- Turbo 03 oz rally
- Boosting my 03 OZ
- Confused about the PSI
- Turbo and egr
- 4G94 DOHC Swap to 4G93T
- SOHC 4G63 heads with 4G94 block?
- Evo 7 ROM flash to base lancer
- Sti swap is it possible?
- Grimmspeed boost control solenoid
- California legal modding?
- Ready to turbo your lancer?
- _666.Papi4g94 Road To Boost
- How do I get to the 4th cylinder rod bearing on my 2008 Mitsubishi Lancer gts?
- '03 4G94 ES supercharger?
- Questions about internals 4g94
- CJBarker2's S/C Sleeper
- Boost time 03 lancer
- Changing the speedometer on a 2003 Lancer
- Built 4g94 max rpm
- Help me with my turbo install thx k bye (2002 OZ Rally)
- Last 02-07 RRM Turbo Kit
- 2003 vr-x 4g94
- Super max 4g94 turbo build
- Boosting at 160k miles
- turbocharge project question
- 2002 OZ Rally Won't Turn On
- The roof trim aka drip molding clips?
- Help! Oz Won't run
- Turbo Lancer picture thread Post a pic of your turbo lancer!
- Eat-Dis Turbo Build
- Demon_ni2 Rebuild Thread. -2015- Monster Turbo build
- 4g94 Forged internals rebuild steps by step guide
- 03 oz Clutch n Flywheel + help for turbo
- Almost time for turbo
- New source for 4G9x flanges, copper gaskets
- stock water pump and belts for turbo build?
- turbo id. for rebuild
- Evo 9 turbo fit the 4g94?
- Turboing my 02 Lancer
- Old turbo lancer crew
- Turbo Help 2002 ES
- should I buy this turbo please respond
- beastly 2.4 build
- Nos ...
- Fluttering Sound at 7ish PSI
- Could you use keyboard cleaner as an alternative to nitrous?
- TSI turbo kit questions about downpipe and cat delete
- Twin turbo Lancer ?
- What is this lancer running?
- what turbo kit should I get?
- Passing Emissions after Turbo Install
- Latest Turbo Threads NOOBS READ THIS
- Need Help with injectors!
- turbo build
- 2002/2002 Grill Question
- Lancer Oz 2006 M/T Turbo
- What else do i need?
- Want Faster
- 2006 lancer es turbo help
- Are there Nitrous Kits for a 2003 Lancer ES?
- Arp head stud question
- Oil Feed & Return
- 2003 es need help turboing
- HID kit to stock housing
- running rich. cant figure out why.
- 02 Lancer ES
- Cold air intake
- Upper oil pan STUCK!
- Lowering?
- Need a Good Header/Downpipe combo '06 0Z
- what are you guys running for boost?
- 2 Quick Q's (small intercooler & first buys)
- 2009 Turbo?
- Coolant Bleeding?
- 03 OZ Rally Start Upgrade Help
- 2013 lance es misfires pls help
- Smoke at WOT?
- Former 308whp 301 wtq lancer oz rally...
- Exhaust Systems Advice
- Need opinions on engine swap
- This turbo Lancer may be done.
- Boost pressure questions
- Turbo compressor housing leak
- should i stay returless or go with return fuel system
- Turbo or n/a
- New personal best at the track !
- Speed corps Manifold
- Questions about EVO 8 Turbo Setup
- Joining The FI Fleet - 03 ES
- Ebay Turbo Kit?
- need new engine soon
- Zankk's 02 Lancer turbo/forged engine build
- Need intercooler?
- TSI Extreme?
- Thinking of Turboing my 04 OZ. Any advice?
- 4G94 max limit
- Want to custom built Turbo for 4G94
- I suppose it is time: andy2964's 03 OZ Turbo Build
- Jos_iQRacingEVO 4G94T with fully forged internals engine bay!!! WATCH HD 1080P
- 2002 to 2006 Lancer Turbo's W/Automatics that tune their own ECU's
- New turbo lancer guys?
- Mitsubishi Lancer Performance Chip 1995-2012 ECU Programmer HP Torque MPG
- Glow-Shift gauges...
- Exhaust setup on Turbo Lancer
- Injector compatibility
- Highest Boost Turbo lancers
- Drove Cross country 4k+
- Turbo
- Coil problems at high load
- Ecuflash write to ECU problem
- Need some parts...
- Turbo Guys......Help
- Where to start?
