View Full Version : Lancer Troubleshooting
Pages :
6]
11
12
- Trouble from K&N Intake
- idle trouble
- egg smell?
- Front suspension problem?
- Light on the Trip Odometer
- Need Help!!!! Tail light problem
- Engine Problem..Need help!!!
- Help Please, I Need Help :-(
- evo steering wheel
- bad relay/flasher...
- everytime i put a new fuse in it blows.
- No Spark, Car Won't Start
- Backlight out on stereo
- Possible Electrical Problem
- Cant remove steering wheel
- help..melted ecu connector..now what
- Looking for a part, turning light holder, 02 lancer es
- Swappable Gauge Clusters?
- I'm screwed!
- Tight Gears!?
- Dash Lights don't work
- clutch goes straight to floor with no pressure
- Heard a "pop" and then it died
- Another water leak!!!
- Spark plugs causing bad MPG?
- Shaking on takeoff in 1st...
- Problem with steering wheel vibration!!
- Dome light comes on at random (power off)
- '02 starting problems
- Eclipse HU and Ipod adaptor help...
- Windshield Washer Spray Nozzles
- Fog Lights
- keyless entry...
- New bored throttle horrible shifts
- Curbs SUCK!
- vibrating/out of round issue
- Wierd "ticking" noise
- Big Problems
- noise after accelerating
- maintaining CAI in wisconsin winter
- Hit a Crub, fixed (some of it) and aligned. Still need help...
- serpentine belt pulley noise
- Small or Big problem??
- PO421:Warm Up Catalyst-below threshold (bank #1) CEL
- Convert to LEDs
- Electrical Problem
- Cigarette Lighter
- this can be a problem
- Must fix annoying rattle!!!!
- car bogs
- trying to find transmission filter in 03 lancer ES
- HELP QUICK!!! Starter wont engage!
- 02 Alarm system
- Help Sunroof
- Squeak Problem Fixed!
- Horrible Problem
- egr help:helpme:
- weird idle after transmission replacement
- EGR Problem...
- Help!!
- Weird Engine Noise HELP!!!
- Problem Accelerating - RPM's Race Up but no power change
- aftermarket tailight problem.
- Battery problem
- weird lights
- Radio and clock just went out
- Problems RPM Stayin Up
- lug nut studs
- loud snap sound after car is warmed up/idle
- Breaks squeaking
- P0421 and P0301 codes after 100 miles...
- My HVAC Dials refuse to move...
- radio and dash
- Intake squeek, belt noises, etc.
- I think this is bad...
- 2 Minor Issues I have questions on...
- How to do a headlight conversion
- Greddy Counterweight shift knob not installing
- 03 lancer ES hvac...
- my lancer is HOT and i mean over heating
- Parts from evo on an ES
- tranny swap?
- compatability between lancers?
- hard gas pedal
- I believe it is but I have to double check...
- Cruise Control
- 03 Lancer ES: Just Quit.
- Exhaust and Intake Question...
- cylinder 4 misfire issues (P0304 and others!)
- ATTN: Those with rough idle....
- ways to prevent/cover up rust?
- Downpipe problem
- Gauge cluster help
- Right Tail Light?
- Coolant temp. gauge acting weird, any suggestions?
- Debadging gone wrong
- Light Bulb Types For Depo EvoVII Tails
- Electrical Wiring - Max Voltage/Watt threshold for 03 Lancer
- Battery dying.
- Daytime running lights
- 03 lancer OZ multiple engine problems
- my keys wont come out?
- Car rocks back and forth when starting
- Fuse Box Diagram
- Car still not runnin(HELP)
- CAI Problems
- brake lights problem, fuse or bulb?
- bulbs?
- timing belt
- rrm pulley
- OEM style foglights of Ebay
- Car wont start
- my a/c exploded
- Having problems with my car starting...
- Remove Stock Side Skirts
- Weird smell.
- Car won't start-not getting fuel?
