PDA
View Full Version : Lancer Tranny/Drivetrain Tech
Pages : [1] 2 3 4
  1. Transmission not shifting until redline
  2. Tranny swap
  3. 4g94 manual Tranny into Mivec?
  4. 02 lancer oz m/t differential question
  5. 2010 Evo X - Cranks but won't turn on
  6. RPMs not dropping after I engage clutch!!
  7. 03 lS Auto able to manually shift gears??
  8. Rebuilding the F5M42 - 2002 OZ - Questions
  9. Clutch replacement help
  10. 2003 Lancer OZ Rally transmission oil help
  11. Seeing what I have in stored
  12. 2003 lancer es
  13. Clicking while turning and accelerating in a straight line
  14. Transmission bellhousing question
  15. Output shaft sensor
  16. Help identifing correct clutch
  17. 03 Lancer ES automatic problem
  18. need feedback
  19. 03 Oz Rally gear ratio help
  20. Compatible slave cylinders for 2002 mitsubishi lancer oz rally
  21. 2002 Manual transmission syncro parts
  22. 02 oz
  23. tranny swap
  24. Auto trans shift cable part number / compatible replacement?
  25. lancer es 2003 automatic
  26. 2002 lancer oz rally manual swap
  27. sppedometer fix
  28. Triptronic Downshift
  29. "Hey my car is making a noise" (trans/clutch)
  30. 08 mitsubishi lancer gear shift & fuse box?
  31. Cv axle differential seal
  32. Crank won't turn by hand!?
  33. 03 ES Lancer Axle Seals
  34. OZ Rally Clutch
  35. New Here, need advice
  36. Hey guys
  37. Transfer case whinning
  38. Torque spec for flex plate to converter
  39. 2009 lancer 2.0 L cvt transmission slow down
  40. 2006 4g69 tiptronic transmission oil
  41. Hard jerks when shifting gears
  42. Hard jerks when shifting gears
  43. Squeaky sound when shifting into reverse
  44. Water in transmission Fluid
  45. 2002 Auto Lancer Snap Ring Problems
  46. 02-03 lancer trans swap
  47. Auto to manual swap questions.
  48. 2004 Lancer Sportback ls (2.4) 4speed auto
  49. won't shift into 5th or reverse
  50. NA Rear bar to JDM rear bar
  51. Tranny wont shift 03 ES
  52. Input Speed Sensor Lancer ES 2003
  53. 02 auto trans. issue
  54. 2006 lancer Es Shifting
  55. F5m42 5 speed transmission swap
  56. Manual transmission problems
  57. Axle pops out of pass side after seal replacement. Ideas?
  58. Dropping Tranny
  59. Another problem
  60. differential bearing replacement in an 04 ES
  61. Lsd in auto Lancer?
  62. Shift Cable Bushing Compatibility
  63. I need to replace my clutch, need help finding the right part
  64. Leaking Transmission Oil [Lancer ES 03]
  65. HELP Guide for bullet proof drive train
  66. 4G94 Auto to Manual
  67. 2005 lancer es manual trans plate?
  68. Hesitate to shift
  69. New clutch
  70. 2002 Lancer OZ a NO GO
  71. NO pilot bearing?
  72. Clutch pedal help!!!!
  73. Clutch?
  74. Strange grinding with throwout bearing. Need help !
  75. 2003 lancer oz rally transmission/clutch issues
  76. Transmission gone? Or fixable?
  77. Tranny from a different vehicle
  78. 03 Lancer ES tranny issue?
  79. How do I bleed slave on new clutch install?
  80. Clutch Chatter Problem
  81. Need TC-SST Transmission
  82. 02 Lancer ES vibrates under acceleration at highway speeds
  83. I must have missed something!
  84. tranny shifts funny
  85. 2003 Lancer OZ Rally Clutch Problem
  86. Different clutch kits
  87. 03 Lancer ES sensor/fluid problem
  88. 02 Lancer Slave Cylinder/Throw out bearing options
  89. Question: 02 oz rally manual transmission in 04 lancer es
  90. Manual Transmission OIL?
  91. so im confused here MD978474 vs MD978473
  92. Automatic tranny fluid in CVT (in trouble)
  93. 03 lancer es clutch replacement?
  94. 4g64 Swap 03 Lancer ES Transmission help
  95. automatic to manual transmission conversion
  96. Transmission Issues
  97. Transmission swap
  98. Transmission problem (please watch video)
  99. 02 OZ lancer soft pedal
  100. Weird Transmission Issues... Please help?
  101. 04 Sportback auto trans rebuild
  102. 03 Lancer OZ clutch problems
  103. 2005 Lancer ES auto trans filter
  104. 2002 Lancer ES Transaxle removal help (with pics)
  105. help! 02 Oz rally clutch or transmission problem?
  106. Short throw clutch pedal/linkage
  107. Need some advice, I am lost.
  108. Weight of 2003 Lancer OZ 5speed transmission?
  109. Automatic transmission to manual for 2003 lancer oz
  110. 02 lancer transmission.
  111. overdrive?
  112. Transmission input sensor 2003 Lancer ES
  113. Manual Transmission Swap
  114. transmission limits
  115. 2003 ES Auto Trans Filter Change
  116. Evo changover
  117. Replace Input Speed Sensor
  118. 2006 Lancer ES Fkywheel Please help
  119. Alternator Belt and Nut Sizes
  120. 03 lancer OZ (automatic)
  121. lancer oz rally slave conversion
  122. 2004 Lancer ES Transmission question?
