View Full Version : Lancer Engine Tech
- Where is the OBD-2 port? Need to reser service engine light.
- flywheel replacement
- Sigma Speed Intake - Any Info?
- Evo X valve cover compatible with Lancer valve cover?
- K20 in 03 Lancer ES?
- 09 gts transmission issues
- RRM exhaust
- E cutout for our lancers
- RPW's New Headers and Exhaust Systems
- custom exhaust muffler
- I think i put too much oil. Should i drain it again?
- RRM Version 1 Header
- INKEN SRI for the 4B12
- 08 Lancer Engine Swap
- Turbotech's Lancer GTS with full Evo X 4B11T engine project!
- Spark Plug Gap for 08 GTS?
- 2010 GTS Sportback
- Custom Engine Torque Damper!
- Advance Speed Shop
- hks carbon ti vs greddy ti c
- lancer with 3 Inch exhasut?
- Lancer Camshaft
- Anyone know the crank specs of the 2.4L?
- 2.4L Injen and the hydroshield
- 09 08 RRM SRI intake problems
- Ebay intake came out for 08/09 LANCER ES/GT/GTS $69
- Anyone changed their own coolant yet?
- Compatible fuel rails?
- after car accident repair issues.....
- Ars sucks
- RRM timing control box
- oil cooler and cvt cooler?
- Magnaflow Catback Installed, Need a resonator..
- Possible Icey Roads.
- A new Short Ram joins the fight
- NOOB needs intake recommendation for 2010 Lancer GTS M/T!!!
- MAF Adapter for GTS/Lancer?
- Anyone have just a muffler and no resonators?
- intake manifold
- intake manifold
- OEM Spark Plugs - are they regular or platinum?
- Halogen ring headlight
- throtle body
- cat back or axel back?
- Evo/ralliart intake scoop on gts
- Bad accident, need a new hood
- question about my magnaflow catback...
- question about air/fuel ratio on a stock 09 gts
- First mod sugg.
- what would be best?
- DIY EVO X hood scoop!!
- N/A 4B11 exhaust
- GTS with Evo Exhaust?
- 2.4 evo?
- 4b12 internals !
- srt4 internals in a 2009 lancer gts
- fujita or RRM SRI?
- When should I change out my CAI filter?
- Fujita SRI for 08+ 2.4l GTS CVT
- about nitrous
- Aux help
- Asian Lancer iO. 2.0
- RRM Lancer Large Intercooler
- After installing SRI...
- jun camshafts
- Anybody have the Works drop in filter?
- Question on the RRM timing control
- Ralliart engine
- compatable starters?
- my NEW custom exhaust!!!
- RRM web claim, question
- Is it possible to make an all motor lancer beat a stock mustang?
- any regrets buying there 2010 lancer?
- 09 gts track times
- What are the chances of getting stronger internals for the lancer?
- Anyone Install these TAIL LIGHTS?
- Hi flow cat and factory warranty issues
- What's that bar on the gauge cluster?
- 09 lancer es tuning help
- K&N intake audio
- Clicking Noise
- Need input on next to do list
- Engine Redline
- A/C add on
- x cams and deck milling
- Evo X Injectors on a GTS
- RRM Timing Module Question
- Greddy 08 Lancer Spectrum Elite installation problem
- 08 GTS with RA Exhaust.
- HELPPPP....upgrades help
- Predator Performance Lancer GTS (Stage 2)
- metal vibrating sound
- 2008 Lancer Standard Oil
- Fluid In Throttle Body
- Another exhaust question... quiet exhaust
- Finito the GTS 2009 2.4L TURBO tuning @ DynoCenter PR need help finding a clutch kit
- Rrm sri
- Quick questions
- K&N filter fit for a RRM SRI V2?
- Fuel System Specs?
- 94 octane on the gts
- Project Lancer NA/T
- 2009 Lancer GTS instake vents (should i enlarge it?)
- My 2.0L Lancer DE dyno after reflash from PR
- stroker kit
- pistons
- what exhaust did you choose?
- what is a performance tune?
- 2009 RRM header
- camshaft
- Fujita SRI
- mods?
- Performance Tuner Chips on ECU
- performance upgrades?
- 4B11 Pistons?
- Lightweight crank puley
- 4b11 good for 400whp?
- CAI Vs. SRI?!?
- Aligning bottom of air filter
- High Performance Green Filter Drop In
- CVT Throttle Body clean???
- RRM SRI Filter fell apart...auto zone solution
- MOD GTS to be as fast as a Rally/Evo?
- Compression ratio???
- Evo engine?
- Just damn...
