PDA
View Full Version : Lancer Aftermarket Forced Induction Tech
Pages : 1 [2] 3 4 5 6 7 8
  1. 16g oil return options
  2. Tachometer
  3. Coil Plugs rated to?
  4. Turbo reliability?
  5. help
  6. Top Speed??
  7. Wastegate and o2
  8. Blown turbo...still??
  9. misfire question
  10. quick question about oil..
  11. kamikaze headers with RRM turbo
  12. GREDDY E-MANAGE questions
  13. Fuel Problem 05 Lancer ES Turbo
  14. Decided to Go with a turbo'd Oz Rally
  15. 05 Lancer Injector Setup
  16. 03 Oz rally bolt pattern???
  17. Cold Air Intake 03 Oz rally...
  18. 10.0 - 4g93 setup
  19. oil feed lines
  20. turbo spark plugs
  21. 06 lancer Auto going turbo
  22. Mitsu.kid.kid's Turbo thread!
  23. Question for guys on Boost
  24. how to set up a louder BOV?
  25. Turbo'ed lancer boost problems
  26. EPM Turbo Manifold = FAIL
  27. Here it is. Another 02 lancer oz turbo project.. Evo 3 gt
  28. lancer turbo 2 step
  29. Subaru Sti Exhaust Swap to Lancer
  30. Random Idea
  31. Turbooooo Timeeee 05 ES
  32. OZ turbo project
  33. tactrix cable
  34. tactrix cable
  35. 4g64 Turbo Lancer (first?)
  36. Fidanza camgear
  37. How do i keep the engine bay cool?
  38. fuel line help.
  39. RRM vs. Turbokit.com Question
  40. List of compatible Downpipes
  41. engine temp
  42. From which car this turbo came from? and what kind of turbo is it?
  43. Turbo q's!
  44. ImportAlliance July 17th. nashville. who might all be in attendance?
  45. Evo 8.5 16G 10.5 Stock wastegate pressure?
  46. Oil feedline source? Looking for pics..
  47. 4G63 DOHC GSR Swap?
  48. ARP head studs?
  49. Turbo manifold question
  50. Installing Turbo Oil Feed + Return Lines?
  51. Demon_ni2 - the "Offical" Build Thread - the no holds bar build -[8UR EVO]-
  52. Does the stock evo 8 BOV + Intake pipe work for our setup?
  53. How do I run my vacuum lines?
  54. Big Baby is home. Check It out.
  55. Mav's 2002 Lancer ES build thread.
  56. Power for egt gauge?
  57. in search of answers..
  58. Whoever said the megan manifold can have the flange rewelded.... wow...
  59. One more 16g thread - few questions
  60. What should I use for tuning?
  61. tdo4hl-15g turbo
  62. Quick TD05HR Lancer Turbo question...
  63. 4g93 and 4g94 EX Manifold
  64. Evo 8 Downpipe and 2002 Lancer Downpipe
  65. TDO5HR Wastegate Actuator for 5-9 psi?
  66. help asap!!!
  67. quik question
  68. Evolution fuel rail for 4G94?
  69. turbo tune
  70. prosport egt gauge
  71. boost leak? car won't keep idle
  72. Need Some Help On A Decision
  73. walbro fuel pump
  74. Spool'd YA!!!
  75. Making sure I have right parts
  76. check trough list
  77. DOHC 4g94--BOOSTIN'
  78. Should i switch???
  79. 9.8 vs 10.5 turbo
  80. 02 oz rally performance/ body mods
  81. *400 whp / 400 wtq!!!*
  82. Would you guys recommend buying a turbo from here?
  83. Can someone please help me build a turbo?
  84. Misfire at higher boost
  85. Boost Guages Decision
  86. spark plugs, nkg iridium bkr7?
  87. evo 8 downpipe too big for my exhaust?
  88. 700hp mirage setup
  89. Vehicle Tag - for turbo lancer guys
  90. Evo VIII 16g Build
  91. RRM Turbo Guys This Way Please...
  92. evo 8 uicp & licp with rrm mani & evo 3 turbo?
  93. tial 3.6 psi spring on forge WGA??
  94. fuel injectors
  95. pistons ycp
  96. Turbo on my lancer oz
  97. Which Bov to take?
  98. 272 stage 3 turbo camshaft
  99. turbo guage question???
  100. **** it.. turbo build
  101. ngk plugs
  102. fuel pressure regulator
  103. 4g63t parts with 4g94 motor?
  104. Dreams of turbo
  105. 4g93 IM with Turbo
  106. 2002 lancer es mod help
  107. What should I do to my Lancer?
  108. a few mock up shots.
  109. Starting a turbo build on my 04 lancer
  110. Time to play
  111. vortech fmu
  112. RRM turbo kit fitment issue
  113. 02 Lancer ES Turbo Project
  114. greddy rs BOV
  115. turbo timer
  116. BOV recirculation
  117. T28 Turbo Build
  118. wrx 420cc injectors
  119. turbo help
  120. air leaking from Turbo Seal?
