PDA
View Full Version : Lancer Tranny/Drivetrain Tech
Pages : 1 2 [3] 4
  1. kartboy ss on 01 eclipse?
  2. Crank Pulley Question
  3. Time for a new Clutch Assembly
  4. auto/manual final drive compatiable?
  5. take care of your tranny
  6. 1st gear popping out
  7. Short Shifter?
  8. Limits of the auto tranny....
  9. Clutch Reccomendation
  10. Clutch Kits
  11. where to buy act kit
  12. GL5 Rating on Synthetic Manual Tranny Fluid
  13. Throw out bearing new still ****ed up
  14. soon to be M/T
  15. Where can I get axles at?
  16. 02-03 Slave Cylinder
  17. 03 lancer rear wheel drive
  18. clutches and suches
  19. tranny
  20. flywheel confirmation
  21. Is the 02-03 and 04-06 clutch the same?
  22. A2 Auto tranny shift kit?
  23. Automatic Shift Kit???
  24. Car jerks betweens speeds of
  25. Short shifter not recommended?
  26. Helping Picking Clutch Kits & Flywheels...
  27. Royal Purple ATF Max.
  28. Which clutch is better?
  29. Tool to use for Manual tranny Drain/Filler plug
  30. Changing Tranny Fluid
  31. throwout bearing HELP!!!
  32. Shifter Bearings aka Bushings - $10 shipped.
  33. FI - Clutch Slippage - New To Forum
  34. Clutch Problems?
  35. Lancer Auto into 5spd
  36. reducing wheel hop?
  37. kartboy shifter base and linkage bushings installed
  38. What size is the bolt going through the motor mounts?
  39. is this the transmission drain plug? picture inside...
  40. Mind Of It's Own
  41. 4G69 tranny in a 4G94?
  42. B&M sport shifter
  43. why my gears wount go in
  44. throwout bearings?
  45. Accolade - Short Shifter Kit
  46. Downshifting in and Auto....?
  47. Things need for a clutch Kit
  48. Damn oppossums and trannys
  49. 3rd Gear Rough Shifting
  50. Help on replacing my Auto tranny
  51. noise in idle...
  52. Auto Shifting Question
  53. 03 lancer es clutch
  54. RRM Stage 2 Clutch / Flywheel / Crank Pulley Review.
  55. Auto 2 Stick
  56. Mitsu Denied Warranty Claim Help !!!
  57. Zoom Clutches
  58. Did I fry my clutch?
  59. short throw shifter
  60. Short throw
  61. flywheel install question (2003 Lancer OZ)
  62. Slave Cylinder Question
  63. transmission mounts
  64. Turn any automatic into teptronic??
  65. 2 days left and counting......
  66. clutch install?
  67. Need tranny shop info....please...
  68. who has a kaaz lsd
  69. Front sway bar???
  70. fidanza installation
  71. kaaz lsd speedo gear
  72. Car stalled on highway - HELP
  73. AWD Lancer?
  74. Flywheel/Headers
  75. Turbo or Clutch/Flywheel etc. Part 1
  76. 03 lancer es auto to manual
  77. Stage 2 clutch issue
  78. stock clamping force number?
  79. Auto tranny problem? Car moves in P.
  80. turbo plus auto tranny=bad
  81. Anyone install clutch themself???
  82. My clutch experience with CNFX
  83. Why is the clutch so expensive
  84. Clutch is dying....
  85. Worksevo or RRM Clutch?
  86. quick shift
  87. Auto Transmission Cooler
  88. short shifter installed, have question
  89. jumps
  90. tranny overworking
  91. KartBoy Bushes
  92. clutch changing question??
  93. Tranny cooler set up?
  94. fidanza short shifter
  95. Need some tranny info for check up
  96. Weird Noises, Please give feedback:
  97. Works Stage 1 Clutch Review
  98. issues with aftermarket oils
  99. Manumatic, Sporttronic, etc...
  100. Question from Singapore
  101. Opinions on SPEC Clutchs?
  102. FWD Transmission Removal
  103. AUTO Tranny problem?
  104. Front motormount specificity Question
  105. Metal or Poly Bushings??
  106. tranny....NEED HELP ASAP!
  107. 2nd trans problem in 2 months!!!
  108. tranny prob with turbo
  109. help with clutch
  110. NTB: Clutch for 2003 OZ
  111. Shifter thread...
  112. Manual Trans Gear Ratio?
  113. knocking noise coming from motor when clutch is released
  114. Cheap Stage 2 Clutch
  115. weird problem never herd of
  116. auto tran to manual
  117. Cluch slipping
  118. Do I need a new clutch?
  119. rev limiter
  120. Blew My Stage II Clutch Set-Up!!!
  121. electrical engineering question
  122. LancerShop Authority short shifter installed
  123. Evo engine,tranny swap
  124. Best Oil For OZ?
  125. axle removal?