- Inner Tie Rod End
- Help with gauge install
- got an issue? here's a tissue!
- Won't start
- Need help removing strut top nut!!
- Jerkiness when slowing down
- a/c help
- A/C not working
- Gas Sensor/Guage
- gaz tank
- GAP btwn Bumper&Headlight
- Front Radiator Support.
- Gauge Cluster needles sticking
- Greddy EVO2 exhust Mid-Pipe Question
- ac problems (im runnin out of ideas)
- Gas mileage problems
- Engine Fans
- air intake problems
- Weird Noise
- Tie rod end issues...
- Low IDle...
- RRM Piggyback with worse MPG
- Evo cluster Anti Lock
- Help!
- damn damn damn
- p0107
- Oil Disapearing
- blackout tail lights
- PO401 Insufficent Exhaust Gas Flow
- A/C not working
- service engine light
- A/C Controlls..
- 60000 Mile Service
- 2003 es hvac the same as the 2005?
- having a hard time shifting into 2nd gear
- instrument panel
- P0715
- p0421
- clutch bleeding problem
- Brand New Optima Red-Top and now Car wont start..???
- Idle Problem
- A/C Issue
- Problem with engine possibly? Over rev's
- Lancer doesnt run properly please help..
- stupid brakes
- HID install
- Front end clanking sound
- Good news about ses light
- OBX Header/ O2 problem
- HELP plz bad
- Headlight going out... often...
- Lancer Es Gear Knob
- Really strange and annoying under-hood noise
- Oxygen sensors?
- Help Help Lancer Wont Start
- Car Stutters during take off, almost no power... picks up when u floor it.
- Glove Box Won't Close
- car wont run right in park
- a/c off car stalls
- Low Idle
- Also an electrical problem
- Depo Evo VII Clear Taillights Wiring Problem
- 2 Questions
- electrical problems
- Bulb frying my harness?
- Vibration In Cabin and Pedals
- Exhaust Prob...
- Crankshaft Position Sensor Malfunction...
- Truck won't open!
- Something wrong with brakes?
- Knocking at right front wheel
- MAF Sensor Problem, unplug ECU and it is fine...
- Car Horn Steeling Wheel
- 2003 Lancer...won't start.
- bad fuel injector???
- Unstable Steering wheel?!
- Quick questions...
- headlight flickers when driving...
- Dash Backlights are dead?
- power steering pump
- A/C led??
- rear seat belt
- boost leak?
- revving during idle...?
- Wont Idle
- wrong air intake??
- Help with code and starter !!
- Lancer Recalls!!!
- thumping sound?
- RRM Header Problem
- Tsb: Dtc-p0335
- ahhh clutch!!!
- HELP!!! Weird knocking when at a stop...
- Warranty question
- car is stuttering big time
- Lower Arm Under-Brace
- K&N Air Filter
- Which Battery
- Latin Lancer: OZ or Ralliart?
- burning smell after CAI install
- Too much power steer fluid
- Cruise Control
- Exhaust Not Fitting
- Speaker problem
- O2 Sensor and Cat Converter
- Very Odd Sound
- intermiitten and slow starting HELP!!!
- Tach redlines at 4000?
- way to brighten stock lights w/o getting cheapo hid's
- Is my car safe?
- Bad tires causing vibrations?
- do i need a new clutch?
- Door Trouble!!!!!
- spark plug tube removal
- My wing broke!!
- alarm
- Nozzle sprayer issues!!!!!!!!!!!
- CD Player E 01?!!
- car died while driving and wont start again
- Exhaust leak causing car to die?
- Creaking noise from steering
- New timing belt, car now makes nosies
- Oil pressure gauge?
- Once again, Lancer + Stupid extreme cold = no fun
- curb problems
- Lifter knocking
- Not Starting after rebuild
- replaced 02 sensor and still a code?????
- Electrical Short
- Car dying on me...wtf?
- Car pulls to the right.
- need help installing tach!!
