- Burnt My Clutch out!
- Clutch line compatability
- Installed B&M Short Shifter
- reinstalling tranny
- Gear Ratios...Possible?
- Where can i find shifter bushings for my lancer?
- What have they done to my car?
- Button to toggle between normal and the piggyback mode for the ECU
- mobil ATF+3 TRANSMISSION FLUID
- Maybe Tranny issues?
- Purchased a short shifter...
- transmission fluid
- short shifter ???
- Triple Disc Clutch?
- Having problems with warranty on tranny
- Question bout the gear
- tranny noise
- noise from under car???????
- Gear ratio's
- Downshifting
- Manny tranny prob.
- Problem Will Not Go Away... Please Help
- Tranny work?
- transmission strength
- rough accel in 2nd
- Loud Ticking....Just Noticed today
- transmission cooler
- fidanza flywheel
- auto tranny upgrades, who's selling it?
- price on short shift kit
- HELP with tranny
- Quarter Stick...
- Is Resistance when Shifting into First Normal?
- looking for ES bushings...
- found this on ptuning.
- Short Shifter: Was I sent the wrong item or is this not the correct shifter?
- Manual tranny fluid
- What kind of lube comes with the B&M short shifter?
- Energry Suspension
- RRM ECU Flash and auto shift points
- short shifter
- NEED HELP, BROKE MY AXLE!!! Mechanics please help...
- Transmission Kit!!!
- How much power can a Lancer tranny take?
- Differential question...
- Clutch issues.
- This was the best deal I have ever got!!!!!!
- n0ob <----- quick question
- Ebay short shifter
- Help out good old uncle marc
- Auto Tranny Information for the Lancer
- RRM Clutch install?
- Auto Lancer Owners Enter Here
- Evo 8 short shifter
- Auto Tranny "Slipping"
- Should I Get The B&M Short Shifter?
- RPW "short shifter"
- Helical Limited-slip Differential
- Wheel Hop!!!
- The difference between Evo shifter & Lancer shifter
- auto ****fting probs
- changing tranny fluid
- sequential shift for automatics
- How tough is the lancer tranny??
- Organic Clutches
- Oil Slosh/Burning
- problem with auto tranny!?
- Clutch
- Ebay short shifters
- Cluth a shifter question
- EVO drivetrain in an OZ?
- Problem please help?
- Invecs II Transmission swap
- do i NEED a pressure plate?
- B&M Short Shifter Part #'s
- How many people have perf. clutch and LSD- U.S. Lancer??
- Another fun part awaiting install
- Vibration in clutch pedal
- rrm clutch and pressure plate
- possible clutch problem
- How much should the B&M shifter loosen up?
- towing ability
- does this sound like a auto tranny prob?
- Will The B&M shifter fit my 03 OZ
- FF convert to AWD. How?
- anyone know about level10 shiftronic
- Auto Torque Converter??
- funny question
- notchy 1-2 shift
- Cost for higher gear ration?
- Programming Your Automatic For Better Shifts
- Motor mount torque specs
- Automatic Shift Points
- Short shifter kit question
- rev limiter
- lightweight flywheel?
- wheel bearing and brake pads.. linked??
- OEM Clutch/Pressure plate capabilities
- ???Auto Slipping???
- Shift Kit
- Slow take-off
- Short shifter causing transmission problems
- awd not in this car yet.
- new rrm clutch bucking?
- clutch install in 02 lancer
- Automatic to Manual
- clutch restrictor Q
- Kazz LSD for US Lancer~!!!
- changing tranny???
- Phantom Grip v RRM
- Lancer - Weak Tranny?
- Phantom Grip LSD
- Slipping clutch
- cost of clutch installation?
- How do you adjust clutch pedal?
- b&m shifter
- flywheel?
- High performance torque converter
- skipping clutch or transmission?
- How much horsepower can stock transmission handle
- minimal response from 1st
- Automatic Transmission...weird sound
- Downshifting an auto?
- Paddle Shifting
- AT to MT Conversion??
- INVECS III Tranny
- clutch
- shift kits for autos
- Short Shifter Install
- EVO shifter in US lancer
- Energy Suspension Bushings?
- Lightened Flywheel???
- which tranny fluid to use?
- B7M ShortShifter for $109?
- Gear ratio?
- clutch
- Confirmation from Clutch Masters
- Aftermarket Clutch Upgrade
- grinding in 5th
- Is my gearbox destined to get fuct?
- Road///race Front Lsd
- clutches help me!!!
- flwheel
- auto draging lancer oz
- Wanna change the transmission?????
- Tranny fluid
- 5 speed overdrive
- Automatic question?
- 3rd gear pull?
- B and M shifter?
- i was wondering about the 4wd?
- first to post hehe (actual content inside)
