- setup timing for 2 coil sohc
- smoke coming from under the exhaust manifold?
- New Evo 8 Owner
- problem logging
- change trans oil.
- re tune for more boost?
- how to tune accessport
- Tactrix
- CEL Flashing on Reset
- evoscan not working
- EvoScan Question
- Cant figure this out please HELP!
- Ignition coil
- Problem with AFR & Fuel trims
- why so hard to find a damn belt
- My Next Tune
- Would you tune on these mods or wait for more?
- were's the boost gone on my car
- Greddy Profec
- need a base map for a 35r having issues
- stock motor hp
- Zeitronix ZT-2 question
- Want to ask an opinion. Clutches....
- E85 Rundown?
- Tuning in New England Area
- How do these numbers look?
- need usb cable
- Advantages/Disadvantages
- Knock sum...need some help
- EDGE insight product info?
- Tactrix Cable missing mitsubishi plug - Can I tune or log?
- HELP! Apexi PowerFC People!
- Greddy E-01 help
- how to log IAT's on evoscan?
- anybody who can tune i need one northeast pa
- Datalogit tuner needed northeast pa
- Stock Waste Gate from an EVO VI
- Need help with turbo controller
- Drivers for tactrix 1.3 cable????
- need a good map fr evo8 stock ecu
- Engine management needed?
- Engine build for turbo help
- engine management
- tach help!
- what do u think of my datalogs
- A/F Info
- P0403 EGR Solenoid error on Evo 5...
- TUNE REQUIRED FOR O2 housing and exhaust mani
- Swapping in a replacement ECU?
- Need help finding uninstallation info
- AEM EMS need inspection sticker
- Evo VI Tommy Makinnen ecu upgrade??
- Autronic EVO8 pnp peak & hold possible?
- Need Help...Underboosting after upgrade
- MAF Sensor Max
- hesitation (?) at 2k rpm
- BISS (base isdle set screw) and bad idle and stall
- Tuned, now a slightly lean idle with new mods...
- ApexI Power FC D-Jetro W/ FC Commander
- service engine soon
- Heater and engine check light on after ecu swap
- Testing a crank sensor?
- Evo 3 idle problem, please help..
- ECU - Flashing ABS & Yaw when OBD has something reading - EVO 9
- Perrin stg 2 for cobb ap evo ix
- Help!
- Questions on Tuning 05 VIII
- RPM DROP OFF too quick
- PNP Autronic for Evo 8 & Autronic Wideband for autotune
- Automatic ECU Tuning
- Questions about AP..
- Swapping ECU's
- Cannot access the ECU for Diagnostics - EVO9
- Please Help
- How for can you go?
- how do I know if I still have my tune?
- Buying a GPS
- PCMSCAN connection issues w/ tactrix cable
- AEM EMS Having hiccup from RPM Signal Noise
- knock count
- Logworks Vs. Evoscan
- MBC vs ECU
- Please help. Need EVO8USDM ECU pinout
- no O2 reading on evoscan?
- Evoscan cable problems
- serial to usb cable trouble for Uego/evoscan
- Spark Plug Change\Car Bogs Down
- Another 4WS tune in the making
- What is needed to log the afrs from a aem uego
- Headers
- Anyone running haltech ps1000/2000 on EVO 6 ?
- two step on autronic
- dual fuel map rom
- new e85 setup
- confused..
- Greddy Profec B Spec2 Settings
- Apexi SAFC
- New to tuning...
- Anyone care to check out my track run?
- currently a mazdaspeed owner trading in for an Evo
- maft wiring question
- Several AP logging questions. Any one help?
- data log can someone read it for me?
- Retune needed for ets licp?
- Service engine code, but not connecting to obd reader
- Newbie needs help
- 2thousand dollar budget what should i do?
- HELP --- Apexi Power FC
- Boost monitor not working
- Evo JDM 03 Issues
- first upgrade?
- Throttle Hang
- Anyone go from Aem Ems to Oem Ecu?
- Cobb AP stage 1 93
- after tuning
- Running rich problem
- Throttle Position prob
- E85 and 91 octane map switching
- Evo3 ECU help please!
- Anybody having problems with the ATR
- 5 bar map sensor?
- couple test pipe questions
- Need some help from some good mechanic
- AVCR.... Sensor Selection
- evoscan
- f con speed density
- ECU+ with plug in play patch harness FS
- going to have my 1st tune at ivey tune on 6/17
- 4WS tuned....!! Finally fixed!
