost leak or problem with BOV?
- IX intake only
- Vishnu IX Reflash Review
- parameters are altred in an ecu flash for IX?
- Stock ecu resolution
- Evo ix Engine management system
- Finally installed
- Intake air temp sensor and methanol?
- Please help, emanage ultimate!
- IveyFlash
- Datalogit W/out the waite
- intercooler tune?
- anyone running unichip?
- Effects of HKS DLI II or AEM TWIN FIRE on tune
- Utec for sale
- feeler: full time tuner
- Apexi power FC or TurboXS UTEC
- Map switching
- Whats are your Greddy E-01 Settings? Please Help!!
- Utec tuners in washington
- Launch Control w/ Power FC
- boost solnoid
- WHo in colorado really knows what they're doing with utec
- Help with error code 001..
- Anyone using Blitz R Fit
- Rev Limiter using engine cutoff
- Has anyone seen this?
- UTEC or no UTEC?
- Whining noise
- Datalogging with palm n stein lil stuck
- "ti ti ti ti" at max boost
- Evo IX UTEC
- Which Value?
- if u bored.. kindly answer my question
- EVO VIII SM4-Based PnP & Ion Sense Knock Detection?
- autronic vs hydra nemesis ems
- Vacuum/Boost vs Boost Gauge
- 3.5 gm maf
- Misfire GONE!! CULPRIT: Magnacore WIRES!!
- Apexi Power FC + Commander Question
- DTEC piggyback
- .xdf file for evo
- Need Help please
- Return to stock question
- EcuTek, 2nd ECU
- Can't seem to get the power fc to work
- Just bought the Evo IX, nice!
- Quest. to people running GM or Perrin BCS
- Do I have a pump?????
- Evo 9 motor work with Evo 8 ECU?
- How do the 4 Seasons affect tuning???
- Need help with ECU pinout
- Opening tunes up for discussion...
- Stock Airbox
- SAFC display
- widebands for pfc
- Hks Ssqv Recirculation Kit?
- What RPM does a stock IX reach peak boost?
- Car won't idle while Engine is cold!!
- Second O2 Sensor with PFC D-Jetro
- Txs tuner pro questions...
- Intake, Turbo-Back, and IC = Fuel Cut????
- Re-flash prices?
- weirdest HKS SSBOV sound
- which flash?
- 2 computers, save warranty?
- AEM EMS Opinions??
- ECU+ Question
- Log Time - Tune Tomorrow, Opinions wanted.
- Problem w/evo
- Turbo back exhaust question
- Can an evo tune itself ?
- gains
- Fs Safc Ii
