PDA
View Full Version : Lancer Troubleshooting
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. Check Engine Light and Water
  2. Problem with cruise control, piggyback
  3. P0421
  4. HID kit with relay harness, weird problems
  5. Lancer doesn't start sometimes
  6. Lancer sportback stalling problem
  7. lancer is overheating
  8. Why? Does it Matter?
  9. Mitsubishis from Costa Rica!
  10. Ohm Fuel Level sender???
  11. A couple of OZ questions
  12. OZ Rally Owners!!!
  13. Please help!!!
  14. header noises
  15. High idle of between 1300 - 2500 RPM
  16. A/C Issues - Clogged?
  17. OZ Rally Lip Kit
  18. A/C knob broken
  19. Mirage head probs I think. Senate help!!!
  20. Where I can get a 2003 lancer fuel-tank cap spring
  21. P0135 CEL 2002 Mitsubishi Lancer ES
  22. Gas Milage for 03 OZ
  23. daytime running lights (front) won't turn on
  24. Downpipe cover?
  25. Xenon bulb help
  26. Help Needed Now! Key position locked
  27. Lancer not starting after sitting a couple hours
  28. 2003 lancer air conditioning problem
  29. tail lights fitments?
  30. Battery light on dash
  31. A/C Problem
  32. volt meter drop
  33. is it a motor mount??
  34. 2003 OZ O2 Sensor
  35. Strange Grinding
  36. Reset Engine service light
  37. My Stick Melted!!!!
  38. rmr seat bracket issues...
  39. 2003 oz problem
  40. srs and seat sensor problem
  41. p0171 engine code
  42. Alternator problem?
  43. engine squeeling
  44. Need Help: 2003 Lancer camshaft position sensor
  45. Spark Plug Wires.
  46. wheel bearing prices
  47. Bolt in starter cross threaded
  48. RRM Throttle Body installed
  49. HID question plz help.
  50. help me and i'll give you penny =)
  51. wierd noises?
  52. Lost Power-Steering
  53. Short Ram Intake, idle problem
  54. the lighter sensor burned out
  55. New Projector Headlights... Dead Battery! Help!
  56. Please Help with Throttle Bucking Issue
  57. Looking to buy a lancer
  58. Radio and power locks not working!
  59. ok i will seem very retarded im an aspiring car guy question about carbonfiber hoods
  60. alternator/electrical mystery...
  61. will and OZ exhaust fit ES
  62. check engine light keeps coming on
  63. water leak under glovebox
  64. Misfire between 0 and 5% throttle? HELP!
  65. Splash guards?
  66. Squeaking from rear end
  67. SRS light on?
  68. odd eletrical problem
  69. EVOVII cf hood on oz
  70. help lumpy bumpy rough idle!!!!!
  71. I need help please
  72. Wheel bearing?
  73. Fan Running Continously
  74. Cruise control and RPM needle issues.
  75. back light not working no matter what
  76. Electrical Problem... Please help!
  77. 2002 Lancer not starting/fuel injectors not recieving signal
  78. gas pedal sticking
  79. Is this SeriouS ???!!! Rust!!
  80. Bad/Rough Idle Thread
  81. Rattle Noise, problem?
  82. Help! Lumpy idle & misfires under high load
  83. Nooooo i need help!!!
  84. exhaust manifold gasket?
  85. How to change coil pack boot?
  86. Big Clunking prob after drop
  87. Aftermarket HID stuck on high beam
  88. PLZ HELP: P0300 , but only at high speeds. . .
  89. I'm a search-tard today, CEL list?
  90. Problem with 2003 Lancer ES
  91. P0181 & P0421 & Dim Dash Lights!
  92. Help! Broken bolt on alternator
  93. new pcv = low idle?
  94. Sun Damage Carbon Fiber
  95. P0171 - System To Lean
  96. Windows Getting Stuck
  97. need seats
  98. Idle Issues
  99. Hesitation under WOT (cold) = bad O2 sensor?
  100. oil leaks and SES lights
  101. overheating after headers installed
  102. Brake problem? What needs to be done?
  103. Cruise control problem
  104. wierd issue, new to me helpme:
  105. Tach problem
  106. light came on after changing my belts
  107. Leaking Tranny Fluid!!!
  108. No go from brembos
  109. almost like a miss when idle???
  110. Weird sucking noise in 2002 Lancer
  111. Timing Belt Repleced
  112. 2009 Lancer GTS Subwoofer Help PLEASE!!!!
