View Full Version : Lancer Troubleshooting
Pages :
8]
11
12
- Driver side window problem
- slow driving shudders?
- I can't find the cause to my misfire: please help
- OZ mirrors vs 'standard lancer' mirrors?
- HELP!! YOUR opinion PLEASE!!
- stalling problem!!!
- Cigarette lighter stopped working!
- A/C Is knocking!!
- My service engine light is on
- IM install gone really really wrong
- My car won't stay running
- Kamikaze DP and RRM CAT Help
- Gauge
- cutting auto gear shifter
- CF tips to make a good fit???
- anyone have a headlight wireing diagram??
- My lancer is making me wish I purchased something else
- 2nd Gear Lag
- i searched but couldnt find
- Need input: Weird engine sound
- Oil light comes on
- header
- why does it feel slower after i installed a down pipe and a cold air intake?
- Front rattles like crazy
- Purge Valve in Gas Tank??
- what fuse is for windows/int light/mirrors
- MPG troubles
- GURUS HELP! Run withouit second o2 sensor????
- Kaminari FB doesnt fit w/intercooler pipes
- What do you guys think-Please read
- Need more help-ASAP
- Help ASAP-Very low idle
- Front License Plate removal
- Is it a TRACTOR or an OZ?
- Need to find Light ECU
- Service Engine Light
- Need Help Please!!
- Kick Pedal Removal
- Cel
- engine overheating after repairs
- AC knob backlight problem
- Somone has to know
- My exhaust giggles
- RRM piggyback problem, gas gauge not accurate
- Trouble code P1400 on 2003 Lancer
- Opened fuel pump to check install then reinstall now wont start!!!!
- Vacuum question
- Throttle issue
- Rpm spike to 2000-2500
- Troubleshoot my sparkplugs
- HELP (weird idle and SES light)
- Broke Dip Stick - Help
- Aem Ram Air
- Brake question
- Cat Bolts
- Exhaust question again
- Rubbing noise from the back wheels
- need help figuring this out
- problem wiht coilovers
- Problem while debadging...
- How often to change air filter
- How hard to change 02 sensors and where are they
- have power, no start? (need all the help i can get)
- Injen SRI hitting battery
- Exhaust question
- Mass Air Flow Sensor Problem
- need help w/ gauge cluster lights
- Programming keyless entry
- Help PLease, fuel pump!!!
- Wheel stud problem
- SRI blew off the intake manifold??
- ssshhhaaakkkyyy
- electrocuted
- CEL after cold air installation
- Aem Intake Problems
- Bit of troubleshooting help
- What Are The Odds Of Fixing This? *pics*
- wheel alignment price?
- Tachometer wont work "Help"
- Check engine light came on tonight. Ideas?
- 4G93 and P0401?
- Ticking, Popping sound I have no Idea
- Fuel Gauge
- Pcv
- Need Help Passing Emissions
- Do I need to replace my air filter or just get a recharger?
- Lancer's running PIG RICH....
- terrible clicking noise
- Please help me with a fitting question
- Keyless entry, clock, and dome not working!
- Misfiring, Spark Plugs, wtf?!
- stuck in the rain
- water leak
- windshield cracked....
- foggy tailight. how to get rid of?
- Interior question
- High Rev in the morning
- code 0421 cat efficiency low
- Fuel Pump relay installation direction
- Spark Plugs Do NOT Want to Come Out!
- Fuel Pump not pumping
- Help ESL On
- From oz rally bumper to evo bumper
- gauge cluster needles
- fuse panel
- Help! B&M adjustable short shifter install problem
- 4G93 IM, idle problems?
- engine idle problem???
- Swapped Evo 7 Wheel, now the turn signals dont turn off...
- Help with Buschur exhaust
- Weird Slipping?
- Engine revving itself in traffic
- Help me.
- volt gauge how-to
- I have coolant in my intake??
- ES->OZ gauge swap
- Loss of power :(
- camber problem
- Idle issue
- fuel
- Need help: Car is not starting
- Factory Service Manual (FSM)
- Leaning Lancer
- what color wires.. guage harness 02lancer
- Grounding Problems - please help!