- Jst bought the 09 gts now i need parts.
- Paddeshifters in Drive
- ~ AEM Q&A INTERVIEW ON THE 2008+ LANCER 2.0L CAI INTAKE with EVOSOUL
- Modifying an Automatic?
- Swap vs turbo
- Help!! first problem with my lancer!
- Which Intake?
- Need second opinion
- Evo IX Throttle Response
- Anybody knows where the engine code is stamped on the block?
- Absolute loudest muffler?
- ~I~ TLC & EVOSOUL INJEN Interview / Q&A for the 2008+ Lancer CAI
- Lancer vs Civic Sedan Si
- has anyone replaced their spark plugs yet
- So, almost halfway into 09 have you had any real problems with your lancer?
- spark plugs
- Does the CVT Engine have to warm up?
- How to get a more aggresive exhaust sound?
- Drop in filter VS. CAI/short ram
- Looking fr more HP
- RRM Filter Falling Apart
- My New Greddy Spectrum Elite SE Exhaust System Video
- fake BOV?!
- Weight Cutting Options
- magnaflow cat back exhaust
- Question
- short ram intake and exhaust?!
- K&N/Works/HKS drop in filter owners
- Cutting the Slits
- Eng Maint. Idle
- Custom Magnaflow Axle-Back
- Is it legal to install RRM's turbo in California?
- 08 Evo/09 Ralliart Gauges on Lancer GTS?
- Positive battery terminal help
- SRI and CAI?!
- magnaflow muffler
- Lost power after service
- Turbo Exhaust/Muffler on N/A Lancer?
- Planning on buying GTS 09 Lancer
- Throttle Controller
- Downshifting in CVT to help braking ok?
- Mitsubishi recalls 08-09 Lancers & Outlanders over faulty breaks.
- Engine break-in period?
- Tranny fluid
- Quarts???
- RWD Lancer?
- new chips
- 4B11 Stroker Kit
- drop in filter
- Power loss
- Chipracing for Lancer 2.0
- WORKS- Performance Sport Package
- Unichip?
- rrm turbo install question.
- ROAD/RACE- Hot Turbo Vid
- Magnaflow Cat-Back Exhaust fit 2.4L?
- Engine, Computer, or what?
- Works ECU flash
- oil change info - interesting read
- More Ponie..Advice
- Injen Headerback Pic request
- broken filter update
- Works exhale leaking *brand new* help
- Help/Advice Needed.
- 09 lancer gts
- Greddy ti-c bumper issue fix
- evo body?
- RRM SRI V2 broke.
- Question
- a new Catback exhaust option
- Questions on Fujita Intakes
- 2008 greddy ti-c question
- ~ Tighten your weekend tuner game with Auto Enginuity OBD II Scanner - Preview
- Question on WORK AB install
- 4B11 compared to 4B11T
- Another Gas Thread
- Totalled Lancer
- Engine swap for 08 lancer
- WORKS Flash & RRM Timing Control
- Sprint Booster & Heel-Toe
- parts help
- My ultimate fix for the fujita sri ses problem!!
- Battery Relocation
- Evo turbo
- meghan racing oil catch can
- Performance Chip..
- Sprint Booster *NEW PRODUCT*
- Bogging - Mivec, SRI, Or Me Trippin?
- Made my own Dual Exhaust(EVOSOULS Idea)
- advice
- Dangerous Beauty!
- RRM Products
- Cleaning RRM Filter
- Another happy works customer! Flash and exhaust just done. Gained 4 MPG
- New Aftermarket Performance Products
- timing control module
- Clicking sound at Idle
- CAI Vs. SRI
- What's the deal of a Cat-back?
- what are some pros and cons with CVT?
- AEM CAI on CVT LANCER
- Break-In
- RRM pulley
- Dual Exhausts On Lancer GTS?
- Why no battery relocation kit
- RRM SRI Intake V2. Launching at low revs?
- OFFICIAL: Tanabe Medalion Touring Available Now For 2008 Lancer
- Quick Tranny Question
- Tiptronic transmission
- paddle shifter question
- 08 GTS issues/questions/problem?
- 2008 es
- Paddle shifters
- problems with sr air intake in lancer es 2009
- New Fujita Intake Arriving Soon
- Magnaflow, Greddy, Injen
- Air filters
- Engine Dampener???
- My car is dead
- HKS Announces Legamax Premium Exhaust
- Pulstar Plugs - Interesting Info
- -=] Hi-Flow Cat Burglar [=-
- ~~~ Project Dark Horse 2.0 - Single Tip Exhaust
- Mivec Tuning for 411B NA
