PDA
View Full Version : Lancer Tranny/Drivetrain Tech
Pages : 1 [2] 3 4
  1. Slave Cylider Goin' Gonna Upgrade Clutch and...?
  2. Input shaft bearing help pls!
  3. Planetary Gear Cover Not Going back On
  4. Front Motor mount
  5. AT with shuddering in Reverse, Idle
  6. 2002 lancer OZ slave cylinder
  7. 2004 Lancer ES Clutch
  8. F%*#ING LANCER!!!!!!! transmission and shifting!!!!!
  9. 04 lancer/01 eclipse slaves...
  10. awd
  11. shifter cable bushing took a crap...
  12. Tranny help
  13. Need clutch help....
  14. really not having the best day :/
  15. Auto to Manual
  16. longer gears?
  17. which clutch to buy??
  18. ebay short shift
  19. upgrade options
  20. 05 trans into a 02 oz
  21. lancer trans and turbo's
  22. shift linkage cables connection
  23. 04-06 clutch release fork?
  24. Clutch Replacement
  25. M/T Screwing up!!!
  26. 2003 Lancer Es Tranny Swap
  27. rebuilding transmission
  28. F1C1 transmission swap
  29. Radiator hose broke now my car wont move!!! HELP
  30. question about tranny swap
  31. 4G94 LSD Options????
  32. torque converter and valve body
  33. jerk in 3rd gear?
  34. M/T axles vs A/T axles
  35. Evo transmission fwd
  36. Axle question
  37. Assebly instructions for the 5spd
  38. Shifter assembly/disassembly
  39. Which tranny for an '02 OZ Rally auto?
  40. question about shifter
  41. 02 lancer OZ Slave cylinder bleeding
  42. Type of Transmission Fluid
  43. 02 lancer OZ service manual
  44. Clutch issue
  45. cel for o2s when the work fine?
  46. i want to swap my tranny help me
  47. Power Steering Gone???
  48. lance clutch act?
  49. 03 OZ clutch question
  50. Clutch slipping
  51. Clutch problems(throwout bearing)
  52. Several Error Codes
  53. Automatic Transmission Filter
  54. are you tired from speed limit sound i have the solutino
  55. auto swap 2 manual
  56. 02 OZ Lancer 2.0L
  57. hey you
  58. Upgraded Torque Converters
  59. Manual tranny oil
  60. Lancer OZ Clutch Kit
  61. Slave cylinder swap
  62. fwd to rwd......possible?
  63. 6 speed on a 02 lancer es ... possible?
  64. swap tranny question
  65. help with clutch install question
  66. alternator belt
  67. Clutch Problem
  68. clutch
  69. Went Out In Parking Lot Today
  70. Need a new clutch for 2003 lancer oz, recommendations?
  71. Am I screwed?
  72. Lancer 03-04
  73. 04 oz trans in an 03 oz?
  74. RRM clutchline
  75. Auto tranny upgrade for 4g94
  76. Torque Converter 2002-2006
  77. Requirements for new Clutch
  78. 2002 Lancer OZ clutch problems
  79. Looking for a Cluch for an 06 Lancer
  80. Ralliart axles???
  81. No clucth
  82. Installing a clutch on an 03 OZ
  83. 2003 Lancer front tranny mount
  84. 2003 Auto Tranny Insanity
  85. Anyone actually seen the factory A/T filter?
  86. 05 Tranny Noise/Vibration
  87. Problem with bleeding the clutch...
  88. Has anyone heard of this??
  89. ralliart tranny onto oz or es engine
  90. Another try at auto shift kits?
  91. Which Stage 1 Clutch to buy? (OZ Lancer)
  92. Help! After trans swap problems
  93. syncros?
  94. Slipping Clutch..
  95. Interchangeable transmission parts 03-05
  96. Built auto or manual tranny?
  97. stonger trans
  98. mirage clutch
  99. Not sure what its called....
  100. ss clutchline help!!
  101. shifter bushings
  102. Question about transmission swap.
  103. motor mounts
  104. Underhood shifter bushings
  105. question for hub swaping
  106. Cluster
  107. A/T Boost Controller
  108. Question about SS Clutch line and Restrictor
  109. doing a drain and fill, ATF
  110. New clutch/flywheel...Resurfacing???
  111. Question about warped flywheel
  112. CV Boot Kit
  113. stock tranny
  114. stage 2 clutch
  115. Fidanza short shifter w/ twm, kartboy...REVIEW...
  116. Shifter linkage
  117. Loud noise
  118. Worst Problem EVER!
  119. Lookin for LSD for may tranny
  120. Transmission blew. Need new axle shaft
  121. CV bad AGAIN!
  122. location of input speed sensor
  123. Tranny problem
  124. Fidanza Flywheel Installation
  125. 3rd gear grind story
  126. Wheel bearing part number
  127. Flywheel resurfacing
  128. 03 OZ Rally Clutch...Performance?
