PDA
View Full Version : Lancer Engine Management / Tuning Forums
Pages : [1] 2 3
  1. 03 Lancer OZ Rally 4G94 – Logging wideband AFR via rear O2 input (pin 75) question
  2. xml def for lancer 2006 4g94
  3. about xml definition
  4. 2008 4B11 N/A Lancer TephraMod ✓
  5. Constant power to cylinder 1 injector
  6. Lancer rpm sudden spike
  7. Help with EVO rom on lancer
  8. Lancer VII 2.0 4G63 NA ECU PINOUT
  9. Tuning
  10. 2003 Mitsubishi lancer OZ rally aftermarket ecu?
  11. Which AFR is better to put on the 93-94 engine without turbo, with WOT?
  12. Проблема с fuel trim low и fuel trim mid 4g93 mpi
  13. Need firmware for the 4g93 motor on maf or map.Who has it?
  14. Help???
  15. 05 Lancer Ralliart Short Run Time With Cold Air Intake Installed.
  16. Ecuflash troubles
  17. 05 ES 2.0 emissions sticker
  18. NEED HELP WITH MY 2005 LANCER CS5 rom
  19. Lancer On SD
  20. How I may take advantage of the situation?
  21. Aftermarket ecu
  22. 4G63 Galant ROM Unknown
  23. Unknown ROM Image
  24. Spark plug help 2008 Lancer
  25. help on 2002 es lancer
  26. 02 Lancer bypassing ac compressor need belt length
  27. 4G94 tuning options
  28. launch control on 4g18 ecuflash
  29. ECU help...
  30. EvoScan questions
  31. 06 es mt rom id
  32. Tephramod and Rom Question
  33. OpenECU missing maps?
  34. 02 Oz Rally ROM & ECUFlash
  35. lancer oz rally tuning
  36. High rpm
  37. Boosting 4g93
  38. i want def file 4g18 at help me pls.
  39. Need to bounce a theory off some other tech savvy head...
  40. Lancer bigger TB
  41. e85 in a 2002 oz????
  42. Rev Limiter
  43. 04-06 USDM Ralliart Tuning process please.
  44. Reprogramming an ECU DIY Lancer CS 2004
  45. 2005 oz rally 4g94 with a 04-05 ralliart ECU
  46. 04-06 Ralliart Engine Management
  47. Evo7GTA vs Airtrek Turbo ECU (4G63T -Auto)
  48. Gathering Parts. Top end. Help?!?!
  49. RRM turbo kit ECU tune
  50. Missing Definition?
  51. Looking for Rom to flash to 2002 manual lancer
  52. 02 ES Catalytic Converter is shot
  53. Auto Lancer Roms?
  54. Need to raise rpm!!!!
  55. Need 02 lancer oz ECU pinout diagram
  56. Need help please tuneing 03 Lancer LS auto trans
  57. finally ordered tactrix
  58. 2014 lancer se tuning help!!!
  59. 05 Ralliart Stock Intake in 02 OZ Rally?
  60. Where to start 03 g94 Turbo tuning
  61. Need virgin rom & xml
  62. Full built engine tuning? Help!
  63. need help with defintion file 92290022
  64. Wide band placement for stock applications
  65. Is it worth it?
  66. newbie / AEM ECU
  67. Looking for definitions for a 2006 JDM Lancer (ID 89430001)
  68. A little tuning help please?
  69. Upper Radiator Hose
  70. afr all over the place
  71. Power Command Chip on ES
  72. ES ECU in OZ Rally
  73. starter issue?
  74. DIY (SRI) short ram air intake
  75. alternator issues?
  76. Just swapped my radiator 2003 OZ rally...
  77. tephra and returnless fuel
  78. 2003 Lancer Oz rally serpentine belt
  79. Lancer Catalytic Converter Problem
  80. wheels wobble under heavy acceleration
  81. 02 OZ rally chip help
  82. RRM piggyback system for turbo lancers
  83. Taking Baseline EvoScan Logs - impossible dyno results
  84. Difference between Evo 8 and lancer ECU
  85. Def file needed 03 lancer
  86. Weird Engine tick
  87. Need some help with my 05 OZ and ECUFlash
  88. 2005 0Z lancer
  89. 02 OZ Rally Auto Question
  90. 0z rally
  91. Air intake queston
  92. 02 Lancer OZ ecu tune help
  93. 02 Lancer piggyback ECU
  94. evo exhaust in lancer
  95. My 2003 Lancer ES project 4g64/kia dohc head swap help
  96. E C U Fuse Location
  97. Alternator charge maps
  98. Guages!
  99. Help me, I need 4G93 GDI TURBO ECU pinout...TKS!
  100. Help on replacing head gasket,timing belt,...
  101. Please help with ecuflash!!
  102. Virtual Dyno for Automatic A/T Lancer
  103. Best exhaust setup pipes/muffler?
  104. 02 Lancer OZ intake??
  105. Common Fuel Pressure
  106. Tune Up Time
  107. AEM Uego question
  108. O2 simulation mod with ECUflash???
  109. What's the cheapest exhaust upgrade for an 03 Lancer LS?
  110. Turbo lancer maf problem? help please
  111. NA/FI Tech Topic: Getting started with Ecuflash
  112. how to tune for fuel saving during idle?