  113. Warrenty/trans issue
  114. Sound in the steering column - need help
  115. SRS light goes on and off randomly
  116. 2002-2003 Lancer Projector Headlights
  117. Help With Start-up
  118. P0763 Shift Solenoid C Electrical
  119. 2006 lancer es problem
  120. Exhaust too loud! Oh No! HELP
  121. Heat wont turn on in 2003 Lancer Es
  122. SES - Cylinder 4 misfire
  123. Man that noise keeps bugging me!!
  124. Cigarate lighter not working....
  125. AC light comes on when heat is on...?
  126. Kind of weird, and I could be wrong.
  127. OZ shuts down in 2 sec.
  128. Hmm, thought the battery was the problem.
  129. Help with interior lights
  130. Loose Shifter
  131. OZ gauge needles off
  132. 03 lancer has noise and vibration
  133. Jacking my car to find noise cause damage?
  134. does this look like an exhaust leak to you
  135. 04 exhuast issue
  136. lights gone out
  137. No Heat!
  138. are lifters adjustable on 03 lancer oz
  139. Intake bolt broke.
  140. Engine running super lean at idle
  141. EGR Valve issues
  142. Problem with SS clutch line
  143. Help Seatbelts Dont Work!
  144. Intermittent starting issue
  145. no sound out of my stereo???
  146. knock sensor problems...
  147. RMR Type 1 Lip Help
  148. Start up belt squeal noise FIX
  149. Tunning Piggyback?
  150. Sputter. HELP
  151. oil leak on a 2002...
  152. lancer problem
  153. has anyone had their lifters replaced?
  154. o2 sensor problems!!!
  155. do i need to modify my exhaust
  156. Noise from engine
  157. emissions
  158. Headlights turning on by themselves
  159. What are the 3 wires going to the positive battery terminal
  160. new/used Exhaust smoking
  161. New Intake issues. HELP!!!
  162. Idle issues... Occurs about 4 days out of the week.
  163. emergency Please help
  164. Signals/Hazard don't work, relay?
  165. Car running a little rich (I think)
  166. tranny trouble
  167. 2 vibrations in 1?
  168. guage cluster help
  169. Sun Roof Gave out..
  170. Reverse Light and start up squeal
  171. Vacuum diagram?
  172. Huge sound when reversing,then something stuck
  173. steering wheel help?
  174. Belt Squeal ?
  175. Slight Squeak!
  176. Power go's Down?
  177. Painting 2003 Lancer ES
  178. 03 ES Engine Light on and off
  179. Clogged Catalytic Converter?
  180. Removing aftermarket EVO spoiler from 2003 lancer.
  181. Warm ac
  182. No spark/no fuel to engine?
  183. egr problem and running rough
  184. Squeaking exhaust
  185. 02 OZ cuts out under 3000RPM
  186. Tach in new dash doe not work. Help.
  187. Code P0421- Call Mitsu before you do anything!
  188. Issues after CAI install
  189. A/C problems and vibrations
  190. 2003 OZ Rally tinging?????????????
  191. Need Help!! (^_^)v Please!
  192. Is this an exhuats leak??
  193. Lancer... Problems with part durability/car reliability...
  194. weird noise coming from engine
  195. 02 Lancer OZ overheating and other problems
  196. steering wheel problems
  197. Factory alarm not working
  198. Help! AC turns on and off by itself
  199. Oh Noes! My Cruze Controlz!!
  200. help needed radio, clock, key fob not working
  201. O2 sensor question
  202. my car died on the freeway
  203. Brake Pedal Vibrating
  204. car shivers
  205. Help!!!
  206. Odd squeal when wheel isn't turned
  207. turn signals not working
  208. What is the Difference between ES and SE?
  209. Help! Nasty Sound when trying to Reverse
  210. Strange Idle after 4g93 manifold
  211. throttle cable siezing
  212. A/C problems.... and few others....
  213. What Engine do I have?
  214. fuse's
  215. Help!!Clock Spring
  216. Need help haveing wierd noise from engine
  217. check engine light... code PO135
  218. Bogging and cylinder misfires in 2002 ES
  219. Car will not start
  220. Wireing / Fuse HELPPP!!!
  221. Grinding noise from left front wheel area
  222. Sunroof Fuse??
  223. Help!!! Bad Rumbling
  224. Evo WING For OZ Lancer
  225. Car won't start, please help
  226. Sunroof
  227. Depo Headlight alignment
  228. rough idle? whats causing it?
  229. Bumpy road steering issues
  230. Help - Engine Fan stays on
  231. some issues, need help
  232. Auto-cruise-control-ecu pin out
  233. How much $$Labor is it to check wear on timing belt?
  234. fuel pump
  235. Before I buy this Lancer...
  236. timing with stage 2 cam
  237. need help asap
  238. Right hand tail light and marker light + no gauge dimmer
  239. Sputter ??
  240. power windows not worcking
  241. walboro fuel pump not pumping
  242. problem with my heater unit?
  243. Car not starting, possibly no fuel pressure
  244. Eliminating Secondary O2 sensor?!?!?!
  245. Unstable voltage!!!! help
  246. High Idle when car is hot.
  247. radio fuse???
  248. 03 Lancer A/C problems
  249. Reconnecting the o2 Sensor
  250. radio reception cut-out when HIDs turn on