  126. Blend of Redline...
  127. auto to manual
  128. 7K Rev Limit ECU questions
  129. 2nd gear
  130. Torque Converter Shop Found In California
  131. Flywheel Bolts???????
  132. stage 2 a auto?
  133. Throw Out bearings
  134. Car accident, need advice
  135. Clink/Clunk from driver side..
  136. ~STAGE 2 cluch/ turn down stock flywheel?~
  137. Can you reset the automatic's computer for shifting gears?
  138. MT Neutral Position Switch?
  139. Stock Clutch Vs Stg 1 Clutch Vs Stg 2 Clutch...which???
  140. Transmission service advice
  141. anyone had a leaking slave cylinder???
  142. where i can buy Pressure Plate
  143. EBAY underhood shifter bushings
  144. Clutch Pedal Adjustment?
  145. possible 6 speed
  146. Just installed stainless clutch line
  147. Street Customs short shifter is solid
  148. Tranny Swap Mystery
  149. Works stage 2 clutch....overkill?
  150. leaking gear oil
  151. ACT clutch for lancers?
  152. Auto Transmission Problems (Warranty Issues)
  153. Tranny swapping???
  154. BG synchroshift
  155. Clutch fluid
  156. A little surprise from Kartboy
  157. Anyone having probs w/ stage 2 clutch?
  158. Flywheel.... interesting
  159. Have a Leaking/blown Slave Cylinder
  160. 5spd to 6spd Conversion
  161. to sell or not to sell
  162. How well will the transmission hold?
  163. Auto Tranny Question
  164. shift retainers..
  165. Weird gurgling sounds when I depress the clutch.
  166. flywheel help
  167. Foam on the intake scoop?
  168. Shiftronic
  169. aut transmission getting stuck
  170. How fast should I slow down without downshifting?
  171. Can You Really Change An Automatic To A Manual?
  172. Great price on Fidanza Flywheel
  173. Transmission Fluid
  174. help! about my tranny
  175. Automatic Transmission Cooler
  176. Motor mount is on (front at least)
  177. Transmission with turbo???
  178. EBAY Short Shifters!
  179. tob question
  180. t.o.b. question
  181. Clutch noise or tranny!
  182. really stiff clutch, sub freezing temp
  183. downpipe???
  184. 1st to 2nd grind
  185. Turbo Kits for OZs
  186. Energy Suspension bushing
  187. My shifting is getting rough.... any ideas?
  188. flywheel for auto's?
  189. prep for tranny swap!!!
  190. Manual Tranny Upgrade?
  191. Stage 2 Clutch, Flywheel and Motormounts Review
  192. Clutch & flywheel review?
  193. Anybody see this short shifter for the Lancer
  194. How do i bleed the clutch for a lancer
  195. fidanza flywheel......centerforce clutch
  196. clutchmasters flywheel
  197. Info about this clutch kit PLZ
  198. engine noise?
  199. Need Some help....
  200. act clutch
  201. Automatic Tranny Fluid Change
  202. Right Hand Drive Conversion?
  203. ok....just wondering.
  204. Clutch stiffness
  205. Help from anyone with an RRM Stage II Clutch
  206. RRM Flywheel
  207. Clutch Question
  208. Broken Oz Rally trans and clutch!!!
  209. Gear oil dilemma!
  210. crank on tranny
  211. Clutch And Transfer Case Going Out..
  212. Third Motor Mount???
  213. drive axle
  214. Got My New Mounts In!!!! (In RED)
  215. Replacing the OZ Rally clutch
  216. RRM's new clutch options
  217. I'm gona go nutz
  218. Tranny question
  219. Automatic Transmission Upgrade
  220. Just installed short shifter
  221. Rumor and Q about tranny fluid
  222. ?'s for Anyone w/Deyeme motor mounts....
  223. Amazing Short Shifters
  224. AWD or RWD conversion?
  225. would you re-gear your tranny?
  226. Wheel bearing nut size
  227. Is the US Lancer tranny the worst?
  228. Clutch!!!
  229. Flywheel/Torque Converter
  230. Automatic Tranny Help
  231. factory short shifter
  232. Cluth Master Cylinder and Slave Cylinder bad??!
  233. RoadRace Flywheel
  234. 5 spd 2 6 spd
  235. Anyone install their own LSD?
  236. Changin the fluid for AT
  237. tranny dipstick is stuck
  238. AMS Clutch Install
  239. Need motor mounts
  240. question re: AT filter change
  241. Best shifter busings?
  242. Changing the clutch
  243. Attn Turbo Guys..Clutch Question..
  244. Kartboy shifter linkage bushings install
  245. Stainless braided clutch hoses???
  246. Automatic Transmission upgrades?
  247. exhaust??
  248. Will tranny hold up
  249. Limited-Slip for an Automatic?
  250. automatic to manual tranny swap