  113. reflashing 05 M/T ECU to evo rom
  114. 03 oz turbo ignition map
  115. 2003 Lancer OZ Rally Upgrade Suggestions
  116. FI Tech Topic: Injector Scaling and Latency
  117. Request for a non-turbo, "stock-ish" lancer 02-06
  118. Evsocan reading TP -5% WOT
  119. Idle Air Control issues
  120. Lancer oz 06 m/t big map
  121. Need help! Injen Clean Air Intake (CAI)
  122. Ecu flash 1.41?!
  123. Moding advice
  124. openport and evoscan will NOT connect
  125. Weird Stall issue after flashing ROM - Help please!
  126. OBD II Software for Tactrix Cable
  127. 03 Lancer OZ questions.
  128. 03 lancer es- gonna be doing sum upgrades
  129. 2004 Lancer ES PERFORMANCE MODS?
  130. Oz rally question
  131. Fuel delivery issues + other questions - Help Needed
  132. Tuning Help: Lancer OZ - Stock NA w/ Bolt Ons
  133. Lancer fuel tuning
  134. Catalytic Converters, catco, bosal, or eastern catalytic?
  135. V-afc
  136. 2006 Lancer Ralliart XML?
  137. 03 Lancer ES Upgrades
  138. 2003 Lancer OZ front catalytic converter
  139. Turbo lancer es 04 tuning
  140. Anyone have experience with acetone as a gasoline additive?
  141. Tuning the turbo lancer
  142. OZ Help!
  143. Ecuflash 05-07 big map rev limiter
  144. read rom problem
  145. ecuflash problem
  146. Wtb 4g94 valve cover
  147. Lancer Es AT 2004 Definition file needed
  148. Triying to flash a manual ROM to an auto ECU
  149. 03 Lancer Definition File & Flash Help
  150. Evo Vs. Lancer ALT
  151. Looking for an 86640015 rom
  152. Tactrix Evoscan Cable
  153. dtc after swap auto to manual trany
  154. 5th injector to 440 wrx injectors
  155. Tuning 02' OZ
  156. 2005 Lancer Definition file needed
  157. I've tried everything! I need help with ECUFlash please guys
  158. 2005 AT ECU pinouts is the same with 2003?
  159. Radiator replacement
  160. Raising the bar (the red one)
  161. ecuflash reading rom problem
  162. 4G94 N/A Build Vendor's & Part #'s (STICKY)
  163. 02' OZ Rally Upgrades?
  164. ecu layout
  165. bov shutter
  166. Periphery bits not working
  167. How to Tune to bypass EGR
  168. How I solved my P0300 code...
  169. e85 question
  170. Mitsulogger dead??
  171. my oz keeps stalling!! help me please!!!
  172. Ecuflash help please
  173. do our cars have an idle relearn procedure?
  174. P0505 throttle hang issue
  175. Looking for a 04-06 MT rom
  176. Tuning timing maps.
  177. what rom to use
  178. Mitsubishi lancer gforce chip???
  179. Ipad vs Galaxy Tablet
  180. 03 OZ Rally Upgrades
  181. need 55780001.xml
  182. New Boost map Idea need thoughts!!!
  183. Tuning 399 maf turbo lancer
  184. Help on Volume Efficiency map
  185. Seeking Advice from my fellow Lancer Community!
  186. Can I flash other Roms into My ECU
  187. Need some help
  188. Definition file for ROM# 94950001?
  189. cel p0171 system lean
  190. Oh geez...Another how to get ECU flash to work
  191. Roadspikes Huge Map Roms
  192. ECU flash definition
  193. Tuning NA
  194. Tuning 06 Lancer ES
  195. Lean on cold accel from a stop
  196. better mpgs on the cheap!
  197. Got some question
  198. OBD-II iPhone connectivity
  199. Old Cables and Ecuflash
  200. K&n sri
  201. BFM tactrix?
  202. Cant read/ write to ECU..
  203. Weird fuel problem with forced open loop?!
  204. Ecu flash help!!!
  205. Flashing Lancer Ecu
  206. Virtual Dyno, Auto Trans pulls?
  207. Stock lancer ROM
  208. 2 byte load, rpm, and airflow?
  209. Community Tephra Tweaking
  210. Issues with fuel!!
  211. Problem with my tephra rom
  212. Important Front 02 sensor question!
  213. Rear 02 sensor periphery bits
  214. ECUFlash help
  215. ltft help
  216. oz rally exhaust help
  217. Need help with installing 1.29 :-(
  218. my knock issue
  219. Stock lancer ROM?
  220. ECU boost control for us?
  221. Motor Mount
  222. Still Need Help
  223. Curious about Load-Maf-ROM-boost correlation
  224. Is this Tephra safe for my base Lancer?
  225. lo octane map question
  226. ECUflash/ Tactrix cable newb thread
  227. Easier way to tune turbo 4G94
  228. DSG tune, or tactrix cable and self tune?
  229. 2nd and 3rd igniton coils not spraking
  230. I installed new Headers
  231. Intake questions
  232. Spark Plug Gap On A N\A
  233. Can u Frankenstein a TB?
  234. 02' Lancer oz ECU?
  235. OZ build, tuning questions
  236. RRM Underdrive Pulley
  237. Omg...WTF dude :(
  238. Tune-up
  239. help rescale injectors and latency 02 lancer
  240. Ecu Flash help
  241. Dfw street tuning club
  242. ECU FLASH cable and questions?
  243. Texas!
  244. Upgrading stock injectors on N/A
  245. I am looking to flash my 2003 Lancer ES A/T ECU, Need Some Help!
  246. Tie Rod Ends- 03 Lancer ES
  247. Turbo Kit
  248. how to log your AEM EUGO with evoscan
  249. Evo ecu swapped successfully
  250. converting to speed density using tephramod ?