- looking for good tunner in pa
- Evo's first tune
- Speed density = p141 code?
- need help with exhaust
- Evo 9 - Plug & Play ECU - fast & easy
- TurnOver, No Start
- E85 and twin fuel rails
- stock ecu and a 35r turbo?
- is this a good boost controller?
- Can't log fuel trims
- Aem Uego
- quickest and cheapest way to get to 400whp?
- i need some input
- How would you know?
- apex i power fc for evo 6 to evo 4
- Dead Battery..Now Problems..Help!
- CEL on, "fuel lean" only few mods .. normal ?
- Cobb AP and EVO VII
- problem with stage 2 map
- Good tuning shops in Nor Cal / SF Bay Area?
- Need Help Wiring TurboXS Tuner Pro
- AVCR Help
- MAP sensor for Zeitronix
- Custom Tune to AccessPort Map Transfer
- Need Help!! tuning issue??
- Thrust Bearing!!!
- Eboost settings and boost fluctuating. Experienced ppl please help
- tactrix 1.3 or 2.0 decision
- ECU RPM signal convert to pulse - Help please.
- A little more about reverse engineering
- Is my battery toast?
- i have tuning questions
- apexi avcr
- Innovate vs AEM...
- Tuning 950cc Injectors & GSC S2 Cams, Stock ECU
- How far can i push stock ecu?
- Immobolizer possible issues with apexi
- evo wont goooooooo
- Need mitsulogger
- How much knock is normal?
- New clutch??
- New clutch??
- TBE+tuning?
- PowerFC Manuals & mapping!
- Need manuel or help asap!!
- Can we get this section to read Autronic
- Tuning Question sorry i'm new
- School me on evoscan...
- Tuning Issues
- Need help
- where to get a GOOD all around tune??
- Can't drive past 20mph
- Free Dynoflash tune
- ecutek and a pump and racegas tune
- HKS 264s
- What Engine management is best for Evo 1
- Bought used evo/found it has a flash...?'s
- MAFT Pro/SD Tuners in CHICAGO
- Dip in AFR Around 3500
- Evo 7 ECU tuning
- JDM evo 8 MR ecu pin layout
- power fc tuning program asap!!!
- Knock at 3k rpm under cruise?
- O2 Volts vs. AFR
- ECU Reflash or COBB Tuning Access port?
- Accessport for evo VII/IX discontinued
- Popping sound at 4k RPM
- zeitronix Dashdaq VS LC-1 with dl32
- Launch Control
- Overheats when defrosters and hot/cold fan is on
- aem hookup to evoscan
- What to look for in Evoscan....low idle start up problems
- Kelford 272's and cam gears
- Question on datalogging values in Evoscan
- Innovate wideband problem!
- UTECH launch control
- Lean condition in Evo 5 w/ knock (Help diagnose)
- How to use DLL
- Evoscan 2.5 on Evo 5, need help.
- Engine rebuild and knock
- ECU+ Anyone ?!?!
- aem uego question...
- EFI tuning (Evo Tuning) Literature
- Thermocouples for air temp
- Hydra ems
- help plz
- Ecu Map graphics
- Can I use a Zeitronix 3.5 Bar MAP sensor in place of stock?
- mail-in flash
- Reading CEL
- CEL P0141, P0136 replaced rear O2 and cleared. and than...
- Leanin Out After 15-20 min Drive
- Programmable ECU????
- FMIC and Tuning question.
- chokes when shifting at WOT
- Evo8's power fc on evo7 ?
- mail in flashes
- Dynoflash mail in tune ftw.
- Check Engine light ON/OFF when EManage installed
- while driving my car shutdown and now will not start!!!
- Mounting solutions for netbook for tuning/logging purposes
- Zeitronix help
- HKS DLI II..should little red light be on?
- RPM Surge at 4th during Boosting?
- injector duty cycle above 100%
- What are the Pros and cons to ECU base boost?
- Which ecu version is this?
- Hks EVC 6 help
- OpenEcu.Org versus Norton Internet Security
- New Intake = Tuning right?
- Evoscan not saving datalogs (searched like crazy)
- Next Best Upgrade before tuning again-
- maftpro map sensor
- Innovate LC-1 can't find the right O2 sensor
- ECU/GM 3-port boost question
- Injector Battery Comp (usec) 1200cc
- MAFT install question
- Zeitronix a/f gauge
- Selling my L-Jetro
- Has the ECU been effed with?
