PDA
View Full Version : Lancer Engine Tech
Pages : 1 [2] 3 4 5
  1. Injectors
  2. diesel D68 engine replacement/problems
  3. MAF cleaning
  4. Stupid Question
  5. Throttle body sizes
  6. where can I get a new MAF o-ring/gasket
  7. Anyone know the CAI pipe diameters?
  8. Performance upgrades 2011 Lancer es
  9. Engine swap
  10. 2013 Lancer GT pulley warning!!
  11. 09 Lancer ES Best Exhaust System?
  12. Mixing/switching between synthetic and regular oil
  13. please help....
  14. 0w-20 for gt?
  15. How do you Reset Service Required Light??
  16. 2.0 4B11 Intake Path Questions
  17. Makeshift Cold Air Intake
  18. Headers
  19. To oil or not to oil..
  20. What's inside 2009 Lancer GT Stock exhaust muffler?
  21. 2012 SE AWC Intake
  22. 200HP+ Project on a 2.0GT 2012 (4b11)
  23. Why does my muffler look different form everyone elses?
  24. Intercooler part of normal intake? (no turbo)
  25. 3 o2 sensors?
  26. Road Race MotorSports Ignition System??
  27. p0171 CEL
  28. Honda hid standoff
  29. Sound clip of 2008 2.0 with Injen intake
  30. 2013 Lancer ES with AUTOMATIC?
  31. 2012 mitsu lancer gt exhaust
  32. 08 Lancer ES 02 sensor
  33. OBX crank pulley
  34. ROAD/RACE- CVT TURBO is Here to Stay
  35. Lancer Sportback
  36. rrm header, adapter on pzev
  37. 08 lancer es 5 error codes any suggestions please?
  38. Advice on a CAI
  39. Can the CVT Handle track use/hard driving?
  40. 09 GTS alternator amps
  41. Newbie with 2012 Lancer ES
  42. re-opening this disscusion
  43. 4B12 dyno result
  44. Routine Maintenance Warning
  45. SRI or CAI for 09 GTS
  46. Concerns about the new RRM Short Ram Intake
  47. RPW 4b11 non-turbo cam shafts
  48. Tsudo Exhaust
  49. Ecuflash
  50. Aftermarket exhaust for 2012 es?
  51. Question bout making exhaust louder
  52. Valve lash adjustment 09 GTS?
  53. K&N Typhoon Intake 2.4
  54. Header opinions
  55. Injen SP sri compatibility
  56. 2012 Lancer GT Parts
  57. Will they fit/ work/ worth it?
  58. 4b11/4b12 cvt tcm/tcu
  59. Just installed Aultec Lighteight Pulley
  60. Weird noise after oil change?
  61. Valve clearances
  62. Puerto Rico 4B12 Lancer ALL MOTOR 13.7 @ 101mph
  63. 4b11 na with evo x camshafts.
  64. Evo X mounts on a GTS
  65. lancer gts muffler
  66. Cant find intake
  67. Opinions for Intakes
  68. 4b12 head gasket replacement
  69. New thoughts on OBX/ RPW? NEED HELP!
  70. Bad Wheel Hop
  71. Clicking from engine!!
  72. 2.4l GTS timing chain or belt?
  73. Obx + injen exhaust
  74. remove governor
  75. When's the right time to get a tune?
  76. RA intake manifold + EVOX fuel rail/ fuel pump
  77. rrm products?
  78. replace 4B11 into 4B12 or not?
  79. Best exhaust for a 2011 GT?
  80. 4g69 throttle body
  81. Should i?
  82. Lancer gts 4g63tcvt swap
  83. Engine Trouble
  84. Exhaust Mod?
  85. GTS with CVT
  86. Header/pully/other options to increase speed+power?? Lancer Auto DE
  87. Takeda 2.0 SRI w/ Heatshield
  88. need help asap with throttle body
  89. =( just 4 months...
  90. What spark plugs to use?
  91. What are the info/items can be found on the multi info display?
  92. 2010 GTS Air Bag Question
  93. Car voltage stabilizer??
  94. Saved up some money, now thinking about a GTS
  95. Lean code aggravating
  96. Wanting to upgrade my Lancer, need opinions.
  97. 0W-30 Instead of 0W-20?
  98. old piggy in new car???
  99. Greddy SP Exhaust for the Lancer!
  100. Exhaust opinions
  101. Cat removal good/bad???
  102. Lancer Hood options?
  103. Whats Next
  104. computer?
  105. bigger throttle body on 2.4l GTS
  106. 4b11T throttle body on a 4b11 na
  107. Ralliart exhaust
  108. Miles put on your Lancer?
  109. 08?09?10?11?
  110. stock intake snorkel with injen sri?
  111. Header options for 2011 Lancer ES Manual
  112. Stereo console kit?
  113. Help with whining noise??
  114. I want to mod a 2008 lancer gt jdm model??
  115. Slightly rough acceleration until warm - normal?
  116. Mitsubishi (Finally) formally adopts a 0w20 oil weight for the Lancer
  117. PZEV..... what to do?
  118. Questions about Tunes?
  119. 2011 lancer cold air intake?
  120. Service engine soon light...
  121. driver side fuel injector noise?