  121. Oil Lines to 16G turbo
  122. Turbo Problems
  123. Mudflap Question
  124. My New build thread..
  125. 19g...
  126. ok so i need some help
  127. Turbo Cam
  128. New To Lancer, Need a few suggestions.
  129. wondering about mods for my 2002 lancer OZ
  130. o2 sensor ?
  131. HELP... MAF Sensor problem...
  132. Lancer ES ? Help
  133. Oil return line for turbo...
  134. 02 lancer oz 16G Build
  135. RRM's 16g turbo kit!
  136. Engine parts
  137. dsm turbo possibillities
  138. List of Turboed Lancers
  139. is a resistor pack require to run evolution 8 550cc injectors...
  140. Speed Corps Forged Rods?
  141. turbo kits and the life span of our cars
  142. o2 housing
  143. what turbo what psi?
  144. 16g oil feed ?restrictor?
  145. what radiator fans do you run after you turbo?
  146. Idle is jumpy
  147. Twin Turbo on a Lancer?
  148. Turbo loud screeching noise
  149. lower engine bay temp
  150. supercharger or turbo??? 4 a 03 lancer
  151. Turbo Mani Help
  152. mirage cam
  153. 03 Turbo lancer OZ
  154. Turbo Oil Feed Help
  155. Problems Diagnosing my turbo Lancer
  156. New exhaust question/help please...
  157. Question about aftermarket exaust....
  158. what could it be
  159. where to connect
  160. turbo trouble
  161. started my oz turbo build 06/01/09
  162. Type of Turbo and there app.
  163. +turbo planning....
  164. Roadrace high flow cat for 03 lancer
  165. Exhaust gaskets for rrm turbo kit???
  166. time for turbo
  167. Extra cash = new exhaust....
  168. Yet another turbo question.
  169. 4g94 map sensor question
  170. help please
  171. Building up to a turbo
  172. Buying my first
  173. Turbo Question!
  174. first E85 turbo lancer?
  175. Automatic Turbo
  176. turbo kit question
  177. Narrowband A/F help needed.
  178. Yet another thread about Turboing a 03 lancer.
  179. Yet another thread about Turboing a 03 lancer.
  180. oz turbo help
  181. 16g oil feed / return
  182. 16g Turbo
  183. LOL.. Piston for sale, and a block also..
  184. Need help building a turbo kit!!!!!
  185. super afc
  186. rpw TB (Throttle Body)
  187. supercharged?
  188. 02-07 lancer es to 08+ es, gts (discuss)
  189. erratic idle
  190. Turbo Problems
  191. 16g hotsides
  192. Safe to turn up boost after tune?
  193. white smoke?
  194. boost question on 05 lancer es
  195. Tons of Questions
  196. wrx injectors
  197. random misfire help
  198. Wrx/Sti fuel pump?
  199. Intercooler question
  200. Z-line intercooler
  201. internal / external wastegate turbos
  202. V1 Piggy on Returnless System?
  203. Boosting questions.
  204. Have you guys seen this?
  205. 4g94t
  206. does an evo9 intercooler fits an 02 oz lancer?
  207. dohc and turbo on ebay 4g93
  208. bov
  209. Rev limiter hitting at 3000rpms
  210. 03 lancer es Evo 8 build
  211. trouble, dont know why
  212. 16g6 manifold for the 4g94
  213. Injector question?
  214. Downside to buying used Rods?
  215. what fuel do you use?
  216. 4g94 turbo wanted
  217. Turbo lancer
  218. New turbo installation but a lot of white smoke
  219. Head Gasket Help.....
  220. A/C fans??
  221. My 02 oz build!
  222. turbo help.....wtf!!
  223. Fuel injectors.
  224. need some help.. can someone fill in this for me
  225. White Smoke only on WOT...
  226. Camshaft ??specs??
  227. Question on tsi kit
  228. injector question
  229. Me doing a Turbo rebuild t25
  230. What do you recommend on cooling fan?
  231. New pistons and rods
  232. evo 8 full cat back on 03 lancer es?
  233. t25 flange vs 14b flange
  234. Turbo?
  235. supercharger?
  236. Does anyone have an exhaust manifold for measuring
  237. Emanage question
  238. Help With Using RRM Piggyback V2 for Turbo!
  239. FPR What is everyone’s personal preference?
  240. Startin to pieace together a turbo kit. Question on walbro
  241. Depsy's custom t3/t4 build
  242. Demon_ni2 - my custom turbo kit build thread(T3/TO4E 60 trim)
  243. what would i need if i bought this?
  244. would this work???
  245. supercharger help
  246. Tuning my car that is soon to be turbo'd lancer.
  247. wastegate question.
  248. How's REESE tuning??
  249. starting my build. (off the topic, oil return line question)
  250. engine build