  129. speed sensor issue after 5spd swap
  130. Shift Problem(I want your expert inputs! :D)
  131. temp sensor
  132. Lost Nut
  133. bad driving on 3rd gear?
  134. 2002 lancer tran problem
  135. help tranny
  136. tranny swap
  137. Would an 05 Lancer tranny fit in an 02??
  138. Trouble Getting into 1st and 2nd when cold...stalling
  139. PO715-odbc code problem
  140. Soft clutch
  141. Transmission F-ed Up
  142. Lubricant for Shifter and Linkage Bushings
  143. Need clutch soon...what one?
  144. which fluid to mask tranny chatter?
  145. CV Shaft
  146. automatic lancer es 3 to 4 gear problem
  147. loss of 4th gear. 02 LS auto trans
  148. 2002 Oz rally PLEASE HELP
  149. Rear wheel hub assembly torque
  150. Shifter assembly question
  151. new clutch
  152. which lsd you have
  153. car not running right?
  154. Clutch too soft.... sometimes wont engage..
  155. skid plate
  156. Still No Parts list for AT to MT swap?
  157. Authority Short Shifter Installed!!!
  158. Clutch Question?
  159. Transmission Done!
  160. Manual Transmission Removal
  161. 6 Speed Lancer?
  162. gear slipping?
  163. Test pipe question
  164. turning off on park...
  165. which reline is best for A/F
  166. Drain Plugs
  167. 02-03 Manual Transmission Limits?
  168. cedia 4g93t gearbox conversion
  169. Got cel Please help with any ideas
  170. Rattle noise?
  171. Bad Clutch?
  172. trying to replace transmission filter in my 03 lancer ES
  173. 03 lancer road race clutch line
  174. lancer es speed sensor issue
  175. Redline or Royal Purple?
  176. clutch line
  177. short shifter quick question
  178. A/T Cooler w/ Fan
  179. how much power can the auto trannies handle??
  180. Clutch replacement prices???
  181. which clutch kit to get?
  182. 5th gear problems....
  183. If I do a tranny swap, should or could I change motors?
  184. tranny swap?
  185. quick question.......
  186. Engine Noise Level
  187. car not going into gear
  188. AT to MT swap - possible?
  189. Help me please!!!!!!
  190. TWM short shifter install question/help w/pics!
  191. Rack in Pinion
  192. Clutch Q
  193. problems with conversions??
  194. How do I know if my clutch is dying?
  195. Evo tranny guts into 02 oz rally?
  196. 02-03 Lancer ES Transmission Part Number
  197. lancer es transmission swap
  198. (Auto) What Type of ATF and Filter??
  199. Reverse gear sometimes doesnt engage.
  200. ra gear swap into oz
  201. 3rd gear... please help
  202. my weekend in pictures :)
  203. where is the reverse light switch???
  204. More TOB questions.
  205. clutch bleeding????
  206. SPEC stage1 clutch for 2003 lancer oz
  207. 03' OZ rally Clutch
  208. auto to manuel conversion
  209. help with tranny swap
  210. cusco lsd
  211. street/strip clutch and flywheel?
  212. (Auto) Tranny Flush vs. Drain & Refill
  213. Fidanza Flywheel
  214. 02-03 gear ratios, once and for all.
  215. Manual Tranny Rebuild
  216. Shift knobs for 02+ Lancer???
  217. Gear Ratio's for a 02 and 03 Lancer OZ?
  218. Whats a good clutch?
  219. Transmission help???
  220. My manual trans is dieing young! help?
  221. Unorthodox Clutch & Flywheel
  222. clutch installation
  223. 02-03 Manual Transmission Fluid
  224. another tob/slave question
  225. Shift Kit for Auto
  226. stupid stock dipstick
  227. Shifters
  228. yes another tranny swap....
  229. hows the tranny swap?
  230. ROAD/RACE Race Series Aluminum Flywheel-4G94
  231. my conversion is on its way
  232. Auto tranny & POWER!
  233. Car move when in gear, engine off
  234. oil cooler
  235. clutch breakage
  236. Tranny Swap?
  237. slave cylinder / throwout bearing
  238. Tranny flush and drive belts?
  239. problem with flywheel
  240. Ordered Buscher Shifter Linkage
  241. works evo clutch issues
  242. Pop out of 1st?
  243. Kartboy Bushings
  244. Flywheel
  245. Phantom Grip LSD
  246. Works product review
  247. act/clutchmasters install w/part numbers
  248. slipped on ice .. dont know what happen!
  249. short shifter
  250. how much HP
