View Full Version : Lancer Troubleshooting
Pages :
3]
11
12
- Hard Wiring L.E.D driving lights...
- dash light is not working ('07 lancer)
- Do not get exedy oem replacement clutch for 06 oz rally
- 2003 Rear window defogger not working
- 2006 lancer oz rally clutch install issues need help asap!!
- 2002 OZ Fuel Shut off valve
- 02 Lancer es heater hose leak
- Need Help Diagnosing Overheating Problem on 2003 Lancer OZ
- Lancer ES/ EVO Exterior Compatibility?
- Blinker wont flash with old or new bullb, all other lights work properly.....
- Tempuature control knob.. Stuck on hot, wont turn
- 2003 LANCER OZ help!!
- P0304 Miss fire
- need help
- Fuel bulb problem??!!
- mitsubishi lancer spark olug issue read please
- '03 & '04 Parts interchangeable?
- Please help
- 03 lancer OZ!! Evo parts??
- 2002 Mitsubishi Lancer OZ Rally ( Idle Problem)
- Evo 7 fq300
- Evo 7 fq300
- How to replace radiator?
- Squeaking noise from passenger side
- p0421 Replaced front Cat SES Light Came Back On Next Day
- Starting Trouble...power but no click or turnover
- 02 lancer oz trans problem
- Huming noise when driving 60+mph
- No spark?
- 2006 lancer seats
- Need help removing some interior parts..
- Disconnecting Ac Compresor?
- 04 Lancer - AC Intermittent / No AC
- Need Help Identifying This Part
- several "minor" problems. Are they all electrical?
- SRS light
- Help! Reduced power, unusual intake sounds...
- Broken knob shaft HVAC
- Sunroof Problems
- P0421....again
- brake light switch problems
- headlights
- How to remove center pillar from oz spoiler?
- Can anybody help me? I need some questions answered in regards to my 04 OZ Rally
- AC isnt blowing cold air.
- crazy misfire issue plz read!!!!
- Lancer Horn
- Assistance please. AC/PS tension pulley bolt
- Need help Identifying a part
- Lancer starting problem
- Headlights
- Looking For Rear Lip Kit 4 OZ Rally 2006
- Temp. Guage
- Engine miss fire ?
- Rear lower control arm bushing VIDEO
- Timing the head
- Car randomly cuts out and bucks
- Rear control arm advice
- Ac not blowing cold?
- A/C not blowing and cannot figure out the issue
- Evolution front on Lancer es 2003
- vibration during accel/turn
- lazy lancer?!?!
- aftermarket radio issue
- Werid Issue
- Look at my plugs plz!! (pic)
- Very weird power loss problem!!!
- 2002 oz rally rough start
- timing belt change. off teeth?
- 03 to 06 lip kit
- 2002 Lancer ES: MY MISTAKE!
- 02 lancer oz rally troubleshooting
- Damn radiator...!!!
- Help with just bought Lancer 2003 Oz Rally
- Fading Lights ?
- Evap Code
- What is this piece?
- Clutch problem maybe?
- 2002 ES tps sensor Question
- 2002 Lancer ES Throttle Position Sensor
- Random power losses; my Lancer is trying to kill me!
- HELP serious electrical problem aka money pit -_-
- Pioneer Head Unit Not Fitting In My 03 Lancer ES
- 03 OZ HID kit
- Bad catalytic converter, P0421 - HELP!
- Lancer A/C Control Unit
- 03 OZ slowly burning oil, what to do?
- Fuel pump going bad?
- where to buy OZ rally badge/emblem ?
- difference between OZ rally and Rally Art 2007
- Install Regarding Fuse Box
- ECU got reflashed today
- cruise control not working
- Temp Dial broke.....
- No power to fuel pump
- Stock bulbs
- Low idle and stalling
- Oil light Turns On at Low RPM
- 2003 Lancer LED Question..
- clarkk18
- Rattling From Front Right of Car
- 04 Lancer ES IAC
- Overheated, lots of issues, now exhaust problems?
- Faulty Fuel Gauge? or Faulty Fuel Sensor?
- Cannot read codes
- P0340 pd code...help :(
- weird idle, please help
- Handbrake
- Whistling sard fuel pressure reg help please
- Coolant Temperature Sensor gone bad?
- Code P0300-Any idea on what could be the cause?
- Oil Pressure light
- revving problem
- Lose of power and car wont rev past 3k
- Exhaust Question! Please help quick!
- Steering Play
- Emissions leak
- Emissions leak
- Two issues, one with audio one with steering column
- Windshield sprayer help!
- Engine turns but car won't start :[
- keyless entry
- O2 sensor
- 03 Lancer OZ Multiple Electrical Issues
- Strange pod filter noise
- Bad alternator symptoms...