- Turbo 16g o2 housing sitting on A/C compressor hose
- New turbo thread! think i can i think i can
- Lancer 04 4g94 turbo
- Turbo A Stock Engine?
- Turbo Setup?
- Epic Build thread
- Update with turbo lancers
- Please help!!! :)
- rocker arms hitting valve cover
- evo fuel pump
- e85?
- RRM cam review
- a quick turbo question... is it worth it?
- ToxicFab Manifold for the lancer guys!!!
- The right nos!!
- Import Alliance... sunday,April 22nd, Atlanta!!
- Custom fuel pump "Lancer"
- How to: Install your custom 16g turbo kit
- Taillights Install Issue
- Injectors <3
- Bones' Build Thread
- Jake's 06 ES Lancer Build
- Turbo Lancer Dedication Thread
- bent turbo fin = bad?
- t3 turbo manifolds
- injectors for turbo
- BOV questions...
- Aftermarket radiator for turbo lancer
- Engine build question
- 02 OZ to EVO X swap
- Automatic Turbo Lancer
- Questions from an afar bro on upgrading Lancer
- 4G94 vs 4G64
- My Turbo Lancer go's to the track !
- fater spooling
- Import Alliance... Nov 13th, nashville. anyone going?
- piggyback enricher
- Oil Analysis: Shell Rotella T6
- Dumb Question Evo Owner bought an OZ as a beater
- mitsu OEM axles. anyone have extras?
- How does my turbo look?
- water cooling lines how are you running them?
- Advice on next turbo choice
- want to turbo 02 lancer
- 02 lancer oz 4g63 Build
- any thoughts?
- Bolt Pattern For Lancer
- Oil pan tap ???? Where to get???
- mitsubishi websites question
- new user, probably the same question
- 03 lancer build boost question
- Turbo support bracket
- Exhaust question
- Need full exhaust advice pls 03 oz ralliart
- Oh Look another Turbo Thread - RyanCB's turn.
- MAPerformance EGR Block Off Plate
- For all new oncoming turbo lancers
- evo 8/9 build question
- Injectors
- 05 OZ turbo build
- Ebay turbo manifold
- HRmmm built Auto, or built 5speed. whatchyallthink?
- Glowshift Wideband Data Logging
- maximum 4G94 head power
- Piston clearance for FI.
- jasma head gasket
- Lean Spike Issues during WOT
- Green_Bandit's 16g build thread
- Clutch options for boost
- Turbocharing your lancer "Custom Kit"
- Pete's 03 Lancer RRM turbo built (your input is appreciated)
- My 05 lancer turboed lancer thread...never thought it would happen
- Rad Fan Help
- Turbo lines
- Looking to purchase aftermarket headers
- What kind of exhaust manifold
- engine swap check list
- my plugs after 1750 miles (ish)
- boost misfire
- 05 turbo help clutch slave
- mm made in china rodz
- turbo clearance help
- traction
- Turbo Fuel economy...
- Turbo Question
- rods and pistons 2
- what turbo kit is this?
- Boost gauge jumping
- Boost controller
- Types of Spark Plugs
- load question
- From 5-6 PSI to 10-12 PSI
- Recommended Turbo
- Vortech Fuel Management Unit Trouble?
- Greddy ti-c fit 03 oz??
- Does this price seem right?
- Apexi TT install help
- not sure what i need to do help lol
- Fuel pressure regulator
- clutch name
- stuck bolts in turbo!!!!
- upgrade axles?
- P0107
- Accident in My Turbo 05 ES
- Whats new for 2011? (for your car) (how will u up the bar!)
- M.A.P Sensor
- Need you guys help A.S.A.P
- merry christmas guys. anything new?
- Universal Adjustable FPR install
- Wicked compressor surge
- spoiler question
- oz rally turbo, need downpipe!
- evo battery tray
- Going turbo but got some questions
- evo interior question
- Got smoked by a camry...
- Probably need injectorss
- Upgraded cam questions!
- 13.75 @ 101.74 :d
- what is needed.
- Lancer Rom Disassembly--CLICK HERE!!!
- EVO 8 Turbo rebuild
- 03 oz tail lights fitment help
- Question about a boost leak
- Starting my new build for the first time, pre-start question
- 03 oz Catback exhaust
- Ride around the block w/ me
- Can I rev my engine? How and what safety precautions?
- buillt rods and pistons
- Idle VAC in/hg
- Hey guys got a question about turboing
- ebay stage 2 clutch
- Check this out guys...not good.
- MAF after turbo
- Help me choose!!!