  123. 04-06 Manual transmission gear ratios
  124. Clutch won't disengage
  125. Auto slow shift 2-3/3-4 when hot, cheap fix?
  126. Manual transmission to block torque specs?
  127. Serious help needed, please!!!!!
  128. CV Axle stuck!
  129. Where to get a good used trans
  130. Clutch Installation
  131. Manual to Auto swap
  132. I need a driveshaft removal tip
  133. BLEW UP MY TRANS, please help.
  134. Transmission Issues-HELPPPPP!
  135. Exedy Clutch kit
  136. Funny little gear box
  137. Replacing Input Shaft Bearing // Help!!
  138. Exedy Clutch kit
  139. Input/Output Sensor Nightmare
  140. Weird acceleration
  141. Lancer Oz 2002 Mb8-xtss act install
  142. 2002 Lancer OZ Auto Tranny kicking HARD
  143. 2006 oz rally trans
  144. input/output shaft bearing replacement and TOB
  145. 03 Lancer shifting weird
  146. 2006 oz rally 2.0 trans
  147. 06 ES High pressures in all ranges
  148. 2002 Mitsubishi Lancer Oz Rally - Possible Transmission Issue
  149. 2002 Lancer: Automatic Transmission Shifting Hard
  150. Drive Axles - instillation help?
  151. Tranny issue. 02 lancer Es. Automatic
  152. Tranny issue. 02 lancer Es.
  153. 02 OZ Rally Clutch install
  154. 02 Lancer Es weird transmission issue.
  155. 4g18 to 4g92 transmission swap HELP!!!
  156. Transfer case oil for 2003 lancer oz manual?
  157. Transmission oil for 2003 lancer oz manual?
  158. 2002 OZ with Clutch Problem - 204k Miles Original Owner
  159. car not starting after clutch install
  160. Transmission funny
  161. Oops stripped something!!
  162. 03 Lancer oz rally manual transmission dripping ALOT!
  163. 2004 Lancer OZ Rally with bad IPS bearing
  164. How to remove shift control housing
  165. Trouble separating gearbox
  166. input speed sensor
  167. clutch chatter on engagement
  168. Changing CV axle / drive shaft on a Lancer 2002 ES
  169. Manual Shifting An Automatic
  170. what rpm should i be at?
  171. Auto trans cooler
  172. 03' OZ Starting problem, possible clutch sensor?...
  173. Help with clutch
  174. Need help
  175. Automatic Transmission, Need Help!!
  176. Price difference in Slave cylinders
  177. OZ hit 185,000... Service time!
  178. 03' oz rally 5 spd swap i need a little bit of help
  179. did i make a mistake
  180. drain plug
  181. Replacing Clutch
  182. Clutch
  183. transmission question.
  184. clutch pedal really hard
  185. Clutch Slipping Questions
  186. help with clutch that wont bleed
  187. Manual transaxle removal
  188. No write-ups? thought this would be common.
  189. Constant leak
  190. Slave leak connection to clutch line.
  191. Syncro sleeves
  192. 02 Lancer: Where to buy Used Transmissio, Replacement Clutch Disc, and Slave Cylinder
  193. Transmission Flush and Possible Leak Fix??
  194. Transmission fluid Change cost ?
  195. how much HP can the tranny take?
  196. Compatible 5th/reverse shift fork
  197. RemOving shift forks
  198. M/T diff bearings
  199. Allow your ES/DE to switch to sport mode (same as GTS)
  200. Preloaded adjustment on differential
  201. transbrake???????
  202. Fluid Type - Automatic
  203. Transmission Noise (Detailed) - Transmission case opened
  204. 2002 lancer axle problem
  205. P0705 Transmission Range Sensor Circuit
  206. 2002 ES clutch replacement
  207. Lancer 02 OZ trans issues
  208. please help tranny problems
  209. bleeding clutch
  210. no clutch resistance
  211. Another tranny swap
  212. Need a Slave cylinder and CLutch release bearing oz rally 2002
  213. FlyWheel fitment Help Plz
  214. Converting AUTO to MANUAL
  215. OEM parts
  216. Flywheel bolts
  217. manual transmission shim
  218. Bolt on evo 8 rear kit
  219. Stainless steel clutch line info
  220. EVO VIII 'Short Throw' for my OZ?
  221. 03 OZ Clutch Problem
  222. 03 lancer oz rally clutch replacement
  223. Transmissions Flush or drain and fill?
  224. a harsh vibrate wobble feeling.
  225. clutch fork leaking around in put shaft!
  226. Question Regarding Clutch
  227. Buzzing/Electric sound when shifting on Automatic.
  228. Auto - Manual Tranny Swap
  229. A/C Lines
  230. So....another clutch problem...
  231. clutchmasters clutch?
  232. 03 OZ Rally clutch lagging
  233. Clutch makes loud sound (video)
  234. 2003 Lancer ES Speed input sensor
  235. input shaft seal leaking again
  236. 03 lancer es a/t wont shift
  237. Stuck Manual transmission
  238. lightsaber sound trans.???
  239. cvt rebuild kit
  240. loosing clutch pressure overnight.
  241. clutch install
  242. Manual Tranny for 4g94
  243. Star is dead...
  244. Lancer es Auto to manual
  245. 02' Lancer OZ trans temp sensor???
  246. 03 OZ throw out bearing / transmission issue
  247. Rattling/Slapping From Front Wheels Need Help!
  248. Auto to Manual
  249. Master Cylinder Part
  250. Sudden transmission issue