- WTF, now I hear a whirling noise, what could it be?
- Help Please!!!!
- i dont have constant power...but accesory works?
- No power when my keys are out...
- New 05 Lancer, and it smells like oil burning!
- Anyone with a sunroof??
- do the OZ come with antilock brakes?
- Need HELP
- Engine Code with RRM Stage 1
- 2000 RPM rattle
- Weird problem no body has! (electrical)
- Help A/F install!!!
- HELP, Oil light????
- Figuring out rattling sound...
- Fadding Paint
- Air
- hand brake removing?
- cold weather = worse engine sound?
- Engine Shut Off.. Why?
- header removal
- Gas Mileage
- Exhaust leak and leak and leak
- Led burned out..why?
- RRM hose kit
- Fuse Diagram?
- Dim Cluster
- Dim lights
- Cigarette Lighter doesn't work. WTF!?
- factory pant problems
- chirping sound when I'm at idle
- Strange winding-up noise
- No More 2nd Gear
- possible transmission problem??
- Help Plz... Head Unit Probs
- A major hole in a metal pipe under my car...problem?
- skipping
- OZ Rally front suspension questions...
- US Lancer Wiring Diagram - PDF
- headlight wiring
- I crashed my lancer
- Any way to check MAS and o2 sensor?
- stock header removal questions
- 02 sensor
- ECU wiring diagram
- loud click
- Has anyone have any problems whit the parking lights in their car
- help is it safe??
- Karr Alarm
- buschur downpipe leaks (flex pipe part)
- keyless signals
- Piggy back and then CEL?
- obd code please help what does this mean?
- I now have a low IDLE
- Grinding in 1st and 2nd
- Where the F is my washer fluid going?
- alternator belt please help
- Timing Belt. Plz help
- concerns of hydrolock
- HELP!!! DEPO tail light wiring problem!!!
- A problem
- gauge cluster light not working
- vibrations in steering wheel
- Gauge cluster km/miles
- Help with Tranny
- GUYS i NEED HELP FAST!!!!
- Just installed cat pipe, muffler rattle?
- Fuel Filter Location
- fuel gauge wrong! help!
- Quick Blinking
- HELP: Fuel Pump Install
- Question Concerning Lancer ES Washer Fluid Reservoir.
- brake pedal...
- rattling noise in neutral?
- anyone install an air/fuel gauge on their lancer?
- grill rattle
- Knocking/clicking feeling 4th gear only, any RPM
- A/C Compressor/Electrical Issue
- Peculiar electrical problem [Please help]
- HELP... Error Code P0421, "Warm Up Catalyst Below Threshhold"
- Wheel hop/tranny slip?
- help with door
- A/C Problem Need Help.
- I keep blowing fuses
- rrm header tingling/rattling noise.
- anyone know how to flush steering fluid
- Weird noise when turning
- Whats wrong. HELP
- Climate Control Problems
- Sealing exhaust gaskets.
- lil vibratn in brake from wipers?
- My car is shaking, please help.
- AEM CAI Mounting bracket broken. With Pics. What do I do?
- Smoked Engine
- Blown engine?
- Piston rings?
- SES light/intake
- Rather odd cooling system question
- is it possible to program a Lancer's remote control?
- the tach needle bounces back and fourth at idle.
- Nothing electrical works…
- Painting the grille.
- How do you clean melted bumper off of muffler?
- steering problem again HELP ME
- anyone else getting code p0300?
- Peeps with RRM header
- driver seat squeaking
- headlight aiming problem
- Bulb size for ES gauges!!
- Emanage schematic
- Felt like tranny was stuck in gear today...
- Radiator Fluid Type
- Springs question
- Speedo gauge is off...
- RRM Throttle Body/Gas Mileage?
- Help!!! Quick
- Flip-Flop trunk help.
- RRM Throttle Body Noise
- Help! Header Install - How to get to the lower left nut?!
- problems with stock battery?
- Smoky the Bandit
- noisey a/c
- Question to everyone
- Knocking Trans
- Knocking when foot is off clutch
- Loosening the top nut during spring installation