  122. Difference in engines
  123. gas oil and service
  124. will the 2.4 bolt up to the 2.0 tranny
  125. parts site
  126. spec question
  127. 2011 Lancer ES M/t
  128. Lancer 09 ES
  129. Lancer ES '10 CVT vibration on drive idle
  130. drive/ serpentine belt replacement
  131. Are you willing to go the extra mile?
  132. Just opened her up! OMG FUN x2.4L
  133. RRM Piggy Back ECU. seriously?
  134. Takeda SRI information?
  135. Stock Crankshaft Pulley problem???
  136. ECU damaged
  137. P0441 EVAP Emission Control System Purge Flow Fault
  138. Anyone changed their own coolant?
  139. Keyless entry problem..
  140. Need a cheap exhaust for GTS
  141. AFE 2.4 intake :) Just recieved...new things instore....
  142. Intake for 2011 Lancer ES
  143. Got my RPW Alutec Pulley (couple of pics and lols)
  144. evo x intake manifold
  145. Magnaflow on PZEV Car?
  146. The does it fit thread!
  147. need help with CEL codes
  148. Difference in two greddy exhausts
  149. exhaust for the 4B11 NA
  150. De with evo x cams
  151. Water Pump
  152. Those with high powered NA lancers
  153. intake manifold
  154. Another CAI question
  155. RPW Header for 4B10 (almost 4B11)
  156. 1st Oil change
  157. 2011 GTS/CVT MODs and engine specs?????
  158. Any reported problems with the RRM v2 pulley?
  159. RPW pulley, compatible with 4B12? US seller?
  160. garages in orange county, CA
  161. Valve Cover Gasket, Sparkplug Seals
  162. Headers/cat-back exhaust good idea?
  163. 2009 lancer gts which exhaust system???
  164. GTS with EVO X Cams
  165. 2009 GTS Proper Maintenance
  166. NA 4B11 Engine mods
  167. what kind of intake should i buy?
  168. 2010 Lancer GTS Cranks no start
  169. works brain flash + rrm timing controller
  170. 2008 Blue GTS Lip Kit with Extrs if anyone is interested
  171. 2010 Mitsubishi Lancer CF Lip...???
  172. Fuel pressure on 2.4liter gts?
  173. maintenance service for 2010 gts
  174. Which Engine?!?
  175. OBX Silicone Radiator Hose Kit.
  176. Need advise on which clutch to get
  177. Seat belt sensor delete?
  178. Puerto Rico GTS 2008 TURBO 380hp DynoCenter
  179. 09 GTS goodies?
  180. P0137 every 300 miles or so.
  181. what is everyone getting for gas mileage?
  182. 4b12 shop manual
  183. Lancer exhaust
  184. Tsudo Header-back Exhaust Fitment. Help! It's leaking.
  185. DC-Sports Headers
  186. Mitsubishi Lifetime Engine Warranty
  187. Forged 4B11 internals
  188. Exhaust Question!
  189. Traction control on 09 GTS
  190. Gas??
  191. Help! plzz
  192. 2010 lancer exhaust
  193. OBX pulley vs RRM pulley
  194. Customized RRM Header and TSUDO full exhaust
  195. greddy vs. borla exhaust
  196. Ohhhh MIVEC, let me count the ways...
  197. Help!
  198. Cams and such for 2.0/2.4 NA?
  199. Help!
  200. Motor oil....
  201. Octane?
  202. newbie needs help
  203. Chance For a New Pzev and FED Header
  204. will this intake fit
  205. Check Engine Service Light 60,000 miles NEED HELP PLEASE!!
  206. Fuel rail
  207. Need help installing Greddy se and Injen sri on my 10' Lancer gts ! please help
  208. Intake and Exhaust Questions
  209. 4B11 into 4B12
  210. cat-delete
  211. exhaust clip and help
  212. EVO X Muffler on 2010 ES
  213. Out goes 2.0 In goes 2.4!!!
  214. greddy ti-c
  215. RRM and SE
  216. HELP! i cant decide?
  217. 2009 Lancer GTS w/ Evo X turbo?
  218. next upgrade purchase lancer es 2010 cvt 2.0
  219. Cat-back/axle-back?
  220. Will a Greddy SE exhaust fit on my 2010 Lancer ES with a 2.0 L engine?
  221. Intake Vs. Exhaust
  222. RRM pulley
  223. TWM shortshifter, 09 GTS
  224. Greddy SE vs Greddy TI-C
  225. 100 shot on 5 spd gts
  226. Yet another intake question :P
  227. Exhaust Question
  228. New here!!!!!!!
  229. HKS Hi Power 4B12/2.4L
  230. CAI for 2.4l 09 GTS
  231. E-cutout installed
  232. SRI or CAI for 2.0 SE engine
  233. Rrm sri v2 question
  234. question about exhaust work..
  235. AEM CAI Install Problem
  236. intake snorkel silencer
  237. Mod #1
  238. Borla 2.0L / 2.4L Exhaust . Just released :)
  239. boost and the 4b11
  240. K&N SRI and power decrease
  241. Aftermarket Projectors
  242. Greddy Ti-C hardware was lost while I was moving, what do I need?
  243. Gripmotorsports
  244. RRM header problem + intake issue
  245. 09 ES-Sport semi stock dyno
  246. Installed Greddy SE on 2.0L 08 Lancer
  247. Exhaust
  248. pivot d1 spec throttle controller
  249. 4B11/4B12 comparison
  250. What is that under my oil cap?