- citylights went off with fog
- OZ Rally work.... need advice
- Rear view mirror
- A/C always on
- Cd disc changing clicking sound coming from dash/glovebox area?
- Dent in my 03 OZ Rally cant be fixed?
- can't figure out "the shakes" when braking
- CEL 421 code - tried new O2 - no luck
- loud popping/hesitation throughout the powerband
- Car dies after battery disconnect
- Need Help!! 02 Oz rally po441 , po300 system too lean
- wiring help
- Humming Fuel Pump?
- Lancer wont Start
- Lancer wotnt Star
- Center console year compatibility
- Girlfriend's 05 ES quit coming home last night...
- 02 Lancer ES issue.. cold start with the idol way too high
- Lights Out
- Remote start and cruise control stopped working
- My check lights (on my gauges) are spazzing!
- Rear speakers not working
- AC LEAK under the dash .. 02 lancer OZ
- oil pressure light comes on
- Lancer es 02 P0421 service engine soon.
- Lancer backfiring
- instrument cluster died on me
- Need some help
- Clutch give out?!
- Leak from hose/Need quick help!
- HELP! stuck at work, car keeps dying...
- Hub
- wet carpet
- Funny Water Temp. Gauge
- ECU PINOUT for 03 Lancer, Non evo.
- Tire rub
- Fluttering Noise
- Glowing exhaust manifold, engine died and now won't start.
- Electrical problems for my RalliArt
- 2003 lancer ES door unlock problem
- Water leak after using AC - 2k3 Lancer
- Steering making a hissing sound!
- a/c problems and insane heat. HELP!
- Any Help with Motor Mounts???
- Accessory belt tensioner hardware
- 2002 ES Strange grinding noise from tranny.
- issues whit carbon trunk
- Issues With Aftermarket Alternators?
- 2002 lancer 4cyl. timing
- 04 Lancer OZ Rally idle issues
- Charged my A/C and engine is being choked??
- Blown Tranny maybe??? :( :( :(
- This is a weird steering issue
- 2002 Lancer heat control unit bad?
- Accessory fuse replaced, parking lights stay on
- Where to buy "junk" cars?
- WTB 2002 lancer es coolant module
- Coolant Fan problem.
- Two seperate problems! Moving steering column?
- Engine problem?
- Engine "Bucking" Intermittent Drag Issue
- Help with an oil leak from the lower crank pulley area
- Split Exhaust Pipe question
- How to get the fuses out of the yellow case next to the ecu?
- How to remove the Climate control unit?
- squeaky clutch pedal....?
- Will an Evo 9 HVAC fit?
- (Australian) Experiences With Accolade Body Kits
- turn signal problem
- ECU question.
- TB, MAF and IAC clean
- Front passenger window help
- Factory Alarm immobilizers
- lancer 02 cardoor locking problems
- Thermostat temp sensor
- Need your help with a drivetrain noise.
- P0421 Need Help ASAP
- Gauge Cluster not working
- Front solid motor mount / Noise problems.
- Where is the ac fan relay and fan controller
- 2002 Lancer w/ Engine Swap Overheating...
- Evo 9 Body Conversion For 2005 Lancer ES
- 03 oz rally idle/rev problems
- 03 oz rally A/T tranny stuck in neutral?
- sun roof acting up
- Weird acceleration noise
- battery issues
- What is this part?? Help identify from photos! Need to know to finish engine swap!
- Bulky Metal Bar (Front End Underneath Bumper) Question
- metal noise?
- Hellppp!! Rusted and stripped bolts
- Headlight Problem
- AC is stuck on!!!!!
- Exhaust flange bolts
- Alternator Belt
- Fuel pressure
- New timing belt noises
- Tail lights/Brake lights
- Pressing brake makes right blinker turn on?
- 03 lancer OZ Dome light
- Wierd grinding or growling noise!
- serious light help needed!
- switching from km/h to mi/h
- Po421 code!!! =[
- Weird Noise Upon Trying to Change Rotors
- Manual transmission "sticky" shifter
- Heater problems. Help!!
- CEL with OBDII code P0420 or P0421
- Battery not wanting to hold a charge???
- Buzzing sound when shifting on automatic.Bad Sensor?
- How to use Seafoam in the 02 A/T Lancer
- oil light
- crank and cam sensors
- Leaking water
- Car shaking when driving?
- spark plugs, intake - questions
- Depo Projector Wiring Harness?
- Questions
- the wonderful world of O2 sensor failure, any help with this code?
- Evo 8/9 Parts on Lancer 02-03 OZ,ES,LS
- Lancer 2004 Tranny
- Sparco Steering Wheel Hub for Evo
- Fuse location help
- Lancer 03 nightmare =(
